Hasni Z.
Top qualité.
Bonne épaisseur et résistance une fois réduit.
Bon sèche-cheveux indispensable (merci madame :)
Hasni Z.
Bon rendu final
Pour un câble de 1,90 m, j’ai commandé 2 mètres mais c’était trop juste… solution : j’ai dû réduire la taille du câble à 1,80m...
Hasni Z.
Excellente qualité de fabrication.
Tout juste monté sans difficulté et un tuto existe sur ce site.
En rodage avec le câble qui va bien sur un Heed Lagrange S.
AUDIOPHONICS LPSU25 Linear Regulated Power Supply EMI RFI Filter 220V to 12V 1.25A 25VA - reviews - There are 17 reviews.
Marc F.
TB qualité, fait parfaitement le job
Achetée pour alimenter le préampli FX-AUDIO Tube01. Une alim classique qui respire la qualité et "assurera" sans doute durant de longues années !
Markus H.
Great progress for little money
The heart of my hi-fi system is a miniDSP 2x4 HD. I use it as a crossover for my DIY FAST dipole speakers and for room equalization. So I thought it might be a good idea to replace the cheap plug-in power supply of this important device with this linear power supply. Given the low price, I thought I might give it a try. After a long evening of listening and testing, I now ask myself why I didn't think of this earlier. Sound impressions are always subjective, but I can clearly say that there is a sound gain. Music from any source (vinyl, CD, HiRes USB audio) sounds more confident and powerful, the stage has become wider and deeper. By nuances, but always clearly audible. As a non-technician, I can't really answer how this can be, but apparently a stable, clean power supply makes sense also for digital devices. Incidentally, as my DVD player also runs on 12 volts, I can use the second socket on the power supply unit for this. Now all the "wall warts" have disappeared from my hi-fi setup. So I would advise anyone who owns a miniDSP or similar processor: Buy an Audiophonics linear power supply!
Many thanks also to Audiophonics for the fast delivery to Germany despite the Christmas period.
Dominic D.
Mr.
Great product! Has all the bells and whistles that you would expect from a good LPS. High grade parts are used. Good value for the price.
Thank you!
Philippe D.
Excellent
Simple de mise en route, zfficace
Miroslava L.
Very happy with delivery and quality. Very serious business, great communication and fast delivery
Miroslava L.
Gregory K.
Super et Merci Audiophonics
Bonjour,
J'ai acheté l'alimentation de la carte Matrix element H pour l'alimenter et elle fonctionne bien.
De l'extérieur, l'alimentation électrique semble très bien faite et comporte un interrupteur marche/arrêt.
On ne peut pas en voir plus de l'extérieur.
Je n'ai pas ouvert la vie intérieure.
À travers les fentes, je peux voir des pièces de haute qualité.
Et il fait ce qu'il doit faire.
Pour le prix, il n'y a rien de mauvais à signaler. En combinaison avec la carte Element H, j'ai reçu une croissance significative.
Ce qui ne peut que signifier qu'il fonctionne comme le pensait Audiophonics et ne peut que les remercier de proposer une alimentation électrique raisonnable et abordable sans le grand vaudou que l'on voit chez les autres fabricants.
J'achète à nouveau et je pense en acheter un autre pour le système téléphonique.
Merci beaucoup à Audiophonics.
Christian G.
Très belle fabrication.
Cette alimentation linéaire vient compléter à merveille la carte Matrix élément H. L'alimentation ne chauffe pas, elle est totalement silencieuse. Elle apporte un surplus de de transparence et de fluidité à la liaison USB de la carte Matrix et ceci pour prix plus que raisonnable.
jean francois F.
alimentation 12v
excellent produit, nette amélioration de l'écoute sur mes deux convertisseurs FX audio. On est pas encore au niveau de sérénité d'une écoute sur batteries mais on approche et le côté pratique est un plus (possibilité d'alimenter deux appareils). Attention cet appareil mérite des cordons de qualité, celui vendu par audiophonics (jack -jack 2,1) est excellent
Stephan C.
Good value PSU
I use this PSU with my FX-Audio Tube-01 pre-amp. It's working great.
ANTONIO M.
muy buena fuente lineal
Indispensable para mi DAC irDAC-II de Arcam. Ahora sí suena bien bien bien
felix j s.
Very good LPSU, for example for some daisy chained LAN-switches.
Denis Gabriel G.
Exeptionnel
J'ai acheté l'alimentation avec le Câble secteur Pangea et le cable alim jack Elecaudio JVC 121. L'ensemble remplace l'alimentation "usine"de mon Dac ARCAM IrDAC.
Le résultat est stupéfiant. Mes enceintes JMR Folia Jubilé on gagnée une ouverture et une profondeur incroyable.
Cet achat, certes onéreux, me semble indispensable pour optimiser les DAC d'un bon niveau.
Zergosi M.
Grande prodotto
Acquistato x alimentare una scheda X Matrix USB collegata al PC ad uso audio è veramente sorprendente come abbia rivoluzionato il suono del mio impianto veramente soddisfatto di questo prodotto
stephane d.
une alim qui alimente
Merci et bravo a audiophonics.
j'ai acheté cette alimentation pour un dac RME.Le but était de ma débarasser d'une polution secteur sensible.Le but a été atteins mais pas que.Mon dac a gagné en perf en particulier dans le bas du spectre et a part une led blanche qui éclairerait le stade de france c'est que du bonheur
 (4)
Philippe G.
un grand plus pour un modem routeur
cette alimentation remplace le petit boîtier 12v d'origine de mon modem/routeur sur lequel sont raccordés le NAS et le lecteur réseau pour une amélioration sonore immédiate ! incroyable.. test comparatif fait avec Songbird de Eva Cassidy notamment.. bravo Audiophonics, je suis plus que jamais votre client !
Rémi J.
indispensable
Définitivement meilleure que l'alim d'origine de mon processeur DSP/DAC miniDSP 2x4 HD, indispensable pour en tirer le meilleur !
