Jerry T.
Audiophonics DAC sabre board ESS9038
Please keep selling this item. It is very high quality! I will buy many more in the future!
Jean-François D.
Impeccable !
Vasilios K.
Avis clients - Il y a 19306 avis.
DIMOKRITOS D.
Fil de Câblage Cuivre / Argent 4mm² Gaine PTFE Ø3.6mm Transparent Ce fil de câblage d'un diamètre de 3.6mm dispose d'un unique conducteur de 4mm² en Cuivre OFC plaqué Argent. Cela permet d'obtenir une excellente...
A remarkable cable and a true bargain
I totally agree with Anders L. review. I do a lot of DIY staff and I gave this cable a try, due to its large cross-section, silver plating and PTFE insulation. I have used it to make speaker and power cables and although I was already familiar with the sound quality of this kind of cable at smaller cross sections, I was totally blown away with this one. After all, the size of the cross section DOES matter. I dare to say that both power and speaker cables I made with it, are very close to the sonic signature of mid-priced Nordost cables, without their complexity and at a very small fraction of their cost. Speed, micro and macro-dynamics, transparency, spatial information, frequency extension in both ends, smoothness, rich timbre and very extended but also very clean and accurate bass. Beware though, as always when PTFE is present, the brake-in period is very long. Do not judge it in the first few hours of listening. It needs at least 20 hours to just start to open-up, especially in the bass section. And it will continue for the next 200-300 hours. So be patient and you will be richly rewarded. I hope that Audiophonics will keep this cable in their catalogue for a very long time.
Vandestienne S.
JANTZEN AUDIO Borniers Enceintes Carbone (La paire) Ces borniers pour enceintes avec finition Carbone peuvent se monter simplement grâce à un système à vis. Ils peuvent accepter des câbles d'un...
bornier
très bon bornier facile d'instalation je recommande pour un budjet raisonnable
Francis B.
Dingue.
Achetez-le!
Tout en rondeur, précis, énergie incroyable, pas de bruits de distorsions, séparation des canaux impressionnante, étagement de la scène sonore incroyable et des possibilités de réglages astucieuses ! Plus en nuance que les petits frères ces modules 1ET7040SA sont largement supérieurs. Et permettent de jouer des enceintes difficiles sans s’écrouler. Alimentation surdimensionnée et extrêmement propres. Boîtier élégant et fin, efficace pour la dissipation thermique fortement atténuée en classe D, on le glisse partout ! Et l’efficience permet une consommation bien plus modérée. Bravo audiophonics. Pendant que certains critiques la classe D, moi je profite de cet amplificateur de puissance qui porte bien son nom.
Francis B.
ISOACOUSTICS ISO-155 Supports d'Enceintes 18kg 155x190x76mm Noir (La paire) Le modèle ISO-155 permet d'améliorer le placement de vos moniteurs ou de vos enceintes grâce à 14 variations de positions (hauteur et...
Ça marche!
J’ai pu mettre quasiment à niveau mes enceintes posées sur deux support inégaux en hauteur. Et cela découple bien du support avec un son amélioré. L’assemblage est astucieux et le réglage de l’inclinaison parfait. Prix correcte.
Jean-Pierre D.
Très bon DAC
Je souhaitais avoir un DAC R2R (ayant des DAC Sigma assez proches au niveau du son). Ce R26 répond plus qu’à mes attentes, bon équilibre entre les détails et une présentation holographique plus saturée en timbres (j’écoute du classique et du lyrique principalement). La définition des notes élevées est superbe et bien étendue comme j’aime. C’est un DAC qui peut être dynamique, donc adapté à mon avis à pas mal de styles musicaux. Autre point fort du Gustard, un espace sonore très vaste. Utilisé avec un lecteur Rose RS 250 que j’avais pour le streaming et intégré Denon PMA 110 avec enceintes Focal Kanta 1, le Gustard apporte une plus-value à mon installation. Un produit avec un rapport qualité sonore, fabrication / prix imbattable.
Laurent M.
Très bonnes fourches
Excellente fourches et très Bon contact
Sur mon ampli tube avec un câble RAMM AUDIO AMADEUS 5 MK2. (j'ai suivi la config conseillé pour ce produit)
sortie ampli : Fourche Red Copper RAMM AUDIO 50400-GT
entrée H.P bas ; Banane Red Copper VIBORG VB401
Entrée H.P haut : Banane Tellurium PANGEA XTREME
Jumpers : 3 rouge et 3 noirs avec câble : NEOTECH NEMOS-3080.
LE RESULTAT EST MERVEILLEUX !
Guillaume B.
NEOTECH CU-AG-20-22 Fil de Câblage Cuivre OCC / Argent OCC Isolation PE 0.326mm² Le fil de câblage Neotech CU-AG assure une parfaite transmission du signal, utilisant des conducteurs composés d'un alliage de cuivre OCC et de 20% d'argent OCC...
NEOTECH, toujours BIEN!
Utilisé pour fabriquer une rallonge phono de 7m, le son est juste chaud sans déséquilibre à la dynamique présente comme dictée par le message, bien musical sans flatter un registre, il est très agréable d'écouter de la musique via ce câble.
Pour ce prix, je recommande les yeux fermés cet alliage Cu OCC/ Ag OCC au TOP.
Guillaume B.
VIBORG VR106G Connecteurs RCA Mâles Argent Pur PTFE Ø11mm (Set x4) Les VR106AG de Viborg sont des connecteurs RCA mâles haut de gamme, utilisant des contacts en argent pur afin de fournir une conductivité maximale. Ils...
Pas mal...mais
Bon rapport qualité/prix, ce sont des connecteurs de qualité, visuellement c'est beau (mieux que la photo;) ) et par les matériaux choisis, le message musical passe très très bien (merci l'argent).
Mais la pince mériterait une plus grande liberté d'ouverture, en effet la bague autour de celle-ci limite fortement sont ouverture, j'ai dû limer une petite lèvre a l'intérieur (invisible une fois monté) pour arriver à enficher ce connecteur sur du Cambridge et du Aurora Sound. Une première pour moi avec Viborg mais je reste positif avec cette marque grâce a la satisfaction des autres produits déjà acquis.
patrick a.
Ravi !
Simplicité, fonctionnalité, musicalité pour du "Bluetooth".
Produit épatant.
joffrey J.
Excellent câble HP
Je donne un second avis
Maintenant que mes enceintes sont rodées je leur trouve une scène sonore plus étriquée qu'avant et des graves secs mais moins puissants qu'avec les elecaudio. Malgré tout pour le prix ça reste d'excellents câbles HP. Je recommande pour des systèmes dont le grave est brouillon et mal maîtrisé.
Thibaud S.
TINYSINE USBI JTAG DSP Programmateur Sigma DSP Le USBi JTAG de TinySine est un programmateur USB pour DSP Sigma. Il peut ainsi être utilisé pour programmer les puces utilisant la technologie de traitement du...
Je l'utilise pour programmer un ADAU1701. La communication se fait parfaitement.
Attention, les alims sont en 5V.
Le pinout est imprimé sur le circuit imprimé:
I2C:
SCL pin1, SDA pin3, Reset pin 6, GND pin 10, 5V pin 4.
SPI:
MISO pin 5, MOSI pin 8, SCL pin 7, SS pin 9, Rst pin 6, Gnd pin 10 et 5V pin 4.
CXG E110S Fer à Souder Réglable avec Support 110W 500°C Ø7mm Le fer à souder réglable CXG E110S offre une puissance de 1100W, permettant d'atteindre une température maximale de 500°C. Son corps de chauffe en...
Great
Really effective with smart display and easy setting of temperature.
NEOTECH NEVD-2001 Câble Coaxial 75 Ohm Pur Argent Quadruple blindage Ø7.6mm Le NEVD-2001 est un excellent câble Coaxial avec une impédance de 75Ω, offrant une large bande passante afin de réduire le jitter et assurer une...
Very good quality
This cable did not disappoint, I made a coaxial cable to use with my AN dac 4.1. I used the WBT 0110 ag 75ohm connectors, and WBT solder with silver in it for the purest connection possible.
It sounds incredible, and you will never need to upgrade to anything else.
Highly recommended :)
GENALEX GOLD LION Tube Double Triode 6922 / ECC88 Gold Pins Le Genalex Gold Lion ECC88/6922 est un tube double triode high-end permettant le remplacement des modèles 6DJ8, ECC88, 6922, E88CC et 7308. Celui-ci intègre des...
Dingue !
Je ne peux faire autrement que de laisser un avis alors que je viens juste de les monter...
(Tuner 100T Magnum-Dynalab
ampli-casque Luxman P-1u
Casque seinheiser HD800s
Cables Sonorus DirectVovox)
Sur un Tuner MagnumDynalab 100T, avec les sortie triodes donc.
Je me doutais bien que que les lampes d'origines avaient leur rôle dans le coté sec et sans relief du son de ce tuner pourtant extraordinaire. Mais comme les timbres et les ambiances étaient tres bon j'ai tenu durant 15 ans.
Apres avoir changé les tubes de pré-amplification de mon Cayin et devant la grandeur de l'amélioration, mon sang n'a fait qu'un tour!
Certes ces tubes Genalex ne sont pas donnés, mais le 100T les vaux bien.
A froid sans rodage c'est juste extraordinaire !
Enfin du grave dans mon casque. Beaucoup plus de détails sur toutes les fréquences qui améliorent la localisation des Instruments.
C'est plus clair et plus rond à la fois.
Apres une période de chauffe : Le grave descend plus bas et est moins ronflant, je perçois les graves comme seul un sub peut les retranscrire. ça file haut mais sans jamais aucune agressivité. Les voix centrées sur France-Musique sont un peu reculées dans l'espace.
Et c'est que le début ! Je vais donc le garder jusqu'à la fin demain vie en espérant qu'ils continuent à émettre bien sur...
ça me donne envie d'investir dans le module DAC que l'on peu greffer à l'intérieur de la bête pour profiter les sorties triodes.
Musicalement vôtre.
Guillermo G.
Really bad!
A really poor board, cheap components, cheap diodes, it came with a different capacitor 2200uf (no brand) instead of 6800uf, cheaper diodes and overall a cheap board.
PHILIPPE C.
Très satifaisant
J'utilise le cable pour connecter mon teléphone à un ampli FX-Audio D802. Cela fonctionne très correctement. Je n'ai pas comparé avec des cables de même type mais 4 fois plus onéreux. Mais le résultat est très honorable
Emmanuel l.
TANCHJIM SPACE DAC USB Portable 2x CS43131 Symétrique 32bit 384kHz DSD256 Le DAC portable TANCHJIM SPACE est un DAC portable compact et efficace. Il  adopte une finition haut de gamme avec un cadre en alliage d'aluminium usiné CNC et...
bien lire la notice
super dac ampli casque une fois le gain réglé sur haut en appuyant sur les deux boutons du volume en même temps ey un rodage de 8 heures, à noter que je n'ai eu aucune interférences contrairement à la concurrence fosi fiio ou shanling, je l'ai couplé en bi perfect avec des final audio e5000 un régale avec de bon fichiers bien sûr la puissance et largement suffisante pour moi
Fidy R.
Concept superbe, mais implémentation non finalisée
+ Idées géniales : le DMP-A6 permet la sortie en format natif stereo et multicanal via hdmi ; sorties nombreuses : le passage d'une sortie à l'autre se fait via l'appli Eversolo sans intervenir sur les branchements ; lecture gapless tous formats en streaming via l'appli uniquement ; qualité sonore en hdmi ou via DAC interne
- Défauts de fonctionnement : certains fichiers dsf stereo ou multicanal non lus (pourtant lisibles sans restriction sur tous mes autres streamers ou DAP) ; implémentation dlna upnp non aboutie (limitation de la navigation sur NAS à 200 albums ou 100 dossiers par niveau ; pas de lecture gapless avec bubble upnp) ; gestion de playlist très insuffisante
David j.
FGA-102 Transformateur Stéréo Ligne Boucle de Masse RCA Ce transformateur ligne stéréo professionnel FGA-102 permet de réduire efficacement les interférences de signaux et les ronflements, pouvant survenir...
encore un produit excellent vendu par audiophonics
J'avais d'importants bruits numériques venant de mon pc connecté à un dac qui gênaient l'écoute (dès que l'ordi tournait un peu fort ou que je déplaçais la souris, j'avais droit à d'horribles ZZCHZRLZZZHHRZH). L'installation de ce transfo de ligne entre mon Dac Gustard 20h et mon préampli DIY d'excellente facture (sur schéma Marantz 7) a permis de réduire à néant ces interférences. Si comme moi vous êtes en PC audio et que vous rencontrez ce type de problème, ce transfo est parfait. La qualité de fabrication est, en outre, irréprochable.
Georges B.
ELFIDELITY AXF-107 Filtre d'Alimentation PCI Express / PCI Express 16x Le module AXF-107 de Elfidelity est un filtre d'alimentation à découpage pour ordinateur se raccordant en PCI Express ou PCI Express 16x et destiné à offrir un courant plus...
Ce filtre ne joue pas que dans la déco !
Le filtre de puissance AXF-107 est monté sur une ASUS Maximus Z690 HERO avec une JCAT USB EX sans jumper.
Pour obtenir le meilleur rendu sonore, le filtre a été placé sur le bus PCIE du haut, cela semble logique, puisque tout ce qui se trouve en dessous bénéficie du filtre. Un test avec la AXF-107 dans le bus PCIE du bas et JCAT en haut n'apporte aucune amélioration sur cette carte mère ASUS.
Un gain supplémentaire de qualité sera encore obtenu en éteignant les leds de la AXF-107, ceci en inversant les 2x3 dips, mais dites adieu aux effets lumière tant convoités mais tellement nocifs à l'audio !
Un autre test avec 2 AXF-107 (bien placées) est prévu ..
recommandé par le constructeur..
Francois B.
THIEAUDIO MONARCH MKIII Écouteurs Intra-Auriculaires IEM Dynamique Électrostatique 20 Ohm 99dB 20Hz-40kHz Avec des haut-parleurs et des ajustements actualisés et optimisés ainsi qu'une ergonomie considérablement améliorée, les écouteurs...
Je viens d'acquérir, il y a quelques petites semaines l’IEM de chez THIEAUDIO MONARK MKIII sur ce site.
Service très rapide (comme d’habitude) d’Audiophonics. Parfait.
Actuellement environ 100 heures d'utilisation en Symétrique 4,4 mm tant sur Walkman SONY NW-WM1AM2 (Modèle Japonais non plafonné), Shanling M9 et Ampli Casque /Dac Sony TA-ZH1ES et parfois Sony PHA2a.
J’utilises le cable fourni, de bonne qualité avec sa prise modulable en 4,4 mm, (celle ci d'ailleurs, de par son adaptateur se détache assez souvent, et constaté par d'autres utilisateurs sur des forums) mais aussi un cable de chez LunaShop et Ears Tips / embouts silicone d’origine, même si je viens depuis plusieurs jours de mettre des SpinFit W1, car j’ai une petite préférence personnelle pour ceux ci, mais dans tout les cas, je trouve un bon confort pour de longues sessions, malgré la taille des coques des MONARK MKIII et j’ai des oreilles normales.
Bref, de très bonnes associations, rien a dire, ça rend très bien et j'en suis vraiment pleinement satisfait y compris dans des styles musicaux divers).
(Pour le son, on trouve quelques avis et tests fiables sur cet IEM qui permettent de savoir a quoi on a affaire et de comparaisons avec d'autres produits équivalents)
Je préciserai que j'écoutes beaucoup d'électronique (Tangerine Dream, Jarre, Carlos, Tomita, Synergy, Steve Roach, Schulze, Pink Floyd etc etc... mais aussi un peu de voix variées : Maria Mena, Assala Nasri, Myrkur, Farmer, Krall, Rondstadt..., musiques de films..., un peu de classique : clavecin et musique d'orgue de différentes périodes et artistes.
THIEAUDIO Monark MKIII : en bref :
Pas d’effet WOW ! a la première écoute, je dirai ici que ce n’est pas mon seul IEM, en effet j’utilise aussi les SENNHEISER IE 900, SONY IER-M9, SHANLING ME800, AFUL Performer 8 et… THIEAUDIO Oracle MKII.
Design simple de base, (je préfères la déco de l’Oracle MKII) mais personnalisable sur le site du fabricant.
Sans rentrer dans les détails, car chacun aura surement un avis différent, en fonction de ses gouts, sources, fichiers musicaux, et que les avis ou reviews du web sont globalement très bons.
Il demande moins de puissance que l’Oracle MKII (surement une histoire de Sensibilité et d’impédance en liaison avec mon matériel d’écoute.
Package typique Thieaudio : vraiment le minimum, mais ça fait le Taf. Je n’ai pas essayer les Embouts en mousse.
J’apprécie beaucoup le son donc son rendu, avec MES oreilles (Pas de Sibilance ou d’aigu agressif, belles basses profondes et organiques si la piste le réclame, (même si l’Oracle MKII est vraiment très agréable aussi), en fait cela pourrait être une fin de jeu en soi.
Je n’ai pas ressenti spécialement qu’il est eu besoin de rodage, même si j’ai eu vraiment l’impression d’un quelque chose de mieux (équilibre ?) après 30/35 d’heures.
(En me basant sur quelques morceaux de musique différents que je connais bien et que j’ai réécoutés plusieurs fois depuis le début pour en tester les possibles évolutions.
j’ai également fait l’essai du changement de cable d’origine par celui d’Effect Audio l’Eros S qui semblent apporter un peu plus de subtilité dans les détails.
Quoi qu’il en soit, je suis pleinement satisfait de ce MONARK MKIII, au point qu’actuellement, il fait de l’ombre aux autres.
(Cela ne remet nullement en doute les qualités de ceux ci, juste une approche différente ou l’effet nouveau jouet).
Une belle découverte et choix que ce MONARK MKIII et qu’ Audiophonics nous permet d’obtenir sans passer par la case import de Chine.
Je ne peux que recommander
Et je n'en oublies surtout pas la qualité des fichiers, qui reste primordiale sur une bonne source pour en extraire la quintessence.
Eemeli T.
Impressive.
Very fast delivery - ordered on thursday, package was delivered on monday morning. Nice! What was not that nice was the way amplifier was packed. I was amazed that my amp was in one piece since there was virtually no padding in the outer box.
What comes to the sound and overall build quality of this amp, is pretty amazing and impressive, especially considering the price. So far very pleased with the product itself. Time will tell how durable it is.
Plamen T.
Great fit, easy to solder.
Great fit, easy to solder. Highly recommended, much better connection than banana plugs that use bolts to secure the cable.
Francois B.
- Service très rapide (comme d’habitude) d’Audiophonics. Parfait.
- Actuellement environ 100 heures d'utilisation en Symétrique 4,4 mm tant sur Walkman SONY NW-WM1AM2 (Modèle Japonais non plafonné), Shanling M9 et Ampli Casque /Dac Sony TA-ZH1ES et parfois Sony PHA2a.
- J’utilises le cable fourni, de bonne qualité avec sa prise modulable en 4,4 mm, (celle ci d'ailleurs, de par son adaptateur se détache assez souvent, et constaté par d'autres utilisateurs sur des forums) mais aussi un cable de chez LunaShop et Ears Tips / embouts silicone d’origine, même si je viens depuis plusieurs jours de mettre des SpinFit W1, car j’ai une petite préférence personnelle pour ceux ci, mais dans tout les cas, je trouve un bon confort pour de longues sessions, malgré la taille des coques des MONARK MKIII et j’ai des oreilles normales.
- Bref, de très bonnes associations, rien a dire, ça rend très bien et j'en suis vraiment pleinement satisfait y compris dans des styles musicaux divers).
- Je préciserai que j'écoutes beaucoup d'électronique (Tangerine Dream, Jarre, Carlos, Tomita, Synergy, Steve Roach, Schulze, Pink Floyd etc etc... mais aussi un peu de voix variées : Maria Mena, Assala Nasri, Myrkur, Farmer, Krall, Rondstadt..., musiques de films..., un peu de classique : clavecin et musique d'orgue de différentes périodes et artistes.
- Pas d’effet WOW ! a la première écoute, je dirai ici que ce n’est pas mon seul IEM, en effet j’utilise aussi les SENNHEISER IE 900, SONY IER-M9, SHANLING ME800, AFUL Performer 8 et… THIEAUDIO Oracle MKII.
- Design simple de base, (je préfères la déco de l’Oracle MKII) mais personnalisable sur le site du fabricant.
- Sans rentrer dans les détails, car chacun aura surement un avis différent, en fonction de ses gouts, sources, fichiers musicaux, et que les avis ou reviews du web sont globalement très bons.
- Il demande moins de puissance que l’Oracle MKII (surement une histoire de Sensibilité et d’impédance en liaison avec mon matériel d’écoute.
- Package typique Thieaudio : vraiment le minimum, mais ça fait le Taf. Je n’ai pas essayer les Embouts en mousse.
- J’apprécie beaucoup le son donc son rendu, avec MES oreilles (Pas de Sibilance ou d’aigu agressif, belles basses profondes et organiques si la piste le réclame, (même si l’Oracle MKII est vraiment très agréable aussi), en fait cela pourrait être une fin de jeu en soi.
- Je n’ai pas ressenti spécialement qu’il est eu besoin de rodage, même si j’ai eu vraiment l’impression d’un quelque chose de mieux (équilibre ?) après 30/35 d’heures.
- j’ai également fait l’essai du changement de cable d’origine par celui d’Effect Audio l’Eros S qui semblent apporter un peu plus de subtilité dans les détails.
- Quoi qu’il en soit, je suis pleinement satisfait de ce MONARK MKIII, au point qu’actuellement, il fait de l’ombre aux autres.
Raphael N.
PSVANE EL34-PH Tubes HiFi (Quad Appairé) Le tube EL34-PH de PSVane est une réplique du connu et reconnu EL34 de Philips, largement utilisé dans de nombreux amplificateurs à lampes. Il est ainsi...
Smooth sounding EL-34s
J'écris cet avis en Anglais pour qu'il soit lisible de tous.
I share the other comments when it comes to Tube break-in. I went from Electro-Harmonix tubes (OEM on my Synthesis Roma) to these PSVANEs. At first the sound was dark and fuzzy. The voices were not forward anymore but in the far back of the sound stage. It's a derouting experience when you know they cost quite a fortune. But after 20 hours of listening the sound began to open.
Quickly after, voices were soft, warm, soundstage was clearer, and the highs were clearer.
Once you let these babies break in sufficiently, you get a good upgrade and lushy sound.
Tubes on themselves are gorgeous and the packing is top-notch. You have a verification sheet that proves the matching of the tubes with obtained results from the factory (handwritten).
The minor con I see is in the price/benefit ratio. You need to embrace diminishing returns with these tubes. Compared to my mid-life OEM Electro-Harmonix, these PSVANE brought just around 20% of an upgrade (if you consider slightly more open sound stage and clearer highs). But if it had to be done again, maybe I would've spent these 350€ somewhere else for more results.
Note : I'm using these tubes after an excellent phono preamp, on a mid-tier Tube Amp (Roma96DC), listening on vinyl only over wonderful vintage Cabasse speakers.
Carlos P.
DAC TV MS8413 Convertisseur SPDIF Coaxial Optique vers Analogique RCA Ce DAC optique coaxial basé sur un convertisseur MS8413 est idéal pour une conversion simple, pour une TV par exemple.
Bon convertisseur numerique analogique
Mon téléviseur Panasonic 4K n'a qu'une sortie audio optique. Ce convertisseur numérique analogique économique est idéal pour écouter n'importe quel programme TV via un amplificateur et des haut-parleurs externes. Je l'alimente via la sortie USB du téléviseur avec le câble de connecteur cylindrique USB-5,5-2,5 mm fourni dans la boîte. De plus, comme il me restait un filtre USB Ifi, je l'ai mis et le son s'est amélioré.
Jean J.
PHIREE U2S 2019 Interface USB vers SPDIF SA9023 OTG 24bit 96kHz Noir Le Phiree U2S 2019 est une interface USB vers SPDIF et Optique, efficace et compacte. Elle se base sur une puce Bravo SA9023, supportant des taux d'échantillonnage...
Magique ....
Ce petit module est super pour envoyer le son d'un PC vers un équipement audio en ayant une isolation galvanique qui garanti
l'absence de boucle de masse et de toutes perturbations électriques.
Il est reconnu immédiatement sous Windows et s'enregistre dans la liste des périphériques audio.
Un excellent rapport qualité prix.
Sebastien D.
SHANLING MTW300 Écouteurs Intra-Auriculaires IEM Bluetooth 5.2 QCC3040 aptX Gris Les écouteurs intra-auriculaires Bluetooth Shanling MTW300 reprennent le design ergonomique et confortable des MTW100, dans une version aux performances...
je corrige mon avis précédent, ces écouteurs sont excellents en terme de son et aussi d'appairage, bizarrement depuis un nouveau smartphone il n'y a plus de probs d'appairage, je venais d'un oneplus 6t et maintenant un oppo find x5 et tout fonctionne impeccablement bien, le tactile pour les pauses et redémarrage de lecture, pour le prix certes c pas rien mais la qualité et vraiment excellente donc un gros 5/5 au final
Rodolphe G.
SMSL AO200 MKII Amplificateur Class D Symétrique MA5332MS Symétrique Bluetooth 5.0 Subwoofer 2x160W 4 Ohm Le SMSL AO200 MKII est un amplificateur numérique Class D compact et performant, capable de développer une puissance de 2x160W sous 4Ω grâce à sa puce...
Je comprend pas …
Acheté pour alimenter des Audience Nova T4 suite à une panne sur un ampli Vincent SP994 je ne m’attendais à rien de mieux qu’un dépannage en attendant mieux. Et bien c’est la claque en pleine G….. ! Ce petit intégré smsl en classe D m’a laissé sur le cul ! C’est mieux que le vincent qui déjà me donnait pneu e satisfaction. J’avais un Atoll IN400SE que j’ai revendu tellement cet ampli était anémique et pourtant il m’avait coûté 5500€ ! Le atoll est littéralement explosé à tous les niveaux par ce smsl AO200 mk2 !
Ne réfléchissez pas, foncez dès que vous aurez l’occasion d’en trouver un en stock, c’est impossible d’être déçu pour 250€ même en comparaison avec des amplis de marques ésotériques à 20x le prix de ce petit génie…
christopher l.
Connecteur RCA Coudé 90° Plaqué Or Ø6mm (La paire) Ces connecteurs RCA à petit prix mais cependant de très bonne facture sont coudés à 90°, et donc particulièrement pratique pour des...
grande satisfaction
RCA coudé de grande qualité livraison rapide
christopher l.
Connecteurs RCA Plaqué Or Ø6mm (La paire) Argent Ces connecteurs RCA de belle qualité profitent de contacts plaqués or, assurant une bonne conductivité électrique et résistance à...
très satisfait
RCA de grande qualité livraison rapide c'est parfait
christopher l.
grande satisfaction
RCA male coudé de grande qualité livraison rapide
Christophe P.
impressionant
venant d'une câble Connect Research d'une valeur approximative de 100€, j'étais un peu sceptique sur la plus-value de ce câble à un tarif assez conséquent. Certes, ça peut sembler superflus de mettre ce prix dans un câble, et pourtant, le résultat est impressionnant. Le spectre sonore devient parfaitement équilibré. La scène sonore s'aère, la polyphonie des compositions complexes devenant plus facile à discriminer. Dernier point non négligeable, la qualité des voix masculines comme féminines s'est grandement améliorée, devenant plus naturelle et moins agressive.
Christophe P.
BURSON AUDIO CONDUCTOR 3X GT DAC 2x ES9038 Amplificateur Casque Class A 10W Bluetooth 5.0 32bit 768kHz DSD512 Le Burson Audio Conductor 3X GT, combo DAC et amplificateur casque, pousse encore plus loin la qualité sonore unique de chez Burson, grâce à un nouvel...
excellent DAC - pré ampli et ampli casque
Que du bonheur dans l'écoute à partir de toutes les fonctions de cet appareil. Très bon ampli casque avec mon casque Audeze LC2.
DAC très précis dans la restitution de la scène sonore, de l'étendue du spectre sonore, de la dynamique et de la justesse des timbres. Il est relié en XLR à un ampli V70E Octave pour une lecture HI RES sur Qobuz via Bluesound.
Sur ampli tubes ok
J' ai déplacé ce câble de mon dac z6 vers mon ampli, il semble être plutôt a sa place dans cette configuration. En core en rodage, les basses sont un poil plus courte qu' avec un elecaudio CS 361.
jean-luc s.
trés bon achat
branché en double cablage à l ampli et cables nus aux enceintes,l apport de ces fiches banane est flagrant:+de dynamique,+de graves bien maitrisés,des aigus définis,donc une belle évolution de mon système hifi.
Laurent M.
Un bon câble H.P
Monté en bi câblage sur H.P à 4 borniers :
*ELECAUDIO HP-25OCC pour le Medium/Haut (les 2 borniers haut) avec connecteur coté ampli Red Copper et Tellurium coté H.P
*MOGAMI W3103 pour le Medium/bas (les 2 borniers Bas) avec connecteur coté ampli et enceinte Red Copper
* NEOTECH NEMOS-3080 pour les jumpers (4 mm²) en pur direct sur les borniers, pas de connecteurs.
C'est Excellent !
Pierrick V.
Récepteur / Émetteur Bluetooth 5.1 DAC SPDIF 24bit 96kHz Lecteur de Fichiers USB Ce combo récepteur/émetteur Bluetooth 5.1 est DAC permet de transformer une intégration audio classique en système audio sans-fil polyvalent et...
Pas cher mais...
J'ai retourné ce DAC immédiatement après l'avoir reçu et testé pour les motifs suivants :
- Imprécision du potentiomètre : le niveau ne monte presque pas sur trois quarts de la course, puis monte d'un coup sur la fin (moyennement gênant car on peut régler le volume avec la télécommande)
- En mode Bluetooth, il y a des micro-coupures intempestives lors de la lecture de musique (même avec le smartphone posé à côté du DAC, rédhibitoire pour mon usage)
- La voix (de très mauvaise qualité) qui annonce la mise sous tension, le changement de source, etc. est toujours à un volume très fort, quelque soit le volume qu'on ait réglé avec le potar ou la télécommande. Assez gênant si votre ampli est réglé à un niveau élevé derrière, je trouve en plus cette fonction totalement inutile.
J'ai testé l'entrée optique avec ma TV, avec une paire d'enceintes actives sur la sortie rca, ça fonctionne bien, correct pour le prix.
Je n'ai pas testé l'entrée coaxiale ni USB, ni la sortie Aux.
Daniel P.
Bien pour le son
Rien à redire à propos du son, mais la limitation à des câbles de moins de 17mm me gêne beaucoup, comme Fabian, j'ai monté du Viborg (à mon avis c'est la meilleure conception toutes marques confondues) j'ai ainsi monté du 18mm.
Difficile de trouver mieux a ce prix
Nice aluminium case
Sober, robust and good for DIY Project.
Fits well with the 3E Audio Module for instance and any LLC / PFC PSU. Rear panel is about 4mm and front one 10mm.
I recommend it )
MP-H250S48 Module d'Alimentation à Découpage SMPS 250W 48V 5A PFC Ce module d'alimentation à découpage SMPS MP-H250S48 est en mesure de délivrer une tension de 48V et un courant de 5A pour une puissance de...
MP-H250S48 SMPS with PFC : 42V to 51V
Good PSU with active PFC. Voltage range can be set between 42V to 51V max. Pretty stable with multimeter measurements.
Nice for TPA3255 amps for example (I am using it @ 42V/6A). Ripple is a little higher than my Connex PSUs. But it's still good and PFC is useful.
I recommend it for the budget )
3e-audio-260-2-29A : TPA3255 Measurements and feedbacks
Hi all,
This module is made in the state of the art rules ! check the Audio Science review Thread (daniboun) for measurements. Very well made and reliable TPA3255 module. Fully differential, SE mode could be supported by adding new OP amps only. So far : this module is neck to neck with the Topping RA3/PA5 with a 105DB Sinad : THD+N in 4Ω / F = 1kHz, Po =5W = 0.0007% .
I really recommend it !
Marijan S.
FURUTECH E-TP80ES NCF Distributeur Secteur Filtré 8 Prises NCF Traitement Alpha GC-303 Le Furutech e-TP80ES est un distributeur secteur sophistiqué et extrêmement bien conçu, éliminant de nombreux problèmes courants...
Meine bisher beste Netzleiste
Ich hatte bisher eine Supra Cables Netzleiste, diese hier führt im Vergleich zu deutlich saubererem Klang und tollen, tiefen, klaren Bässen.
Das mitgelieferte Stromkabel habe ich aber gegen ein hochwertigeres getauscht.
Und der Strom in Berlin ist anscheinend so schlecht, dass ich einen Supra Cables DC Blocker noch davor geschaltet beibehalten musste.
Martijn v.
Just amazing
The sound quality and the power are just amazing. This tiny package delivers a great sound with really nice details and amazing sounding low frequencies. The 48 volt 5a version is a must.
Herve M.
Mon ami
Câble qui se travaille très bien et qu'il est bien construit avec de bons matériaux . Je trouve qu'il est équilibré niveau tonalité associé à des jacks Neutrik N2X pour le branchement guitare . Pour les soudures le site Neutrik fournit schéma et indications , c'est parfait avec en plus la rapidité d'expédition et de livraison . Merci 1001 X .
Gaspard T.
DD TC28CPRO Adaptateur USB-C Mâle vers 2x USB-C Femelle OTG Cet adaptateur DD TC28 Pro se compose d'un connecteur USB-C mâle ainsi que de deux ports USB-C femelles, l'un compatible OTG et l'autre dédié à la...
Produit très bien fini qui répond parfaitement à un besoin spécifique (pouvoir recharger son smartphone pendant l'utilisation d'un dongle USB DAC)
Thierry R.
Envoi très rapide et protégé. L'appareil est bien conçu, ne chauffe pas, discret, sauf cette satanée led blanche, alors qu'il sert aussi en support home cinéma, donc dans le noir...
Le son n'est pas très chaud, mais c'est souvent le signe d'un manque de coloration et donc de distorsion.. les Klipsch Heresy lll en frontales sont bien reprises la ou le Yamaha rx V6 était un peu mou, les autres voies ont plus d'impact, les effets plus sensibles..
En le branchant, j'ai senti qu'il serait moyen avec les câbles Viard premium, que j'ai remplacés dans la foulée par une commande de simple, moins cher. mais très efficace Canare 4S11.
Il est relié au "préampli" par des RCA Canare L4e6 succédant à de vieux Mit...
J'aurais préféré les branchements H.P en bas, mais en pratique, ils sont mieux là où ils sont...
Un bon achat...
Michel S.
IAN CANADA PUREPI Module d'Alimentation Double à Supercondensateur / Batteries pour Raspberry Pi 5V / 3.3V Le PurePi de Ian Canada est un module d'alimentation audiophile compact, spécifiquement conçu pour les systèmes basés sur Raspberry Pi afin d'en...
Je voulais voir à quoi ça rimait cette débauche de cartes d'alimentations à base de supercondensateurs et batterie LifePo4 sur ce site. Pour satisfaire ma fringale, j'ai donc commencé par celle-ci et bien ! je ne suis pas déçu mais enthousiasmé, l’installation de cette petite carte électronique sur un Rapsberry pi 3 c'est la "cerise sur le gateau"
La petite framboise s'est transformé en une bête de course musicale, rien que ça. Bravo Ian Canada et Audiophonics. A mon avis, une réussite, et un accessoire indispensable.
