Vincent B.
Bof
Shigeo I.
Couldn't be more satisfied
A flawless power amplifier. The extension of the sound and the precision of left-right imaging are excellent—especially in solo...
Shigeo I.
outstanding cost-performance!
Purchased together with the Audiophonics LPA-S450ET. Since the power amplifier has a balanced architecture, when used with...
Avis clients - Il y a 19131 avis.
ADRIAN EMIL T.
SHANLING EC3 Lecteur CD ES9219C Bluetooth 5.0 LDAC 32bit 384kHz DSD256 Noir Le Shanling EC3 est un lecteur CD qui se distingue au premier coup d'oeil de par son format compact avec des mensurations de seulement 188mm de largeur pour 255mm et de...
CD-player Shanling EC 3 review
The parcel arrived in good condition.
The CD player was in its original packaging and factory sealed.
It is a good product that is worth buying.
Pros: very good sound; compact size and well build; good-looking; top-loading mechanism wich, from my experience, is more reliable than tray-loading mechanism; the transparent cover is made from glass, not plastic; you can play usb memory sticks up to 2 TB, through Eddict Player app; remote control; with volume of the cd-player you can control the level of the signal of the RCA output so that active speakers can be connected (not available for digital outputs).
Cons: only 1 year warranty; the user manuals are too brief (eg: it is not specified that the volume of the cd-player must be set to 100 when you connect the amplifier to the RCA output of the cd-player, because otherwise the output signal is too low and cannot be heard in the amplifier. Therefore, I thought the cd-player was faulty.); the USB connector is mounted upside down, so the USB stick is upside down; Edict Player app sometimes crashes; the remote control has a small operating angle; you can`t play music from computer; no Wi-Fi.
ADRIAN EMIL T.
Cable review
Good quality cable.
ADRIAN EMIL T.
Cable review
Good cable, good quality
Emmanuel S.
TONEWINNER ETM-2 Microphone de Mesure Omnidirectionnel pour Calibrage Home Cinéma Le microphone de mesure Tonewinner ETM-2 est conçu pour vous permettre, en association avec certains appareils home cinéma de la marque, d'effectuer la correction...
Fait son taff...
...mais le jack n est pas du 6.35 comme indiqué dans la description technique mais du 3.5...comme sur les photos. Fonctionne aussi avec un AD-7200HD si l on a un adaptateur jack 3.5/6.35 .
Sinon article expédié rapiidement en emballages cartons bien calé par du papier. Merci Audiophonics
Slav A.
Excellent cable, true tonal balance, good separation and darkness.
Slav A.
One of the must have cable.
Eric L.
Élément trop négligé
Ce LPSU25 alimente mon dac smsl sanskrit mkll et mon lecteur réseau nuprime omnia, résultat une meilleure définition, de tout le spectre ….
Merci à Audiophonics de nous proposer de tel matériel ☺️ à ce tarif.
Eric L.
Révélateur de potentiel
Je suis tellement conquis par la qualité du produit que j’ai commandé un deuxième pour la liaison pré ampli /ampli, le premier relis mon dac au pré ampli, tout semble plus naturelle, transparence et neutralité, la dynamique es t top…
Frank G.
ELFIDELITY AXF-106 Filtre d'Alimentation pour PC SATA / Molex Ce module Elfidelity AXF-106 a intégrer au sein d'un ordinateur est un véritable filtre d'alimentation qui permettra aux éléments de votre...
Installed in the Roon Rock server between the PicoPsu power supply and the two SSD hard disks (250GB RoonCore and 4 TB music data storage). In my system, audibly more calm and balance.
Grégory O.
Bonjour, il s’agit d’un bon module d’alimentation. Un grand intérêt pour la possibilité de réglage du courant de sortie selon le besoin à l’usage. Un grand remerciement au SAV pour les échanges techniques. Cordialement,
eric l.
DD TC35C DAC ALC5686 USB-C Mâle vers Jack 3.5mm Femelle 32bit 384kHz Cet adaptateur DD TC35C pour smartphone se compose d'un connecteur USB-C mâle et d'un Jack 3.5mm femelle. Il embarque de plus un DAC Realtek AL5686 permettant...
pour le prix le son est tres bon tres ample et ne craque pas à fort volume et reconnu toute suite par mon smartphonr (samsung s9+).
eric l.
IKKO LOT Adaptateur DAC USB-C Mâle vers Jack 3.5mm Femelle 16bit 48kHz Cet adaptateur et DAC Ikko Lot doté d'une part d'un connecteur USB-C mâle et d'autre part d'un Jack 3.5mm femelle. Il est notamment idéal pour vous permettre...
tres bon
fonctionne parfaitement ,le son est puissant et net
Steffen K.
TINYSINE AUDIO-B PLUS Module Récepteur Bluetooth 4.2 aptX SMA Si vous souhaitez fabriquer un amplificateur Bluetooth simplement et pouvoir streamer votre musique depuis votre smartphone, alors le module de réception Bluetooth AudioB...
Is working fine, but not the advertised chip
The module seems to work fine, but the description is not correct. It says it has the CSRA64215 Bluetooth 4.2 chip, and the one I received had the QCC3008 Bluetooth 5.0 chip on it.
Mark H.
Mr h
Not really worth the message money with a pi would of been more acceptable there are better units out there
Davorin V.
Module Contrôle de Volume Motorisé 50K Ce module de contrôle de volume très pratique est équipé d'un potentiomètre motorisé 50K, ainsi que d'une LED de réception IR....
Motorized Volume Control Board
Everything working as it should and board have output to switch ON or OFF some aditional board with relay on it - of course with remote controll :) Very usable. Motor works very slow but fast enough for me. With on Board LED Diode we see when you press ON/OFF Button on remote power is ON - LED IS SHINING and when you Controll Volume up or down LED IS BLINKING. Very satisfied ... Bravo
Davorin V.
AIYIMA T8 Préamplificateur à Tube 6N3 Amplificateur Casque MAX9722 DAC ES9018K2M Bluetooth 5.0 24bit 96kHz Aiyima propose avec le T8 un appareil polyvalent, à la fois préamplificateur à tube, amplificateur casque et DAC, et ce à un prix tout à fait...
AIYIMA T8 Tube Preamplifier
Sound and functionality very good fast delivery and good packed
Davorin V.
AIYIMA A08 PRO Amplificateur Class D TPA3255 2x220W 4 Ohm Bluetooth 5.0 Aptx-HD LDAC Le Aiyima A08 PRO est un petit amplificateur Class D, très puissant, performant et abordable. Il se base sur une puce d'amplification TPA3255 et un AOP NE5532P, lui...
Aiyima A08 Pro
Very good sound and look. Very good packed and fast delivery.
1877PHONO EVANJEL MK2 3.5-RCA Câble Modulation Jack 3.5mm vers RCA 1.5m Evolution remarquée de son prédécesseur, l'EVANJEL MK2 se distingue par un choix de matériaux de haute qualité et des finitions particulièrement soignées.
bon rqp
Restitution équilibrée transparente et homogène , plus naturel et épanoui que le oyaide du même type vendu sur ce même site . Tout dépend ensuite de votre source .
SYITREN R300 Lecteur CD sur Batterie Bluetooth 5.3 Blanc Le Syitren R300 est un petit lecteur CD affichant un design rétro du plus bel effet. Équipé d'une sortie optique Toslink et d'une sortie casque Jack 3.5mm,...
Utilisé sur la sortie casque avec un câble phono evanjel ( mini jack vers rca ) connecté à un ampli smsl ( enceintes 3 voies bc acoustique niger ) . Son transparent sans agressivité , on distingue la scène sonore qui respecte les divers plan de positionnement des musiciens et chanteurs , son naturel . Etonnant vu le prix .
Tomas H.
1877PHONO GC-09 Fiche Banane Verrouillables Noir Ø9mm (Set x4) Fidèle à son image de créateur "Haute Couture" en matière d'accessoires Audiophile, 1877 PHONO nous propose avec sa série GC des fiches...
Great!
Easy to work with
Looks nice and feels professionaly made.
The fitment and how it locks in the socket is fantastic! No movement what so ever!
Great for large diametres of cable. I paired it up with Mogami W3104 - easy peasy!
If aluminum body is the best?
Well I suppose that´s up to how you like your system to sound.
This cable worked really great in my system and beat the crap out of a 30 times as expensive cable.
It´s not allways the price - it´s the performance...
Frederic H.
TRIANGLE OPERA OS100C Câble Haut-Parleur Cuivre OFC 2x2.5mm² Développé par Triangle, les câbles pour haut-parleurs Opéra garantissent une excellente qualité de transmission du signal électrique....
Très bien !
Une excellente alternative au Sommer Orbit 225 , plus vif et tout aussi bon sur les autres registres
En plus le prix est canon
Janne P.
VIABLUE UFO Absorbeurs de Vibrations Ø35mm Noir (Set x4) Les absorbeurs Viablue UFO permettent d'amortir les vibrations néfastes en se plaçant sous vos enceintes ou appareils HiFi. Du fait de leur pression optimale sur...
Works as it should
Neat, goodlooking feet that does it job. And price is not bad for quality.
Alain S.
Excellent couteau suisse de streaming
Moins cher que la concurrence et offrant nettement plus de possibilités (Chromecast, entrées analogiques, trigger, connecteur RJ45 etc ...)
Il est aussi nettement meilleur ...
Il m'arrive aussi d'utiliser l'Airplay ... le commentaire de "Jakub M" sur le sujet est incompréhensible ... mais les clients de la pomme ne sont pas vraiment des techniciens ...
Frédéric B.
Rapport Q/P excellent
De nombreuses revues et mesures existent sur le net. En résumé l'interface est géniale et le DAC mauvais selon ces avis. Pour ma part, je trouve l'interface en effet très pratique (ancien propriétaire d'un Lindemann DSD25) et le DAC tout à fait correct! C'est un peu "sec" mais avec une bonne séparation des instruments et des voix. Pour le prix, allez-y !
Module amplificateur mono Class D TPA3255 1x 140W 4 Ohm Ce module d'amplification mono intègre une puce d'amplification TPA3255, lui permettant de développer une puissance conséquente de 1x250W sous 4Ohm (1%...
Ampli de qualité
Très bon rapport qualité prix pour cet ampli qui peut fonctionner en large bande ou pour alimenter un caisson de grave. Le son est excellent, musical , aucun souffle. Il est utilisé dans une ancienne radio de 30 litres avec un HP de 93db et un tweeter, le niveau sonore atteint est plutôt élevé.
Laurent z.
Une des meilleures toutes marques confondues
Ça faisait un moment que je voulais essayer ce câble mais je ne suis plus aussi habile qu’avant pour des câbles aussi technique à monter. Et au miracle pour moi quand j’ai vu qu’audiophonics le proposait et je ne regrette rien. Ce câble est magnifiquement bien monté, les fiches XLR sont superbe, quand au son, c’est un mélange avec un parfait dosage entre transparence,définition, dynamique, aération et douceur. J’ai une dizaine de câbles ( ayant plusieurs enceintes et amplis) : siltech wireworld phono cardas furutech et j en passe , bref que des modèles reconnus, et bien ce neotech est celui qui a le plus de qualité rassemblées dans le même câble. Ce n’est pas pour faire de la lèche mais il n’y a que chez audiophonics qu’on peut trouver ce genre de pépite à ce tarif là . N’hésitez pas même sur un système HDG ( pour moi un ampli MBL qui ne pardonne rien) Encore merci de l’avoir proposé déjà monté….bluffant !!!
AUDIO-GD DI-20HE Interface Digitale Amanero Accusilicon 32Bit / 384kHz L'interface Audio-GD DI-20HE est basée sur un module USB Amanero Combo 384 couplé à une paire d'horloges Accusilicon 90/98M. Le circuit est conçu...
Excellent.
Commande passée le 21 février et reçue le 24.
Le DI20HE est exceptionnel. En USB en sortie d'un Roon Core.
Il sort en I2S sur un R27HE.
Pas encore rodé, mais déjà très bon. Les silences sont plus profonds, le scène sonore plus définie et un poil de matière en plus.
Dans ma configuration, c'est juste parfait. Si le rodage améliore encore le rendu, alors jusqu'où ça peu encore s'améliorer ?
Je ferais un autre compte rendu plus tard. Pour l'instant, j'écoute...
Jean-Pierre B.
TOPPING A30 PRO Amplificateur Casque NFCA Noir Le Topping A30 Pro est un amplificateur casque NFCA de grande qualité qui fera le bonheur des amoureux de l'écoute au casque. Avec ses deux sorties casque à...
Véritable 'pépite'...
Ce 'petit' Ampli-Casques est tout simplement sensationnel !
En effet, pour son prix modeste, et en dessous des 800 à 1000 eur, impossible de trouver un ampli capable de 'pousser' mon AKG 340 qui est monstrueusement gourmant en puissance avec ses 2 x 400 Ohms !
Non seulement il arrive à bien 'driver' l'ogre 340 mais en plus la qualité sonore est au Rendez-Vous ! (DAC à 2700 eur en amont tout de même !).
Donc, avec une bonne source vous aurez un grand plaisir d'écoute de TOUS types de casques (3 niveaux de gain) pour un budget abordable. Merci AUDIOPHONICS pour vos produits 'miracles' abordables.
Gyorgy H.
Déçu
J'ai voulu tenter de remplacer les JJecc83s sur mon ampli à lampes Synthesis. Après une dizaine d'heures de rodage les PsVane ne tiennent pas la comparaison. Manque de basses et de dynamique. Ça ne percutte pas. De même la richesse sonore souvent évoquée tourne plutôt au brouillon sur mon système : Dac Pegasus, enceintes tqwt Supravox. J'ai remis les Jj.
Gregory G.
VIBORG BP-604 (G) Borniers Cuivre Pur Plaqué Argent / Or 24K 5µ Ø4.5mm (Set x4) Les BP-604 (G) de chez Viborg sont d'excellents borniers, idéaux pour des montages DIY de très grande qualité. En effet, ceux-ci intègrent un...
Borniers Viborg
Je suis trés satisfait de mon achat. Ces borniers sont de trés bonne qualité, bien meilleurs que mes borniers dorigine triangle antal Ez. Serrage puissant, ouverture du son grâce à la bonne qualité des connecteurs. N'utilisant pas la double amplification ou le double câblage j'ai supprimé les borniers graves et réuni le cablage interne grave et aigu sur les borniers viborg avec les vis de serrage.
Moins de connections = moins de pertes, amélioration du son incontestable dans mon cas.
Serrage du câble sommercable sc-dual blue directement dans le bornier, il est parfaitement bloqué.
Miroslav T.
High level line level audio transformer
I tried to form a low level signal to power subwoofer crossover, but this dvice introduced strong hum and brum and was not useable at all. I guess it should be shieldes somehow as hum changed when I move a transformer but never dissapear.
Guillaume B.
TOPPING L30 II Amplificateur Casque NFCA Préamplificateur Argent Topping dévoile son L30 II, évolution du très bon amplificateur casque et préamplificateur L30. Cette nouvelle version reprend la base de...
Parfait sauf...
Arrivé rapidement et très bien emballé. Fonctionne parfaitement, et facile d'utilisation. Je suis malheureusement déçu par le bloc d'alimentation, qui fait 9cm de long par 5cm de large par 6cm de haut... Énorme et consomme aussi énormément pour une sortie 15v 1a, il consomme 6w au repos et je n'ai pas pu tester sa conso en charge. Pour comparaison mon chargeur téléphone consomme moins d'1w au repos et 3w en charge en sortie 15v 3a...
En fonctionnement l'ampli chauffe légèrement (normal pour un classeA) mais même après des heures d'utilisation, il est juste tiède au touché.
Et enfin le son ! Extrêmement propre, hyper réactif, puissant, pourrais sûrement détruire mon casque et pousse facilement aux maximum mes haut-parleurs, sans distorsion !
Guillaume B.
TOPPING E50 DAC ES9068AS XMOS XU216 Symétrique MQA 32bit 768kHz DSD512 Argent Topping propose avec son E50 un DAC compact et très performant, utilisant des composants audio éprouvés et largement reconnus par les audiophiles. Celui-ci...
Parfait sauf...
Est arrivé très vite, bien emballé (mais il n'y avait plus le plastique de protection ?), Fonctionne parfaitement, facile d'utilisation même si j'aurais aimé pouvoir changer le volume autrement qu'avec la télécommande IR. Et il y a aussi l'histoire toirevdes filtre... Aucunes explications et impossible de les désactiver. Sinon le son est sublime, presque impossible d'entendre du bruit.
Eric E.
SMSL SU-6 DAC ES9038Q2M XMOS Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 Argent SMSL propose avec le SU-6 un DAC performant et abordable, profitant d'une conception soignée garantissant une restitution sonore précise.
Bien, bien. Et bien.
J'ai deux Sanskrit mk2, fiables et sans failles, qui m'ont donné une belle confiance en la marque SMSL. Je viens d'acquérir le SU-6 et c'est encore mieux. Logique, je vais continuer à monter en gamme avec SMSL.
C'est hors-sujet mais je l'écris quand même : il y a eu un grand boum de la reproduction sonore autour des années 80, nous traversons un nouvel âge d'or. Vraiment.
Eric E.
Longueur...
Le câble fait en réalité un 1,2 mètre. Du coup je ne peux rien en faire. Mais c'est pas grave puisque le SAV Audiophonics est nickel.
Christophe M.
ben mazette
Reçu en cadeau en remplacement d'un Chromecast audio, en v'la une belle surprise. Facile d'installation, fonctionne parfaitement avec Qobuz en 192 et en plus est gapless, que demander de plus? Branché en optique sur un Rega Mydac, je n'arrive pas a aller me coucher tant je me fais plaisir à petit prix
Vincent D.
DAYTON AUDIO DCS165-4 Classic Haut-Parleur Subwoofer Kevlar 100W 4 Ohm 87dB 36Hz - 1100Hz Ø16.5cm Ce haut parleur pour subwoofer de 16.5cm propose une fréquence de coupure de 36hz. Il permet la conception de petits caissons de grave de qualité et abordable. un...
Good subwoofer
I build it in a closed box with the recommended box size. The sub cut off is 120 hz in my setup. The bass is good and tight. The metal that holds the wire terminals bends easy. So support it when pushing in the terminals.
Vincent D.
DAYTON AUDIO DC28FT-8 Haut-Parleur Tweeter à Dôme Soie 50W 8 Ohm 89dB 1300Hz - 20kHz Ø2.8cm Ce tweeter à dôme en soie de 28mm fortement inspiré des solutions nordiques prestigieuses procure un son soyeux, agréable et de haute capacité...
Very good cheap tweeter
Good tweeter for the money. The tweeter sounds nice and clear. 4 stars because the tweeter membrane is covered in some sticky stuff which dust will stick to. A dust cover is a must for this tweeter!
Vincent D.
Good quality
Good quality stands.
Guillaume B.
Bon streamer, fait ce que je lui demande à savoir lire ma bibliothèque musicale stockée sur HDD connecté à ma box. Raccordé en toslink à un DAC le son est pas mal mais pourrait être mieux. Vais devoir investir dans un câble optique de meilleure qualité que celui livré avec le Wiim et je verrai bien...
Patrick R.
GUSTARD DAC-R26 DAC R2R Discret I2S Bluetooth LAN AirPlay Roon DLNA 32bit 768kHz DSD512 MQA Argent Gustard dévoile avec son DAC-R26 un convertisseur numérique / analogique absolument exceptionnel. Celui-ci utilise une architecture R2R utilisant des composants...
Extra
Ce DAC qui embarque à la fois un streamer (utilisé dans mon cas avec Roon et/ou HQPlayer) est absolument fabuleux en terme de précision transparence et détails. La scène sonore est vaste. Il se dégage un certain naturel dans la restitution. Je pense que du fait de toutes ces qualités, il faut prendre soin à ce qu'on met pour accompagner cet appareil.
Le grave est massif ou autoritaire selon l'appréciation ou son système, mais très bien controlé toutefois.
Le fait de pouvoir se passer d'un streamer est vraiment très appréciable. Je pense qu'il doit falloir investir beaucoup pour aller plus loin que le streamer intégré.
Des petits moins qui sont à signaler et peuvent concerner certains:
- En mode LAN (streamer), l'UPnP présente semble t'il avec la dernière version du firmware (v1.4) des petits problèmes. Ce sera surement corrigé mais pas d'info claire de Gustard encore à ce jour.
- La documentation très très légère.
En comparaison avec un Tefnout de hifi câbles déjà très bon dans sa game de prix le viablue montre beaucoup plus de profondeur et de souplesse. C'est très défini mais sans côté insistant dans l'aigu du Tefnout. Pour finir les basses sont bien plus pleines et donnent beaucoup d'ampleur a la restitution. Je confirme les commentaires avec Patricia barber c'est somptueux.
fais le job
Restitution neutre et fidèle ; vu le prix aucune contestation possible .
AUDIOPHONICS TPA-S120 Amplificateur 2.1 Class D 2x TPA3255 Bluetooth 5.0 QCC5125 2x120W + 1x240W 4 Ohm Noir Le Audiophonics TPA-S120 est un amplificateur Class D capable de fournir une puissance confortable et une restitution sonore riche, le tout à prix contenu. Au cœur...
4 étoiles
Ses points forts : un punch et une énergie accompagnés d' un suivi rythmique qui procure une écoute enjouée . Une scène sonore qui s'élargit laissant place aux musiciens . J'ai était obligé d'orienter mes panneaux magnepan MG 1.7 de façon moins concentré vers le point d'écoute .
Ses points faibles : La qualité du médium notamment sur l'entrée analogique rca est limitée ( à tendance à miauler légèrement) . On retrouve ce phénomène en Bluetooth et optique mais de façon moindre . Défaut acceptable vu le prix .
Conclusion : Ecoute un peu typée mais pas caricatural ; idéal pour une chaine secondaire . Toutefois je préfère dans la même catégorie de prix SMSL en vente sur ce même site plus fidèle musicalement mais plus sage dans sa restitution .
Bruno C.
EVERSOLO DAC-Z6 DAC 2x ES9068AS XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA Le DAC-Z6 de EverSolo est un DAC performant basé sur une structure technique soignée. Il embarque des composants haut de gamme avec notamment deux puces de...
PRELIMINAIRES
On va faire monter la température en douceur!
Le premier contact avec le produit est très positif et surprenant.
La présentation du conditionnement est vraiment premium.
Ok, rien à voir avec les qualités musicales du produit mais un constructeur qui pousse la présentation et l'emballage de son produit à ce niveau ne peut pas prendre le risque de livrer une "bouse" au final.
De toute façon l'impression positive initiale concernant l'emballage se poursuit avec la prise en main du produit.
Assemblage, matériaux utilisés, la qualité perçue est vraiment d'un très bon niveau.
Et le son dans tout çà? J'avais bien dit que c'était des préliminaires. Juste 3 heures d'écoute qui se finissent l'air un peu bête avec un large sourire sur les lèvres, la tête encore dans un nuage musical dont l'espace sonore a augmenté de volume en re définissant la localisation spatiale des différents interprètes. De la matière, de l'épaisseur mais avec beaucoup d'air entre les notes pas cet effet maigrelet et éthéré qu'on entend malheureusement trop souvent. Combien d'entre nous ,pourtant satisfaits de notre système, reconnaissent devoir pousser le volume pour avoir cette sensation de corps, de matière, d'épaisseur. Avec le Z6 c'est bien la première fois que toute ces qualités se retrouvent dès les premiers db. Et si l'envie vous prend de pousser le volume pas de crainte de tassement ni d'agressivité ou de fatigue.
Très belle excursion du registre grave à la fois tendu et nuancé et montée des aigus sans crispation et semblant monter très haut. Le médium sonne vrai et place les interprètes quasi dans votre pièces sans faire trop d'effort. Au final une belle exploration de la bande passante assez linéaire et neutre mais pas sans émotion ni musicalité.
Pour le moment ce qui m'embête le plus avec le Z6 c'est que j'avais l'intention de changer l'ampli mais il m'a enlevé cette envie en me donnant ce que j'attendais de mon système.
Adieu nouvel ampli mais bienvenue à la musique.
Merci Z6 et à Audiophonics qui comme d'habitude par leurs conseils et disponibilité ont fait mouche.
Je conclurai en rappelant que Le Z6 coute moins de 500€ et que tout jugement comporte une part de subjectivité.
Si vous avez compris ça alors oui produit hautement recommandé.
Salutations à toutes et tous.
Wissem B.
TOPPING G5 Amplificateur Casque NFCA DAC ES9068AS Portable Bluetooth aptX HD LDAC Argent Topping présente avec le G5 un amplificateur casque et DAC portable à la fois compact et performant. Celui-ci intègre notamment un puissant étage...
Topping g5
Excellent ampli dac. Peut conduire les intras les plus sensibles tout un casque du calibre du Sennheiser hd800s. Fonctionne mieux avec des intras full armatures équilibrées, ou à base de driver dynamique comme mes unique melody 3dt (triple DD)
Laurent F.
DD TC09S Câble USB-C Mâle OTG Argent / Cuivre OFC 50cm Le câble USB-C DD TC09S profite d'une conception parfaitement maîtrisée, utilisant des composants de très grande qualité afin d'offrir une...
J'ai acheté ce câble pour connecter mon Earmen Angel (super Dac/Amp) à mon PC et mon Smartphone.
Comme souvent avec cette marque, la qualité et la finition est irréprochable.
Le prix est élevé, c'est vrai, mais le produit est vraiment très bon.
A chacun de décider si il est justifié.
david b.
NEOTECH NEUB-1020 Câble USB-A Male/USB-B Male 2.0 Argent pur plaqué Or 24k 1.5m Le câble USB AUDIO class 2.0 Neotech NEUB-1020 offre une qualité de restitution numérique redoutable utilisant des technologies innovantes venant bousculer la hiérarchie des...
Conforme
Câble conforme à mon attente, n'est pas fait de comparaison mais semble dans le haut du panier.
david b.
SMSL D400ES DAC ES9039MSPro XMOS XU316 11x OPA1612 Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA Avec son DAC D400ES, SMSL revient sur le devant de la scène en adoptant la toute dernière puce DAC haut de gamme ES9039MSPro de chez ESS. Associée à...
Beau produit
Aspect du produit convaincant, mise en place facile, le réglage nécessite quelques essais afin de trouver les bons paramètres, première écoutes un Poil fatiquantes.
Je suis confiant du rendu après le rodage.
Service audiphonics bon !
Franck B.
AUDIO BASTION X-PAD III Contrepointes Aluminium Acier Inoxydable Ø50mm (Set x4) Conçues en acier inoxydable polie à la main et aluminium T6061, ces contrepointes sont pensées pour réduire efficacement les vibrations de vos...
Bien conçu et efficace .
Système d'insert en caoutchouc entre le récepteur conique de la pointe et l'embase ,très efficace .
