Jochen M.
Tout n'est pas parfait
Richard M.
Bernard g.
Excellente Interface
Avis clients - Il y a 19551 avis.
Jorge m.
Muy bien
He comprado esto desde España en dos días lo tenía en casa. El aparato funciona muy bien y es muy práctico lo de los dos interruptores
Pavel J.
SINGXER SA-1 Amplificateur Casque Préamplificateur Class A Symétrique Le Singxer SA-1 est un amplificateur casque et préamplificateur complet et performant, basé sur une architecture Class A et des circuits discrets totalement...
Excellent discreet balanced amplifier in the price/performance ratio.
The SINGXER SA-1 is an excellent headphone amplifier and preamplifier for active speakers.
Its quality surpasses, for example, the cheaper Schiit Jotunheim 2 or MONOLITH THX AAA-887. If you want a better amp, go for more expensive ones like Burson Audio Soloist 3X Performance or HeadAmp GS-X Mini.
If you are going to use the SINGXER SA-1 in combination with a DAC, I recommend choosing one with enough power to drive the SINGXER SA-1 amplifier. I use it with the powerful RME ADI 2 DAC FS via balanced XLR cables and I am extremely satisfied. Other recommended DACs are Denafrips Ares II, GUSTARD X26 PRO.
I use HiFiMAN Ananda Stealth and HiFiMAN Sundara headphones. Other headphones I would highly recommend for this amp are the more expensive HiFiMAN Arya Stealth, Audeze LCD2 and LCD-X or Focal Clear Mg.
The sound of SINGXER SA-1 is very very clean (almost dead silent), detailed, smooth and warm with a lot of space, separation of instruments and soundstage.
I highly recommend this amp for purchase at a great price!!!
Rene C.
Best buy
Reasonable priced, high quality EMI filter
Rene C.
Best buy
I recommend the use of this cable in all solid installations, fx. inside wall sockets, to and from or inside power strips .......
Viorel S.
Station solder Blanko ZD-931
Come fate a dire che questa stazione saldante è una professionale? Io l'ho comprata qui da voi è non a neache un anno di vita è già non funziona più, le punte dopo 2 giorni di utilizzo, li devi buttare perché si consumano rapidamente. Una stazione pessima meglio la mia 100 volte che l'ho pagata 20 euro. I soldi adesso chi me li ridà? Ovviamente nessuno. Ma così fatte soltanto figuracce rispetto alla gente. Già siete poco seri ero un vostro cliente ho dovuto cambiare strada.
Iulian M.
Verry good opamps
Replaced the default JRC 5534 's in burson playmate 2.
Very good transparency.
Vivid's reveal rough edges in the audio setup so if you can't stand to listen with them then you have some more work to do on your setup.
Jose l.
IFI AUDIO DC BLOCKER Filtre d'Alimentation Secteur 90-240VAC Le iFi Audio DC Blocker est un filtre d'alimentation secteur, permettant de supprimer les tensions DC résiduelles afin de limiter le niveau de bruit.
plus de clarté
brancher sur l'alimentation indépendante de ma box, je vais en reprendre pour mes amplis.
Jürgen K.
Excellent!
The cable is really fabulous, hasn`t fully broken in yet, however the quality is already noticeable. Compred to Neotech NES 3002, which is not bad at all, I noticed clear superiority of RAMM in female vocal. Absolute clarity and no sizzle in "S". As well as bass is well defined, sharp and weighty. All in all a lot of value for money. Great PRAT, snappy, airy, detailed. Bravo!
Emmanuel A.
FIIO FD1 Écouteurs Intra-Auriculaires IEM Haut-Parleurs Dynamiques Plaqués Beryllium Fiio propose avec ses FD1 des écouteurs intra-auriculaires de grande qualité à prix réduit. Ils profitent ainsi d'une conception soignée afin...
Ecoute très agréable, équilibrée.
Tres confortable, avec un spectre étendu ( non mesuré ) qui semble préservé. Une belle dynamique.. Par rapport a d'autres marques pour ce meme budget, les graves descendent bien, les médiums ne débordent pas, et les aigus, voix, cymbales, sont claires et précis. L'essentiel est surtout d'offrir une belle musicalité.
Samuel B.
1er FDA pour moi, donc la comparaison ne se fait qu'avec des amplis analogiques (NAD C 356, Hegel H 80 de mémoire) et il les surpasse aisément. Je le trouve excellent, son limpide, détaillé, et bien équilibré. Je sens aussi une grande réserve de puissance, ce que je cherchais (à 25 sur 78 très exactement, c'est déjà énorme pour ma pièce d'env 60m2, et je sens que l'on peut encore monter sans saturation/distorsion).
Très content!
nicolas s.
Excellent ampli FDA !!
Rapport qualité prix incroyable. Cet ampli procure vraiment du plaisir. Précis et suffisamment puissant pour une majorité des enceintes et pièces d'écoute. Je me permets de partager un test audio réaliste pour donner une idée du rendu, à écouter avec un casque ou écouteurs : https://youtu.be/jVVeyU2VsB0. Bonne écoute et merci à Audiophonics pour leur service et conseils.
Stephane N.
Utilisé pour la réalisation de câble XLR modulation, sans blindage extérieur supplémentaire, le rendu est excellent ( liaison ampli NCore et Dac Sabaj ).
Énormément de détails sur tout le spectre.
Vraiment un must.
Stephane N.
NEOTECH BRDCC-20 Fil de Câblage Plat Tressé Cuivre UP-OCC Fil de Litz 20AWG 0.5mm² Les fils de câblage Neotech BRDCC sont une excellente solution en Cuivre UP-OCC. Le procédé UP-OCC, du professeur Ohno, est reconnu dans la fabrication de...
Bonne idée mais…
Impossible pour moi d’insérer les câbles Neotech argent SOST 22 au delà de 5 cm.
Déçu.
Florent D.
Acheté pour remplacer un kit elektor ampli/filtre Sub (trop fragile: pistes décollées, irréparable), cet ampli classe D est étonnant: graves fermes et moins empâtés qu'avec mon vieux kit elektor. Il descend bas et tient bien le HP grave.
Sensibilité d'entrée un peu plus faible que celle de mon kit elektor. Pour finir il rayonne un peu en HF: j'ai un recepteur DAB et j'ai du éloigner l'ampli et l'orienter dans un certain sens pour eviter les pertes du signal DAB.
Florent D.
Module Protection stéréo pour haut parleurs large borniers Voici un module de protection Stéreo pour Haut Parleurs. Avec ces relais rapides de marque Omron à faible résistance de contact, ce module protégera...
Très bon produit, qualité pro: circuit imprimé epoxy double face trous métallisés, du solide.
Composants de qualité.
La tempo haut-parleur est de 6 à 7 s. lorsque le circuit est hors tension depuis 'longtemps'.
La protection tension continue est entre 2 et 3 V.
Voir les commentaires de Jean Pierre G. que je confirme ici, 'à ce prix c'est imbattable'.
L'idéal est d'installer ce module avec le transfo pour le 12 V alternatif commandé
par le même interrupteur secteur de l'ampli:
l'alimentation doit se faire par du 12 à 18V alternatif,
ceci parce qu'à la coupure d'alim les relais s'ouvrent immédiatement
(avec du continu il y a toujours une capa. balast qui maintient l'alim pendant 'un certain temps'),
cela permet d'éviter les plops à l'extinction.
Sebastien D.
SHANLING MTW100 Écouteurs Intra-Auriculaires IEM Bluetooth 5.0 Noir Les écouteurs Shanling MTW100, particulièrement pratiques, permettent une transmission stable et performante de votre musique. Les haut-parleurs Knowles et la...
tres bien
un rapport qualité prix défiant toute concurence, malheuresement apres 4 ans d'utilisation intensive au taf un des écouteurs commencait à rendre l'ame (gresillements) , je me suis donc retourné vers les mtw300 car les mtw100 n'étaient plus en stock à une période sur le site et je regrette de n'avoir pas été plus patient...
Sebastien D.
SHANLING MTW300 Écouteurs Intra-Auriculaires IEM Bluetooth 5.2 QCC3040 aptX Gris Les écouteurs intra-auriculaires Bluetooth Shanling MTW300 reprennent le design ergonomique et confortable des MTW100, dans une version aux performances...
bof
Venant des mtw100 je prefère ces derniers, le son est bien meilleur certe sur ceux ci mais l'appairage est un brin ennuyeux à cause de l'aptx qui se reconnecte et déconnecte régulierement dès qu'il repère d'autres sources bluetooth , vraiment dommage car le son y est...
charles Z.
AUDIOPHONICS HPA-S400ET SPARKOS EDITION Amplificateur de Puissance Class D Stéréo Purifi 1ET400A 2x400W 4 Ohm Nous sommes fiers de vous proposer le AUDIOPHONICS HPA-S400ET SPARKOS EDITION, un amplificateur de puissance stéréo class D basé sur deux modules PURIFI...
Excellent à mes oreilles !
Expédition : délais annoncé tenus, très bien emballé. Appareil acheté en juillet 2022.
Qualité de fabrication: aussi beau a l’extérieur qu’à l’intérieur. Je l’ai ouvert quelques fois pour régler le gain et la construction est vraiment soignée. Les tôles qui constituent le boîtier sont épaisses et les ajustements sont propres.
Le plus important : le son, la Musique.
Deux mots sur ma config:
- enceintes Thiel 3.7
- streamer Auralic Altair G1 branché en direct sur l’ampli via XLR MIT
- barbette filtrée et câblages Audiophonics et MIT pour les enceintes.
L’ampli ne laisse rien passer, il est très (trop) transparent, et la qualité de la partie preampli sera importante dans votre installation. J’avais auparavant un Meridian G08, je trouve que l’Auralic va plus loin, et l’ampli suit sans sourciller.
Tenu des basses incroyables, les médiums et aigus vont très loins aussi.
Ce qui me frappe le plus, c’est la dynamique et les extinctions de notes: rapides , fluides sans jamais tronquer la musique.
Sur mon système, le son peut paraître analytique et j’essaierai sûrement un preampli à tube ou une grosse électronique japonaise, pour voir… ou plutôt écouter.
Reste que mon ancien système semble bien obsolète ( blocs mono Rega Exon) et que mon fils de 9 ans m’a dit hier soir: qu’est ce que t’as fait à la musique papa? C’est bien mieux qu’avant ! Avec le pied qui battait le tempo sur un Clapton…
La vérité ne sort’ elle pas de la bouche des enfants ?
Simon N.
SIVGA Câble pour Casque Jack 3.5mm vers 2x Jack 2.5mm Mono Cuivre OCC 1.8m Ce câble Sivga a été conçu pour accompagner des casques HiFi avec câble détachable. Il dispose d'une part de deux connecteurs Jack 2.5mm...
Faux contact après 3moi
Le câble avait l'air de bonne qualité mais un faux contact est apparu après a peine 3 mois d'utilisation (je pense que c'est à cause du fait que le câble soit trop fin et qu'il ait tendance à se torsader)
Boitier 3U
Excellent coffret, la qualité est toujours là.
Dommage que les vis tôle de fixation du capot et du dessous soient d'un diamètre légèrement trop petit et ne permettent pas un serrage avec léger blocage.
A part ça, épaisseur des tôle et rigidité des plus satisfaisants.
Jean Claude L.
RAMM AUDIO ELITE 8 Câble de Modulation Cuivre OCC Triple Blindage Ø9,2mm Le Elite8 de Ramm Audio est conçu pour offrir la meilleure connexion analogique possible afin de préserver l'intégrité du signal transmit. Le...
Exceprionnel !!
Monté avec des fiches KLEI Silver en masse flotante.
Ce câble a détrôné des modèles à plus de 1200€.
Époustouflant.
Très dynamique , grande transparence, profondeur de la scène sonore, détaillé, bande passante , précis et clair, tous les critères d'un excellent câble sont réunis à un prix dérisoire.
Grande musicalité !!!
Une constante chez RAMM.
Même niveau que leur Amadeus 5 (utilisé en secteur )
Laissez tomber les pseudos référence à pas de prix, ne cherchez pas, tout est concentré dans ce câble
Jean Claude L.
Gaine Thermo Rétractable 3:1 Ø12.7mm 1m (Transparente) Gaine thermo rétractable avec un ratio de 3:1, dotée en interne d'une couche adhésive assurant un meilleur maintient sur tout type de surface (plastique, caoutchouc, métal...)
De la qualité
Produite de grande qualité
Très bonne qualité , de bonne épaisseur, pour une finition professionnelle
Jean Claude L.
Correcte
Rapport Q/P correct
Jean Claude L.
Bon produit.
Il faut juste bien respecter la température de fusion pour
de belles soudures
Jean Claude L.
Moyen
Gaine de faible épaisseur.
Pas trop de grip une fois rétrécie
Jean Claude L.
Correct
Monté sur du cuivre OCC.
Difficile de dire qui fait quoi, acoustiquement semble neutre.
Qualité correcte, facile de montage
Excellente
Pour remplacer les prises hp de mon ampli roksan k2. Le système vissé des câbles est très bien pensé.
Ça respire le sérieux et la qualité je recommande vivement
Ces selfs creusent l’écart !
Ces selfs Jantzen WAX COIL ont remplacé des selfs de même valeur et R série proche déjà de bon niveau sur une enceinte TANNOY.
Si une amélioration était certe espérée, jamais je n’aurais imaginé qu’un tel écart qualitatif soit possible.
La transparence est nettement améliorée ainsi que la distorsion subjective ; de nombreux micro détails auparavant quasi imperceptibles apparaissent.
Remarquable et hautement recommandable.
CB
Excellent interrupteur!
Il vient remplacer avec brio un interrupteur de base qui équipait mon
appareil et c'est beaucoup plus rassurant! Le contact est beaucoup
plus franc!
VIBORG GX16G Connecteur GX16 2 Pôles Plaqué Or Ø8mm Le Viborg GX16G est un GX16 à deux pôles. Ses contacts sont fait d'un alliage de cuivre plaqué or, assurant une bonne conductivité. Le corps du...
Déçu par ce connecteur!
C'est fabriqué en Chine et don,c c'est de la m---e!!!! Un des contacts
est sorti de son logement lors de la soudure!!!! De plus,tout le corps
du connecteur est en laiton peint en gris,ce qui est compliqué pour
souder une tresse de blindage de câble car il faut enlever la peinture
pour pouvoir la souder! Sinon,ce connecteur fait le job correctement!
Dejan R.
Adaptateur DAC ES9280C PRO USB-C vers Jack 3.5mm Hi-Res 32bit 384kHz DSD256 Cet adaptateur USB-C vers Jack 3.5mm femelle offre une belle qualité de conception, favorisant une transmission du signal de qualité. Celui-ci intègre un...
ES9280 sound
Very fine sound, well designed device
Très bon câble pour tweeter
Cable chantant tout est beau une gaine plus une gaine neutre, mieux que le CA1 que j'avais qui était un poil trop montant
Jean-pascal H.
Rapport Qualité Prix imbattable à ma connaissance
Tout est dans le titre. Présentation cossue, petit sac de rangement. La qualité perçue est au rendez-vous. Relie mon lecteur réseau Cambridge a ma box 4G+, et après quelques heures de rodage, le rendu sonore est parfait. Du coup, j'en ai racheté 2 afin de raccorder mon macbook et un NAS à la box. Le seul problème est que ça "force" à l'arrière de la box malgré la présence de 4 entrées RJ45. Celles-ci sont trop rapprochées par rapport à la taille des connecteurs des câbles. (Box SFR 4G+)
TRès bon conducteur multibrins
Très bon conducteur avec un excellent isolant pfe.
Juste les brins très très fin qui sont cassant mais c'est la descrition exacte du produit dans sa fiche technique et c'est ce qui me l'a fait sélectionner.
Donc RAS vous pouvez y aller très bon conducteur
RAS toujours la perfection
Rien a dire pur cuivre et connectique au top.
IEC remarquable.
Moyen très moyen
La prise elle même ne souffre pas de gros défaut sauf pour les vis de serrage des conducteurs réalisées dans un métal mou (cuivre ?) et qui ne permet absolument pas de serrer correctement la connexion.
Dommage
Jean-Michel P.
Pratique et économique
Cet adaptateur me permet d'utiliser une entrée BNC de mon DAC avec un câble S/PDIF.
Il est très facile à installer.
La qualité semble au rendez-vous.
Janez R.
Poor higher tones
Unfortunatelly, I can only confirm some previous comments. I bought 12 of them, 4 were used with Mogami 2549, 4 with Canare 4e6s, on both very poor results in higher tones. 4 will remain unused. Cables were made by devoted audiophile who owns workshop which is also authorised repair service for Bang and Olufsen, Bose, ... My worst 'audiophile' purchase so far. Sorry to write this I was really looking forward to them.
Higher tones are supressed, no joy in listening music through these connectors. I should have gone for Neutrik or Klei. Money lost. I will probably buy Klei.
Peter W.
Excellent amp,even not regarding the price.
I used a nuforce Ref 8.5 V3 and wyred4sound SX1000 monos before,
this one will stay.
Very clear sound,many details,not harsh at all,dead quiet and enough horse power for loud sessions.
Bass control is on par with the rest.
And.... after finding the 3 silicon rings in the package,and fixing them
on the plastic feet,it stays in the rack,when switching on,which I pretty much appreciate!
Not absolutely sure if it is getting better and smoothens even more,after a few hundred hours,but I have the slight impression.
Recommendation from my side
Peter O.
Upgrade
Ik heb 5 van deze versterkers gekocht om een actieve home cinema set op te zetten door middel diy luidsprekers. Hoewel ik zeer tevreden ben over de geluidskwaliteit heb ik een tweak uitgevoerd door alle elektrolytische condensatoren te overbruggen met een kleine film condensator van Panasonic omdat ik die hier toch op voorraad had. En ik heb ook de ingang condensators vervangen. Ik dacht dat dit nauwelijks iets zou opleveren maar toen ik naar een vergelijkende test luisterde viel mijn mond open van verbazing. Vooral in het midden en hoog is er net een grote waas verdwenen. Stemmen hebben veel meer detail en het hoog is volledig opgehelderd. Ik heb dit getest met mijn achtergrond luidsprekers die bestaan uit een full range luidspreker zonder filter en in omnidirectionele opstelling. Het resultaat is gewoon geweldig! Ik heb nu een 150 van die condensator bijbesteld. Per versterker is de kost voor 9 stuks van 1uF en 2 stuks van 2,2 uF ongeveer 10 Euro. Echt aan te bevelen!
Christian V.
AUDIOPHONICS SUB Amplificateur Subwoofer Class D TPA3116 100W 4 Ohm Cet amplificateur compact pour subwoofer Audiophonics SUB vous permettra d'alimenter un caisson de basses avec une puissance de 100W sous 4Ω. Il intègre notamment une...
ampli sub
Petit mais costaud ! Bon renfort de basses nettes et pas ”boursouflées” . Super rapport qualité prix
Préamplificateur Contrôleur de Volume AOP OPA2604 Ce préamplificateur, à la fois simple et efficace, profite d'une conception robuste et performante permettant une restitution audio de grande qualité, transparente et précise.
À ce prix, difficile de trouver meilleur preampli en hi-fi
Envoi très bien emballé et reçu comme prévu.
Merci Audiophonic
Gérard H.
séparation de circuit audio
Utilisé pour supprimer la ronflette 50hz pour la liaison symétrique de 50m entre préampli et ampli. Installé en sortie de de préampli.
entrée 1-2-3, sortie 6-7-8. tout est OK.
Yvon C.
produit rare !
Audiophile depuis de nombreuses années, j'ai essayé de très nombreux câbles de toutes marques et tous prix. Certains, très chers, m'ont laissé dubitatifs ou carrément frustré. D'autres m'ont
apporté une progression qualitative évidente. L'intérêt final se situant dans le juste rapport qualité prix.. Avec ce produit RAMM AUDIO, le rapport qualité prix est prodigieux (je pèse mes mots), car il fait mieux que beaucoup, coûtant le triple !
Une véritable bonne affaire à connaître et faire connaître.
Cédric B.
Tres bon mais encore des problèmes avec Deezer
Tres pratique, facile à mettre en place et polyvalent tant qu’on n’a pas l’utiliser de streamer du chromecast. Il an encore des problèmes à se connecter avec Deezer, il semble “oublier” le login après quelques pistes et revient en MP3 128 malgré mon abonnement wifi. Mais avec Spotify connect, tout est transparent. J’en ai déjà acheté 2, pour le salon et mon bureau. Pas trop d’utilité du multiroom mais ça marche !
Arto L.
Clear as crystal
I wanted to try this new Purifi-module amp to hear if it is as good as claimed.
It is. Hard to say if this is neutral sounding or not but it is very accurate. My Nuprime ST-10 class-D amp is good but has a bit more warmer sound that I like too.
If I want to dig deep in the recording nuances I would use Audiophonics. It is very relieving with details and may occasionally sound too harsh with some recordings. Power handling is more than I need.
The value of this product is exceptional.
Jam M.
WIMA MKS2 Condensateur Polyester 5mm 100V 2.2µF Les condensateurs WIMA MKS2 disposent d'un très bon rapport capacitance / volume et peuvent être utilisés pour des applications très variées. Ceux-ci disposent d'une durée de...
Conforme à la description.
Prévue comme capa de liaison peu encombrante.
Jam M.
Prévue pour un filtre HP. Il faudra la maintenir sur le CI avec des colliers en rilsan.
Jam M.
Jean-Claude F.
Sur une Rega 3
J'avais déjà acheté la même plaque bitumée. Les 2 m'ont servi pour amortir une vieille platine Rega 3. J'ai posé une plaque dessus et l'autre dessous en pratiquant des découpes là où il fallait. Cela n'empêche pas le fonctionnement de la platine. Une de mes meilleures améliorations de cette platine qui n'en finit pas de me surprendre!
