Sandy G.
EXCELLENTE REVELATION.
Je l'utilise avec ROSE RS 150 B en mode drive , ou avec mon 3D NANO LAB PLAYER SIGNATURE' en mode drive lui aussi....
Denis K.
Très bon!
Un son de très bon niveau dans un tout petit boitier!
La clarté de la reproduction sonore est épatante pour le prix de cet...
Gerrit G.
Very good DAC , BUT .....!
The USB A to C cable that comes with it is only good for powering the davice , not for data transfer . If used for data ,...
Avis clients - Il y a 19040 avis.
Eemeli T.
DYNAVOX SDS4 Absorbeurs de Vibrations Aluminium / Silicone 40 x 18mm Noir (Set x4) Ce lot de 4 pieds SDS4 de Dynavox pour appareils Hifi et enceintes permet d'absorber efficacement les vibrations de vos équipements. Ils sont composés d'un patin...
Cannot withstand 10kg/absorber as promised
The described max load of 10kg per pad is nowhere near these absorbers can handle (40kg total). Under a combined weight of just 18kg which is 4,5kg per pad the absorbers lose practically all of the absorbing capability as they bottom out. They work fine with a load of about 2,5-3kg/pad, no more. So do not try to use these under an equipment weighting more than about 12kg total. I bought these to be fitted under my BKE XLS200 mk2 subwoofer which weights about 18 kilograms and they were useless - all of the vibrations were conducted directly to the floor and I had to replace them with my old Norstone absorbers.
Afterwards I installed Dynavox SDS4 absorbers to my gaming set, under a small Audio Pro Subsoniq subwoofer weighting 10kg at which they work adequately and as promised absorbing the vibrations efficiently.
Sergio N.
NEOTECH NES-3004 MK2 Câble HP Cuivre UP-OCC plaqué Argent 8x1.3mm² Ø13mm Ce câble d'enceintes Neotech est doté d'une architecture 8 cœurs de type  StarQuad  avec isolation centrale permettant d'abaisser l'effet capacitif....
Best copper cable
Naturalness is its strenght, a champion of balance and dynamism
Sergio N.
SMSL SH-8S Amplificateur Casque Symétrique OPA564 2x6W 16Ω SMSL propose avec son SMSL SH-8s un amplificateur casque abordable et efficace. Il utilise des AOP OPA564 pour délivrer, avec une grande précision, une puissance...
Exceptional amplifier
Powerful refined, infinite details
IFI HDMI ISILENCER Suppresseur de Bruit EMI HDMI Femelle vers HDMI Mâle Le HDMI iSilencer de iFi Audio est un filtre HDMI ayant pour but de réduire le bruit et le jitter de votre signal et de protéger vos équipements d’une...
un plus en image et son
Bonsoir , j ai mis IFI hdmi isilencer sur mon plasma via wireworld sphere , j ai remarqué que je gagne un peu en chaleur , largeur du son et l image est plus contrastée ,un poil plus de relief ,il y a des petits gains mais c est toujours bon a prendre . Franck
Renaldo V.
Celestion SL6
Merci à Auphonics pour leur rapidité à traiter les commandes.
J'ai choisi les condensateurs ANTZEN AUDIO STANDARD Z-CAP pour mettre à jour mes enceintes Celestion SL6. Ils s'intègrent parfaitement dans le filtre, et le résultat est à la hauteur de mes attentes. Je retrouve pleinement la signature sonore caractéristique des SL6.
Renaldo V.
Celestion SL6
Renaldo V.
Celestion SL6
David n.
AUDIOPHONICS Câble d'Alimentation Jack DC 5.5/2.1mm vers GX16 Cuivre OFC pour Alimentations Audiophonics LPSU100 1m Ce câble d'alimentation Audiophonics, assemblé en France dans nos ateliers, se compose d'une part d'un connecteur Jack DC 5.5/2.1mm et d'autre part d'un connecteur...
La différence est sensible par rapport au câble d'origine de l'alimentation linéaire 12V.
Meilleure qualité apparente et contacts parfaits.
Une meilleure définition générale et une image stéréo plus ample et étagée.
Yoann L.
Adaptateur Convertisseur SPDIF Optique Toslink/Coaxial vers Toslink/Coaxial Pratique, ce petit convertisseur permet de transformer un signal audio SPDIF optique Toslink en coaxial, et inversement. Il supporte les technologies Dolby, DTS, AAC et PCM...
Fonctionne parfaitement entre une vieille TV qui sort en coaxial et une entrée spdif sur un WiiM pro plus.
Mickael L.
Merci à audiophonics pour les conseils sur le choix des tubes.
A tout possesseur d'ampli pier audio ms88se, je vous conseille le changement des tubes sans attendre qu'ils soient à changer c'est vraiment un nouvel ampli dans cette configuration.
Très content du résultat.
Hocine H.
RAMM AUDIO ELITE 8 Câble de Modulation Cuivre OCC Triple Blindage Ø9,2mm Le Elite8 de Ramm Audio est conçu pour offrir la meilleure connexion analogique possible afin de préserver l'intégrité du signal transmit. Le...
Super câble
Je l'ai acheté sur les avis et je comprends pourquoi tous sont unanimes sur ce câble.
Il est déjà de très bonne qualité, quoi que un peu bling bling avec sa gaine dorée. Il n'est pas simple à dénuder, il faut de la patience car chaque conducteurs est composé de 3 brins de cuivre qui sont eux-même blindés et enroulés dans du coton. Pour le coup, la protection est poussée à l'extrême.
Un petit détail que j'ai vraiment apprécié; c'est quand on prépare des câbles de modulation en symétrique, le point chaud et la masse sont inversés entre mâle/femelle ; Ici les connecteurs sont placés directement pour accueillir le mâle et la femelle, pas besoin de tortiller le conducteur pour pouvoir souder, c'est du génie, le soucis du détail.
Quant au son, il limpide, neutre, précis, ce que je recherchais avec beaucoup de dynamique, ce câble remplace un câble pur argent, mais je l'ai connecté avec des VIBORG pur argent et c'est du bonheur. J'ai enfin trouvé mon câble de référence.
Hocine H.
VIBORG XF203AG Connecteur XLR Femelle Argent Pur PTFE Ø11mm Noir (Unité) Le XM203AG de Viborg est un connecteur XLR femelle haut de gamme, utilisant des contacts en argent pur afin de fournir une conductivité maximale. Il intègre...
Connecteur de grande qualité avec une bague de serrage qui sert vraiment, de ce fait le câble ne bouge plus. De plus la soudure adhère immédiatement sur les pins, chose très appréciable et quant à la qualité sonore, un super son fluide, précis, harmonieux. N'hésitez pas à ce prix, il n'y a pas plétore de connecteurs valables et c'est bien dommage.
Stefano D.
AUDIOPHONICS U-SABRE PRO DAC USB 32Bit/384kHz SA9227 / ES9018K2M OTG TCXO Le fameux DAC Audiophonics U-SABRE évolue en version PRO, avec une mise à jour de ses composants principaux. Le décodage se fait maintenant grâce...
Essenziale e molto dettagliato
circuito essenziale con DAC slave, viene immediatamente riconosciuto dal PC e da' il meglio se lasciato in configurazione 32 bit. Dettagliato e dinamico, l' ho installato direttamente in ingresso all' amplificatore gainclone e casse autocostruite. Si tratta di un componente con caratteristiche Hi-end al prezzo di un componente consumer
philippe C.
Audible
Utiliser cette soudure est clairement "audible". Comme d'habitude Audiophonics a été impeccable dans la gestion de ma commande pourtant compliquée car plein de petits objets de montage pour connectique. Que ferait on sans eux en France ? Pourquoi ne pas leur dédier le cabinet du Ministère des mélomanes...
philippe C.
LETSHUOER S08 Écouteurs Intra-Auriculaires IEM Planar Magnetic 26Ω 105dB 20Hz-40kHz Noir Les écouteurs intra-auriculaires Letshuoer S08 sont des IEM planar magnetic. Ils profitent d'une conception de qualité avec un diaphragme planar magnetic custom de...
Très bon Iem. J'aime la sonorité des membranes "planaires". Dans tous les cas : panneaux, casques, ou intras. D'aucun se plaignent d'un manque de grave et d'infra grave... ce n'est pas le cas ici. C'est petit bijou dédié aux mélomanes nomades et il est magnifiquement dessiné et la finition est parfaite.
J'aime bien...
Bertrand T.
FX-AUDIO D01 DAC Amplificateur Casque Bluetooth 5.0 ES9038Q2M TPA6120A2 XMOS CSR8675 32bit 768kHz DSD512 Intégrant une excellente puce de conversion numérique / analogique ES9038Q2M 32bit, le DAC FX-Audio D01 offre d'excellentes performances audio, avec une importante...
FX-Audio ampli pour casque
Décidément une marque offrant des produits avec un rapport qualité/prix déroutant. J'utilise un ampli de cette marque depuis 2017 pour mon streaming Qobuz et mes B&W. Très content
Tres bon amortisseur
Tres bon amortisseur mais pour des appareils assez legers.
Je les ai installes sous un DAC SMSL
Marian U.
DENAFRIPS HADES 12TH Préamplificateur Symétrique Discret Pure Class A Argent Élevez votre expérience audio avec le préamplificateur Denafrips Hades, un chef-d'oeuvre né d'un dévouement sans compromis à la...
Very nice
Love this piece, I have with Pontus 15th, best match
Marian U.
DENAFRIPS PONTUS 15TH DAC R2R NOS Symétrique 1536kHz DSD1024 Argent Le DAC NOS R2R symétrique double mono Denafrips Pontus 15Th représente une excellente solution de conversion numérique/analogique high-end, offrant des...
Wow
Beautiful sound, love it!
pascal v.
excellent pour le prix
Câble Nexans titanex utilisé pour alimenter et recabler une multiprise diy . Grave et spatialisation bien meilleur que le câblage d'origine. Monté avec schuko Bals et gaine elecaudio vipera. Excellent rapport qualité prix
Jerome A.
AUDALYTIC AH90 DAC AK4499EX XMOS XU316 LAN UPnP Roon 32bit 768kHz DSD512 MQA Noir Le Audalytic AH90 est un DAC proposant d'excellentes performances de décodage et une restitution sonore précise grâce à une conception soignée...
Complet et sobre
Ce dac ne fait pas dans l'esbroufe, aucune option inutile, très sobre, l'écran est petit, pas très lumineux, limite triste.
Pas très grave pour moi, car je n'aime pas ces petits écrans quand j'écoute de la musique, d'ailleurs j'ai activé la fonction qui l'éteint après 30 secondes sans activité.
Il reste donc que le voyant en façade, qui est aussi le bouton tactile pour l'allumer/l'éteindre, mais ce dernier ne change pas d'apparence si allumé ou éteint, stupide.
Il m'arrive donc de l'éteindre en voulant l'allumer... ou l'inverse.
On n'achète pas ce dac pour son physique, mais pour ses caractéristiques, et là, il est bien placé.
Je ne rentre pas dans le délire des puces, chacun fait son choix.
Ce dac contient une partie amplification casque, avec 2 sorties, très pratique, des sorties asymétrique & symétriques, nombreuses entrées dont une prise RJ45 pour le streamer, ce qui, pour moi est l'élément déclencheur de l'achat.
Compatible ROON, reconnu immédiatement, c'est parfait.
Toutefois, bien penser à mettre à jour le firmware (assez simple comme opération) sans quoi, le DAC génère une nouvelle adresse mac à chaque allumage, engendrant parfois des conflits d'adresse IP sur votre réseau.
Là encore, étrange, on peut trouver le firmware sur un forum "Head-fi", mais pas sur le site officiel de la marque.
Ce dac est donc à destination des utilisateurs qui recherchent un produit performant sans options inutiles et vu-mètre multi-couleurs, au rapport qualité prix excellent.
Thierry S.
JANTZEN AUDIO SUPERIOR Z-CAP Condensateur 800V 3.3µF La gamme Superior Z-Cap de chez Jantzen Audio se compose de condensateurs non polarisés haut de gamme, conçus spécialement pour l'audio afin de permettra...
étonnant
montés sur des klipsch rb81mk2. derrière un cayin cs 55 KT88
tout de suite on perçoit une image, notamment sur les voix et bien sur avec un bon enregistrement.
aigus très maitrisés mais bien présents et délicats.
un poil trop à mon goût, ça entraine une petite perte de détails fins. je testerai bien les silver de la même marque.
Le plus étonnant est que au bout de 10 h ou plus, le grave remonte de façon spectaculaire. j'ai l'impression d'avoir changé les boomers.
c'est d'autant plus surprenant que ces 3.3 sont sur les tweeters.
D'enceintes plutôt braillardes on passe à du très propre et même beau par moment, en tout cas bien meilleur que l'origine et en plus insaturable. bien sûr vu la taille, ils sont à l'extérieur sur le bornier juste sous les dernières fiches, il y a un peu de place dans l’arrondis.
Jacques T.
FOSI AUDIO BOX X2 Préamplificateur Phono MM à Tubes 2x6A2 Stéréo Noir Avec son préamplificateur à tube BOX X2 Fosi Audio dévoile un appareil Hifi abordable et qualitatif pour les personnes désirant profiter du...
Bon préamplificateur phono
C'est par curiosité que j'ai essayé ce petit préamplificateur .
Le résultat est vraiment étonnant compte tenu se son tarif plus que raisonnable.
Sans le modifier pour le moment, le son est déjà excellent, je le teste avec une Thorens TD 125 MK2 équipée d'une cellule Stanton 681 EEE avec un diamant Jico et la comparaison avec des préamplificateur 10 à 15 fois plus cher est étonnante : pas de souffle, une correction riaa stable et une dynamique superbe.
Cerise sur le gâteau il m'a été fourni avec des tubes Ge 5654w de très bonne qualité.
Je recommande fortement ce produit d'un rapport qualité prix imbattable (réservé bien sur aux cellules MM, on ne peut pas tout avoir).
Jacques
Theodore A.
AUDIO-GD DA-7 MKI 2023 Module DAC R2R 24Bit 384kHz Le module DA-7 MKI 2023 de chez Audio-GD embarque un DAC 24 bit basé sur réseau de résistances. Il profite de tout le savoir-faire...
amazing
I built my own DAC based on this. It is an amazing piece, worthing every penny... If you can built a DAC use this R2R, unbeatable for price
Eric E.
whouaou
Je dois utiliser une rallonge pour alimenter mon système qui se trouve au tiers/centre d’une grande pièce. J’utilisais une vulgaire rallonge parce que j’ai toujours douté de l’intérêt de soigner l’alimentation. C’était une erreur, énorme erreur.
Le son de mon système était étriqué, la musique semblait comprimée dans deux boites distinctes et je croyais, à tort, que le problème venait de mes vieilles Infinity, dinosaures âgés de 45 ans, elles vont parfaitement bien en réalité - je me contenterai de nettoyer les potards et changer deux électrolytiques connus pour mal vieillir.
À force d’entendre parler de câbles d’alimentation je me décide enfin en me disant que pour 100€ le risque est limité. Donc je fabrique une rallonge avec Tornado et des prises Elecaudio, je rebranche mon système et... je reçois une grosse claque. Les améliorations sont spectaculaires, le terme n’est pas exagéré. D’abord je suis frappé par le volume qui semble avoir monté de plusieurs crans, puis par les basses propres, précises, naturelles, les voix charnelles, la douceur lumineuse des aigus, puis par l’image sonore large, profonde, limpide avec des plans sonores parfaitement lisibles. Ensuite je constate que mes enceintes s’effacent complètement derrière la musique qui se forme autour d’elles, enfin je découvre des finesses et des détails que j'ignorais. Ce n’est pas un effet placebo, les améliorations sont très sensibles et ma chère moitié les a elle aussi perçues spontanément. Avec quelques heures de rodage une ouverture lumineuse est venue couronner l’ensemble. Je suis comblé et je dois avouer que la redécouverte de certains enregistrements m’a… plus que troublé.
Évidemment je suis impatient de remplacer mes autres câbles d’alimentation. Il me semble que j'ai fait l'inverse de ce qu'il fallait faire, aujourd’hui je dirais qu’il faut commencer par fignoler l’alimentation et s’occuper du reste après. Oui, je suis désormais convaincu que les câbles source et HP ne viennent qu'après.
Il s’agissait de ma treizième commande, je félicite Audiophonics pour la qualité de son offre et l’infaillibilité de son service expédition.
Elom G.
TI LME49720NA/NOPB Amplificateur Opérationnel AOP Class AB 2 Canaux DIP8 (Unité) Le Texas Instruments LME49720NA/NOPB est un amplificateur opérationnel (AOP) hautes performances 2 canaux, fonctionnant en Class AB et intégré dans un...
Je suis d'accord les avis précédents. Bon aop bien équilibré. Mais le rendu manque un peu de corps; la musique semble "dégraissée". Avec une très bonne dynamique, presque trop.
Finalement, je ne recommande pas vraiment cet aop
Elom G.
CWC1 Pince 2 en 1 pour Couper / Dénuder Cette pince 2 en 1 CWC1 se dote de 2 fonctions. En effet elle vous permettra de couper et dénuder des câbles. De bonne qualité cette...
Elom G.
NJR MUSES8820 AOP Double DIP8 (Unité) L'AOP MUSES8820 à été développé par le constructeur spécialiste NJR. Il s'agit d'un amplificateur opérationnel optimisé...
Très bon aop, avec le son muse; j'aime beaucoup ! Très bon rapport qualité prix. Peut paraitre un peu brouillon dans le bas, suivant les systèmes, mais il reste vraiment très bon.
Je recommande !
Elom G.
Bon Aop
bon aop, bien équilibré. pas grand chose à lui reprocher, même si finalement je préfère lui le muse ou le burr Brown
Jaring B.
LT3045 Régulateur de Tension Linéaire 12V Le régulateur de tension linéaire LT3045 offre d'excellentes performances et est idéal dans des intégrations HiFi, permettant de fournir aux circuits...
LT3045 didn't deliver for me
My Netgear GS308 switch is quite sensitive for the 12V power it receives. I already improved the sound quality significantly by going from an L7812 to a LM1085 voltage regulator. I read that the LT3045 is much quieter in terms of noise, as such I wanted to try it out on my switch. The results however are disappointing, as it lacks musicality in the sound. It costs 15 euro, which is 10 times higher than a LM1085 and it didn't deliver for me.
Nikos Z.
SOVTEK 12AX7WA / 7025 Tube Double Triode (Unité) Ce tube double triode Sovtek 12AX7WA/7025 à faible gain et microphonie extrêmement basse est idéal pour le remplacement d'un tube type 12AX7/ECC83, ou dans...
Order Detail N°479896 - 2024-10-28
Je les ai reçus le 11/04/2024 17.20
Merci.
Fabrice L.
TRIANGLE OPERA OS100C Câble Haut-Parleur Cuivre OFC 2x2.5mm² Développé par Triangle, les câbles pour haut-parleurs Opéra garantissent une excellente qualité de transmission du signal électrique....
Le cable équilibré
Pour un besoin de longueur 2× 10m, j'ai opté pour ce cable Triangle au prix contenu.
Choix judicieux, ce cable ne favorise aucun registre et respecte la musique dans toutes ses nuances.
De plus pas de "rodage" particulier, sa qualité s'exprime dès la 1ere mise en place.
Equivalent d'un Sommercable Magellan qui est une de mes références à prix doux.
Patrick D.
FOSI AUDIO ZD3 DAC ES9039Q2M Bluetooth 5.0 32bit 768kHz DSD512 Le ZD3 de Fosi Audio est un DAC symétrique possédant une excellente connectivité grâce à ses multiples entrées et à sa puce...
Une reussite
Connecté par câbles XLR à un ampli ZA3, et relié en optique à mon Yamaha WXC-50, en coaxial à un lecteur de Blu-ray Sony et en hdml arc à un téléviseur Samsung, ce Dac ZD3 joue les chefs d’orchestre avec une redoutable efficacité. Mes enceintes JMR Folia jubilé (4ohm) restituent un son à la fois précis, légèrement chaud avec des aigus sans aucune agressivité. Hauts et bas Médiums sont superbes et très bien équilibrés. Les basses n’en font pas trop et sont bien contrôlées. Bref que du bon. Le Dac apporte de la précision à ce petit système tout en restant très musical. Cette nouvelle puce ESS 9039 est une réussite quelque soit l’entrée utilisée.
A ce prix c’est vraiment une affaire.
Yannick r.
THIEAUDIO HYPE 4 Écouteurs Intra-Auriculaires IEM Dynamique 17 Ohm 105dB 10-22kHz Noir Thieaudio nous propose ici la nouvelle mouture de leur série d'écouteurs intra-auriculaires HYPE (pour Hybrid Performance): les HYPE 4. Avec ce nouveau...
Tremblez les IEM haut de gamme!
Après des mois d'écoutes quasi quotidiennes, je pense avoir pu jauger ces petites bestioles.
Pour ce qui est de l'apparence, chacun se fera son idée, pour ma part je les trouve très sympas, même si je préfère le look des modèles Oracle de la marque.
Pour l'ergonomie, rien à dire ça se positionne parfaitement dans l'oreille, et l'isolation est de premier ordre.
Pour les embouts, je ne peux pas trop dire, je suis vite passé à des SpinFit, l'idéal niveau confort pour moi.
Quant au plus important, à savoir le rendu sonore, eh bien j'en espérais beaucoup, mais pas tant quand même.
En effet, étant mon premier achat chez Thieaudio, j'ai pu comprendre pourquoi certains ne tarissent pas d'éloges à leur propos.
Il ne manque rien, même la scène sonore est plutôt spacieuse pour des intras (j'ai déjà pu tester des Astell&Kern Aura).
Les fréquences graves sont à l'honneur, mais tout en précision, pas de boum boum excessif ici, et le reste du spectre est à l'avenant.
En somme l'équilibre est pour moi remarquable, ce qui rend ces Hype 4 très versatiles.
C'est bien simple, mon Ananda Stealth Magnets, que j'adore pourtant, est en sommeil cryogénique.
Ils consomment un mariage réussi avec le DAC portable iBasso DC07 Pro, j'ai d'ailleurs posté un avis directement sur leur page.
Je ne peux les recommander chaudement, surtout si vous êtes restreints dans cette gamme de prix.
Yannick r.
IBASSO DC07PRO DAC Amplificateur Casque Portable Symétrique 4x CS43131 32bit 768kHz DSD512 Noir Le DC07Pro est la nouvelle version du DAC portable / amplificateur casque de iBasso. Cet appareil compact est équipé de quatre puces CS43131 ainsi que d’un...
Un petit DAC peut en cacher un grand...
Voulant un convertisseur transportable, mais quand même de qualité, j'ai tenté ma chance avec cet iBasso.
J'avais bien aimé le son du DC03, regrettant juste le câble non amovible, qui a du coup lâché.
Ici ce n'est plus un problème, mais c'est loin d'être le seul avantage.
En effet, le son produit par ce petit appareil, en association avec une paire de Hype 4, est complètement hors norme.
Déjà la puissance disponible est bien plus grande qu'il n'y paraît, c'est très confortable en fonction des enregistrements.
Mais surtout, la qualité perçue est immense, et ce quel que soit le style de musique écouté.
Branché sur un OnePlus 11 avec l'application USB Audio Player Pro (réechantillonnage activé), ça marche de manière divine.
Le grave s'exprime à merveille, les voix sont parfaitement claires et les aigus présents mais soyeux.
A l'arrivée ce DC07 Pro est un investissement minime vis-à-vis du résultat obtenu.
Je vais quand même tester son grand frère le DC Elite, mais je ne serai pas surpris si le gap n'est pas si important, malgré la différence de prix.
Je peux donc vous le dire, vous pouvez y aller les yeux fermés, vous risquez surtout d'être étonnés.
Rikard C.
TOPPING MX3S Amplificateur Class D Infineon Amplificateur Casque DAC Bluetooth aptX Adaptive 2x50W 4 Ohm 24bit 192kHz Argent Véritable couteau-suisse de l'audio, le Topping MX3S endosse à la fois les fonctions d'amplificateur Class D et amplificateur casque avec DAC AK4377 et...
My travel partner
Works fine and this is my travel partner, used with a pair of Ino Audio piXM.
The only issue I have is the low level of amplifying when running blue tooth from my Android. When serving by USB-C from Android one gets much more power out and far better sound as well.
Manuel P.
XANGSANE XS-A012 Pieds Aluminium avec Pointe de Découplage Cuivre 44.5x34.5mm Noir (Set x4) Les pieds en aluminium XS-A012 de Xangsane intègrent une pointe de découplage réglable en cuivre pur. Ils permettent une absorption des vibrations et des...
Meilleure définition, basses plus propres ...
Ma recommandation : avant tout investissement significatif et changement intempestif (voire maladif) de matériel, découplez donc vos enceintes et appareils avec ces pointes de découplage ...
SINGXER SDA-6 PRO2 DAC Symétrique 2x AK4499EX AK4118 FPGA XMOS I2S LVDS 32bit 768kHz DSD512 Le SDA-6 PRO2 de Singxer, seconde version du SDA-6 PRO, est un DAC symétrique haute fidélité. Il présente de nombreuses améliorations par...
Très belle qualité, son excellent pour ce prix.
Branché sur un PC HDG générant des interférences sur tous les autres DAC testés, ici, l'entré USB est filtrée admirablement.
Mathieu N.
XANGSANE XS-6001AU Connecteurs RCA Plaqué Argent Ø8.5mm (Set x4) Ces  connecteurs RCA XS-6001AU  de la marque  Xangsane  sont des connecteurs de très bonne qualité. Les contacts sont faits d'alliage...
Superbe Fiche RCA
Très bonne fiches RCA, meilleur que les viborg VR105S en comparaison. Meilleures Sonorité,plus dynamique, et une meilleur ouverture sonore. Simple à souder. Fiche très haut de gamme pour un prix très modérer.
Elom G.
BURR BROWN OPA2604AP AOP Double DIP8 (Unité) L' OPA2604AP est un AOP qui combine la précision et le faible bruit de transistors bipolaires avec la vitesse et la qualité sonore des JFETs. Cela permet...
Edit avis du 12/10/2024
Après une écoute prolongée et le test de plusieurs aop, je reviens sur mon avis du 12/10/2024.
Cet aop est très équilibré: des graves propres et bien tenus; les aigus sont clairs et doux. Le rendu global est équilibré, clair et doux; plutôt musical et pas fatigant.
Je recommande vivement cet aop; en tout cas dans ma configuration, c'est un vrai bonheur: ampli Fosi v3 et enceintes Monitor Audio Bronze 6.
ENDRE A.
IAN CANADA TRANSPORTPI DIGI II Module Interface Audio Numérique Ultra Faible Jitter Avec le TransportPi Digi II, Ian Canada nous propose une belle évolution de leur interface audio numérique tout-en-un haute performance pour Raspberry Pi. Ce...
Very good for streaming with RPI
Compared to Ifi Zen Stream on coaxial output is more focused and the vocals timbre is more realistic. Amazing sound, relaxed, natural with a lot of detail. Highly Recomended!
Très bien.
Super tubes 6922, meilleurs que les JJ ou les Sovtek.
Au-dessus il y a les Philips SQ (Spécial Quality) mais ce n'est pas le même prix !
Livraison éclair, merci Audiophonics.
Arnas K.
AUDIOPHONICS OBSIDIAN Câble Secteur Schuko vers IEC C15 Cuivre 102SSC Argent 1.5m Nous vous proposons ici le câble d'alimentation Audiophonics Obsidian, conçu et assemblé à la main dans notre atelier en France. Modèle haut de...
Bravo Audiophonics team!!!
Just got this.
1st impressions: Very luxurious and beautiful looking cable! Build quality seems fantastic and it is quite flexible! I expected more stiff cable, but this one seems very flexible for a large power cable which makes me super super happy :) .
I never had aftermarket cable so i thought i should get 1 high end cable in my lifetime for my dac.
I use it with Topping DX9, but i only have stock cables for my Genelec 8351b since i dont want go into the rabbit hole, dont want to buy expensive cable for speakers also.
I expected tiny difference, but i feel that there is a quite a noticable difference in sound quality.
It seems like there is massive drop in noise which makes everything more dynamic, wide, not to mention that everything sounds more 3rd
Im very happy with my purchase, there is a reason why im 2 hours late to the gym:) Well done guys!
P.S special thanks Clement Narolles for staying patient with me and guiding me.
David T.
Je possède cet appareil depuis plus de deux mois, le son est fabuleux sur toute la bande passante, ce n est pas pas un peu mieux dans les aigus ou autre, mais sur tout le signal sonore.
100 heures de rodage sera nécessaire,
Class A , class ab et les tubes se sont fait dépasser par la class D.
Laurent M.
Un de mes préférés.
Ce câble est pour moi une référence à son prix.
On sent qu'il y a une grande maîtrise sur le médium aigu.
C'est doux , ça "chante " bien , une écoute posée avec une dynamique bien gérée.
On peut écouter des heures sans fatigue contrairement à beaucoup de références .
Si Furutech est connu pour certains produits high end je trouve que leurs câbles au mètre sont très aboutis.
Sur ce modèle j'ai branché les fils des blindages sur la masse phono de mon ampli.
Laurent M.
NEOTECH NES-5005 Câble Haut-Parleur Cuivre UP-OFC 2x2.5mm² La gamme NES-5000 de Neotech intègre des câble à conducteurs Cuivre Ultra Pur UP-OFC tout en assurant un prix abordable. Dans cet esprit, le NES-5005 va...
Un must
Essayé sur divers systèmes ça reste cohérent, souple .
Rien n'est ostentatoire ou projeté.
On peut aller plus loin en terme de transparence mais à 4€ le mètre, je le trouve supérieur en matière de timbres et d'équilibre à la plupart des câbles jusqu'à 5 fois son prix voire plus.
Laurent M.
Punchy
Assez spectaculaire avec un grave percutant et des aigus brillants et soyeux.
Il fera l'affaire pour réveiller un système anémique.
Genre petit Nad 328 sur de petites enceintes.
Ensuite sur un ampli puissant et des colonnes ça risque d'être lourd.
Je préfère à ce titre le Neotech 5005 qui est remarquable de cohérence avec une écoute plus décontractée.
Roberto G.
XDUOO TA-26S Amplificateur Casque symétrique / Préamplificateur à Tubes 6N8P 6N5P Le TA-26S de xDuoo est un amplificateur casque à tubes, profitant d'une belle conception permettant de dévoiler un son à la fois, doux, chaud et...
Le son et l’esthétique !
Je connaissais déjà, depuis plusieurs années, le très joli petit ampli xDuoo TA-02 d’excellente qualité. J’avais changé les tubes pour une amélioration sonore et j’écoute encore de la musique avec lui de temps à autre.
Avec le xDuoo TA-26S c’est un peu un autre monde. L’ampli est lourd et de belle dimension. Construction sérieuse, aucune radiation autour de l’ampli. La dimension des tubes, la couleur grise légèrement métallisée et le bouton rouge ajoutent quelques touches particulières à une esthétique classique revisitée. Un design à la fois épuré et industriel. La sonorité est légèrement chaude (plus ample et chaude que sur le TA-02) comme on pourrait l’attendre d’un ampli à tubes mais sans excès. Tout le spectre est bien représenté et équilibré. Belles basses, beaux médiums, des aigus fins et détaillés. De toute évidence, sans dureté ou acidité avec une voix de soprano, un violon ou une trompette mais sans douceur excessive non plus.
Pour l’instant, j’ai associé l’ampli xDuoo TA-26S à un lecteur Denon DCD-1700NE afin d’écouter une collection de CD et SACD. Après avoir essayé divers câbles d’alimentation, Isotek, Supra, Silent Wire, j’ai choisi les câbles Isotek, très bien sur le lecteur et l’ampli casque. J’ai essayé aussi divers câbles RCA, Canare, Atlas, Gotham GAC 4/1. Finalement, j’ai installé un Sommercable Epilogue parfaitement équilibré et transparent. Il se marie très bien avec le xDuoo TA-26S.
Avec ce xDuoo certains casques même audiophiles ne sont pas compatibles. L’impédance démarre à 60Ω. Il faut donc se tourner vers les casques à haute impédance.
Sennheiser HD600 / 300Ω / 97dB, excellente sonorité claire, aérée et détaillée. L’ampli xDuoo ainsi qu’un nouveau câble fait sur mesure (Mogami) pour le HD600 ajoutent des basses, une touche de chaleur et plus de douceur aux aigus. Une écoute à la fois analytique et hi-fi. Volume à 9h-10h.
Beyerdynamic DT880 Edition / 600Ω / 96dB, belle sonorité pleine et profonde, bien équilibrée sur l’ensemble du spectre, légèrement chaude, à la fois lisse et détaillée. Avec l’impédance élevée du DT880 on peut monter un peu le volume ce qui permet d’avoir aussi plus de détails sur les instruments en donnant l’impression de s’approcher du centre de la scène sonore. Le xDuoo s’exprime parfaitement avec un casque à 600Ω. Volume à 11h-12h.
AKG K612 PRO / 120Ω / 101dB, très belle sonorité équilibrée, enveloppante, à la fois douce et détaillée sans être trop analytique. Le xDuoo fait bien ressortir les basses du K612. Elles ne sont pas très tendues mais paraissent naturelles. Une sonorité très agréable et reposante pour une écoute hi-fi. Volume à 10h.
FiiO FT3 / 350Ω / 105dB, un son dynamique fin, précis, aéré et détaillé. De l’espace et de la profondeur. Reverb et delay des enregistrements ressortent particulièrement avec l’impression d’être en concert. Le xDuoo et le FT3 s’accordent parfaitement. Volume à 9h-10h.
Audio-Technica ATH-R70x / 470Ω / 98dB, sonorité claire, aérée et dynamique. Des attaques vives et rapides. Basses tendues, définies et un peu en retrait. Une sonorité précise à tendance studio mais très attirante pour une écoute hi-fi. Le xDuoo apporte un peu de chaleur et une touche vivante au réalisme sonore de l’Audio-Technica. Volume à 9h-10h.
On a vraiment envie d’écouter de la musique le plus longtemps possible avec chacun de ces casques pour une multitudes de raisons différentes. Le xDuoo TA-26S met bien en valeur toutes les qualités de ces casques. L’ampli est à l’aise avec les diverses musiques écoutées, rock prog, fusion, jazz, classique symphonique, baroque, sacré… Et surtout, très à l’aise avec de la musique classique contemporaine comportant de l’espace, des longues notes, des harmoniques et de la complexité entre les instruments. Très à l’aise aussi avec les voix du jazz ou les effets spéciaux d’une guitare électrique. Le xDuoo est vraiment capable d’entrer dans les détails de manière parfaitement naturelle.
Pedro P.
GENALEX GOLD LION Tube Double Triode 6922 / ECC88 Gold Pins Le Genalex Gold Lion ECC88/6922 est un tube double triode high-end permettant le remplacement des modèles 6DJ8, ECC88, 6922, E88CC et 7308. Celui-ci intègre des...
Merveilleux tube !
J'avais besoin d'agrandir la scène sonore, de gagner en profondeur et en 3D, sans toutefois perdre en définition et bande passante. Ils ont remplacé avantageusement les 6H1N-BN (déjà pas mauvais) livrés avec le petit préampli XLR DOUK Audio T8Pro (+ AOP1656 & AOP1612). Le tout monté entre mon DAC et DSP, alimente 4 AUDIOPHONICS LPA-S400ET équipés de Sparkos Labs SS3602 branchés sur des baffles plans qui hébergent des Lii Song F15/W15 et des Bliesma à dômes en béryllium T25B/M74B. Les Genelex remplissent parfaitement mes attentes, le grave est profond et la résolution est égale sur tout le spectre avec un caractère élégant sans perdre de réalisme. Les sons se matérialisent sans faire de la gonflette, tout est naturel et crédible, rapide, détaillé et dynamique, tout en restant musical. Ce tube vaut largement son prix, c'est un must have pour tout amoureux du beau son.
HIDIZS SD2 DAC Amplificateur Casque Portable USB-C vers Jack 3.5mm ES9270 32bit 384kHz DSD128 Noir Le Hidizs SD2 se présente comme un dongle DAC et amplificateur casque portable USB-C vers Jack 3.5mm polyvalent et performant. Équipé d'une puce DAC...
Good...
Good sound, strange shape (and you have to put it in the right position...) but good.
