Luca C.
Panos M.
Its more my personal taste
Ludovic P.
Avis clients - Il y a 19585 avis.
Patrick M.
pat 54
je ne m attendais pas a une telle ecoute a ce prix.tres bon service merci
Robert C.
LUDIC KRATOS Distributeur Secteur Filtré 6 Prises Filtrées + 2 Prises Directes Schuko Noir Le Ludic Kratos est un distributeur secteur avec section filtrée extrêmement performant, capable de soutenir la comparaison avec les produits les plus haut de...
Ludic Kratos Recommened Product
For device I will give five stars and for the Ludic support I will rather give two stars but fortunately we have Audiophonics.
I can compare this product with products up to 500 euros and it is noticable upgrade in my case. The device removed that grainy overlay from the music in my system. So yes, there is less noise and you get that feeling of better dynamics and better instrument separation.
Pros: Very good filtering, quality build, 6+2 sockets, fancy display with useful info.
Cons: brass contacts in sockets.
Technical specs:
Dimensions WxHxD 15x10x29,5 cm
Weight 2745 g
Number of sockets 8 (filered 6, unfiltered 2)
Maximum load up to 3000W.
Maximum current up to 15A (fused).
Wiring is parallel connection lines. Socket contacts are brass, internal wires are OFC. Wire skin is PVC.
Rosario Roberto S.
ELTAX MONITOR III Enceintes Bibliothèques 2 Voies 90W 89db 50Hz-22kHz Noir (La paire) Les Eltax Monitor III sont des enceintes bibliothèques offrant d'excellentes performances sonores pour un prix des plus abordable. Le grave délivré est...
Eltax Monitor III , davvero ottime e facili da pilotare
Questi diffusori mi piacciono moltissimo per la timbrica di suono che hanno , sono facili da pilotare con 89 db , bassi corposi e medio alti non troppo squillanti e neanche troppo chiusi , li faccio suonare con un amplificatore in classe D SMSL A300 e ci ascolto musica rock , metal e pop e musica italiana leggera . Rapporto qualità prezzo eccezionale , vi consiglio di comprarle.
BEATRIZ H.
Paul
Hi there, making your own power cables without this plier will be very difficult for 5€ a must
Patrick G.
indispensable
Mis en place en debut de barrette secteur qui alimente mes appareils numeriques(drive et DAC) et en debut de la barrette des appareils analogiques(amplis,preamp,tuner),ils révèlent la musicalité de mon systéme audio:naturel,qualité des silences,qualité de l'image stereo.....Superbe.
René d.
Used it for DC, connecting power supply to DAC
Replaced the 80 cm standard DC power cable with a 40 cm Canare 4S6 SQ cable. Results were above expectations. Recommend for DC applications.
Fabien T.
DAYTON AUDIO DSA175-8 Haut-Parleur de Grave Aluminium 70W 8 Ohm 88dB 38Hz - 7500Hz Ø16.5cm La gamme Designer Serie de Dayton Audio a été conçu pour fournir des haut-parleurs abordables mais pour autant extrêmement performants. Ils combient...
Polyvalence
Totalement satisfait par ce woofer dans cette gamme de tarif !!! Je ne vois pas vraiment ce qu on peut lui reprocher. Monté dans une grosse "bluetooth box" en association avec des tweeters Monacor dtm104-8 et deux radiateurs passifs Dsa215-pr par woofer. Avec un crossover d ordre 2 sur chaque pilote incluant le delay des centres acoustiques ainsi qu un zobel pr le woofer et la prise en compte du baffle step par le DSP de l'ampli intégré, l image sonore, la musicalité et la polyvalence d écoute d ensemble est vraiment très plaisante pour ne pas dire réellement étonnante pour un montage dans une seule "boîte" où les canaux droites et gauches sont pr ainsi dire les uns sur les autres. des heures d écoutes en mode relax sans jamais être soulé, punchy et jamais agressif a fort volume, équilibre même à faible niveau d écoute. Peut être pas l écoute la plus analytique du monde mais y a du détail et de la profondeur de champ, du punch malgré la sensibilité pas très élevée tout en restant assez "rond". Pour une entrée en budget raisonné dans le DIY, ces DSA m ont étonnés
Léonard H.
IBASSO DC06 DAC Amplificateur Casque Portable 2x ES9219C 32bit 384kHz DSD256 MQA iBasso Audio nous propose avec le DC06 un duo DAC et amplificateur casque portable compact, intégrant des composants de grande qualité afin de fournir une...
Chouette petit DAC !
Acheté pour exploiter principalement du FLAC, branché sur un Sony WH1000XM3 actuellement (et peut être plus gros un jour).
Très satisfait du produit. Construit en aluminium, il respire la qualité. Livré avec toute la connectique nécessaire (USB-c / USB-c, USB-c / USB-a, USB-c / lightning) cela donne une impression de sérieux de la part du vendeur. De plus, sa petite taille (à peine plus qu'une clé USB), il se transporte facilement.
Utilisé sur Windows 11 aussi bien qu'Android (penser à utiliser l'application iBasso UAC), je n'ai rencontré aucun soucis, la lecture est fluide (aucun délai après une pause par exemple). Tout a été fait automatique, il suffit de brancher le câble et c'est parti, vraiment pratique.
Au niveau de l'audio, j'en suis très satisfait. J'ai immédiatement ressenti un gain de précision, et de propreté, quel que soit le style écouté !
Bref, je recommande fortement ce produit pour les personnes cherchant un DAC portable !
SMSL PO100 Interface Numérique USB-C vers Coaxial / Optique XMOS 24bit 192kHz DoP64 Noir Le SMSL PO100 est une interface numérique hautes performances basé sur une puce XMOS. L'entrée se fait en USB-C et la sortie en Coaxial ou Optique Toslink....
...sauf en OTG
L'interface étant alimentée par le port USB, elle ne fonctionne pas connectée à un téléphone ou à une tablette via câble OTG ; pour cette application, préférer une interface possédant sa propre alimentation.
Mission accomplie
Acquise pour attaquer un DAC avec une 2e sources USB (PC en plus du streamer) en utilisant l'entrée S/PDIF, cette boîte minuscule fait le boulot sans histoire, en toute transparence audible.
Robert L.
TOPPING E50 DAC ES9068AS XMOS XU216 Symétrique MQA 32bit 768kHz DSD512 Noir Topping propose avec son E50 un DAC compact et très performant, utilisant des composants audio éprouvés et largement reconnus par les audiophiles. Celui-ci...
Ce que je cherchais
Ce DAC vient en remplacement d'une carte USB Tascam US322, limitée au 24/96, et d'un dac Sanskrit mk2 pour l'ampli casque. Il me permet de n'avoir qu'un périphérique pour mes enceintes Présonus (Eris E5+sub8) en TRS, et en RCA pour mon little DOT MKII retubé. Le son est plus détaillé, plus precis que le sanskrit au casque, et sans comparaison par rapport a la Tascam qui datait de 10 ans.La découverte des fichiers DSD, et PCM 24 /384 Flac avec ce type de materiel est assez bluffant, La transparence et l'ouverture de scene que donnent ces fichiers est vraiment mise en valeur par ce DAC. A première vue, je l'ai trouvé un peu "montant"...mais en fait, il est juste comme il faut, de toute façon, le déséquilibre serait facile a compenser juste avec les contrôle des enceintes bi-amplifiées. Les mediums sont bien définis, sans aucun voile, les instruments ou les voix sont parfaitement distincts les uns des autres, comme détourés avec un bonne spatialisation, l'ensemble est coherent et très musical. Les basses sont precises, naturelles, bien a leur place, et donnent une belle assise , les infras descendent très bas, avec une belle profondeur sans prendre le dessus, sans trainage, et bien articulées: Les notes sont parfaitement séparée et audible, pas baveuses. Bref, un tres bon rapport qualité/prix
John B.
SMSL A300 Amplificateur Class D Infineon MA5332MS USB Bluetooth 5.0 Subwoofer 2x160W 4 Ohm SMSL propose avec le A300 un amplificateur Class D compact mais pour autant puissant et performant, basé sur une puce d'amplification Infineon MA5332MS. Celle-ci lui...
So good, I bought two
I bought one device on the strength of online reviews. I was impressed with the line inputs, less so with usb and BT. I have CD and streamer through a DAC taking one line in connection, and my Technics deck into the other.
My main use is in a large room with stand mount ATC SCM11 speakers, quite hard to drive.
Then I read about the BTL facility and ordered a second device. It arrived, like the first one, promptly and well-packaged.
I connected following the instructions with a phono lead between the two boxes. It’s good, but when I play a test CD (‘my voice should be coming from the left channel only …’) the voice sounded different between left and right.
So I ditched the instructions and connected in simple monobloc style, one amplifier per channel. A single remote will control two devices simultaneously.
Great result. The sound is fuller and with more authority than just using one device. I do not listen at very high volume but I am enjoying this combination a great deal.
FRANCIS C.
Super produit idéal pour pour le bi-câblage pour les amplis qui ne possède pas de double sortie haut parleur, ou pour connecter un caisson de basse.
Ángel P.
Sennheiser HD 650
Excelente elección para usar con este headphone. No dejen la malla suelta conete un vivo a ella.
Johan L.
AIYIMA A07 Amplificateur Class D TPA3255 2x225W 4 Ohm Le Aiyima A07 est un petit amplificateur Class D, simple, puissant, efficace à prix abordable, idéal pour le montage d'un système audio nécessitant...
A no-brainer
This is a no-brainer. I prefer it to an Ncore I had. But it's of course dependent on your other equipment, your needs in terms of sound pressure and of course your tastes. Highly recommended.
Radu D.
SINGXER SU-6 Interface Numérique I2S USB XMOS XU208 32bit 384kHz DSD512 Le Singxer SU-6 est une interface numérique nouvelle génération offrant d'excellentes performances audio grâce à une conception basée...
Best DDC under 4 digit figures
One of the best DDC's measured by ASR, this one use a femto clock usually found in very high end gear and also have configurable switches for I2s to try any DAC with I2s. Highly recommended! Very fast delivery and excellent handling by Audiophonics!
Bas v.
Allo Nirvana
I have tested this low noise power supply with my Node 2i with PSU mod. And I can confirm it does a good job. Background is definately blacker and everything sounds smoother and quieter. The sound is very neutral. Build quality seems pretty good and look & feel is great. An on/off switch would be a nice idea for further improvement. As is the possibility to switch power cables. These are fixed now. But you cannot have it all for only 70 euro. Great value for pricewise. In the end I have returned the unit because I had buyers remorse and wanted to have a linear power supply. I would like to mention the great customer service Audiophonics provides. They replied quick to all my questions. Pleasure to deal with this company. Highly recommended!
Thierry S.
SHANLING EM5 Lecteur réseau audio DAC AK4493 32bit / 768kHz DSD256 MQA Noir L'EM5 est une station complète DAC / amplificateur casque haut de gamme, avec un large éventail de de connecteurs différents, dont XLR symétriques et...
Bon, mais pas parfait
Signature sonore transistorisée typique, qui penche plus vers le bipolaire que vers le mos-fet (les anciens me comprendront).
Cela reste globalement toujours très naturel.
Sur tous les paramètres d'analyse audio, l'EM5 n'est jamais premier de la classe, mais il est toujours bien placé, ce qui en fait un appareil très homogène.
Vous voulez mieux ? Et bien, se sera beaucoup plus cher! Un M30, par exemple, c'est plus de 4 fois le prix, et c'est seulement un poil mieux et en éléments séparés c'est un budget au moi moins 3 fois plus important pour se dire "ok, c'est mieux!
Des défauts et bien oui : la partie soft, brouillonne, qui bug quelquefois, qui s’améliore doucement avec les maj, mais bon...
Le dlna compatible avec peu d’applications tierces.
À améliorer donc, le consommateur ne doit pas servir de testeur bêta...
Thierry S.
ASTELL&KERN KANN ALPHA Baladeur Numérique DAP HiFi 2x ES9068AS Bluetooth 5.0 WiFi 32bit 384kHz DSD256 MQA Noir Le KANN Alpha est le troisième produit de la gamme de baladeurs KANN. Si l'objectif de la gamme Astell&Kern KANN est de fournir une puissance de sortie ultra...
Une main de fer dans un fin gant de soie...
Dap d'une grande rigueur, qui ne transige pas avec la vérité.
Image spacieuse et très aérée.
Performant sur la grosse dynamique et rapide sur les transitoires (très).
Timbres justes, ni chaleureux, ni ascétiques, mais cependant avec léger côté soyeux.
Ne pardonne pas les mauvaises prises de son.
Drive la plupart des casques de marché.
Soft moyen, système parfois un peu lent, android fermé (est-ce que l'on y gagne vraiment en musicalité), dlna imparfait (ne reconnait pas mon serveur Qnap alors que Foobar si ???)
Delacour j.
MONOLITH M1060C Casque Fermé Planar Magnetic 90dB 18 Ohm 10Hz - 50kHz Le casque Monolith M1060C se dote de haut-parleurs planar magnetic repensés, capables de reproduire une scène sonore détaillée et précise au...
Un son de grande qualité.
La première demi heure d'écoute permet de redécouvrir les enregistrement même amateurs sur ce casque extraordinaire d'ouverture et de "spacialisation ". Contrairement au Elegia de chez Focal le son n'est pas en fermé dans la boite, et la vraie dimension des lieux de prise de son apparaît... JMD
Henri G.
Excellente alimentation
ALLO frappe fort avec cette très belle alimentation.
Dans mon système, le résultat d'écoute est bien supérieur à une alimentation iFi iPower2.
Dommage qu'il n'existe pas d'autres tensions...
Kevin G.
MINIDSP SHD STUDIO Processeur Audio Numérique DSP SHARC ADSP21486 Dirac Live Lecteur Réseau Volumio Le Studio SHD (pour  Streaming High Definition ) de MiniDSP est un Processeur Audio Numérique (DSP) embarquant la solution de correction acoustique Dirac Live. Une...
Apres avoir esseyer un open drc que l'on ma prêté, sur mon system a pavillon lecleach 53cm+ compression bms 4590 et grave de 38cm, j'ai pu expérimenter le traitement numerique pour lineariser la courbe de réponses et la phase de mon system, les résultats étaient deja exception a l'écoute, pour finir mon système avec un filtrage full numerique grave - pavillon je me suis lancé sur le shd studio avec dirac live, ce que je fesais avec rew et rephase en 1h30 (et pas parfaitement) le shd le génère de facon completement linéaire (vérifiée a la mesure) en moin de 15sec. Le tout en aes ebu diy , c'est démentiel et extrêmement efficace. A l'écoute tout prend sa place comme il se doit, les applaudissements sur les live devienne réel et ne sont plus des crépitement disgracieux. Les timbre des instruments sont respectées a la perfection, on entre vraiment dans une autre dimension d'écoute. Il sera impossible pour moi d'écouter sans mon shd. J'ai donc 2 dac, un pour la voie grave et 1 pour le medium aigu (compression coaxial avec filtre passif) on fais vraiment ce qu'on veux avec chaque registre. Je l'utilise avec un micro calibré ecm8000 behringer sans probleme. La courbe mesuré sur rew est plate et tient dans 2db de 35 a 20khz. La partie streamer volumio n'est pas exceptionnel et bien moin bon que mon lumin u1 mini twerké, mais pour 1000e on a quand meme un streamer qui fonctionne bien.
Pascal S.
IFI AUDIO GND DEFENDER Filtre d'Alimentation Secteur Boucle de Masse 90-240VAC Le iFi Audio GND Defender est un filtre d'alimentation secteur, permettant de supprimer les boucles de masse. Une boucle de masse peut créer des bourdonnements dans les...
mauvaise conception
Si votre interrupteur marche est situé au dessus de votre prise IEC dans bien des cas lorsque vous brancherez le gnd defender ou DC blocker vous ne pourrez pas l enclencher à fond car il viendra heurter l interrupteur de marche arrêt.
Prenez garde !
Dick v.
Dick Van de Merwe
The AUDIOPHONICS XMOS U208 Digital interface is top quality. I have spent a lot of money in the past, often a multiple of what the U208 costs, on functionally identical USB converters of less quality, with fewer connection options.
In that light, I can recommend the U208 very warmly. The price / quality ratio is a big 10 out of 10.
The only thing that can be said about the U208 is that it runs quite hot during operation. Make sure there is enough space around the converter.
Dirk d.
rca Rc90
j ai acheté 2 paires de ces connecteurs
les embouts sont de travers , lorsque je les connecte .
Vraiment pas esthétique .
Sans intérêt.
Fabuleux
Canare n’arrêtera pas de surprendre.
Pour 30€ avec des prises RCA elecaudio Tellurium rc85,soudure mundorff argent 10%, vous allez titiller le très haut de gamme à 3 chiffres.
Dynamique, ouverture, détail, avec les timbres réservés à l’élite des câbles comme le structura3 de chez Esprit qui est mon câble étalon a 1200€.
Ce petit Canare se rapproche de très très près dans tous les domaines.
Alors n’attendez plus pour faire plaisir à vos oreilles.
Montage avec les deux câbles blanc et bleu sur le point chaud et la tresse cuivre à la masse.
Vraiment exceptionnel.
Yannick r.
XDUOO LINK2 BAL DAC USB Amplificateur Casque Symétrique Portable 2x CS43131 32bit 384kHz DSD256 Particulièrement compact pour vous accompagner dans tous vos déplacements, le xDuoo Link2 BAL offre également de très belles performances sonores,...
Petit mais costaud!
Chanceux comme je suis, on m'a offert ce DAC portable et il a été une vraie révélation.
Pour commencer il a de la puissance à revendre, largement suffisante pour la majorité des casques (surtout en symétrique), et énormément pour la plupart des intras, je dirais même presque trop (avec des écouteurs sensibles et un câble Pentaconn vous ne dépasserez les premiers niveaux de volume sur l'appareil).
Quant au son lui-même, pour moi l'équilibre est très bon, parfait pour les écoutes dites reposantes, de la douceur dans les hautes fréquences, les graves et les médiums restent bien contrôlées.
J'ai eu un excellent combo avec des Shure Aonic 4 et l'appli mobile USB Audio Player Pro, et aussi bien avec Roon sur PC.
Eu égard au prix et aux qualités précédemment décrites, je dirais que c'est un must have si vous cherchez une solution portable intéressante.
Jean Richard L.
GUSTARD A20H DAC Full symétrique 2xAK4497 / Amplificateur casque XMOS PCM384 DSD264 Le AH20 est un DAC &  amplificateur casque complètement symétrique avec circuit de contrôle de volume à relais (hardware). Doté des...
Réception de la commande
Je viens de recevoir le Gustard A20H. Très bien emballé. Expédition rapide.
Superbe appareil et merci beaucoup.
Pour améliorer la qualité musicale d'une Box
Freebox. Bon, ok, c'est de l'informatique qui passe dedans pour mon lecteur de réseau HifiRose 250, et ça fonctionne très bien.
- "Essaie de mettre une alim linéaire de qualité pour ta box, et tu verras (écouteras en fait) le gain qualitatif".
- "Mais bien sur (gros doutes) !"
- "Je passe avec la mienne".
- "Ok"
Expérience faite, j'ai du acheter la PSU d'Audiophonics !
Si je ne m'explique pas le pourquoi c'est mieux, je constate avec évidence la très nette amélioration de "la matière sonore". Voila.
Stéphane K.
Sans intérêt
Monté avec des fiches Viborg haut de gamme plaquées argent, ce câble est gras et terne.
Après 200 h de rodage il n'y a pas eu d'amélioration. Je me suis laissé tenté suite aux différents avis très élogieux mais le résultat est très décevant.
Bande passante restreinte, beaucoup de grave mais un grave lourd, un medium/aigu mate pour ne pas dire terne …
Vraiment à éviter surtout au vu du prix qui ne justifie absolument pas son achat. Je l'ai remplacé par un Cardas Clear Power et c'est le jour et la nuit.
Certes le Cardas est beaucoup plus cher. Le Yarbo SP 1100PW était monté sur un préampli Mark Levinson 38S.
Je l'ai installé sur une alimentation Sbooster et la c'est moins mauvais. Du Furutech ou de l'Oyaide donneront des résultats bien supérieurs et ce sans forcer !
A méditer avant tout achat pour éviter de perdre du temps et de l'argent !
Fait parfaitement le taf
Souple, facile à dénuder et à monter dans des connecteurs Speakon, pas cher, en plus l'isolant extérieur a une couleur gris mat pas désagréable...
Rien de mieux à attendre d'un câble en cuivre de 2x2.5 mm² - référence adoptée !
Michel C.
IBASSO DX170 Baladeur Numérique DAP 2x CS43131 Bluetooth 5.0 aptX LDAC WiFi Android 11 Bleu iBasso propose avec son DX170 un excellent DAP audiophile. Celui-ci profite d'une conception soignée, utilisant des composants de qualité, permettant de fournir...
Cet appareil ne me convient pas.
A part avec l'application dédiée 'Mango Player', toutes les manipulations sont lentes et souvent n'aboutissent pas. Il y a beaucoup d'erreurs de lancement d'applis de streaming. J'ai un abonnement Qobuz, un Apple Music et un Amazon Music HD. Aucune de ces applis ne fonctionnent correctement. Quand elles arrivent à démarrer (les messages 'appli a cessé de fonctionner' sont constants), elles sont extrêmement lentes.
Bref, ce iBasso DX170 est, pourmoi, quasi inutilisable . Et c'est dommage parce que son appli dédiée est excellente, le son est parfait avec mon HD660S et en plus il est d'un beau bleu métallique.
Dommage, vraiment...
la dernière version de l'APK Qobuz fonctionne et Ibasso propose un firmware correctif qui corrige les soucis rencontrés avec les application de streaming les plus communes.
Henri G.
Très étonnant
Le résultat de ce "grigri" audiophile est très étonnant.
Les duretés dans l’aigu de certains enregistrements s'estompent,
La scène sonore gagne en profondeur.
L'écoute est plus apaisée, en bref plus analogique.
Associé avec des filtres secteur IFi Audio AC iPurifier, le résultat est magnifique.
Vraiment EXCELLENTS
J'ai eu une expérience malheureuse avec ces câbles branchés entre un petit dac Audio GD et mon ampli (AF 3S) et depuis ils dormaient au fond d'un tiroir. Mais je viens d'acquérir un lecteur CD (MT CD One) et par curiosité je les ai branchés entre le MT et l' AF 3S et là grosse surprise c'est vraiment excellent , une très grande transparence tout en étant chaleureux : parfait ! Et je comprends aujourd'hui qu'il faisait bien ressortir les défauts du dac Audio GD qui d'ailleurs est revendu depuis longtemps . Pour infos les fiches sont des RAMM AUDIO 30891
FX-AUDIO Adaptateur Secteur Alimentation 100-240V vers 32V 5A Cet adaptateur secteur 100-240V vers 32V 5A est conçu pour fonctionner avec les amplificateurs FDA FX AUDIO D802 et D802C.
Très bien.
Utilisé avec AIYIMA A07 Amplificateur Class D TPA3255 2x225W 4 Ohm
pour alimenter des enceintes atmos.
Fait totalement le job.
Répond à mes besoins
En remplacement d'un fxaudio indisponible, recommandé par audiophonics.
Il me sert de blocs de puissance pour alimenter des enceintes atmos.
Fait très bien le job et amplement suffisant.
Et pourtant à la base je ne suis pas du tout un aficionados de la classe D.
Je recommande pour dette utilisation.
David O.
Vraiment ravi de mon ampli. J'avais, juste avant un FX-AUDIO, (D802C) qui faisait le taf musicalement mais qui avait deux soucis, la connectique : pas de sortie Subwoofer et l'écran qui a mal vieilli et qui était illisible, à part dans le noir total... Pour mon caisson je le branchait donc en parallèle sur mes enceintes mais bon...
Là on a produit vraiment au top, je le préfère 100 fois ! Déjà la finition, l'écran magnifique à côté de mon D802C. Couleurs personnalisable, dimmer automatique ou non, sortie Sub, et SURTOUT plus progessif niveau volume. Dans mon cas je suis branché en USB sur mon PC (donc en système 2.1 caisson Magnat et enceintes maison) Avec le FX-AUDIO, avant, même volume à 1 c'était trop fort une fois tout le monde couché, mon PC étant sur le palier devant les chambres... C'était tout ou rien, à moins de me brancher en analogique mais cela n'aurait aucun intérêt. Là je trouve un volume progressif parfait sur ce LOXJIE. Franchement, pour 30€ c'est le jour et la nuit.
Il faut lui laisser quelques jours de rodage et après résultats est la : fond noir grande ouverte beaux médium timbre parfait et basses aussi
C'est le transport reclocker du moment
Dirk d.
MOONDROP DAWN 3.5mm Amplificateur Casque DAC Portable 2x CS43131 32bit 768kHz DSD256 Avec le Dawn 3.5mm, Moondrop dévoile un combo amplificateur casque et DAC portable performant et abordable. Celui-ci embarque, dans un châssis en aluminium, deux...
que dire...sur ce produit
la finition pas terrible
je pense pouvoir faire mieux au niveau des soudures
les filles sont jaunis par la chaleur des soudures
je ne suis pas sur de la fiabilité niveau connectique
mais ca reste mon avis
par contre point de vue puissance , il envoie
j ai été impressionné de ce qu il peut délivré , et il reste très correcte sur la qualité de restitution j ai plusieurs dac vraiment plus chère , il faut être difficile pour voir la différence.
Mit l ampleur un peut fade, le reste est très correcte .
j ai mis 3 Etoiles non pas pour le son mais la finition .
A ce prix je ne pense pas trouvé mieux .
bref pour moi très bon produit .
Je ne regrette vraiment pas cette achat .
Jean Michel P.
Excellente fiche banane
Ayant acheté ces très bonnes fiches bananes il y a quelque temps que j'utilisais en vissant mon câble hp de faible diamètre elles se sont révélées encore meilleures en soudant le câble ( échancrure prévue) .
Les timbres sont parfaits et beaucoup de raffinement dans les aigus.
A recommander sans aucune hésitation
Un gain indiscutable.
Il faut vraiment commencer par cette prise.
efficace
Utilisé sur la face arrière de mon alimentation séparée de mon ampli ou se situe toutes les prises . L’écoute s'est apaisée et la fréquence grave s'est amplifiée . Deuxième essai sur la face de la barrette secteur côté des prises uniquement . La scène sonore s'élargit . Dans ces deux cas j'ai finalement utilisé peu d'isolant pour un résultat audible . Appliquer au fur et à mesure en fonction du résultat d'écoute désiré . Ne pas mettre trop d'isolant du premier coup qui pourrait nuire à l'écoute ; à vous de trouver le bon équilibre .
johnny b.
TOPPING E30 II DAC 2x AK4493S XMOS XU208 32bit 768kHz DSD512 Noir Topping revient avec le DAC compact E30 II, véritable évolution de l'excellent E30, présentant de nombreuses améliorations techniques permettant...
Topping e30 ii
Top 100%
Philippe A.
IFI AUDIO IPOWER X Adaptateur Secteur Alimentation Faible Bruit 12V 2A iFi Audio propose avec son adaptateur secteur iPower X une alimentation très faible bruit, destinée à alimenter proprement vos modules et appareils HiFi,...
bon matos
très bonne alimentation, très silencieuse, dommage les leds blanches qui s'allument en permanence en utilisation. je ne regrette absolument pas mon achat.
Fonz V.
Great Power Supply. Great Service
Thanks Audiophonics for the great service and quick delivery of the Power Supply. It's a perfect combo with the Intel NUC and Roon Rock. The power amp does not get warm at all. Sound has more detail and a more relaxed bass. Only minor thing to me is that the red light at the front is 2 strong for my taste.
Jochen B.
A really good bang for the buck
I'm using these tweeters for about 2.5 years now in my active 2.5-way floorstanders. They take over at 3000hz with a brickwall from a Gradient W 130 AL8 and I have nothing to complain. I like the sound and they are very robust.
Clive S.
IAN CANADA UCPI 2025 Module d'Alimentation à Supercondensateurs pour Raspberry Pi Le UcPi 2025 de Ian Canada est un module d'alimentation 5V à supercondensateurs haute performance et abordable, conçu spécifiquement pour les applications...
Great product. I installed it under my raspberry pi. Installation was quick and easy I have a few speaker spikes keeping it off the table. I have a audioquest dragonfly red connected to the pi and what can I say. The bass has increased and it's tighter more accurate. The sound stage has widened everything just sounds better. Ian Canada sure knows his stuff.
Luka C.
MUNDORF MLYTIC AG Condensateur 63V 22000µF Ces condensateurs ont été spécialement développés pour les amplificateurs de petite puissance ou les préamplificateurs. Ce nouveau...
MUNDORF MLYTIC AG Capacitor 63V 22000μF
I order 2 of Mundorf Mlytic AG Cap
1 Cap Measurement:
Vloss=4.9%, Capacity=22.73mF, ESR=0.09 ohms
2 Cap Measurement:
Vloss=4.9%, Capacity=22.67mF, ESR=0.09 ohms
Quality 10/10
Product 10/10
VINCENT D.
NEUTRIK NADITBNC-MX Transformateur d'Impédance XLR AES/EBU 110 Ohm Mâle / BNC 75 Ohm Femelle Cet adaptateur numérique se compose d'un connecteur BNC 75Ω femelle et d'un XLR 110Ω mâle. Il permet d'installer des câbles de grande longueur via une ligne...
Placé en entrée AES/SPDIF d'un DAC Dangerous Source et connecté à un lecteur CD mécanique Teac via un CANARE Câble numérique coaxial 75ohm BNC-RCA 0.5m. Ainsi l'impédance est respectée en entrée du DAC. Respect du signal ce qui améliore le rendu global.
Comme toujours, livraison ultra rapide de Audiophonics. Merci.
TINYSINE TSA7500B Module Amplificateur 2.1 TPA3221 Bluetooth aptX 2x100W + 200W Le TinySine TSA7500B est un module amplificateur 2.1 en Class D, embarquant une puce d'amplification TPA3221, capable de délivrer une puissance conséquente de...
le ventilo souffle en permanence
... meme a très faible puissance et le bruit devient gênant. Comme amelioration j'ai intégré un bilame 45° collé a la pate thermique sous la carte + inséré depuis le bornier d'alimentation du ventilo. Ca fonctionne correctement. Je verrai a l'usage...
