Stephane G.
Incroyable !!
Je possède depuis une vingtaine d’années du Naim Audio (NAC 282 / HICAP / NAP 250.2) couplé à des ATC SCM 50 Passives.
Très...
Attention fragile
La conception est fragile et le conditionnement très sommaire : certaines des vis sont coincées dans la banane.
Egalement,...
Yves F.
Marvelous DAC
Ma configuration : Denon PMA 3000NE, streamer dmp a6 master edition gen 2 + dac holo cyan 2 (connection en USB : câble Black...
Avis clients - Il y a 20987 avis.
James S.
AUDIOPHONICS LPA-S400ET - Superb!
In my system, to my ears, this amp sounds perfect. Clear, transparent, fast, and uncolored, it sounds like whatever I put into it. When I first turned it on I was startled by the clarity and the rock-solid rendering of a wide and deep soundstage. If the music is relaxed, it sounds relaxed. If the music is punchy, it sounds punchy. You get the idea. I listen to a wide range of music - classical, jazz, rock, funk, afro-cuban, bluegrass. From top to bottom this amp renders them all with accuracy and ease. I love it.
GERASIMOS Z.
Attila R.
Cheap and good
It is relatively cheap and if great quality overall. It does the job, no complaints :)
Attila R.
Amazing sound, in-wall cable
I was expecting a less rigid cable, this is definitely not the best choice for your standard IEC cables. The copper is a SOLID CORE inside, which makes this cable extremely rigid. You bend it and it stays like that. I would definitely use this as an in-wall cable as it has the certifications you need and would do the job (if you don't bend it too much). Out of necessity however, I have built a component Schuko-IEC cable with it and it sounds mind-blowingly good! If I had to run a new power line to my Hi-Fi rig, I would probably use these now.
Francisco Javier R.
Radiateur Dissipateur Thermique Anodisé Noir 170x45x61mm Ces radiateurs vous permettront de dissiper efficacement la chaleur dégagée par vos composants, comme une puce d'amplification par exemple.
Bon, mais...
Bon dissipateur de chaleur. Je lui donne une note faible car ils sont arrivés avec des rayures
J'espère que les deux que je viens de racheter arriveront en parfait état.
Attila R.
Fantastic sleeves!!
Amazing quality, was a breeze to work with it. I use a wiha tool to crimp it and it does the job perfectly. I used it for silver plated speaker cables so far.
Philipp G.
Embase Jack 3.5mm Stéréo 3 Pôles Corps Carré Cette embase Jack 3.5mm 3 pôles disposant d'un corps carré (2 angles biseautés) vous permettra la création de prises casques pour vos conceptions DIY.
robust
Everything fine. The Jack seems to be robust.
Philipp G.
Looks Nice
Was easy to assemble and the aluminium front looks nice.
Eric P.
YAMAHA MUSICCAST WXC-50 Lecteur Réseau Audio ES9006 WiFi AirPlay DLNA Bluetooth 24bit 192kHz DSD128 Yamaha dévoile avec son WXC-50 un lecteur réseau extrêmement complet, basé sur le système MusicCast de la marque. Il profite d'une...
Tres bien pour le streaming
Ce petit lecteur réseau n'est pas trop Cher et fonctionne très bien avec tidal master et audirvana studio ,un régal
Eric P.
PANGEA PREMIER Câble Ethernet RJ45 Cat7 Cuivre Plaqué Argent Triple Blindage 0.129mm² 0.6m Si vous disposez de périphériques audio high-end connectés en réseau, alors il est essentiel d'utiliser des câbles Ethernet de qualité...
Parfait pour un lecteur réseau le Yamaha.
Eric P.
PANGEA PREMIER Câble Coaxial Cuivre OFC Plaqué Argent Double Blindage 1.5m Ce câble digital coaxial Pangea intègre d'excellents conducteurs, composés de cuivre OFC et d'un plaquage Argent, avec un double blindage pour réduire...
Tres bien pour le streaming ou pour un lecteur cd
Parfait pour du matériel entre 500 et 1500euros
Eric P.
PANGEA AC-14SE MKII Câble Secteur IEC C7 Triple Blindage OCC / Cardas 3x2mm² 1m Le câble Pangea AC-14SE MKII est spécialement conçu pour les composants source qui ne nécessitent pas la même puissance de courant que les récepteurs et les amplis.
Idéal pour un petit lecteur réseau comme le Yamaha
Johny C.
Déjà très satisfait de ces PSVANE après seulement 4h d'écoute
J’ai acheté plusieurs types de tubes chez Audiophonics pour upgrader ceux de mon ampli Line Magnetic LM845 IA
- Etage d’entrée : 2x 12AX7 (upgrade : Psvane 12AX7-S Art-Series)
- Rectifier : 1x 5AR4 (upgrade : Gold Lion U77 - GZ34 Genalex – Russie)
- Drivers : 2x 6P3P (upgrade : TAD 6L6GCM-STR Redbase Premium Selected)
Ces choix ont été effectués en tenant compte des avis divers provenant des détenteurs du même ampli.
Je commence dans un premier temps par effectuer le changement des tubes d’étage d’entrée (les PSVANE 12AX7), et au bout de 4 heures d’écoute seulement je dois dire que le changement sans être radical est bien notoire. Des aigus plus fins, une dynamique plus perceptible, et surtout une musicalité bien plus évidente. Très agréable et jamais agressif. Après les 50 à 80h d’utilisation préconisées, je pense que le son ne pourrait que s’améliorer encore.
Je ne testerai les autres tubes qu’une fois la période de rodage des premiers sera terminée pour mieux cerner le réel changement au fur et à mesure des changements.
Je remercie donc Audiophonics de proposer tous ces tubes disponibles à la fois, sans avoir à les acheter dans plusieurs boutiques.
Alexandre G.
super chouette
il brule depuis peu sur mon convertisseur , franchement ce lecteur reseau vaut un tres bon drive et l'appli est super bien faite. aucun bug , facile a installer ... aucune critique! j'ai eu un auralic bien plus cher et franchement je vois pas pourquoi il l'etait!
Frederic G.
Très bon en streamer/ pas essayé en dac…
L’Eversolo a remplacé deux steamers (1600 et 2500 euros) que j’utilisais en Roon endpoint aussi bien qu’avec leurs propres applis.
J’en étais satisfait mais j’étais à la recherche d’un streamer abordable pourvu d’une sortie USB performante car les entrées spdif du Hugo Mscaler ne sont pas ses meilleures, mesures à l’appui (écoute également, chez moi et selon mes goûts)
Je me disais que quelque chose pouvait peut-être être amélioré dans ce domaine.
C’est appareil est neutre et dynamique avec beaucoup de détails parfaitement intégrés. Les timbres sonnent justes et pleins, surtout en Roon endpoint. Je n’ai remarqué aucune dureté ou brillance dans les aigus, au contraire. Il fait preuve de finesse, de douceur et de fluidité.
L’apport du Chord scaler y est sans doute pour quelque chose mais je n’avais jamais ressenti autant de nuances et de naturel auparavant.
Ce streamer est vraiment très bon dans mon système, sans même parler de son remarquable rapport qualité prix!!
Musique : jazz, classique, électro, rock, pop, métal,
Système: pc + Roon core / network acoustics Muon pro / câble ethernet Cardas clear network / Eversolo + câble secteur Shunyata delta / filtre secteur Niagara / câble usb audioquest carbon / Hugo Mscaler + Ferrum Hypsos / câble Oyaide bnc 510 / Chord TT2 + Ferrum Hypsos / câbles rca Cardas clear / Dartzeel 8550 mkii / enceintes perso.
Barrette secteur de grande qualité
Barrette secteur de grande qualité qui a pu apporter un plus indéniable à mon installation audio video.
De plus le matériau utilisé rassure sur la solidité de cette barrette.
Le prix peut paraître certes un peu élevé mais cela en vaut la peine !
Grzegorz B.
I echanged A22 to A26 and this was good step
I have Gustard A22 for over 2 years, it goes to second system and A26 exchanged it in main system. I short - the same good, natural, full and balanced sound, with little improvement of low frequency, new model is more accurate, more detailed. And has improvements like input for external clock (I will add in future) and with LAN input! Only screen is smaller than in A22, but looks more stylish. Important - new model heat-up less than A22
osman b.
FURUTECH FT-7445(R) Connecteur Jack 4.4mm TRRRS Cuivre Plaqué Rhodium ⌀6mm (Unité) Ce connecteur FT-7445(R) Jack 4.4mm symétrique de chez Furutech profite d'une très belle conception, avec un conducteur en cuivre plaqué rhodium, le tout traité Alpha.
super fast shipping
The product is excellent. The seller is very relevant and helpful. Very fast shipping 2 days. This is my next favorite shopping company. Thank you very much for everything.
osman b.
FURUTECH FT-735SM(R) Connecteur Jack 3.5mm plaqué Rhodium Ø5mm (Unité) Les connecteurs FT-735 compatible Jack 3.5mm ont été façonné autour du savoir-faire de Furutech.
super fast shipping
Turkka L.
TOPPING PA5 II PLUS Amplificateur Class D Symétrique 2x125W 4 Ohm Argent L'amplificateur PA5 II Plus de Topping est un modèle compact et puissant, adoptant une structure totalement symétrique et un circuit d'amplification Class D...
Great little amp with plenty power
I am driving Linton 85 speakers with this amp and E50 DAC. Lintons are recommended for 25-200W and I never listen beyond 50% volume setting because it gets so loud, and I can hear zero distortion.
I'm very happy with the clarity and neutrality of the amp. Amazing package for the price.
I wish it had sub out, but I am taking the sub now from the DAC.
Cris K.
Excellent build and astonishing sonic performance especially for its cost. ΅Well done ΡΑΜΜ AUDIO.
ISOACOUSTICS OREA INDIGO Absorbeur de Vibrations Ø58x33mm (Unité) Les absorbeurs de vibrations de la gamme Orea de chez IsoAcoustics éliminent les vibrations parasites et offrent une plus grande clarté et précision sonore....
Au départ j'avais placé sous mon ampli des iso puck de la même marque supportant 9 kg ; le son s'était nettement amélioré . Cependant je n'étais pas tout à fait satisfait . J'avais constaté que l'essentiel du poids se situait sur l'arrière de l'ampli dû à la présence des transformateurs . J'ai décidé de réduire l'amortissement sur l'avant de l'ampli en installant ces indigos et gardait iso puck 9 kg à l'arrière . Super résultat son transparent et ultra naturel . Conclusion ne pas hésiter à associer différents types en fonction de la répartition du poids de vos appareils . Hautement recommandable .
philippe C.
TOPPING A90 DISCRETE Amplificateur Casque Préamplificateur Discret Symétrique Argent Topping revient avec le A90 Discrete, une amélioration du précédent A90, cette fois-ci équipé de composants discrets. À la fois...
Fantastique !
Comment peut-on dire que cet ampli casque n'est pas bon ? Non il est fantastique ! D'une droiture et d'une bande passante extraordinaire et d'une neutralité incroyable. Très puissant écouté avec des casques planars de trés haut de gamme,Que ceux qui cherchent un appareil qui "fait" de la musique avec du relief des basses comme ci des aigues comme çà passent leur chemin... C'est un ampli casque avec une connectique pléthorique, une puissance fantastique et une fabrication hors pair. Je ne lis pas les blogueurs mais quand il est bien accompagné : câbles, secteur propre, symétrique du début à la fin, DAC etc et surtout musique ... Je parle de LA MUSIQUE, il est incroyable. Ceci dit on peut aimer ou ne pas aimer Carl Bohm, Furtwamgler ou Baremboîm mais de là à dire qu'ils ne sont pas bons...
Cet appareil est si précis et exigeant que sa mise en oeuvre pour en obtenir la quintessence demande de l'exigence et il vous fera entrer au plus profond de la musique. Il ne FABRIQUE pas de musique, il JOUE LA MUSIQUE avec plénitude et rigueur.
C'est un trés bon ampli Casque pour 600€.
PS : Les critiques du web sont comme les chiens qui pissent aux pieds des lampadaires.
Eric P.
Le son est très bon avec tidal master c'est parfait et même avec les radios Internet vu le prix que demander de plus.
Eric K.
SMSL D-6 DAC 2x AK4493S XMOS Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512 Le D-6 rejoint la large gamme de DAC de SMSL, offrant d'excellentes performances pour un prix contenu. Celui-ci est équipé de deux puces de conversion AKM AK4493S...
Le D6
Excellent petit dac (chaleur/profondeur/même les graves sont mordants) ! Quelle belle surprise en ligne avec ampli de puissance (je vais essayer avec un preamp bientôt). Livraison rapide comme d'habitude. Merci.
mathieu l.
ATOHM ZEF Câble de Modulation RCA-RCA Cuivre OCC (La Paire) 0.6m Fidèle à sa philosophie haut de gamme et fort de son expérience, Atohm a conçu un câble de modulation RCA sans compromis. De par sa...
Trop transparent
J’ai gagné en clarté, précision et surtout en transparence, malheureusement au détriment de l’articulation des médiums et des voix.
Très bon câble malgré tout.
mathieu l.
Neutre, clair et précis.
Extérieurement le câble est très bien fabriqué, souple, avec des connecteurs Cinch qui se dévissent puis se revissent très rapidement et sûrement.
Jusqu’à aujourd’hui je me contentais d’un QED Performance Audio 40i pour relier un Atoll AM100 à un
CXA81. Bien m’en à pris d’y réfléchir. Dès le branchement l’écoute à immédiatement apporter une clarté et une précision dans les médiums et les aigus. Avec du Rocket 11 pour les graves et du Viard Audio Premium HD pour les aigus qui font chanter des petites Monitor Audio Silver 50 7G, l’écoute est devenue excellente.
Davor R.
Davor
A long-time user of only class A and tube amplifiers, this is a new great experience. I couldn't believe my ears how deep, wide and clean it sounds full of the most subtle informations, uniform and connected from bottom to the top into one huge picture full of beautiful natural details. This amp sounds just like your source, cables and speakers do.No less, no more,but beautifully big...Outstanding !!!. Perfect match with Topping pre90
Francois B.
MATRIX ELEMENT S Lecteur Réseau DAC USB I2S SPDIF WiFi DLNA AirPlay 2 32bit 768kHz DSD512 Avec le Element S, Matrix Audio dévoile un excellent lecteur réseau, polyvalent, pratique et performant, qui vous permettra de faire entrer votre système...
Très bien, mais...
Produit bien protégé par Audiophonics (toujours au Top), d’autant que le packaging du Matrix est sympa, le produit est dans une petit sac simple avec poignée, le tout dans son package.
En quelques mots, c’est un lecteur audio/réseau sans Dac (Player) avec une bonne connectique. Le produit est mini.
La mise en route se fait par un système de QR code (m’ouais, j’ai un peu galéré, il me disais non valide sans arrêt lors du Scan) via une iDevice et l’application Matrix MA.
Une fois en route, pas de soucis, mais uniquement en anglais ou… chinois.
Après plus de 15 heures d’utilisation avec SSD 2 To et fichiers Flac (avec dac Hegel HD20 + ampli Hegel H190 et enceintes Sonus Faber Venère 3/0, c’est excellent, et je trouves l’ensemble un peu plus « défini - détails qui ressortent mieux » qu’avec mon autre lecteur audio Pioneer NAE 50) sur la même configuration.
Maintenant les choses qui m’agacent : c’est la reconnaissance des Tags des fichiers, que je fais manuellement et vérifiés, c’est très sujet à l’incomprehension (pourtant je n’ai aucun soucis sur les mêmes fichiers sur Walkman Sony (pourtant pénible a ce sujet) ou Shanling)
En fait c’est un peu la panique, il m’affiches parfois des infos dans les tags (que je sais même pas d’ou cela vient, je vérifies encore et encore, je refais = rien a faire, on gère, mais le pire c’est l’affichage avec le classement par artiste (ou autres choix dans les onglets de classement aussi), certes au niveau du nom d’Artiste, ça va, autant il cherches a mettre les photos des artistes qu’ils ne trouvent pas, ou quand il en trouves c’est pas le bon !!! Bref c’est un peu ‘’naze’’. (Attention aux mêmes noms de fichier/track si artistes différents, il mélangera tout, comme chez Shanling, chinois aussi …
tiens tiens !). Par exemple, il ne met (ou trouves rien a mettre) rien pour des artistes comme Vangelis, ou Diana Krall etc… reconnaissance surement plus adapté a des artistes du continent asiatique ou carrément chinois.
Par contre pour l’affiche des pochettes d’albums c’est tout bon a 99,9 %
Ceci dit, je ne regrettes pas mon achat, c’est un très bon produit.
Todor S.
Great device!
I have a USB powered DAC and I could hear the noise from my desktop PC. To solve this problem I use iFi iDefender+ in combination with Allo Nirvana and everything works perfectly. The noise is completely gone and the sound quality has improved significantly. Highly recommended device!
Joan M.
Very solid product
This is a very solid product you can trust when building your next DIY project.
Front panel is aluminum, very elegant finish
Rear panel is steel so you will need cobalt or titanium drill bit.
Fortunately for us IEC rectangle and fuse holder are already drilled
Jean-Francois B.
Parfait!
J'utilise cet adaptateur sur mon Hugo2 et franchement c'est du solide. J'en ai pas mal d'autres de ce type mais d'autres marques et c'était faux contact sur faux contact! Avec celui là, c'est parfait.
Alain S.
E1DA POWERDAC V2.1 Amplificateur Casque FDA TAS5558 320mW 32 Ohm L'amplificateur casque FDA PowerDAC V2.1 de E1DA reprend l'excellente base de son prédécesseur, le PowerDAC V2, tout en permettant maintenant un fonctionnement...
Le seul FDA pour casque du marché
Produit exceptionnel à de nombreux égards ...
Il a l'audace d’être à la fois moins cher et meilleur que tous ces concurrents dans le domaine (sans parler des possibilités de réglages inédites).
Si vous aimez l'écoute aux casque et intras foncez !!!
WONDOM AA-AB31471 Module Amplificateur Mono Class D TPA3110 30W 4 Ohm Le Wondom AA-AB31471 est un petit module d'amplification mono en Class D, simple et efficace. Il embarque une puce TI TPA3110 pour lui permettre de fournir une puissance de 30W...
Wondom AA-AB31471 review
I bought this little amplifier for my portable system with JBL Control 1 Pro speaker. It is incredible what this little amp can do, it makes declared 30W with the 19Vdc power supply. I posted a review at ASR:
https://www.audiosciencereview.com/forum/index.php?threads/wondom-aa-ab31471-1-x-30-watt-class-d-amplifier-board-review-and-measurements.46972/
laurent A.
Discret et efficace
Merci a Audiophonics pour l'efficacité.
Dac discret, bon son naturel, son mat et flatteur avec les enregistrements de moyennes qualités.
Parfait pour le prix
Ruben B.
a well build super clean amp
It's a great clean amp, a class D amp that does not sound like one like all NCore amps, it's just gain on a wire. Build quality is good, design is basic, but so is the price compared to other builds. The only complain is that the led on the power buttom is way to bright (but modable).
Pascal B.
En remplacement de 4 patins Linn Skeet en fonte d’alu , ces contrepointes font merveille sous les pointes de mes plateaux supportant mes deux lecteurs Luxman ( D05 pour les cds et PD171 pour les vinyles)
Amélioration de la spacialisation et du réalisme de la scène sonore . Je suis ravi .
Décidément, Audio Bastion est une marque qui sait lutter contre les perturbations dues aux vibrations !
excellent raport qualité prix
Cette alimentation est vraiment silencieuse et enlève le stress sur le hautes fréquences. Précision : elle est connectée sur un boitier de filtrage du courant du secteur. Pour le prix, elle est parfaite.
ATAUDIO POLARIS Câble Secteur Schuko IEC C15 Blindé Cuivre OFC Plaqué Argent 1.5m D'une qualité exceptionnelle, le câble secteur ATAudio Polaris utilise des conducteurs extrêmement conçus à partir de matériaux...
qualité
Câble bien construit avec des fiches de qualité. Utilisé entre la prise secteur et mon transformateur de filtrage de courant, il conserve la dynamique de mon système. Il est parfait pour un prix très raisonnable.
Hector S.
Fiches Bananes Plaquées Argent Ø5mm (La paire) Ces fiches bananes à petit prix permettent une connexion simple et rapide aux borniers de vos enceintes et amplificateurs. Les contacts sont plaqués Argent afin...
Excellentes
L'efficacité du maintien est admirable, la fabrication est exemplaire. Elles s'insèrent avec douceur dans les prises des appareils.
C'est du zéro prise de tête; exactement le type de petits matériels qu'il est utile de toujours avoir en réserve.
Bastiaan v.
parfait, très content
Acheté en remplacement d'un IFI Zen V2 qui n'arrêtait pas de faire des micro coupures dans le flux. Un violon qui se coupe ce n'est pas possible.
Aussitôt branché, aussitôt trouvé par l'ordinateur. Le son est parfait, un peu plus chaud et un poil moins défini que le processeur Sabre de l'IFI Zen, mais ce sont des affaires de gout.
Pour 65 euro c'est un appareil fantastique, bien construit. Et surtout, depuis 4 heures d'écoute aucune coupure, même si j'ai traversé la pièce et donc les ondes Bluetooth des nombreuses fois. Envoi rapide, rien a dire.
Laurent B.
TRIANGLE SYMPHONIE SYS25A Câble Haut-Parleur Cuivre OFHC Plaquage Argent 2.5m (La paire) Le câble pour enceintes Triangle Symphonie a été conçu pur assurer une excellente qualité de transmission du signal, grâce à...
Agréablement étonnant !
Dubitatif quant à la nécessité de changer mes bon vieux et basics câbles d'enceintes.
J'en reconnait l'utilité maintenant avec ces "câbles triangle symphonie".
Je n'ai pas changé d'enceintes (des triangles) et pourtant !
Plus de détails dans tous les registres , moins d'agressivité et plus de finesse dans les aigus, des médiums enchanteurs et des basses plus profondes et tendues.
Je redécouvre des morceaux de musique avec des détails non perçus auparavant et pensait que mes enceintes donnaient déjà leur maximum, il n'en était rien.
Câble de qualité de fabrication reçu rapidement par Audiophonics.
Rien à redire.
Patrick G.
Etonnant!!
Par sa musicalité:donne corps aux notes musicales.Tout est à sa place concernant les timbres,la dimension spatiale....Au vu du prix,bluffant!!!!
placé entre mon drive cd shanling tempo et mon DAC reimyo 777mk2.Mon commentaire n'a de sens qu'à l'ecoute de mon système....A essayer avant tout achat définitif.
Laurent B.
Qualité de fabrication, esthétisme et efficacité.
Ces jumpers sont très bien fait, la qualité est au rendez-vous.
Certes ils sont grands et assez visibles mais ils sont beaux.
Je les ai mis en place et achetés en même temps que mes câbles "triangles symphonie " et ai gagné à l'écoute sur tous les registres.
Plus de clartés, de précisions sur les basses et hautes fréquences.
C'est grâce aux câbles d'enceintes ou à ces jumpers, c'est évidement les deux.
Reçus dans une jolie petite trousse à conserver et bien emballés.
Livrés rapidement ,rien à redire.
Léo Q.
Presque
La prise en elle même est très bien. J'adresse cet avis surtout pour le fabricant Elecaudio car il est dommage de proposer une prise coudée si grande alors qu'elle est sensée permettre de gagner un espace important. J'ai heureusement pu la bricoler à l'aide d'une ancienne référence Elecaudio PI-22G. En effet la partie iec de celle ci remplace parfaitement celle prévue permettant un gain de 8 mm environ. C'est donc dommage de ne pas directement proposer une référence plus petite constituée directement de bonnes pièces. A bon entendeur.
Niklas R.
Great Cable
Used this cable for DIY microphones. It's easy to solder, flexible, and very stable, while having a small diameter.
TI LM4562NA/NOPB Amplificateur Opérationnel AOP Double DIP8 (Unité) Le Texas Instruments LM4562NA/NOPB est un amplificateur opérationnel (AOP) hautes performances 2 canaux, intégré dans un boîtier PDIP8. Cet AOP ultra...
EXCELLENT UPGRADE
Pour un prix très modique ce LM4562 fonctionne à merveille sur l'amplificateur Aiyima A07. Belle dynamique, définition excellente et image stereo superbe en largeur comme en profondeur. Je le
préfère même à mon autre Aiyima A07 équipé de deux AOP Sparkos
Jean Louis G.
Ca fonctionne !
J'étais dubitatif mais c'est efficace : meilleur discernement des différents instruments, image sonore agrandie et stable, impression d'ouverture plus grande, que du subjectif mais facile à mettre en oeuvre et la comparaison avec- sans est immédiate et parlante. A recommander pour le prix dans un système ayant pour point de départ un Mac et Roon (chez moi)
Fabian T.
MINIDSP FLEX DIGITAL Processeur Audio DSP SHARC ADSP21489 XMOS Bluetooth Le miniDSP Flex Digital est la 3ème génération de processeur audio à 2 entrées et 4 sorties de la marque. Il garde ainsi le puissant...
Nettes améliorations
Ce minidsp Flex D vient en remplacement d'un Minidsp 4x10HD.
Avec l'aide de deux DAC1 Benchmark, l'idée était d'améliorer la qualité sonore du 4x10, chose réussie mais un peu normale eu égard aux moyens mis en oeuvre.
Parmi les améliorations :
- meilleure connexion logicielle
- télécommande moins capricieuse
- affichage sympa qui heureusement s'estompe automatiquement
- entrée analogique plus silencieuse
Les gros regrets sont :
- pourquoi un deux fois deux voies ? Il eut été beaucoup plus intéressant d'en faire 4 x 2 voies stéréo. C'est vraiment le gros regret, il suffit de voir comment les Nonodigi s'arrachent sur le marché de l'occasion. Du coup, la troisième voie a été filtrée en passif. Les sorties optiques ne sont qu'un dédoublement des sorties coaxiales.
- suppression de la possibilité de configurer une entrée avec le contrôle de volume désactivé, cette fonction était intéressante pour y brancher un ampli
C'est vraiment dommage pour ces deux points car ce sont des fonctions qui ne coutent rien d'autre qu'une programmation logicielle, mais il n'y a pas d'autre alternative à un tel produit sur le marché, ce minidsp reste donc la seule possibilité confortable et abordable pour faire de la filtration active, mais en deux voies uniquement à la base.
Ghislain R.
SYITREN R300 Lecteur CD sur Batterie Bluetooth 5.3 Noir / Bois Le Syitren R300 est un petit lecteur CD affichant un design rétro du plus bel effet. Équipé d'une sortie optique Toslink et d'une sortie casque Jack 3.5mm,...
Fonctionne sur batterie rechargeable avec un chargeur de mobile.
D'où faible bruit. Bien insérer le disque. Relié (optique) à un DAC (2XESS 2038). Résultat très bon. Excellent pour le prix.
