Schiit VALHALLA 2 Amplifier Tube Headphones Zero Feedback
Schiit VALHALLA 2 Amplificateur Casque à lampes Zero Feedback
Reference : 8910
469,00 €tax incl.
390,83 € tax excl.
Schiit VALHALLA 2 Class A Tube Amplifier Zero Feedback
Valhalla 2 is a complete reinvention of the Valhalla, with improved performance, higher capacity, lower distortion and output impedance.
This class A tube amplifier is standard equipped with the best components on the market (Alps potentiometer, Dale resistors, Wima capacitors ...).
This will give you a warm and detailed sound as well as sustained bass.
While most OTL tube amps are really only designed for 300 ohm and 600 ohm headphones, Valhalla 2 allows you to use other types of headphones to reveal the best. Try it with an AKG or a Grado!
Characteristics :
  • Frequency response: 20 Hz-20 kHz, -0.1 dB, 7Hz-200KHz, -3dB
  • Maximum power, 50 ohms: 180mW
  • Maximum power, 300 ohms: 800mW
  • Maximum power, 600 ohms: 450mW
  • THD: <0.04%, 20Hz-20KHz, 1V RMS
  • IMD: <0.05%, CCIR to 1V RMS
  • SNR:> 97dB
  • Crosstalk: <71 dB-, 20 Hz-20 KHz
  • Output impedance: 14 ohms, 3.5 ohms
  • Gain: 7 (16.9db) or 1.5 (3.5 dB)
  • Tubes: 6N1P, 6N6P, 6N1Ps
  • Power Consumption: 40W
  • Size: 23 x 15 x 8 cm
  • Weight: 3kg
https://www.audiophonics.fr/images2/8910/8910_schiit_valhalla2_5.jpg
https://www.audiophonics.fr/images2/8910/8910_schiit_valhalla2_4.jpg
https://www.audiophonics.fr/images2/8910/8910_schiit_valhalla2_3.jpg
https://www.audiophonics.fr/images2/8910/8910_schiit_valhalla2_2.jpg
https://www.audiophonics.fr/images2/8910/8910_schiit_valhalla2_1.jpg
