Claude T.
Bonne config
L'ensemble
- Monitor Pro contrôleur.
Apporte un plus...
Claude T.
Bonne config
L'ensemble
Apporte un plus...
Avis clients - Il y a 19323 avis.
FURUTECH FI-UK1363-N1 (G) Connecteur Secteur UK Type G Plaqué Or Coudé Ø16mm Ce connecteur secteur Furutech FI-UK1363-N1(G) est adapté aux prises du Royaume Uni ou d'Irlande. Ses contacts sont fait d'un alliage de Cuivre plaqué Or et...
Flimsy
I've bought two of these plus and both broke the same place i.e. tightening down on main cover over a 16mm cable. They certainly are NOT suitable for such cables or hefty conductor thickness i.e. 5/6mm sq.
One other thing that bothers me about Furutech is their phosphor bronze alloy as the base conductor. Phosphor bronze is one of the worst conductors out there and coating with gold or rhodium (also an awful conductor) is like putting lipstick on a pig.
VIBORG VE512S Connecteur Secteur Schuko Type E/F Cuivre Pur Plaqué Argent Ø20mm Ce connecteur secteur Schuko Viborg VE512S profite d'une qualité de conception exceptionnelle, utilisant uniquement des matériaux de grande qualité pour...
Decent but..
I've used most of the Viborg connector types and would have rated them higher were it not for IeGO connectors which are just a cut above Viborg. Shame Audiophonics don't stock them as they are exceptional after a few months of burn in.
Jasper V.
THIEAUDIO MONARCH MKII Écouteurs Intra-Auriculaires IEM Dynamique Électrostatique 36 Ohm 108dB 20Hz-20kHz Avec ses écouteurs intra-auriculaires MONARCH MKII, Thieaudio propose un an et demi après sa sortie initiale le plus populaire et le plus apprécié de...
5 / 5 - They are are brilliant, Crinacle was right.
The Moondrop Blessing 2 introduced me to the world of "detailed" sound...then the Monarch MKII came along and completed it filling in all the gaps. I needed something stellar when I left the house - taking my Hifiman Arya was just a little silly.
Compared to the Blessing 2 these are the most important differences:
- Dead neutral tuning, wow.
- Magical treble extension ( Blessing 2 is still great though )
- Bass. The Blessing 2's major weakness, but these IEM's have it...and there's enough. I worry for reviewers unable to hear it, or claim it's "thin".
Mikael B.
AUDIOPHONICS LPA-S600NCX Amplificateur de Puissance Class D Stéréo NCore NCx500 2x600W 4 Ohm Nous sommes fiers de vous proposer le Audiophonics LPA-S600NCX, un amplificateur de puissance stéréo Class D basé sur deux modules NCore NCx500. Cette...
Dynamics and Control !
A power amplifier with fantastic dynamics and control. My previous power amp was 1st generation class D (ICE Power) and development has really progressed since then with these Hypex NCx500 modules.
Can really recommend this power amplifier which, in Audiophonic's design, is of top quality at a reasonable cost.
The purchase process was without problems with fast delivery.
Istvan N.
TINYSINE TSA1701 Module DSP ADAU1701 Sigma Studio Le TinySine TSA1701 est un module de traitement du signal audio numérique complet. La puce principale utilisée est une ADAU1701, permettant à ce DSP...
Superb little DSP'
I've bought this DSP kit initially for fun. However, it was a life saver!
I had programmed it with a dynamics compressor, to be able to get rid of the LOUD action sounds and inaudible dialogues on Netflix (and movies in general). It does the job very well, you don't get a heart attack each time family is watching some movies...
In Sigma Studio there are a lot of interesting algorithms and other applications.
MATHIEU B.
WONDOM AA-JA11117 Package Câbles Fonctionnels pour Modules JAB3+ / JAB4 / JAB5 Pour faciliter l'utilisation et l'intégration des modules JAB3+, JAB4 et JAB5, Wondom propose un kit contenant l'ensemble des câbles et accessoires...
recommandé pour faciliter les connections du JAB5
Tout est compris, inclu les potentiometres de réglages des entrées alanogique! Pour ce prix, cela ne sert à rien de chipoter avec des connections foireuses faites "maison"!
Great cable
I use this cable for my turntable, which doesn't see a lot of use. I also use it to connect my Bluetooth DAC and I can't fault the cable, especially at this price.
I think this cable is worth trying before spending x3 times the price for alternatives. I changed every cable in my system to Neotech and haven't regretted it at all.
Hector S.
SMSL DA-6 Amplificateur Class D Infineon 2x70W 4 Ohm Argent Le SMSL DA-6 est un petit amplificateur Class D, pratique, performant et abordable, basé sur une puce d'amplification Infineon offrant un rendement élevé et...
Un amour !
Couplé au DAC SMSL SU-6, le résultat est formidable. Transparence et silence de fonctionnement, rien à dire au niveau des sens : c’est le fond noir.
Utilisé dans une pièce de 16m², bruit de fond +46dB, le SMSL SA-6 se montre totalement suffisant; avec enceintes 84 dB/8 Ohms. Le potentiomètre reste généralement au 2⁄3 soit 20/60 à l’écran, le niveau sonore atteint aisément les 90 dB à 2m. Cela permet de s’approcher du point de puissance qui optimise ses performances. Les réglages de tonalité (Bass/Treble) sont excellents et sans distorsion. La télécommande est parfaite.
Son alimentation externe est pour moi un point positif avec une longueur du câble respectable, il ne chauffe pas et remplace efficacement un amplificateur AB vintage 12 fois son volume. Le SMSL DA-6 est une solution élégante et discrète, il a les épaules pour tout usage raisonnable. C’est un appareil parfait pour transitionner vers un système plus ambitieux et, peut-être que comme moi, vous aurez même du mal à justifier de passer à autre chose par la suite.
Mihai T.
Waiting for MPC6 V3
Could we get please the same version with FI-09 NCF Rhodium inlet, and FI-E30 Rhodium sockets instead? And upgraded cabling ? Some of us are not a big fan of gold.
Serge V.
EVERSOLO DMP-A6 MASTER EDITION Lecteur Réseau 2xES9038Q2M WiFi DLNA AirPlay 2 Roon Bluetooth 5.0 aptX HD 32bit 768kHz DSD512 MQA Eversolo présente avec son DMP-A6 MASTER EDITION un lecteur réseau aussi performant qu'intuitif et design. Il vous permettra de diffuser votre musique en...
Son dynamique, détaillé, haut de gamme. bluffant !
Il est devenu ma tour de contrôle à la place de mon PC.
Je l'ai comparé à mon DAC R2R Denafrips+DDC Iris et je préfère l'Eversolo pour le dynamisme qu'il apporte dans les graves. Les aigus sont aussi bons qu'avec mon DAC. Il est branché à un pre-Amp à tubes Trafomatics Head2 avant d'attaquer un ampli class-D pour mes enceintes. J'écoute également sur des casques haut de gamme.
Je peux gérer l'audio de mon PC, du NAS, de la TV du DAC et tout ce qui peut se connecter en BlueTooth. Une vraie réussite technologique et audiophile.
A consommer sans modération !
Bertrand D.
SMSL AO200 MKII Amplificateur Class D Symétrique MA5332MS Symétrique Bluetooth 5.0 Subwoofer 2x160W 4 Ohm Le SMSL AO200 MKII est un amplificateur numérique Class D compact et performant, capable de développer une puissance de 2x160W sous 4Ω grâce à sa puce...
Incroyable !!
J’ai acheté ce petit intégré symétrique pour remplacer un Yamaha WXA-50 (en Class D lui aussi avec un module IcePower). Mon Yamaha était super, droit, neutre, increvable … sachant tout faire … mais … un peu juste à mon goût pour alimenter mes Saxo 50 de la marque System Audio (absolument extraordinaires, au passage).
J’avoue que quand j’ai demandé conseil à Audiophonics, je ne m’attendais pas à la réponse. J’hésitais entre un Topping PA5 et ce SLSL … avec une petite préférence (sur le papier) pour le Topping très bien critiqué sur le site ASR.
C’est donc fébrile que j’ai cliqué sur « Commander » en priant pour ne pas avoir fait une connerie …
J’ai fait confiance à Audiophonics … et j’ai, encore fois, bougrement bien fait !
Le SMSL est un ampli avec un récepteur Bluetooth, c’est tout. Par rapport au Yamaha qui sait tout faire … j’avais de quoi trembler …
Reçu en 3 jours (merci Audiophonics) … et installé dans la foulée avec une lecture depuis un Mac mini / DAC SMSL Sanskrit 10Th MkII … un bon DAC mais pas un tueur non plus … en asymétrique. Donc pas les meilleures conditions pour tester cet ampli de fond en comble …
Et bien malgré cette «petite» config, le SMSL fait un travail tout simplement incroyable !
Je voulais réveiller mes enceintes et profiter (enfin) d’une scène sonore plus holographique … je l’ai ! La musique sort avec une puissance jamais entendu avant … même à faible volume (dans mon salon de 30m2).
L’équilibre tonal est parfaitement neutre … mais c’est la clarté du son qui me scotche le plus ! Je redécouvre complètement le DAC … qui, pour son prix, est déjà incroyablement bon !
Cet ampli SMSL est tout bonnement incroyable … très puissant … neutre … pas cher … et symétrique ! Il me reste à commander un DAC symétrique pour remettre une claque à la claque que je viens de prendre …
DIMOKRITOS D.
Fil de Câblage Cuivre / Argent 4mm² Gaine PTFE Ø3.6mm Rouge Ce fil de câblage d'un diamètre de 3.6mm dispose d'un unique conducteur de 4mm² en Cuivre OFC plaqué Argent. Cela permet d'obtenir une excellente...
A remarcable cable and a true bargain
I do a lot of DIY staff and I gave this cable a try, due to its large cross-section, silver plating and PTFE insulation. I have used it to make speaker and power cables and although I was already familiar with the sound quality of this kind of cable at smaller cross sections, I was totally blown away with this one. After all, the size of the cross section DOES matter. I dare to say that both power and speaker cables I made with it, are very close to the sonic signature of mid-priced Nordost cables, without their complexity and at a very small fraction of their cost. Speed, micro and macro-dynamics, transparency, spatial information, frequency extension in both ends, smoothness, rich timbre and very extended but also very clean and accurate bass. Beware though, as always when PTFE is present, the brake-in period is very long. Do not judge it in the first few hours of listening. It needs at least 20 hours just to start to open-up, especially in the bass section. And it will continue for the next 200-300 hours. So be patient and you will be richly rewarded. I hope that Audiophonics will keep this cable in their catalogue for a very long time.
Istvan N.
Very nice device, but no standby
What I like:
1. Overall the build quality is very good, the PCB is sturdy, seems to be populated with quality components.
2. Sort of nice surprise: if wired properly, one can control 5(+1) stereo inputs ;)
There are is one thing which I don't like: there is no Standby functionality.
Pay attention when wiring the rotary control. If plugged in incorrectly, the input selection will always go only one way. If wired correctly, turning left will decrease the input number, turning right will increase it. When it gets to the end, it starts from the opposite end.
One question: what is the MON button supposed to do? Press once, the currently selected channel LED blinks, press 2 times, all the LEDs light up for a second.
Istvan N.
Not bad, could've been better
What I like:
2. Sort of nice surprise: if wired properly, one can control 5+1 stereo inputs ;)
There are two things which I don't like:
1. there is no Standby functionality
2. The input selector goes only one way, no matter which direction the rotary is turned. I would've expected that if it's turned to the left, the inputs are switched by decreasing order, and if turned to right, the other way around...
Johannes F.
Best performance/price ratio ever
I recently purchased one of these beauties for a customer who is very sensitive to radiation of all sorts and looked for a noise-free replacement for the switching power supply that came with his Squeezebox Classic streamer.
First I went for the ubiquitous Teradak DC-30 but then found out that all sources to buy one are in China. Looked around some more and was amazed to find that there is a French company selling a similar PSU for even less! The ordering process was hassle-free and straightforward. Took less than a week to have it here.
Unfortunately I had only very little time to check it out, but I really like what I see.
I need to emphasize that I don't consider myself an audiophile, I am more focused on things that I can feel and measure. Therefore, I won't share any audition results and comparisons between this PSU and others regarding the sound quality. Sorry folks.
** Case **
The build quality is superb all over. Nice anodized aluminium case, thick front panel, the back panel is also aluminium, everything fits exactly, it's heavy and solid. Chunky IEC power connector, indicator LEDs on the front (white) and back (green). It's a beauty to behold.
** Inside **
Inside things go on like that. Heavy duty toroidal transformer, massively oversized, discrete rectification, four Nichicon electrolytic capacitors, 4700µF/40V each to reduce any ripple, very clean PCB layout. Not a single wire. No flux residue anywhere, it's just as clean as it could ever be.
** Measurements **
There is not much to say about the output. It's absolutely flat 5VDC with no ripple or distortion whatsoever. Even under load this won't change. I hooked up three Squeezebox Classic with a consumption of around 6 to 7 Watts each. Even though this is close to the maximum specified, the PSU had no trouble serving them all the cleanest power. The peak power drawn from the 230V supply was ~34W so it appears that the PSU will consume around 4W for itself per output used. Haven't had the time to play around with smaller loads but I assume this is in relation to the power demands of the consuming device.
Power factor is close to 0.9 which I consider good, not stellar but a lot better than the typical switching power supplies.
Power consumption is shown with 0.0 Watts on the HOPI meter when the PSU is on but nothing is connected! Wow!
The three outputs are joined together but there is so much power available at any time that the consuming devices won't affect each other. This might be different if one emits extreme amounts of distortion, but then such units are best isolated from others and not supplied on the same power rail. Not a fault of this device in any case.
** More Observations **
The unit produces a good amount of warmth so it should not be used in tight spaces with little air around. It's far from red hot though.
There is a fuse inside, protecting the primary side of the transformer. In case it is blown it's just a matter of lifting the top lid and putting in a new one. However, I would have preferred a more accessible place for the fuse, somewhere on the back panel.
The LEDs are just poking through their respective panel, they are not fixed so it's possible to push them in. All that holds them is their own two legs. Not a major concern though, considering the price this is a tiny compromise.
The USB ports don't have a lot of grabbing force. It is rather easy to pull out USB connectors. A bit more spring tension wouldn't hurt.
Although I ordered only a PSU, there was also a 5.5/2.1mm cable delivered along. Nice touch, guys, and very appreciated!
** Summary **
This is an amazing piece of kit, unexpectedly well-built considering the budget price. I think this little thing can compete with PSUs in the price range of 400 to 500 EUR. Much of that goes into the brand names, not the values inside. A lot of attention was paid here, and all pieces that count are well done.
I will recommend this unit, and Audiophonics overall, to anyone who is interested in enhancing their audio equipment and musical experience.
 (9)
Johannes F.
Just stunning! Incredible performance for the money
** Case **
** Inside **
** Measurements **
** Summary **
Claude J.
TOPPING D70 PRO OCTO DAC 8x CS43198 XMOS XU316 Bluetooth 5.1 LDAC aptX-Adaptative 32bit 768kHz DSD512 Noir Le DAC Topping D70 Pro OCTO embarque de nombreux raffinements propres à un produit audio haut de gamme. Puces performantes, horloges ultra faible jitter, interfaces...
Exceptionnel rapport qualité/prix
Après avoir utilisé longuement le Topping E30-II que je considère modestement comme un exploit à ce prix, je viens de découvrir le D70 Pro Octo et dès les premières minutes, j'ai pu découvrir un appareil ultra-performant à la musicalité sans pareille surtout dans cette gamme de prix. Un véritable exploit. A recommander vivement.
DIMOKRITOS D.
Fil de Câblage Cuivre / Argent 4mm² Gaine PTFE Ø3.6mm Transparent Ce fil de câblage d'un diamètre de 3.6mm dispose d'un unique conducteur de 4mm² en Cuivre OFC plaqué Argent. Cela permet d'obtenir une excellente...
A remarkable cable and a true bargain
I totally agree with Anders L. review. I do a lot of DIY staff and I gave this cable a try, due to its large cross-section, silver plating and PTFE insulation. I have used it to make speaker and power cables and although I was already familiar with the sound quality of this kind of cable at smaller cross sections, I was totally blown away with this one. After all, the size of the cross section DOES matter. I dare to say that both power and speaker cables I made with it, are very close to the sonic signature of mid-priced Nordost cables, without their complexity and at a very small fraction of their cost. Speed, micro and macro-dynamics, transparency, spatial information, frequency extension in both ends, smoothness, rich timbre and very extended but also very clean and accurate bass. Beware though, as always when PTFE is present, the brake-in period is very long. Do not judge it in the first few hours of listening. It needs at least 20 hours to just start to open-up, especially in the bass section. And it will continue for the next 200-300 hours. So be patient and you will be richly rewarded. I hope that Audiophonics will keep this cable in their catalogue for a very long time.
Vandestienne S.
JANTZEN AUDIO Borniers Enceintes Carbone (La paire) Ces borniers pour enceintes avec finition Carbone peuvent se monter simplement grâce à un système à vis. Ils peuvent accepter des câbles d'un...
bornier
très bon bornier facile d'instalation je recommande pour un budjet raisonnable
Francis B.
Dingue.
Achetez-le!
Tout en rondeur, précis, énergie incroyable, pas de bruits de distorsions, séparation des canaux impressionnante, étagement de la scène sonore incroyable et des possibilités de réglages astucieuses ! Plus en nuance que les petits frères ces modules 1ET7040SA sont largement supérieurs. Et permettent de jouer des enceintes difficiles sans s’écrouler. Alimentation surdimensionnée et extrêmement propres. Boîtier élégant et fin, efficace pour la dissipation thermique fortement atténuée en classe D, on le glisse partout ! Et l’efficience permet une consommation bien plus modérée. Bravo audiophonics. Pendant que certains critiques la classe D, moi je profite de cet amplificateur de puissance qui porte bien son nom.
Francis B.
ISOACOUSTICS ISO-155 Supports d'Enceintes 18kg 155x190x76mm Noir (La paire) Le modèle ISO-155 permet d'améliorer le placement de vos moniteurs ou de vos enceintes grâce à 14 variations de positions (hauteur et...
Ça marche!
J’ai pu mettre quasiment à niveau mes enceintes posées sur deux support inégaux en hauteur. Et cela découple bien du support avec un son amélioré. L’assemblage est astucieux et le réglage de l’inclinaison parfait. Prix correcte.
Jean-Pierre D.
Très bon DAC
Je souhaitais avoir un DAC R2R (ayant des DAC Sigma assez proches au niveau du son). Ce R26 répond plus qu’à mes attentes, bon équilibre entre les détails et une présentation holographique plus saturée en timbres (j’écoute du classique et du lyrique principalement). La définition des notes élevées est superbe et bien étendue comme j’aime. C’est un DAC qui peut être dynamique, donc adapté à mon avis à pas mal de styles musicaux. Autre point fort du Gustard, un espace sonore très vaste. Utilisé avec un lecteur Rose RS 250 que j’avais pour le streaming et intégré Denon PMA 110 avec enceintes Focal Kanta 1, le Gustard apporte une plus-value à mon installation. Un produit avec un rapport qualité sonore, fabrication / prix imbattable.
Laurent M.
Très bonnes fourches
Excellente fourches et très Bon contact
Sur mon ampli tube avec un câble RAMM AUDIO AMADEUS 5 MK2. (j'ai suivi la config conseillé pour ce produit)
sortie ampli : Fourche Red Copper RAMM AUDIO 50400-GT
entrée H.P bas ; Banane Red Copper VIBORG VB401
Entrée H.P haut : Banane Tellurium PANGEA XTREME
Jumpers : 3 rouge et 3 noirs avec câble : NEOTECH NEMOS-3080.
LE RESULTAT EST MERVEILLEUX !
Guillaume B.
NEOTECH CU-AG-20-22 Fil de Câblage Cuivre OCC / Argent OCC Isolation PE 0.326mm² Le fil de câblage Neotech CU-AG assure une parfaite transmission du signal, utilisant des conducteurs composés d'un alliage de cuivre OCC et de 20% d'argent OCC...
NEOTECH, toujours BIEN!
Utilisé pour fabriquer une rallonge phono de 7m, le son est juste chaud sans déséquilibre à la dynamique présente comme dictée par le message, bien musical sans flatter un registre, il est très agréable d'écouter de la musique via ce câble.
Pour ce prix, je recommande les yeux fermés cet alliage Cu OCC/ Ag OCC au TOP.
Guillaume B.
VIBORG VR106G Connecteurs RCA Mâles Argent Pur PTFE Ø11mm (Set x4) Les VR106AG de Viborg sont des connecteurs RCA mâles haut de gamme, utilisant des contacts en argent pur afin de fournir une conductivité maximale. Ils...
Pas mal...mais
Bon rapport qualité/prix, ce sont des connecteurs de qualité, visuellement c'est beau (mieux que la photo;) ) et par les matériaux choisis, le message musical passe très très bien (merci l'argent).
Mais la pince mériterait une plus grande liberté d'ouverture, en effet la bague autour de celle-ci limite fortement sont ouverture, j'ai dû limer une petite lèvre a l'intérieur (invisible une fois monté) pour arriver à enficher ce connecteur sur du Cambridge et du Aurora Sound. Une première pour moi avec Viborg mais je reste positif avec cette marque grâce a la satisfaction des autres produits déjà acquis.
patrick a.
Ravi !
Simplicité, fonctionnalité, musicalité pour du "Bluetooth".
Produit épatant.
joffrey J.
Excellent câble HP
Je donne un second avis
Maintenant que mes enceintes sont rodées je leur trouve une scène sonore plus étriquée qu'avant et des graves secs mais moins puissants qu'avec les elecaudio. Malgré tout pour le prix ça reste d'excellents câbles HP. Je recommande pour des systèmes dont le grave est brouillon et mal maîtrisé.
Thibaud S.
TINYSINE USBI JTAG DSP Programmateur Sigma DSP Le USBi JTAG de TinySine est un programmateur USB pour DSP Sigma. Il peut ainsi être utilisé pour programmer les puces utilisant la technologie de traitement du...
Je l'utilise pour programmer un ADAU1701. La communication se fait parfaitement.
Attention, les alims sont en 5V.
Le pinout est imprimé sur le circuit imprimé:
I2C:
SCL pin1, SDA pin3, Reset pin 6, GND pin 10, 5V pin 4.
SPI:
MISO pin 5, MOSI pin 8, SCL pin 7, SS pin 9, Rst pin 6, Gnd pin 10 et 5V pin 4.
CXG E110S Fer à Souder Réglable avec Support 110W 500°C Ø7mm Le fer à souder réglable CXG E110S offre une puissance de 1100W, permettant d'atteindre une température maximale de 500°C. Son corps de chauffe en...
Great
Really effective with smart display and easy setting of temperature.
NEOTECH NEVD-2001 Câble Coaxial 75 Ohm Pur Argent Quadruple blindage Ø7.6mm Le NEVD-2001 est un excellent câble Coaxial avec une impédance de 75Ω, offrant une large bande passante afin de réduire le jitter et assurer une...
Very good quality
This cable did not disappoint, I made a coaxial cable to use with my AN dac 4.1. I used the WBT 0110 ag 75ohm connectors, and WBT solder with silver in it for the purest connection possible.
It sounds incredible, and you will never need to upgrade to anything else.
Highly recommended :)
GENALEX GOLD LION Tube Double Triode 6922 / ECC88 Gold Pins Le Genalex Gold Lion ECC88/6922 est un tube double triode high-end permettant le remplacement des modèles 6DJ8, ECC88, 6922, E88CC et 7308. Celui-ci intègre des...
Dingue !
Je ne peux faire autrement que de laisser un avis alors que je viens juste de les monter...
(Tuner 100T Magnum-Dynalab
ampli-casque Luxman P-1u
Casque seinheiser HD800s
Cables Sonorus DirectVovox)
Sur un Tuner MagnumDynalab 100T, avec les sortie triodes donc.
Je me doutais bien que que les lampes d'origines avaient leur rôle dans le coté sec et sans relief du son de ce tuner pourtant extraordinaire. Mais comme les timbres et les ambiances étaient tres bon j'ai tenu durant 15 ans.
Apres avoir changé les tubes de pré-amplification de mon Cayin et devant la grandeur de l'amélioration, mon sang n'a fait qu'un tour!
Certes ces tubes Genalex ne sont pas donnés, mais le 100T les vaux bien.
A froid sans rodage c'est juste extraordinaire !
Enfin du grave dans mon casque. Beaucoup plus de détails sur toutes les fréquences qui améliorent la localisation des Instruments.
C'est plus clair et plus rond à la fois.
Apres une période de chauffe : Le grave descend plus bas et est moins ronflant, je perçois les graves comme seul un sub peut les retranscrire. ça file haut mais sans jamais aucune agressivité. Les voix centrées sur France-Musique sont un peu reculées dans l'espace.
Et c'est que le début ! Je vais donc le garder jusqu'à la fin demain vie en espérant qu'ils continuent à émettre bien sur...
ça me donne envie d'investir dans le module DAC que l'on peu greffer à l'intérieur de la bête pour profiter les sorties triodes.
Musicalement vôtre.
Guillermo G.
Really bad!
A really poor board, cheap components, cheap diodes, it came with a different capacitor 2200uf (no brand) instead of 6800uf, cheaper diodes and overall a cheap board.
PHILIPPE C.
Très satifaisant
J'utilise le cable pour connecter mon teléphone à un ampli FX-Audio D802. Cela fonctionne très correctement. Je n'ai pas comparé avec des cables de même type mais 4 fois plus onéreux. Mais le résultat est très honorable
Emmanuel l.
TANCHJIM SPACE DAC USB Portable 2x CS43131 Symétrique 32bit 384kHz DSD256 Le DAC portable TANCHJIM SPACE est un DAC portable compact et efficace. Il  adopte une finition haut de gamme avec un cadre en alliage d'aluminium usiné CNC et...
bien lire la notice
super dac ampli casque une fois le gain réglé sur haut en appuyant sur les deux boutons du volume en même temps ey un rodage de 8 heures, à noter que je n'ai eu aucune interférences contrairement à la concurrence fosi fiio ou shanling, je l'ai couplé en bi perfect avec des final audio e5000 un régale avec de bon fichiers bien sûr la puissance et largement suffisante pour moi
Fidy R.
Concept superbe, mais implémentation non finalisée
+ Idées géniales : le DMP-A6 permet la sortie en format natif stereo et multicanal via hdmi ; sorties nombreuses : le passage d'une sortie à l'autre se fait via l'appli Eversolo sans intervenir sur les branchements ; lecture gapless tous formats en streaming via l'appli uniquement ; qualité sonore en hdmi ou via DAC interne
- Défauts de fonctionnement : certains fichiers dsf stereo ou multicanal non lus (pourtant lisibles sans restriction sur tous mes autres streamers ou DAP) ; implémentation dlna upnp non aboutie (limitation de la navigation sur NAS à 200 albums ou 100 dossiers par niveau ; pas de lecture gapless avec bubble upnp) ; gestion de playlist très insuffisante
David j.
FGA-102 Transformateur Stéréo Ligne Boucle de Masse RCA Ce transformateur ligne stéréo professionnel FGA-102 permet de réduire efficacement les interférences de signaux et les ronflements, pouvant survenir...
encore un produit excellent vendu par audiophonics
J'avais d'importants bruits numériques venant de mon pc connecté à un dac qui gênaient l'écoute (dès que l'ordi tournait un peu fort ou que je déplaçais la souris, j'avais droit à d'horribles ZZCHZRLZZZHHRZH). L'installation de ce transfo de ligne entre mon Dac Gustard 20h et mon préampli DIY d'excellente facture (sur schéma Marantz 7) a permis de réduire à néant ces interférences. Si comme moi vous êtes en PC audio et que vous rencontrez ce type de problème, ce transfo est parfait. La qualité de fabrication est, en outre, irréprochable.
Georges B.
ELFIDELITY AXF-107 Filtre d'Alimentation PCI Express / PCI Express 16x Le module AXF-107 de Elfidelity est un filtre d'alimentation à découpage pour ordinateur se raccordant en PCI Express ou PCI Express 16x et destiné à offrir un courant plus...
Ce filtre ne joue pas que dans la déco !
Le filtre de puissance AXF-107 est monté sur une ASUS Maximus Z690 HERO avec une JCAT USB EX sans jumper.
Pour obtenir le meilleur rendu sonore, le filtre a été placé sur le bus PCIE du haut, cela semble logique, puisque tout ce qui se trouve en dessous bénéficie du filtre. Un test avec la AXF-107 dans le bus PCIE du bas et JCAT en haut n'apporte aucune amélioration sur cette carte mère ASUS.
Un gain supplémentaire de qualité sera encore obtenu en éteignant les leds de la AXF-107, ceci en inversant les 2x3 dips, mais dites adieu aux effets lumière tant convoités mais tellement nocifs à l'audio !
Un autre test avec 2 AXF-107 (bien placées) est prévu ..
recommandé par le constructeur..
Francois B.
THIEAUDIO MONARCH MKIII Écouteurs Intra-Auriculaires IEM Dynamique Électrostatique 20 Ohm 99dB 20Hz-40kHz Avec des haut-parleurs et des ajustements actualisés et optimisés ainsi qu'une ergonomie considérablement améliorée, les écouteurs...
Je viens d'acquérir, il y a quelques petites semaines l’IEM de chez THIEAUDIO MONARK MKIII sur ce site.
Service très rapide (comme d’habitude) d’Audiophonics. Parfait.
Actuellement environ 100 heures d'utilisation en Symétrique 4,4 mm tant sur Walkman SONY NW-WM1AM2 (Modèle Japonais non plafonné), Shanling M9 et Ampli Casque /Dac Sony TA-ZH1ES et parfois Sony PHA2a.
J’utilises le cable fourni, de bonne qualité avec sa prise modulable en 4,4 mm, (celle ci d'ailleurs, de par son adaptateur se détache assez souvent, et constaté par d'autres utilisateurs sur des forums) mais aussi un cable de chez LunaShop et Ears Tips / embouts silicone d’origine, même si je viens depuis plusieurs jours de mettre des SpinFit W1, car j’ai une petite préférence personnelle pour ceux ci, mais dans tout les cas, je trouve un bon confort pour de longues sessions, malgré la taille des coques des MONARK MKIII et j’ai des oreilles normales.
Bref, de très bonnes associations, rien a dire, ça rend très bien et j'en suis vraiment pleinement satisfait y compris dans des styles musicaux divers).
(Pour le son, on trouve quelques avis et tests fiables sur cet IEM qui permettent de savoir a quoi on a affaire et de comparaisons avec d'autres produits équivalents)
Je préciserai que j'écoutes beaucoup d'électronique (Tangerine Dream, Jarre, Carlos, Tomita, Synergy, Steve Roach, Schulze, Pink Floyd etc etc... mais aussi un peu de voix variées : Maria Mena, Assala Nasri, Myrkur, Farmer, Krall, Rondstadt..., musiques de films..., un peu de classique : clavecin et musique d'orgue de différentes périodes et artistes.
THIEAUDIO Monark MKIII : en bref :
Pas d’effet WOW ! a la première écoute, je dirai ici que ce n’est pas mon seul IEM, en effet j’utilise aussi les SENNHEISER IE 900, SONY IER-M9, SHANLING ME800, AFUL Performer 8 et… THIEAUDIO Oracle MKII.
Design simple de base, (je préfères la déco de l’Oracle MKII) mais personnalisable sur le site du fabricant.
Sans rentrer dans les détails, car chacun aura surement un avis différent, en fonction de ses gouts, sources, fichiers musicaux, et que les avis ou reviews du web sont globalement très bons.
Il demande moins de puissance que l’Oracle MKII (surement une histoire de Sensibilité et d’impédance en liaison avec mon matériel d’écoute.
Package typique Thieaudio : vraiment le minimum, mais ça fait le Taf. Je n’ai pas essayer les Embouts en mousse.
J’apprécie beaucoup le son donc son rendu, avec MES oreilles (Pas de Sibilance ou d’aigu agressif, belles basses profondes et organiques si la piste le réclame, (même si l’Oracle MKII est vraiment très agréable aussi), en fait cela pourrait être une fin de jeu en soi.
Je n’ai pas ressenti spécialement qu’il est eu besoin de rodage, même si j’ai eu vraiment l’impression d’un quelque chose de mieux (équilibre ?) après 30/35 d’heures.
(En me basant sur quelques morceaux de musique différents que je connais bien et que j’ai réécoutés plusieurs fois depuis le début pour en tester les possibles évolutions.
j’ai également fait l’essai du changement de cable d’origine par celui d’Effect Audio l’Eros S qui semblent apporter un peu plus de subtilité dans les détails.
Quoi qu’il en soit, je suis pleinement satisfait de ce MONARK MKIII, au point qu’actuellement, il fait de l’ombre aux autres.
(Cela ne remet nullement en doute les qualités de ceux ci, juste une approche différente ou l’effet nouveau jouet).
Une belle découverte et choix que ce MONARK MKIII et qu’ Audiophonics nous permet d’obtenir sans passer par la case import de Chine.
Je ne peux que recommander
Et je n'en oublies surtout pas la qualité des fichiers, qui reste primordiale sur une bonne source pour en extraire la quintessence.
Eemeli T.
Impressive.
Very fast delivery - ordered on thursday, package was delivered on monday morning. Nice! What was not that nice was the way amplifier was packed. I was amazed that my amp was in one piece since there was virtually no padding in the outer box.
What comes to the sound and overall build quality of this amp, is pretty amazing and impressive, especially considering the price. So far very pleased with the product itself. Time will tell how durable it is.
Plamen T.
Great fit, easy to solder.
Great fit, easy to solder. Highly recommended, much better connection than banana plugs that use bolts to secure the cable.
Francois B.
- Service très rapide (comme d’habitude) d’Audiophonics. Parfait.
- Actuellement environ 100 heures d'utilisation en Symétrique 4,4 mm tant sur Walkman SONY NW-WM1AM2 (Modèle Japonais non plafonné), Shanling M9 et Ampli Casque /Dac Sony TA-ZH1ES et parfois Sony PHA2a.
- J’utilises le cable fourni, de bonne qualité avec sa prise modulable en 4,4 mm, (celle ci d'ailleurs, de par son adaptateur se détache assez souvent, et constaté par d'autres utilisateurs sur des forums) mais aussi un cable de chez LunaShop et Ears Tips / embouts silicone d’origine, même si je viens depuis plusieurs jours de mettre des SpinFit W1, car j’ai une petite préférence personnelle pour ceux ci, mais dans tout les cas, je trouve un bon confort pour de longues sessions, malgré la taille des coques des MONARK MKIII et j’ai des oreilles normales.
- Bref, de très bonnes associations, rien a dire, ça rend très bien et j'en suis vraiment pleinement satisfait y compris dans des styles musicaux divers).
- Je préciserai que j'écoutes beaucoup d'électronique (Tangerine Dream, Jarre, Carlos, Tomita, Synergy, Steve Roach, Schulze, Pink Floyd etc etc... mais aussi un peu de voix variées : Maria Mena, Assala Nasri, Myrkur, Farmer, Krall, Rondstadt..., musiques de films..., un peu de classique : clavecin et musique d'orgue de différentes périodes et artistes.
- Pas d’effet WOW ! a la première écoute, je dirai ici que ce n’est pas mon seul IEM, en effet j’utilise aussi les SENNHEISER IE 900, SONY IER-M9, SHANLING ME800, AFUL Performer 8 et… THIEAUDIO Oracle MKII.
- Design simple de base, (je préfères la déco de l’Oracle MKII) mais personnalisable sur le site du fabricant.
- Sans rentrer dans les détails, car chacun aura surement un avis différent, en fonction de ses gouts, sources, fichiers musicaux, et que les avis ou reviews du web sont globalement très bons.
- Il demande moins de puissance que l’Oracle MKII (surement une histoire de Sensibilité et d’impédance en liaison avec mon matériel d’écoute.
- Package typique Thieaudio : vraiment le minimum, mais ça fait le Taf. Je n’ai pas essayer les Embouts en mousse.
- J’apprécie beaucoup le son donc son rendu, avec MES oreilles (Pas de Sibilance ou d’aigu agressif, belles basses profondes et organiques si la piste le réclame, (même si l’Oracle MKII est vraiment très agréable aussi), en fait cela pourrait être une fin de jeu en soi.
- Je n’ai pas ressenti spécialement qu’il est eu besoin de rodage, même si j’ai eu vraiment l’impression d’un quelque chose de mieux (équilibre ?) après 30/35 d’heures.
- j’ai également fait l’essai du changement de cable d’origine par celui d’Effect Audio l’Eros S qui semblent apporter un peu plus de subtilité dans les détails.
- Quoi qu’il en soit, je suis pleinement satisfait de ce MONARK MKIII, au point qu’actuellement, il fait de l’ombre aux autres.
Raphael N.
PSVANE EL34-PH Tubes HiFi (Quad Appairé) Le tube EL34-PH de PSVane est une réplique du connu et reconnu EL34 de Philips, largement utilisé dans de nombreux amplificateurs à lampes. Il est ainsi...
Smooth sounding EL-34s
J'écris cet avis en Anglais pour qu'il soit lisible de tous.
I share the other comments when it comes to Tube break-in. I went from Electro-Harmonix tubes (OEM on my Synthesis Roma) to these PSVANEs. At first the sound was dark and fuzzy. The voices were not forward anymore but in the far back of the sound stage. It's a derouting experience when you know they cost quite a fortune. But after 20 hours of listening the sound began to open.
Quickly after, voices were soft, warm, soundstage was clearer, and the highs were clearer.
Once you let these babies break in sufficiently, you get a good upgrade and lushy sound.
Tubes on themselves are gorgeous and the packing is top-notch. You have a verification sheet that proves the matching of the tubes with obtained results from the factory (handwritten).
The minor con I see is in the price/benefit ratio. You need to embrace diminishing returns with these tubes. Compared to my mid-life OEM Electro-Harmonix, these PSVANE brought just around 20% of an upgrade (if you consider slightly more open sound stage and clearer highs). But if it had to be done again, maybe I would've spent these 350€ somewhere else for more results.
Note : I'm using these tubes after an excellent phono preamp, on a mid-tier Tube Amp (Roma96DC), listening on vinyl only over wonderful vintage Cabasse speakers.
Carlos P.
DAC TV MS8413 Convertisseur SPDIF Coaxial Optique vers Analogique RCA Ce DAC optique coaxial basé sur un convertisseur MS8413 est idéal pour une conversion simple, pour une TV par exemple.
Bon convertisseur numerique analogique
Mon téléviseur Panasonic 4K n'a qu'une sortie audio optique. Ce convertisseur numérique analogique économique est idéal pour écouter n'importe quel programme TV via un amplificateur et des haut-parleurs externes. Je l'alimente via la sortie USB du téléviseur avec le câble de connecteur cylindrique USB-5,5-2,5 mm fourni dans la boîte. De plus, comme il me restait un filtre USB Ifi, je l'ai mis et le son s'est amélioré.
Jean J.
PHIREE U2S 2019 Interface USB vers SPDIF SA9023 OTG 24bit 96kHz Noir Le Phiree U2S 2019 est une interface USB vers SPDIF et Optique, efficace et compacte. Elle se base sur une puce Bravo SA9023, supportant des taux d'échantillonnage...
Magique ....
Ce petit module est super pour envoyer le son d'un PC vers un équipement audio en ayant une isolation galvanique qui garanti
l'absence de boucle de masse et de toutes perturbations électriques.
Il est reconnu immédiatement sous Windows et s'enregistre dans la liste des périphériques audio.
Un excellent rapport qualité prix.
Sebastien D.
SHANLING MTW300 Écouteurs Intra-Auriculaires IEM Bluetooth 5.2 QCC3040 aptX Gris Les écouteurs intra-auriculaires Bluetooth Shanling MTW300 reprennent le design ergonomique et confortable des MTW100, dans une version aux performances...
je corrige mon avis précédent, ces écouteurs sont excellents en terme de son et aussi d'appairage, bizarrement depuis un nouveau smartphone il n'y a plus de probs d'appairage, je venais d'un oneplus 6t et maintenant un oppo find x5 et tout fonctionne impeccablement bien, le tactile pour les pauses et redémarrage de lecture, pour le prix certes c pas rien mais la qualité et vraiment excellente donc un gros 5/5 au final
Rodolphe G.
Je comprend pas …
Acheté pour alimenter des Audience Nova T4 suite à une panne sur un ampli Vincent SP994 je ne m’attendais à rien de mieux qu’un dépannage en attendant mieux. Et bien c’est la claque en pleine G….. ! Ce petit intégré smsl en classe D m’a laissé sur le cul ! C’est mieux que le vincent qui déjà me donnait pneu e satisfaction. J’avais un Atoll IN400SE que j’ai revendu tellement cet ampli était anémique et pourtant il m’avait coûté 5500€ ! Le atoll est littéralement explosé à tous les niveaux par ce smsl AO200 mk2 !
Ne réfléchissez pas, foncez dès que vous aurez l’occasion d’en trouver un en stock, c’est impossible d’être déçu pour 250€ même en comparaison avec des amplis de marques ésotériques à 20x le prix de ce petit génie…
christopher l.
Connecteur RCA Coudé 90° Plaqué Or Ø6mm (La paire) Ces connecteurs RCA à petit prix mais cependant de très bonne facture sont coudés à 90°, et donc particulièrement pratique pour des...
grande satisfaction
RCA coudé de grande qualité livraison rapide
christopher l.
Connecteurs RCA Plaqué Or Ø6mm (La paire) Argent Ces connecteurs RCA de belle qualité profitent de contacts plaqués or, assurant une bonne conductivité électrique et résistance à...
très satisfait
RCA de grande qualité livraison rapide c'est parfait
christopher l.
grande satisfaction
RCA male coudé de grande qualité livraison rapide
Christophe P.
impressionant
venant d'une câble Connect Research d'une valeur approximative de 100€, j'étais un peu sceptique sur la plus-value de ce câble à un tarif assez conséquent. Certes, ça peut sembler superflus de mettre ce prix dans un câble, et pourtant, le résultat est impressionnant. Le spectre sonore devient parfaitement équilibré. La scène sonore s'aère, la polyphonie des compositions complexes devenant plus facile à discriminer. Dernier point non négligeable, la qualité des voix masculines comme féminines s'est grandement améliorée, devenant plus naturelle et moins agressive.
