iouri C.
Au final déçu.
Déception (pour ma part) sur mon primaluna et enceintes highland. Tubes de préamp TOUS en psvane serie S. Après quelques...
Antoine S.
CD Player Upgrader
C'est le produit idéal pour mettre à niveau sa platine CD pour un tarif modéré.
Je suis très satisfait par le gain sur le...
Michel R.
Parfait pour mon usage
Ce petit drive est bien construit, de bonne qualité perçue, de riches possibilités de connections, avec une belle sonorité ....
AUDIOPHONICS MPA-S125NC RCA Amplificateur de Puissance Class D Stéréo NCore NC122MP 2x125W 4 Ohm - avis - Il y a 35 avis.
Jurijs B.
There's a day-and-night difference between this amplifier and all the others on the TPA3255 chip. The soundstage is much wider, the sound is more transparent, and there are more details. I use it with the Topping D70 pro Sabre as a preamplifier. Good punch. I could never imagine that my Heco Victa Prime 302, which I want to change, would sound so good. David's kindness was the reason I bought AUDIOPHONICS MPA-S125NC. Thank you very much, David!
Martin S.
Lacking Some Detail and Control.
The aim was to replace my Musical Fidelity KW500 with something physically smaller.
I paired the MPA-S125NC power amp with a Lehmann Black Cube headphone/preamp, which I know very well with various headphones and have for a short time used it as a pre-amp combined with a class A/B power amp.
I initially just listened to music to give it a fair test, after a couple of evenings listening, these were my thoughts. Pros: wide soundstage; pretty good instrument positioning; fairly musical / Negs: lack of detail in bass and generally getting a bit muddled in complex layered tracks.
I switched to some test tracks:
1) Elbow, Asleep in the Back. This trips up many systems, the sibilance on this track can make it almost unlistenable if it is not well controlled. Not a total failure here, but was struggling a bit.
2) Clearlake, Lido. A layered album. Struggling to keep it from becoming messy.
3) Animal Collective, Feels. Again struggling to keep control of everything, sounded too harsh.
4) Pepe Deluxé Queen of the Wave. Could quite get the power and majestic and theatrical quality out.
There were other test tracks, but the above were the ones to highlight what I believe are the issues.
Conclusion. Just not good enough to replace the KW500. Perhaps this is a bit of an unfair comparison as the KW500 was a lot more expensive. However, I do not feel I can live with the MPA-S125NC as a main system component.
Oliver B.
I am the proud owner of a preamp and power amplifier combination from a French manufacturer of first-class tube amplifiers. I actually ordered the small Audiophonics power amplifier with the intention of reducing the high power consumption of the tube combination when using it as a home cinema sound system (the tube power amplifier has 12 power tubes). At the weekend I had the opportunity to "test" the Class D power amplifier for the first time. To put it briefly: what the small power amplifier delivers in combination with the tube preamp is simply a small sensation. The sound is powerful and warm. The stage is large. Instruments can be located precisely. Vocals sound simply fantastic. I had not even remotely expected that from a power amplifier that costs less than a tenth of the purchase price of the preamp. The large tube power amplifier will probably only be used rarely in the coming weeks. Instead, I am looking forward to many hours together with the little "magic box". Thanks to Audiophonics. What you deliver for this price is simply unbeatable.
Edmond H.
MPA-125NC RCA
Commandé le dimanche et livré le mardi soir, parfait.
Ampli acheté pour driver des 'monitors' des 70's.....quelle claque !
J'ai eu une bi-amplification NAD qui ne lui arrivait pas à la cheville, que ce soit dans la faculté de gérer le HP de grave que dans la tenue des notes des medium/aigües.
Je suis maintenant dans la réécoute de mes meilleurs morceaux. De l'orgue au rock en passant par youn sun nah, rien que de l'exceptionnel.
Mes enceintes ont une impédance de 4 ohms, les 21 cms sont tenus, fermes, expressifs ( le bonheur ), alors que le reste du spectre est sensuel, précis, ciselé.
Je n'ai jamais entendu une différence telle sur un ampli.
Simple, de prix raisonnable, facilement logeable....Merci Audiophonics, vous m'avez redonné le sourire.
Balazs L.
A real step forward
Based on a year of problem-free use: accurate sound image and high level of detail, a huge step forward in my sound system
Marc F.
Parfait même pour enceintes paresseuses (84db) !
J'ai choisi ce 2x75W/8Ohm pour alimenter, en configuration bi-câblage, des Bowers & Wilkins 707 S3 à faible sensibilité (84db). La préamplification est confié à un FX-AUDIO Tube01. J'en ai également profité pour remplacer mes très vieux câbles d'enceintes et passer de 2x2mm2 à 2x2x4mm2 en ELBAC. J'ai souhaité optimiser et écouter différentes sources plusieurs semaines durant avant de poster mes avis sur ces matériels. La différence de rendu est toute à l'honneur de cette nouvelle configuration : l'ensemble du spectre sonore est devenu très intelligible, la dynamique est formidable et mon nouveau système se joue des fortissimo et grosses masses orchestrales ! Cet ampli de puissance joue parfaitement son rôle en restant très transparent et ne faiblissant en aucun cas. Je n'ai détecté pour ma part ni sifflante dans les aigues, ni "ploc" à la mise sous tension, ni quelque autre défaut que ce soit. C'est du tout bon, je recommande !
Emilio Y.
Good transparent and vivid amplifier
I bought the amplifier to replace my beloved Marantz PM-8005. Nowadays, I do not need most of the features that the integrated amplifier offers and I just wanted to have a simple amplifing block to link a Wiim Pro streamer (Tidal and Quobuz as sources), a Topping E30II DAC used as preamp and a pair of Dali Oberon 5. I had tried several cheap class D amplifiers in my secondary system and, although all of them performed well, I wanted to check whether Hypex Ncore modules made justice to their fame and measurements.
The amplifier arrived perfectly packed within a few days. 10/10 for Audiophonics! It is well built, robust and the connectors are also of really good quality. As expected, it is smaller and much lighter than my Marantz PM-8005 so it is a good alternative when espace is limited.
It has enough power to drive the Oberon 5 without problems and I have still quite a lot of margin using the volume control of the DAC to play to absurdly loud levels (definitely not healthy listening volumes). Regarding the sound (knowing is subjective and considering that I am by no means an audiofool), I have to admit that it is taking me a while to get used to it when compared to that of the PM-8005. I percieve a better detail, instrument separation and dynamics than in the Marantz, as well as better and cleaner bass control. However, I am missing certain soundstage and musicality or mellowness (some may call it distortion), which makes the PM-8005 a real pleasute to listen to in my system. I have the feelings that the Marantz is more forgiving with the quality of the source while, with the Ncore-based amp, poorly mastered records are almost inaudible.
All in all, really good option for reduce espaces or simple setups in which the conectivity of an standard integrated amplifier is not needed. Totally transparent, dynamic and with amazing bass resolution.
Richard Ö.
This amplifier sounds fantastic !
Having heard many different highend amplifiers the last 20 years, Im very impressed by the sound quality from this amplifier. It is very clean, neutral and powerful, and the spatial qualities and resolution are stellar.
The sound from this amplifier is an upgrade from the otherwise very good sounding Fosi V3 and Aiyima a07.
Ruben B.
a well build super clean amp
It's a great clean amp, a class D amp that does not sound like one like all NCore amps, it's just gain on a wire. Build quality is good, design is basic, but so is the price compared to other builds. The only complain is that the led on the power buttom is way to bright (but modable).
Eric L.
Un grand son
Capable de restituer avec beaucoup de fidélité la musique, sans vous faire les poches…
Il est associé au Pre-A préamplificateur classe A d’Audiophonics, un mariage qui tient toute ses promesses.
 (4)
Bernard a.
Très satisfaisant.
Très satisfaisant.
Streaming Qobuz HD studio sur PC
DAC : TC electronic bm-c2
écoutes : Magnepan MG 1.5qr bi-câblés
auditorium de 20m²
Il a remplacé 2 T-amp 75w/4Oh bridgés en mono
Les Magnepan sont gourmands, le NCore ne s'essouffle pas, même sur la musique de chambre et le préampli du DAC à encore de la réserve.
Impressionnant sur les grosses musiques symphoniques du XXème, genre Prokofiev, Sibelius, Chostakovitch, Malher, etc. Détail, scène stéréo, profondeur.
Ruben B.
Great clean neutral amplifer
It's a great clean amplifier, the quality that we know from NCore . The build is very well done, the case is sturdy, just like the connectors.
It has no trace, even very minimal, of the harshness that many class d amps have, it's just gain on a wire, very low distortion, and very high sound quality.
Only one remark, that led in the powerknob is way to bright for me, i'll try to mod that, but you should dim it and maybe make it something else than that annoying cold white colour. I prefer red or yellow myself.
The ordering and shipping went all flawless, and even in highseason (Christmas time) the delivery was fast and correct.
Payment was a bit a hassle, but that has more to do with my bank than with audiophonics, on their side no remarks.
Jaime S.
great value
This little amp is serious and transparent. The box is solid and appealing. Fantastic value for the money!
On top of that, the order-payment-delivery process worked without issue. Great stuff.
C b.
fait le job parfaitement
Le rendu sonore est excellent.Ampli relié à un denon avr 3313.
Hormis un souci d'extinction complète de mon ampli denon qui reste en veille quand je veux tout éteindre.Je ne sais pas à quoi c'est dû.
Jerker M.
Well built and plenty of power.
Very well built, sounds great, generates little heat and uses little power, very happy.
My one wish is that I would like the input above the speaker terminals.
Alexis R.
Impressionnant
Je cherchais à remplacer mon bc ex-222 pour un prix modique et je n’ai pas été déçu. Évidement l’ampli est solide dans les basse, son prédécesseur l’était aussi. Mais la finesse et la scène sonore sont sans comparaison !
Un rapport qualité son/prix a mon avis imbattable.
En cherchant la petite bête je relevé que certaines sifflantes ressortent mais sans que l’écoute soit fatigante. A voir après rodage. En tous cas je ne regrette pas cet achat.
Amont: lecteur réseau/preampli yamaha wcx-50
Aval : dynaudio emit 20
Franck R.
Excellent rapport qualité prix
J'ai acheté ce bloc de puissance afin de remplacer un FDA Alientek D8 dont je me lassait un peu. Il est connecté à un preampli Rotel rc 980 pour alimenter des Elipson planet L associées à leur caisson de basse dédié. En amont la source principale provient de fichiers flac lus par un PC via un Dac usb sabre es 9023.
Je suis très surpris et enthousiasmé par cette association qui me convient en tout point. C'est puissant, très puissant, dynamique, détaillé, et en même temps musical, pas fatiguant pour un sou. On se situe à un niveau ou ce système est capable de rivaliser avec des ensembles beaucoup plus honereux.
Bref, vous l'aurez compris, ces blocs Ncore sont une excellente alternative à partir du moment où vous prenez soin de les associer à des sources se situant à leur niveau.
A ce prix Je recommande chaudement !
David B.
Content de cet achat
Par rapport à la génération précédente, il est à présent possible de couper totalement l'alimentation à l'arrière du boîtier, les fiches HP sont plus qualitatives, le boitier est plus large er fait plus chic, belle évolution, il ne me reste plus qu'à l'écouter voir s'il y a amélioration, mais ça, j'en doute, le module interne semble identique, et comment améliorer le son de quelque chose d'aussi fidèle dans la reproduction sonore.
Merci Audiophonics, excellent rapport qualité prix.
Hans S.
Ampli of high quality
I replaced my 35 years old Technics amplifier with this Hypex Ncore endstage in combination with the Loxjie DS30 as preamplifier. Connected to speakers from TEUFEL UL40-MK2. I read some articles and test reports a few month ago. I really don't regret this purchase. One word only, WOUW, what a difference. What a gain on low frequencies, strait, dynamic, ...etc. A real pleasure to listen to my music.
Ludovic B.
Excellent ampli mais mauvais boitier (2019)
J'ai acheté cet ampli en 2019 pour remplacer le SMSL AD18 acheté un an plutôt ici même pour monter en qualité d’écoute.
Je n'ai pas été déçu, à côté l’AD18 parait bien fade !
Pas besoin d'être un expert pour se rendre compte que cet ampli à base d'Hypex NCORE est bien meilleur à la production actuelle.
Ses qualités sont le dynamisme, la neutralité et la clarté de l'écoute.
Pour vous donner une idée aller voir sur le site Audio Science Review le test du March Audio P122 équipé du même module pour lire son test.
Par contre il a un petit défaut, c'est le ronronnement qui provient de l'alimentation du trigger qui une fois éteint se fait entendre.
Donc si vous dormez dans la même pièce c'est insupportable, il faut à chaque fois le mettre sous tension.
Aujourd'hui AUDIOPONICS vend cet ampli avec ce bouton à l'arrière sauf qu'en 2019 ce n'était pas le cas !
Je suis très déçu de la part d'AUDIOPHONICS de ne pas y avoir pensé dès le début et le vendre avec un boitier plus large pour y intégrer cette option qui est indispensable.
Car aussi qui dit boiter plus grand dit plus d'air pour refroidir les composants. Dans l'ancien boité commercialisé il chauffe assez vite et je ne préfère pas m’en servir en cas de forte chaleur.
Donc 5 étoiles pour la qualité d’écoute mais -1 pour la conception d'AUDIOPHONICS.
 (3)
Ji-Ping S.
Great performance!
I don't have any other amp at hand for fair comparison but the combination of this amp with Dali Oberon 5 sounds very dynamic and clear, better than my previous setup of class AB integrated amp with Castle's which costed more and used a lot of electricity.
Will definitely buy this again for center and rear.
PS: no preamp and connected to PC directly.
Christian A.
Amazing performance - great match with tubes
I ordered this device based on the good reviews on linearity and the ability to provide power across the impedance range of a loudspeaker (also difficult loads). I always felt that this could be a limiting factor to my KEF LS50 loudspeakers.
Transparency and punch are just amazing. It outperformed a number of A/B Class amps with ease, even devices which cost 2-5 times more. What I particularly like is the (perceived) linearity and clarity. I sometimes felt that matching a preamp with an amp is a bit of a gamble, very much depending on the specific character of each device. With the MPA-S125NC I just stopped worrying about that as I think that it's so revealing and neutral.
I can now fully focus on tube rolling with my Schiit Freya preamp without the fear that what I hear will be a mix of factors. It´s amazing how the amp is able to reveal (yes again) even the slightest difference in a tube or source quality. Holography of tubes is directly transformed into the listening room now.
On the downside, the box seems sturdy, but the front panel paint easily gets wiped off (be careful when cleaning). The form factor is a bit strange - but works well for me. Clarity can be a big plus, but you might want to feel the urge to upgrade other parts of the chain soon though, this little box is able to unsurface weaknesses ;)
Strong recommendation! Especially the combination with KEF LS50 and the Schiit Freys Preamp in my case. Love it!
Emmanuel S.
Impressionant
J'ai eu des amplis de classe A, de classe AB, à lampes, à transistors, à 500 euros, à 3000 euros.
Pour ne pas mourir idiot je me suis dit qu'il fallait que je teste un classe D. Après recherche je me suis dirigé vers celui-ci, les modules ncore semblants être parmi les plus réputés, en me disant qu'au pire il fera power pour mes arrières s'il est moyen.
Que dire... J'ai été bluffé !
Il se retrouve à amplifier des klipsh Cornwall depuis un an, et pas de changite en vue.
Les écoutes sont très naturelles, transparentes, avec des basses bien péchue et profondes, pas trainantes. Les aigus sont détaillés mais pas agressifs. Très équilibré, exactement ce que je demande à un ampli. Neutralité, transparence, pêche.
En plus c'est minuscule, ça ne prend pas de place, royal.
Du top, ne vous fiez pas au prix.
Pour du HR ça va impeccable, pour du rendement plus faible prenez la puissance supérieure si vous aimez les écoutes musclées.
Je recommande chaudement.
William H.
Bill
Waited 2 weeks to be in stock, took 3 weeks to deliver.
I wanted to check out company and products.
Amp is first rate. You get what you pay for!
Very happy with it!
Fred d.
Fred
Great performance! What goes in comes out. In combination with a good pre-amp you have a beautiful sound.
Tae-Gil N.
Very nice companion for my KEF LS50
Previously I was using NAD D3020 (internally uses Hypex UcD102-based output stage) as amplification for my KEF LS50 speakers. I've purchased this amplifier as an "upgrade" to grant some more natural output to the speakers. I am quite satisfied with the result. This tiny amplifier drives full dynamics of the speaker with ease. The amplification / sound performance alone would be 5 star!
However, I am not totally happy with the chassis, and thus giving only 4 stars. It may be just my module, but I am having a tiny physical hum noise from the amplifier, near transformer side: This is tiny (i.e. tiny noise you can hear only within 50cm or so), and it is a typical 50hz mains hum. It comes out both in standby / on. Minor issue, since this is strictly on physical side, and not on signal side. So it isn't affecting output at all. However, I hate any such noise from my audio equipment. To identify further the exact source of the noise, I've opened the case (okay, warranty sticker removed and void now, but I don't care) and tried to identify which component is making this noise. But surprise surprise, the noise is gone when the top cover is off. I suspect some magnetic effect between one of transformer component with the enclosure cover. If the enclosure was slightly bigger, I guess this won't happen. Running with the cover-off can be very dangerous (NC122MP document shows front side of components with red color of dangerous voltages). So for the moment, I am with this hum. I am planning to do some DIY with a slightly bigger enclosure.
It would have been 120% perfect (?), if the module was supplied with a slightly bigger enclosure, with both XLR & RCA connection. Well, for this, 699 euro PA-S250NC is exactly that kind of stuff, but I didn't need that much gain for my current setup, so I am rather happy with this cheap-but-great amplifier.
Well, all in all, I am totally happy with it. Great job, Audiophonics, on providing one of the most economic NCore amplifier.
 (3)
Clément M.
Sans concurrence.
Finition et construction assez sommaire. Je regrette les connecteurs très exigus à l'arrière, ainsi que le placement: Les borniers devraient être en dessous des emphases RCA et non l'inverse. A noter que l'ampli est aux normes: Terre rattachée au châssis et phase bien à gauche de l'entrée IEC.
Ceci étant dit, cet ampli, qui est le moins cher du marché en Ncore (ampli monté) est tout juste excellent pour une entrée en la matière. Les chiffres mesurés parlent d'eux même: La majorité de la puissance est disponible en dessous de 0.005% de Distorsion Harmonique + Bruit, soit la limite théoriquement audible. Dans la pratique, cela ce ressent, on peut pousser l'ampli dans ses retranchements (sensibilité d'entrée max à 1.17V - 3.6 dBu). Tout en profitant d'une puissance particulièrement propre. Signature très neutre: pour les personnes qui n'attendent pas d'un ampli qu'il apporte une quelconque coloration (ce qui n'est, en aucun cas, le rôle d'un tel matériel).
Hautement recommandé. Je l'ai tellement apprécié que je ne pouvais pas en rester là! j'ai donc commandé deux PA-M250NC Mono pour aller plus loin en puissance disponible.
David B.
Très bon ampli
J'ai été très étonné du dynamisme de ce petit appareil, qui n'a rien à envier à des appareils bien plus imposants. Analytique, aéré, et aucunement enjôleur ou clinique. En plus ça ne chauffe quasiment pas, parfait pour la multi-amplification. Pour être parfait, si vous pouviez améliorer le défaut de "ploc" à l'allumage, ou à l'extinction, sur des enceintes à très haut rendement (105 db/1/w/1m), ça s'entend quelque peu...
Daniel B.
ASSOCIATION EXCEPTIONNELLE.
Mon dernier achat ( ampli audiophonics N CORE ) s'intègre au niveau des éléments suivants : récepteur Bluetooth CRS 8675, préampli audiophonics PGA 2310, et dac X3 Fx Audio. La restitution sonore se fait par le biais d'une paire de Q Acoustics 3020i câblée en Viard hd 12 et modulation canare. Les fichiers audios sont tous en flac hd. Que dire de la restitution: " exceptionnelle". Cet ensemble n'a rien à envier à des systèmes que l'on qualifie haut de gamme. Tout le spectre sonore est restitué avec une qualité surprenante. La tessiture des voix est riche en émotion. Les aigus files très hauts avec matière et subtilité. Tous les types de musique sont restitués avec une véracité surprenante. Le secteur grave n'est pas en reste. Il est surprenant non seulement par sa spontanéité, mais également par son exploration des infras graves. Bluffé par cette déferlante sonore, mon ami aux système haut de gamme, reconnaissait avec fairplay la qualité exceptionnelle de ces nouvelles électroniques.
Pieter T.
Good for the price, but lacking power
Good amplifier for the price.
But for larger 3 way speaker the power is ok, but not the class d tight bass.
If you can go for the ncore250 (or higher), that has more power.
jean pierre T.
petit mais costaud
Excellent ampli de puissance;
Il est très proche d"un Nuprime ida 8 ; avec un supplément de matière dans la restitution et un bas medium/grave moins boursouflé .
Très bonne dynamique et pas d'agressivité .
Une main de fer dans un gant de velours.
Il chauffe pas mal , mais peut-être est-de du aux températures caniculaires qu'il fait actuellement.
La finition est très bonne et inspire confiance.
anastasios f.
Its better than my custom LM3875
I bought this amp because of the very good reviews for the ncore technology. I have a very transparent system , with a metrum acoustics dac and monitor custom speakers with a high quality crossover. My system is as transparent as possible and colorations are easily perceivable. There is a substantial difference to my custom built lm3875 amplifier. The sound is clearer , more dynamic, I would say more contrasty. The biggest difference is in the bass. Its overall better. However the music from youtube videos can be better with my old amp....... Sometimes colorations and artifacts can make a poor audio stream sound better. Needs good recordings to show its true potential. It is easily the best amp i ever had! Everybody should buy one of these. It is a must! The price quality ratio is the best on the internet. It matches very well my metrum acoustics dac.
Ivano P.
End of the games
To me the amplification issue is solved whit this device.
Thanks to Audiophonics that make accessible this great technology at fair price.
Andrea S.
nCore Technology rocks !
I would like to spend a couple of words about this amplifier. Being it based on a new concept and being nCore technology something really new, especially in terms of the mathematical theory behind its design that has been recently formalized. I have a real passion for audiophile devices and even if I didn't have the possibility to buy very expensive rigs I had the possibility, along the years, to test several devices passing through the complete digital audio revolution started in the 80s. I don't have the ability of the perfect pitch and I'm not the kind of audiophile that spends one million words speaking about the music planes, the perspective box or other amenities or buys a 1m mono signal cable costing 1000€. What I have to say is that this amplifier really doesn't sound.. it doesn't sound at all, it simply amplifies the signal for your speakers. This could seem a very minimal statement but it's not actually ! I always
had the impression, with ALL the amplifiers I tried before in this 40 years, that there was a kind of "alias" following the sound, something like a "noise" modulated by the main signal that was superimposed to the real sound. In some amplifiers this "coloration" was less evident in some others was more but it was ALWAYS there. I was blaming the speakers, I was blaming the digital conversion but I couldn't really tell what it was causing it. Now I know, it was the amplifier ! This amplifier really amplifies only the sound you put at its inputs and doesn't generate this distorted alias that ALL the units I tried before
were adding. This "alias" has nothing to do with harmonic distortion or intermodulation stuff since I tried amplifiers with very nice numbers in this respect and it was the same. This is the first time in my life that I find an amplifier that is completely transparent. You can easily spot this because typically the
superimposed noise of other amplifiers was masking partially or completely the very subtle ambience-related echo signals, with this amplifier the sensation of reality instead is increased a bunch. Also the voices (that typically are causing a lot of the alias signal I was mentioning in other amplifiers) here are
reproduced with a very high degree of reality and you can easily grasp any nuance. The bass is hugely deep and very precise and clean. The absence of the alias allows you also to appreciate subtle sounds in the music that with other mplifiers are inaudible. The difference in the reproduction of songs I know very very well and the absence of this distorted alias is very evident and audible with exactly the same setup of source, cables and speakers changing only the amplifier. The alias noise I'm speaking about is mainly generated in the mid-high frequencies so, its absence, could seem to make the sound "dull" if your speakers have a very linear response on the high frequencies and you're used to amplifiers producing a lot of this alias sound. Nevertheless the amplifier reproduces the high frequencies with a very high control and an impressing cleaness. The sound of the trumpets and the piano are incredibly detailed and "real". In short, this amplifier is really of another league for me respect to anything I heard before. Let's come to the two only small issues I would like to pinpoint. The first one: there is a transient noise made by the amplifier when switching OFF that is clearly audible in the speakers. It's not loud but it's audible. It's mainly mid and high frequencies (woofers are not moving at all). This happens if the amplifier, after being switched ON, is not run for at least 10-15 minutes with music. The issue is related to the amplifier board, Hypex knows about it and they're working to a solution. The second drawback is the heat produced by the unit. nCore Class D amplifiers are VERY efficient and the on-board SMPS is very efficient as well, nonetheless a certain amount of heat is
produced when the amplifier works. In this implementation of the amplifier the only heat dissipation is provided by the aluminium box since there are no external/internal heatsinks. Running the amplifier at an average volume (in an apartment) for an extended period of time with an ambient temperature of 25-26°C makes the amplifier box gets warm. I don't know what could happen to the temperature of the amplifier in hot environments if the amplifier is run near its limits. In a domestic envrionment however I don't anticipate any issue with heat dissipation. Do I recommend this amplifier ? Well I bought two !! draw your own conclusions :-)
Frédéric D.
Parfait !
Dynamique d'enfer, timbres raffinés, équilibre parfait et transparence absolue.
Cet ampli a avantageusement remplacé 2 Parasound Halo A23 bridgés. C'est un ampli qui rivalise avec les meilleurs amplis du marché.
Il est trés (trop) compact. Seul détail légèrement ennuyeux: pas d'entrée XLR et un promiscuité des connecteurs qui rend le raccordement des cables un peu difficile. Mais une fois que cela est fait ... Toutefois, le boîtier est de bonne qualité.
Dommage que Audiophonics ne fait pas les plus gros modèles avec entrée XLR.
Stephane L.
Excellent rapport qualité/prix
Ce module Hypex n'a pas grand chose à envier au nCore NC400 que j'utilisais précédemment. Vivement recommandé.
 (3)
Le Audiophonics MPA-S125NC est un amplificateur de puissance Class D basé sur la technologie Hypex Ncore. C'est...
