FRANK D.
Impressionnant.
Une fois compris le systeme et en ayant pris des precautions pourque les parties en plastique ne se desolaridesent pas cette...
Bruno R.
Alain p.
top du top
Avis clients - Il y a 19082 avis.
Sérgio S.
Can't fault it for the price!
First of all, it feels well built and sturdy. And it doesn't look half bad, although I would have prefered the silver option. The volume pot has a nice feel to it, and the buttons have a nice positive action to them. So it gets to an impressive start!
Regarding the sound quality, out of the box it sounds dull and flat, with a small soundstage, a bit ragged on the top end and unimpressive, but with the promisse of sufficient power to drive a pair of unsensitive bookshelf speakers with quite a complex cross-over, on a 20m2 living room.
After a couple of days the sound got waaaay smoother, with a wide and tall soundstage, with reasonable depth, relatively refined highs, great separation and cristal clear vocals. Just make sure you press "direct" button to bypass tone controls! Having said that, it is relatively thin sounding sometimes, and sounds a bit cold and lacking some harmonic richness. But I think that there is still room for improvement with a few more days of burn-in! And it responds well to power conditioning accessories, at least in my stereo system. I'm getting the feeling that the DAC is the real limiting factor regarding sound quality, as there is some detail lacking in music, but this is just the audiophile in me talking a bit too much...
As it stands, for a 2nd stereo system on a bedroom or on a desktop, it is more than adequate and borderline impressive for it's size and price!
frédéric B.
superbe !
Un cable qui fait preuve d'une grande neutralité.Les basses sont tendus, bien présentes, l'aigu et le médium soyeux avec du corps donnent une nette sensation de transparence. Un très bon cable qui nécessite un temps de rodage assez long ( 50 heures) ensuite que du bonheur ! (écoute réalisé avec lecteurs Denon et Ayre - amplis Denon et Rotel - enceintes Cabasse et Triangle).
Gregory G.
Bof
Un léger mieux sur les contacts de ma cellule phono mais c'est tout. Je n'ai pas constaté de réelle différence sur les autres contacts (modulation et secteur). Peut-être mes câbles ont-ils des contacts déjà efficaces. Pour ma part c'est de l'argent perdu.
Gregory G.
Il n'est pas parfait mais le son est tellement bon qu'on lui pardonne. Il n'a pas d'écran mais je m'y suis habitué et finalement c'est assez pratique de pouvoir changer de titres sans à avoir à le regarder (dans la poche par ex.). Toutefois 2 choses m'énervent particulièrement: il lit les titres par ordre alphabétique et non dans l'ordre de l'album et surtout il ne sauvegarde ni la position ni le volume à l'extinction (Grrr). Malgré la fiche technique, oubliez Les fichiers 24bits. Je n'ai pas réussi à lire correctement ceux provenant de Qobuz. Oubliez aussi les casques à arceaux. Il n'arrive pas à les piloter. Avec mon Grado SR325 (pourtant pas difficile) le son est plat et sans intérêt. Mais avec mes intra le son est vraiment exceptionnel. C'est assez troublant de constater que ce petit baladeur fait mieux que mon Audiophonics U-Sabre ES9023 et même que mon Audiophonics U-Sabre ES9018 avec ampli casque dédié. Sur les bons enregistrements, la différence n'est pas forcément très sensible (quoique). Mais à l'écoute d'enregistrement moyens, la différence est importante. Incroyable la quantité d'informations qu'il est capable d'extraire. Je découvre des enregistrements que je n'écoutais plus à cause de leur manque de qualité technique. Pour la 1ère fois je prend autant de plaisir à l'écoute au casque qu'aux enceintes.
Xavier T.
Perfect !!
Que dire de ce petit dac ... il est parfait il fait le boulot pour un petit prix,pas eu de soucis a l'installation sous calculate linux,le plaisir d'ecoute est retrouvé un grand merci du fond du coeur a Audiophonics pour ce produit.
Reçu rapidement et bien emballé ... du tout bon !!
Très bon module pour du DIY
J'ai hésité pas mal avec d'autres modules ampli, dont les LM3886...
L'avantage avec celui-ci est qu'il est complet et directement fonctionnel une fois branché à une alim, HP câblés ainsi que la source.
La seule soudure nécessaire est pour le connecteur jack ou cinch pour la source.
Il fonctionne depuis quelques jours maintenant (un 2ème système) branché sur des Concept20. La source est un chromecast audio alimenté par un powerbank.
Alors l'écoute est vraiment surprenante, un rapport qualité prix imbattable ! Et pour du class D la signature sonore est plutôt chaleureuse et douce.
J'en suis tellement séduit que j'aimerai dans le futur en reprendre un pour en faire une config double mono (sympa pour un 2ème petit système ! ;-))... ce qui m'amène à un point fort regrettable: le manque du tutoriel ou d'information sur ce module !!
J'aimerai beaucoup pouvoir bridger ce module en mono mais je n'ai pas la connaissance nécessaire et ne trouve aucunes info sur le sujet... vraiment dommage !
A cause de ce point j'ai hésiter à mettre les 5 * au lieu de 4 (la note ici vaut pour le produit en lui-même).
Beauté Intérieure
Certes noir c'est noir, mais le son que délivre ce petit ampli est excellent, chaleureux sans excès, il se compare à des amplis casque beaucoup, mais alors beaucoup plus chers! Il fait aussi très bon ménage avec un Grado PS500, un achat très recommandable!
Très mauvais son
Si la qualité de fabrication est sérieuse, le rendu sonore, lui, est désastreux ! En comparaison directe avec mes vieilles fiches (en laiton également), le son de ces IEC est beaucoup plus maigre, les voix sont en retrait, et la restitution est généralement plus acide. A éviter.
Christophe D.
Super!!!
Je viens d'installer et tester cet ampli avec une paire d' Highland Aingel 3201. Résultat : une petite config de bureau (et plus) pas chère qui envoie et la qualité musicale est sérieusement au rendez-vous. Très satisfait!
PIERRE R.
Cable Arcadia RCA-RCA 1,5 m
Très bon câble audio,précis, fluide , linéaire et dynamique . Il nécessite un rodage de plusieurs heures avec un signal qui peut être constant
Jean-Marc B.
Qualité décevante
Le placage est mal fait, il y a quelques traces qui ressemblent déjà à de l'oxydation. Il y a du jeu dans les pas de vis. Bref, qualité assez médiocre.
Jean-Marc B.
Excellent RQP
Pour le prix, c'est sûr, il pulvérise les appareils analogiques. On lit parfois qu'un FDA est aussi bon que l'analogique dix fois plus cher .... Peut-être. Les graves sont très bien tenus, les timbres sont réalistes, la dynamique est aussi au rendez-vous. C'est dans les aigus que cet ampli pèche un peu pour l'instant. Ils sont un peu embrouillés, mais c'est typiquement le genre de chose qui s'arrange avec le rôdage. Mais je ne l'ai pas acheté pour moi, je ne vais donc pas pouvoir vérifier si c'est vrai.
Jack A.
AUDIOPHONICS I-TDA1387 TCXO DAC
Je voulais entrer dans un DIY DAC comme un moyen de rendre ma bibliothèque FLAC (650GB / 21K chansons) disponibles sans fil à mon système de musique principal à l'étage. La musique vit sur un NearGear Ready NAS dans mon placard d'équipement et a été la fourniture de musique à travers le niveau inférieur dans 4 zones par le biais d'un Logitech Squeezebox Touch.
J'ai décidé sur le "vintage" CC-DAC principalement comme un point d'entrée facile. Je ne savais pas trop à quoi m'attendre d'un CFA de 16 bits de la vieille école, étant donné la propension à recevoir plus de bits et des fréquences d'échantillonnage plus élevées dans la grande majorité des chipsets DAC disponibles aujourd'hui. Sans approfondir dans une longue dissertation, je dirai simplement que le CAD a dépassé mes attentes les plus fous. La profondeur et la largeur de la scène sonore est superbe. Le détail est sans faute. Les hautes fréquences étaient très lisses. En comparaison avec le Squeezebox, il n'y a tout simplement pas de comparaison. Le I-TDA1387 TCXO DAC l'a simplement soufflé. Je me suis retrouvé en train d'entendre des éléments musicaux qui, dans d'autres sources, (LP & CD) étaient auparavant embourbés dans la confluence du mix soundtage. Le I-TDA1387 TCXO DAC a été étonnant dans sa capacité à diserne la clarté, la position et la largeur de la scène musicale. Je le recommande fortement à tous ceux qui pourraient être intéressés par une expérience musicale plus DAC.
Système: Raspberry pi 3 B, RUNE Audio 0.4 bêta, avec Raspberry 7 "Écran tactile, YP Audio 5v régulé linéaire PS, tous alimentant un pré-amplificateur Onkyo Integra P-304, Stratos Odyssey Stereo Plus Power Amp, VMPW Super Tower II Haut-parleurs. Lecteur supplémentaire Lecteur CD CS-5000 avec lecteur de CD V-MR, NAD C545BEE de type Shure V15.
FWIW: J'ai chargé Rune, MoODe, & Volumio pour lancer les pneus avant de décider que Rune répond mieux à mes besoins. Bien que MoOde était le plus rapide et le plus facile à obtenir en cours d'exécution, headless n'était tout simplement pas une solution réalisable pour moi. Volumio, de loin est l'interface utilisateur le plus asthetically agréable, mais j'ai eu des problèmes de chargement de ma bibliothèque, dans la dernière goutte, qui semblait être un problème pour les autres aussi. La bêta Rune 0.4 n'est pas sans bugs aussi bien, mais aucun d'entre eux impeeded le résultat final. Je suis sûr que avec un peu plus de travail sur ma fin les autres auraient bien travaillé, mais ce n'était pas le temps, je voulais investir à ce point.
I wanted to get into a DIY DAC as a way to make my FLAC library (650GB/21K songs) available wirelessly to my main music system upstairs. The music lives on a NearGear Ready NAS in my equipment closet and has been supplying music throughout the lower level into 4 zones by way of a Logitech Squeezebox Touch.
I decided on the "vintage" CC-DAC primarily as an easy entry point. I was not sure what to expect from an old school 16-bit DAC given the propensity for more bits and higher sampling frequencies in the vast majority of DAC chipsets available today. Without delving into a lengthy dissertation I will simply say the DAC exceeded my wildest expectations. The depth and breadth of the soundstage is superb. Detail is without fault. High frequencies were very smooth. In comparison with the Squeezebox, there simply is no comparison. The I-TDA1387 TCXO DAC simply blew it away. I found myself hearing musical elements that in other sources, (LP & CD) previously were mired in the confluence of the mix soundstage. The I-TDA1387 TCXO DAC was amazing in its ability to diserne the clarity, position and breadth of the musical soundstage. I recommend it highly to anyone who might be interested in a more musical DAC experience.
System: Raspberry pi 3 B, RUNE Audio 0.4 beta, w/Raspberry 7" Touch Screen, YP Audio 5v Linear Regulated PS, all feeding an Onkyo Integra P-304 pre-amp, Stratos Odyssey Stereo Plus Power Amp, VMPW Super Tower II Speakers. Additional playback Dual CS-5000 turntable w/Shure V15 Type V-MR, NAD C545BEE CD player.
FWIW: I loaded Rune, MoODe, & Volumio to kick the tires before deciding that Rune better fit my needs. Although MoOde was the quickest and easiest to get running, headless was just not a workable solution for me. Volumio, by far is the most asthetically pleasing UI, but I had issues loading my library, in the latest drop, that seemed to be an issue for others too. The Rune 0.4 beta is not without bugs as well but none of them impeeded the end result. I'm sure with a little more work on my end the others would have worked fine, but it was not time I wanted to invest at this point.
Nicolas P.
NEOTECH SOCT-14 Fil de câblage Cuivre UP-OCC PTFE 2mm² Neotech a longtemps été le leader dans la production de câbles en utilisant le cuivre UP-OCC "monocristal" développé par le professeur Ohno de...
Exceptionnelle
Musicalité sublime en cable secteur et HP
Nicolas P.
WBT-0210Cu Embases RCA Nextgen cuivre 75 Ohms (La paire) Une référence pour le montage interne des plus prestigieuses électroniques, les prises RCA femelles WBT offrent des prestations qui rendent hommage à votre travail.
Tres musical, sonorité un peu chaude
Nicolas P.
Bon RQP
Pas cher et bonne fabrication
Sonorité un peu chaude
Nicolas P.
Je confirme le 1mm2 en HP est décevant, trop terne, mais Ca cogne.
Le 0,5 est top.
Le multibrins est meilleur en HP.
Je vais le tester en secteur ou je pense il sera mieux car monobrin.
Par contre RQP ilmbattable.
Nicolas P.
Excellent Borniers, qualite irréprochable musicalité exceptionnelle mais oui tres cher
Nicolas P.
Les meilleurs fiches que l'on peut trouver sur le marché, oublier les eti obsolète
Nicolas P.
Excellent RQP
Pour le prix difficile de faire mieux.
Le jantzen en 0,5 est pas mal aussi.
Canare est une marque pro japonaise donc pas de chichi marketing, Ca sonne bien et cest pas cher.
Son plein et transparent à la fois, excellente dynamique.
Son frère xlr da206 est largement au dessus.
Le HP aussi est top
On le paye un peu plus cher en France dommage
Jean-Marie G.
je ne suis pas vraiment un geek, mais malgré l'interface et la notice en anglais ce n'est pas trop dur d'utiliser l'appareil.
La bi-amplification change beaucoup de chose ! ( quadri-amplification possible ...)
La fameuse transparence des FDA est maximisé par exemple.
La possibilité de changer de réglage avec la télécommande est vraiment quelque chose d’extrêmement pratique qui permet de se fier à ses oreilles pour les réglages fins ( il y a 4 réglages mémorisables ).
Après il y aura beaucoup de musique à dégustée.
merci
Herve B.
AUDIOPHONICS RASPDAC DAC I-SABRE V4 Kit DIY Lecteur Réseau Raspberry Pi 3 B+ & DAC Le RaspDAC d'Audiophonics est ici livré en kit complet, afin que vous puissiez monter vous même votre lecteur réseau DIY. Ce modèle est basé...
Parfait mais manque d'infos au montage
--> livraison : rapide
--> assemblage : tout d'abord à savoir qu'il n'y aucune notice de montage. Au départ, rien de compliqué, il suffit de suivre la vidéo. Ça se complique lors de la connexion sur la carte du Dac (afficheur et bouton) car sur la vidéo on explique le cablage avec la generation 1 du Dac or celui vendu est de génération 2. En fouillant un peu sur le site on trouve le lien pour la cablage : http://www.audiophonics.fr/fr/dac-diy/audiophonics-i-sabre-dac-es9023-v3-tcxo-raspberry-pi-20-a-b-i2s-p-10657.html
--> Partie Software : là encore il faut chercher les infos (merci Google). Lorsqu'on installe RuneAudio téléchargé sur le site RuneAudio, ni le bouton et ni l'afficheur fonctionne (normal !) et le lien proposé sur le site Audiophonics est mort pour avoir un RuneAudio compatible au RaspDac. En cherchant sur divers forum, on trouve l'image à télécharger : http://forum.audiophonics.fr/viewtopic.php?f=4&t=1777
--> Le produit final : le produit dans le boîtier métal est vraiment bien fini. ll démarre rapidement, est très réactif avec une application installée sur SmartPhone Android. Je ne suis pas un pro audiophile mais la qualité du son me convient largement, même avec l'alimentation de base fournie avec le RaspDac. Autre point sympa : les webradios et la gestion du volume sur tablette ou SmartPhone.
Je mets 4 étoiles et non 5 à cause des infos sur l'assemblage qui pourraient être réactualisées et regroupées sur une même page.
shuko occ
je pense que la neotech cuivre occ et super neutre et rajoute rien comme certaines ,furutech or, iego sont aussi de super shukos dommage que audiophonic les vendent pas .Pour moi iego ,neotech sont les meilleurs shukos
Un bond technologique et une revolution
Cette puce de chez ST microelectronic fait faire un bond technologique et occasionne une révolution dans le monde de la HiFi. En effet il n'y a plus que les enceintes qui coûtent cher. Pour 125€ et un vieux pc portable ou pas et disons une super paire d'enceintes à 2000€ plus les cables, allez, pour 2500€ ont est dans la vraie audiophilie dans HdG voir THdG. on peut aussi se contenter d'une petite paire d'enceintes et là, le rapport Q/P est encore plus effrayant.
Mais vous voulez que je vous parle du FX-Audio D802. Bon, la télécommande n'est pas top et quand on regarde la taille de l'ampli on y croit pas. La sélection des programmes n'est pas très claire pour moi on est pas certain d'avoir bien sélectionné flat et tone pour avoir le meilleur son possible.
J'ai utilisé le FX avec Daphile cela a demandé quelques mises au point et je pense n'avoir pas tout exploité loin de là.
J'affirme que cet ampli que j'ai écouté que sur des cd rippés a une lecture totalement analogique il fait ce qu'on lui dit. Pas de dureté. Les legatos sont respectés ainsi que les silences entre les notes et on entends tout.
Dans l'album White winds de Andreas Wollenweider au début les bruits de pas dans l'eau sont confondant. Ailleurs dans Les Marquises de Brel on entends distinctement sa respiration et les bruits de bouche. Je mettrais juste un petit bémol sur la dynamique et le grave mais encore une fois c'est peut-être une question de réglage. L'image ou la scène est très profonde mais manquerais un chouia de largeur Il faut dire que l'Artec est un champion dans ce domaine.Pour info mon ampli est un Artec P60E, cd philips 723 par Christian Blerald Ultima T, cables modulation maison fil d'argent .isolé coton 0.6mm, Lyrinx (isolé téflon 2 conducteur Cu + 2 Arg, Red dawn Blue Haven et pour les enceintes 4X1mm arg isolé coton. Mes enceintes des BH200 de chez Bruno Henry
jerome g.
Installé sur portable Toshiba avec Win 10 et Foobar.
Tous les formats sont très bien reproduits, y compris les DSD natif. Installation avec le mini cd d'origine. Un peu luté pour faire fonctionner le tout. Les driver fournis sur le site ne fonctionnent pas chez moi, bien que plus récents que ceux du cd.
Mais à part cela, très content. Idéal avec l'alimentation SMSL. Les filtres à disposition sont bien ajustés.
Baptiste D.
Lecteur fun
C'est un petit bijou de conception et fabrication, idéal en nomadisme pour celles et ceux qui veulent s'encombrer un minimum, sans se priver notemment d'un bel écran. Attention cependant, tout ici est fin et précis mais petit ( les commandes aussi ) et s'il remplira très bien son rôle à l'exterieur, il ne conviendra pas forcément à une écoute posée et plus exigente en terme de rendu sonore mais aussi de confort d'utilisation. C'est un petit Dap en adéquation avec son prix.
Gaine Tressée Extensible Nylon (PET) 10-18mm Noir Cette gaine tressée noir élaborée en PET (Polyéthylène Terephtalate) monobrins peut être utilisée pour de nombreuses...
Taille petit
Bon rapport qualité prix mais fait plutôt 10-12mm maxi car à partir de 12mm on commence à voir au travers.
Dominique P.
LA CLAQUE
Après avoir revendu mon ampli HEGEL H160 à 3000 €, encensé par le presse en ayant reçu plusieurs récompenses internationales , mais finalement déçu par l' écoute , j' ai décidé d' acheter ce QULOOS QA 690 avec entrée USB.
En configuration avec un Raspberry 3 ( avec VOLUMIO 2 ) et une carte USB XMOS Audiophonics en sortie SPIDF , là je n' avais jamais entendu un son pareil ! Un son détaillé, chaud , ouvert , pas agressif . Tous les registres sont parfaits. Ouahhh !
Merci à Audiophonics
Olivier A.
Pour le prix, rien à redire. Contacts de qualité
Olivier A.
Pour le prix, rien à redire. Contacts de qualité.
Olivier A.
ELECAUDIO PS-34GB Connecteur Secteur Schuko Noir Or 24K 5µ Ø16.5mm La prise Schuko de référence PS-34GB se distingue au premier coup d'œil par son corps en nylon noir anthracite à la finition impeccable et aux...
Bonne qualité mais
Prise de bonne qualité mais rien ne semble différencier la PS-24GB de la PS-34GB. Pas de référence inscrite ni de marquage élecaudio par ailleurs. Donc comment être sur d'avoir la bonne ?
Thomas R.
Pas mal du tout
Ce DAC est en écoute à la maison depuis quelques jours maintenant, et effectivement, meilleure perception des micros détails et de la spatialisation.
Oubliez le driver fourni ici, il vaut mieux configurer Asio4all et Foobar2K correctement pour un meilleur fonctionnement. De plus, la dernière révision d'Asio4all solutionne le problème de son lors d'une lecture vidéo sur youtube par exemple, alors que Foobar2K est en pause, ce que ne fait pas le driver dédié à ce DAC.
Une autre piste d'amélioration est l'utilisation d'une alimentation régulée à base de LM7805 et d'un câble USB data uniquement afin d'éviter une pollution électrique venant du PC.
En revanche, ça aurait été sympa de trouver dans la boite un manuel d'utilisation avec les spécificités du produit.
En bref, bon produit qui devient assez rapidement indispensable pour toute écoute musicale dématérialisée.
Angélique D.
Produit impeccable,
La Cerise Sur Le Gâteau pour Terminer La Finition de mon Caisson DIY avec 31 TE.
Livraison Express
Tout Est parfait.
Merci Beaucoup
Bruce B.
Bonne entrée en matière
Après quelques temps d'écoute du D8 associé à un lecteur iEast soundstream Prod, je peux vous confirmer la transparence du son.
La prise casque est un peu anectdotique (ne coupe pas les enceintes), et le réglage du volume bas assez limite, mais en écoute standard, que du bonheur !
Mathieu B.
AUDIO-GD DAC-19 2017 PCM1704UK & DSP USB AMANERO 24bit 192kHz TCXO BNC Le DAC19 d'Audio-GD, ici en version 2017, atteint des performances rarement égalées grâce à un convertisseur PCM1704UK. POINTS CLÉS : PCM1704UK DSP Altera Cyclone...
Conseil !
Voici un petit conseil d'utilisation.
Si vous écoutez essentiellement des CD ou des fichiers FLAC, il faut impérativement configurer ce DAC en NOS et là, vous obtiendrez le meilleur de cette machine : que de beauté, davantage de scène sonore, plus de détails, plus d'aération, les enceintes gagnent alors une nouvelle jeunesse ! C'est tout simplement splendide.
Mais si vous écoutez essentiellement des mp3, alors laissez la configuration de base et les fichiers de faible qualité seront alors plus agréables à l'écoute.
Voilà, si vous suivez ce conseil, vous serez un utilisateur heureux.
Nicolas S.
pour remplacer mon FX D802C
vous me direz, quelle drôle d'idée de remplacement le FX audio par l'Alientek D8.
Je l'ai pris pour sa prise casque. en terme d'écoute, c'est sans surprise, équivalent !
mais voila, quelques points viennent ternir le tableau : la prise casque, lorsqu'un casque lui est raccordé, ne coupe pas les enceintes, donc inutilisable. de plus, j'ai beau tenter de paramétrer l'affichage pour qu'il reste allumé (en mode custom) , il se coupe automatiquement après 5 secondes, quel que soit le réglage de la tempo backlight... bizarre.
Bruno l.
Machine incroyable !
Après un mois d‘utilisation de cette machine hors norme, je poste mes impressions pour tous ceux qui hésitent et qui ne devraient pas attendre 1 seconde pour passer commande !
Pour commencer ce qui fâche: Pas de notice, le volume qui revient à zéro à chaque mise sous tension et il faut appuyer 30 fois sur le bouton + de la télécommande pour mettre le bon volume…, la télécommande, très belle taillée dans la masse, mais ultra directive et à la portée assez faible. Elle est livrée sans pile, il faut deviser le boîtier pour les mettre et les contacts ne sont pas particulièrement bons. Le câble USB fourni ridiculement mauvais. Les drivers XP indisponible sur le site audio GD, il faut aller les chercher sur le site du fabricant de la puce Amanero.
Pour continuer tous ce qui est bon…
En premier, la bête demande un bon rodage d’environ 15 jours. La construction est remarquable, le poids impressionnant. Avec foobar2000, le driver de la puce amanero Asio, inhibe parfaitement tous les Controls de Windows.
Pour le câble USB, prenez le moins mauvais que vous avez, coupez le blindage à 10 cm de la prise du dac pour ne plus relier la masse du PC à celle de la chaine, mettre une self CMS de de 22µH en série sur le fil de +5V puis mettre 1000µF chimique + 2,2µ tantale + 50 nF céramique entre le fil + et le fil – coté dac de façons à faire un filtre passe bas pour rejeter les parasites du PC. Avec ce montage, l’entrée USB est transfigurée.
La partie pré-ampli analogique, est remarquable de neutralité, le réglage de volume est très agréable en matière de progressivité avec le réglage 60 pas.
En usb, dans la configuration de la livraison, la machine sonne très bien mais avec la petite coquetterie en haut que l’on retrouve souvent avec les puces ES9018 et qui fait que l’on sait que l’on a affaire à un enregistrement numérique.
Mais l’AUDIO-GD NFB-29H (2016) a une botte secrète. Sa puce de nouvelle génération permet de passer en mode NOS, C’est à dire de «bypasser l'oversampling» X8 du ES9018. (Pour cela il faut ouvrir la bête, voir le site du fabricant).
Là, fini la petite coquetterie, place à la musique, la machine est transfigurée ! On passe de la conserve au produit frais, du plat cuisiné industriel, au menu d’un trois étoiles. La différence est Incroyable ! En particulier avec les enregistrement 16bits 44k, on redécouvre tous ces disques. Le suivi rythmique est fabuleux, les silences entre les notes sont vivants, les timbres sont sublimes. La positions des interprètes se fait au millimètre en largeur et profondeur. Rares sont les enregistrement qui ne passent pas. Même les radios internet en MP3 permettent de prendre du plaisir. La dynamique est foudroyante, la bande passante va de l’infra grave jusque à l’aigu. L’aigu semble moins présent dans la position NOS, mais en fait il est juste normal au lieu d’être insistant.
On écoute et on redécouvre chaque enregistrement que l’on croyait bien connaître, on tape du pied et on va jusqu’au bout du disque. Aucune fatigue auditive même à fort niveau.Si cette machine était née en France, aux USA , en Suisse ou Angleterre elle serait 10 fois plus chère et serait encore une affaire.
Pour toute installation avec des liaisons asymétriques, cette machine est exceptionnelle.
Un mot sur le réglage de volume : d’habitude quand on baisse le niveau du volume, on perd en même temps tous les petits détails de la musique. Ici rien de tout cela, grâce au schéma à relais très particulier choisis par le fabricant, tous les détails restent présents à bas niveau, c’est d’ailleurs assez déroutant car on a tendance à écouter beaucoup plus bas, du coup on manque un peu de ressenti physique, mais dès que l’on pousse le volume normalement, ça pousse très très fort.
Système d’écoute DIY: multi-amplificateurs classe D Audiophonics MA-ST01 modifiés au niveau des capas d’entrée (4), 2x38cm multi aimant focal pour le grave, 4 cellules isodynamique Fostex dans le medium et 2x tweeter à ruban Supravox. Câble argent rg 223U pour le DAC et multicablage triangle OFC 2,5² pour les enceintes.
Hervé M.
Un très bon câble
J'avais un apriori sur la qualité d'écoute. je suis agréablement surpris, ce câble est à recommander aussi bien pour sa qualité de fabrication que pour celle de son écoute. Ma platine REGA Planet reliée à un DAC AUDIO-GD NOS 19 donne un son neutre avec beaucoup de relief et de couleur. Comparé à une liaison coaxiale avec connecteur RCA sur les mêmes appareils, je dirais même que j'ai gagné en dynamique. Ce câble est une bonne révélation.
Alain G.
BT 60 W
Bon ce n est pas un SHINDO ni un CELLO ! mais moins de 40 euros pour ce petit ampli ! Branché sur des Q Acoustic 1010 mais aussi sur des GAIA MINOR et des PHY ( 21 et 30 ) il se débrouille très bien dans ma grande pièce . Je ne regrette pas mon achat .
Marek M.
for High impedance headphones
I am satisfied with the module, Beyerdynamic T1 I can play. It is also the backup module. I listen to the 100-118 range volume levels.
Jean François B.
ALLO KALI Reclocker I2S FIFO Sparky SBC et Raspberry 44/48MHz 32bit 384kHZ Voici le KALI de ALLO, un Reclocker I2S FIFO 44 / 48MHz qui permet de traiter parfaitement les signaux numériques et les envoyer à votre DAC. Il fait partie de la...
Bluffant !
J'étais un peu sceptique quant à l'amélioration que pourrait apporter ce reclocker. J'ai été bluffé. Je l'ai installé entre mon raspberry et mon dac I-Sabre DAC ES9018K2M J'ai énormément gagné dans la définition des aigus, les basses et médium sont encore plus propres et la scène musicale s'est agrandie, comme si les musiciens étaient plus "ecartés". La dynamique est elle aussi meilleure.
Un régal !
Jean-Marc B.
Qualité assez moyenne
Ce n'est pas cher, mais quand même le trou d'enfichage de la fiche banane pourrait être un peu mieux usiné. Les fiches sont à peine tenues, et ça ne donne pas confiance dans la qualité du contact, ni la longévité.
Etienne H.
Étonnant petit ampli. Associé à deux HP Fostex FF 85 WK dans des bass reflex de 3.5 litres pour améliorer le son d'un téléviseur et rendre les paroles plus intelligibles, le résultat est très satisfaisant, bien mieux qu'une "barre de son" je crois
Marc T.
Trés efficace
Apporte une nette amélioration sur mes enceintes, audible en quelques secondes. Le son est plus précis avec des micro détails et réverbération inaudibles sans : Grave plus fermes, voile en moins sur le medium et aigu plus analytique, ... .
Marc T.
Suite mon précédant avis et après des années d'utilisation sur plusieurs systèmes dont multi amplifications.
Je confirme un rapport qualité sonore / prix exceptionnel, le son est hyper naturel sans stress après des heures d'écoutes ; Les timbres des voix sont magiques, les graves sont conforme aux instruments (Ce qui est rare) et tout les micros détails sont présent sans excés d'hyper analyse, etc. Que dire de plus.
tres deçu
tres deçu de ce cable sur mon systeme je les trouver lent,sombre,baveux ,comparer a un qed revelation il tient pas la comparaison ,je les preter a deux amis qui ont fait la meme constatation ,dnm ou qed me parait superieure a ce cable
a recommander
shuko neotech relié avec du 1100 yarbo , jai pu le comparer au furutech plaqué or , neotech est tres dynamique,neutre,propre,detaillé,basse seche, mais a pas le timbre,chaleur,matiere,douceur des furutech juste un choix ,si vous voulez du timbre matiere opter furutech or ,si vous voulez dynamique ,detaille,transparence opter neotech
excellente embase
iec embase qui remplace ma basique sur alimentation , la furutech est plus rapide,fluide,neutre,nuancé,precise, juste un poil moins de matiere que la laiton , a conseiller fortement
Benoit G.
il y a mieux mais c est plus cher
Rapport qualité prix c est pas evident de faire mieux
Puissant fin un peu fougueux un incontournable
Benoit G.
ahhh le sp 60
Voici un papy de 30 ans qui assure toujours
Quelques litres un condo sur le tweeter et c est parti
Ce n est pas le meilleur hp du monde mais pour une petite anceinte d ambiance c est un must
Avec un tweeter amt ca marche d enfer avec un lm 3886 c est encore mieux
Je mange avec lui tous les jours
Quel talent
