Richard H.
Dayton Audio BST-300EX
précis et chaleureux
Eric v.
bonne prise
Avis clients - Il y a 19688 avis.
Eric L.
FIIO BTR15 Amplificateur Casque symétrique DAC Portable ES9219MQ Bluetooth LDAC 32bit 384kHz DSD256 MQA Cet amplificateur casque DAC portable FiiO BTR15 est un petit appareil abordable, mais pas moins performant, puisqu'il intègre de nombreux composants reconnus sur le...
Floats like a butterfly, stings like a bee!
Fantastic value and power for a tiny headphone amp.
Nice to have both the usual unbalanced 3.5mm and also an even nicer 4,4mm balanced output.
This thing can drive both my kinda hard to drive TruthEars Crinacle One and also my HiFiman Ananda to shaking levels without even breaking a sweat!
Use it as your portable amp for your phone, both by bluetooth with almost flawless LDAC performance or just use the usb dac capabilities to either save battery on your phone by using phone mode or use PC mode to save the DAC batteries, the choice is yours (yes, this also works on a pc, just like a desktop dac!).
I cannot think of any better deal when it comes to an allrounder dac/headphone amp!
Eemeli T.
TOPPING A70 PRO Amplificateur Casque / Préamplificateur Symétrique Volume R2R Noir Le Topping A70 PRO se présente comme amplificateur casque sédentaire efficace et abordable. Sa conception soignée en fait un allié idéal pour...
Got A70Pro as a preamp and it works like a charm. Easy to set up and use even though the manual could be better. Possibility to save two user profiles and safe volume limiter are handy features.
The unit is heavier than I expected for its size, and feels very solid and well built. When changing the volume relays click a bit louder than I anticipated but that doesn't bother me. Screen is bright and easy to see at least from 3 meters away. And the most important part - sound quality - is top notch.
All in all an excellent hp-amp/preamp.
Eemeli T.
KAIBOER Câble de Modulation XLR Mâle vers XLR Femelle Plaqué Argent 1m (Unité) Ce câble de modulation XLR KAIBOER est un câble XLR mâle vers XLR femelle. Les conducteurs de ce câble  sont  en cuivre pur OFC plaqué...
Good stuff
Bought these as I needed a pair of xlr cables between my preamp and power amp. The cables feel nice, are flexible and the connectors are of good quality aswell.
Eemeli T.
A bargain
Excellent quality-price ratio. Little thin in bass but easy to EQ.
Denis Q.
Pour moi, c'est ce qui se fait de mieux.
Ce tissu a une maille suffisamment serrée, et offre une bonne résistance. Sa consistance facilite la confection (je n'aime pas les tissus trop souples).
Acoustiquement, qui peut entendre une différence entre les différents tissus ? sérieusement.
Denis Q.
Conforme à la description
Bien réalisés, ces pieds remplissent leur rôle. Ils ne sont pas durs, c'est vrai, et amortissent bien. Montés sous des enceintes "bibliothèque", il en faut impérativement 4 par enceinte pour la stabilité. Le restitution est amortie, surtout dans les basses, et perd un peu en dynamique. Tout est affaire de compromis, comme toujours...
Jean-Pierre D.
Excellent RQP pour un OCC enceintes
J'ai fait monter ce câble avec fiches bananes Viablue T6S, résultat, belle scène sonore, douce et détaillée avec une neutralité respectée, le prix est ultra compétitif. Pas noté que une c'était en dessous d'un Tellurium Ultra Black beaucoup plus cher, je voulais être en full Neotech sur mon installation, disposant d'interconnexions OCC argent de la marque.
Jean-Pierre D.
RQP excellent
Câble acheté chez Audiophonics, j'ai fait monter avec contacteurs Furutech FT 111 pour permettre d'avoir un prix contenu, ce câble est hyper agréable à écouter, très immersif et fluide, nous place à l'intérieur de la musique, très bonne dynamique. J'utilise avec un lecteur CD à tubes. Dans ce segment de prix, il y a peu d'offres, je ne connaissais Furutech, très bon. A recommander, je ne peux que confirmer avis précédents.
Jean-Pierre D.
NEOTECH NEI-1001 II Câble de Modulation Symétrique Argent UP-OCC 2x1.17mm² Triple Blindage Le Neotech NEI-1001 II est un câble de modulation symétrique composé de 2 conducteurs en Argent UP-OCC d'une section de 1.17mm². Chaque conducteur est...
Après un 1220
Je confirme avis précédent, câble qui m'a été monté chez Audiophonics avec connecteurs AECO ARP 1512, après un Nemoi 1220, la signature est identique, plus d'aération, dynamique meilleure, énormément de profondeur. C'est très cher, meilleur câble que j'ai eu, certains câbles sont plus immersifs, mais il leur manque de la neutralité ou de la profondeur, celui-ci vous apportera les deux.
Jesse D.
AUDIOPHONICS OPA1612 AOP Double DIP8 (Unité) L'amplificateur opérationnel Audiophonics OPA1612 se base sur une authentique puce 1612 de Texas Instruments. Cet AOP permet une très bonne performance...
Tip Top !
Excellent en buffer de DAC (certains appellent cela "LPF') à condition que ses entrées soient de faible impédances (jusque 1K cf DATASHEET) mais aussi que celles-ci soit "équilibrées" (Ze+ = Ze-): avec l'OPA2211 (gamme supérieure Hi-Res que devrait proposer AUDIOPHONICS...), ce sont les amplis OP BIPOLAIRES accessibles qui ont les meilleures caractéristiques chez TEXAS INSTRUMENTS.
Sans doute le meilleur choix dans ces conditions auquel cas l'utilisation d'un AOP de type FET ou JFET sera plus appropriée (ex: OPA1656, OPA1642).
Vivement conseillé !
Philippe E.
FOSI AUDIO E10 Amplificateur TPA3251D2 MS8413 Bluetooth 5.0 24bit 192kHz 2x125W 4 Ohm Le Fosi Audio E10 est un amplificateur Class D à la fois puissant, performant et abordable. Il embarque une puce d'amplification TPA3251D2 lui permettant de...
Quoi demander de plus....!
ce petit ampli a été pour moi une révélation......branché sur des Klipsch RB81 MKII et alimenté par un Yamaha WXC-50 sur Netradio. La restitution est très dynamique, détourée avec des attaques franches et beaucoup de grain dans la tessiture de timbres. En fait, c'était un cadeau pour un ami mais je vais en commander un pour moi.....et très rapidement. Cet ampli est de plus très fonctionnel et doté d'une connectique presque complète, 2 prises numériques, 2 RCA, une sortie PréOUt pour caisson, 1 USB qui lit les Flac (il manque peut-être une HDMI Arc). Son esthétique sobre et original fait classieux et pas bling bling ! Vraiment excellent rapport qualité prix. Top
Gregory S.
THINKYA JA-310 Lecteur CD et Fichiers Audio USB Optique Jack 3.5mm Bluetooth 5.1 Le Thinkya JA-310 est un lecteur CD compact et design, faisant également office de lecteur de fichiers USB. Profitant d'une esthétique mêlant vintage et...
Excellent sound via Toslink, but mechanical noise intrudes
The CD player produced impeccable sound when connected via Toslink to my DAC. Unfortunately intermittent mechanical noises from the laser stepping motor were audible from 3 m away, and intruded upon quiet passages in the music.
Bernard D.
DENAFRIPS ARES 15TH DAC R2R Symétrique 24bit 1536kHz DSD1024 Noir Pour célébrer ses 15 ans d'expertise, Denafrips propose avec le Ares 15TH un DAC R2R symétrique NOS haut de gamme extrêmement performant....
Un grand potentiel.
Livraison en 48 h (vers Belgique). Bravo et merci Audiophonics !
Première impression après branchement et écoute de Oracle de Gary PEACOCK : scène sonore plus large sur mes KLIPSCH Reference.
Deuxième impression : son naturel et précis tant pour les basses que les aigus.
Troisième impression : de l'énergie présente, des attaques franches.
Je précise que j'ai opté pour le mode NOS et que je viens du SMSL D400PRO/AKM.
ARES raccordé en usb à mon Eversolo A6.
Reste plus qu'à faire le rodage mais cela sent déjà très très bon...
Contrepointes Aluminium avec Anneau Caoutchouc 50x19mm Argent (Set x4) Ces contrepointes en Aluminium seront parfaite pour une installation sous des appareils HiFi (amplificateur, préamplificateur, DAC...) ou sous des enceintes, afin de...
Good, but
These little shoes are great with a small but. The spike entry diameter is quite narrow and also deep. The shoe will contact with the cone of a spike rather than just the tip unless your spikes are very narrow
Pawel W.
AMANERO COMBO384 Digital latest version BK2304
The original product should be used with ASIO drivers for DSD DAC. The power supply requires 2 additional capacitors at 5V and 3.3V voltage, which results in super precise performance.
It s the latest version of amanero B2304, it needs new version of tool http://www.amanero.com/update118new.zip, old one doesnt work.
SINGXER SU-6 Interface Numérique I2S USB XMOS XU208 32bit 384kHz DSD512 Le Singxer SU-6 est une interface numérique nouvelle génération offrant d'excellentes performances audio grâce à une conception basée...
indispensable
ce DDC permet de passer de l'usb au I2s et vous permet d'obtenir un rendu sonore exceptionnel a partir d'un portable . les drivers asio fonctionne sans problème (W11) +Jriver32;
PANGEA PREMIER XL MKII Câble USB-A Mâle vers USB-B Mâle Cuivre Cardas Plaqué Argent 1m Avec le Pangea Premier XL MKII, vous profitez d'un câble USB-A vers USB-B de très haute qualité, permettant une parfaite transmission du signal entre vos...
L'usb a son meilleur.
ce câble me donne un bon rendu en entée d'DDC singxer su 6 en sortie ver un DAC HOLO AUDIO SPRING 3 , j'utilise un cable PANGEA PREMIER SE MKII Câble HDMI 2.1 en format I2s Tout vient de chez Audiophonics . le rendu sonore est exeptionnel .
Thierry C.
MINIDSP FLEX HTx Processeur Audio DSP 2x8 Canaux Symétriques SHARC ADSP21489 HDMI ARC eARC Grand frère du Flex HT, le Flex HTx de la marque MiniDSP est un processeur audio multicanal  de 2x8 canaux parfait  pour une...
Remplace avantageusement les 2 DCX 24-96 pour gérer les 3 voies de mon système
Après avoir mis au point mon filtrage à l'aide de petit Behringer DCX, j'ai choisis de bénéficier du rapport signal/ bruit exceptionnel de ce DSP : 24dB de mieux (encore amélioré sans doute par le recours à un filtre à Supercondensateurs)
Les seuls bémols :
* Seulement 4 presets
* Pas de gestion de la convolution FIR contrairement à d'autres appareils de ce gamme moins ambitieux
Mohammed B.
Super Stecker spielt sehr neutral
Die Silver Steckern spielen sehr neutral detailreich flüssig sehr sauber musikalisch und der Bass kompakt trocken und sehr schnell.
Vorsicht!!
Im Vergleich zu Standardsteckern spielen die WBT viel zurückhaltend
und Neutral daher sind sie für Musikanlagen die zu dynamisch unsauber und zu offen spielen geeignet.
Alle neue WBT CU bzw AG Steckern spielen wie oben beschrieben ist
wer mehr Bass sehr offen bevorzugt , sollte was anderes kaufen Massivsteckern spielen mit mehr Druck im Bass und Dynamischer.
David T.
test sur Wilson Audio Watt Puppy 7
mes amplis actuels sont 2 Mark Levinson no.331 en configuration Monophonique . un son tres rapide , des superbes basses , microdetails fabuleux .
ce test sera fait sur plusieurs semaines .
excellent rqp
Ce distributeur secteur dispose d'une qualité de fabrication indéniable ; boitier en métal brossé de forte épaisseur et de bonne finition ; prise iec d'entrée en cuivre . Au niveau du son un gain très significatif en netteté et propreté d'image . j'ai rajouté mes filtres quiet line + des pieds antivibratoires sur roulement à bille ( en vente sur ce site) ( gain d'aération de la scène sonore ) . Ce distributeur est une excellente base pour un prix plus que raisonnable , certains plus chers ne feront pas forcément mieux .
Laurent C.
Fabuleux
Branché entre un Nuprime Ida-8 et sa boîte d'allumette le D-Sream Primo HD, enterre tous c concurrents... très musical, précis, dynamique sans fatigue comme certains hdg... un véritable régal.
Laurent C.
Le Must !!!
Ne cherchez pas plus loin... c le bon !!! Encore une excellente trouvaille chez Audiophonics, après le rca canare et le RJ45 audiophonics, une nouvelle très bonne surprise. Bravo
Laurent C.
Excellentes !!!!
Montées sur de l'elecaudio hp25OCC, j'ai pas trouvé mieux que les viborg... idem sur de l'atohm zef max. Je pense que c fiches bananes plaqués argent/or sont neutres comparé aux viborg tout cuivre qui amènent un brin de chaleur. Dans tous les cas, rapport qualité prix imbattable !!!
Jesse D.
AUDIOPHONICS OPA1656 AOP Double DIP8 (Unité) Audiophonics est fier de présenter sa gamme d'AOP avec l'OPA1656 basé sur une authentique puce Texas Instruments. Cet AOP offre de très bonnes performances...
Superbe !
Le meilleur OPamp a marier, selon moi, avec l'amplificateur FOSI AUDIO V3.
Linéaire et neutre sur toute la bande avec le circuit de cet amplificateur, il sera capable de retranscrire au mieux ce qu'il recevra à ses entrées.
Sinon pour AUDIOPHONICS, juste un petit message:
la forme particulière que vous avez donné au PCB de vos AOP est super sympa MAIS elle ne permet pas cependant de pouvoir l'intégrer dans tous les appareils, comme le FOSI AUDIO V3 ou j'ai du pour la peine intercaler des "Support Tulipe DIP8 Plaqué Or pour Circuit Imprimé" entre son PCB et l'AOP, ce qui éloigne le condensateur de découplage de sa proximité conseillée dans les datasheet de TEXAS INSTRUMENT...
Adam S.
AUDIO-GD DA-7 MKI 2023 Module DAC R2R 24Bit 384kHz Le module DA-7 MKI 2023 de chez Audio-GD embarque un DAC 24 bit basé sur réseau de résistances. Il profite de tout le savoir-faire...
this is brilliant
made a dac with 3 r2r bords and passive output without opamps ,tried with opamps it sounded dull and bad compared with my dddac, with passive output it beats ny dddac and my friends metrum pavane and a denafrips, they just got beated very bad, the psu used is a 3 stage psu with emi filters and lt3045 in the last stage, lm1084 in first stage and lf80 in second stage, and a lot af b4 15000uf caps in indput and before lt3045, this is the best dac i ever heard
Thierry C.
ATOHM WT-7992-G Bornier Encastré Isolé pour Enceintes Plaqué or 92x79mm (Unité) Le bornier WT-7992-G , tout comme l’ensemble des modèles proposés par Atohm, est équipé de bornes largement dimensionnées en Laiton...
La marque ATHOM n'apparaît pas mais inspire le sérieux aussi bien pour le plastique épais et pas cassant et le bornier proprement dit en métal massif bien plaqué.
Thierry C.
Reçus rapidement, bien emballés (2), tweeters de bonne facture, tout métal. J'ai pu remplacer des tweeters plus classiques (ferrite) dont l'impédance devait être légèrement supérieure. En portant de 4,7 à 7,5µF le condensateur série du filtre le raccordement avec le médium est impeccable à l'oreille et à la mesure. La courbe remonte vers les 20 kHz mais ça ne me gène pas et musicalement c'est très bien je trouve.
Jonathan K.
AUDIOPHONICS GREYHOUND Câble Secteur Schuko IEC C15 Cuivre OCC / OFC Blindé 3x2.5mm² 1.5m Assemblé à la main en France dans nos ateliers, le câble secteur Schuko vers IEC C15 Audiophonics Greyhound offre une excellente solution pour raccorder...
Déroutant
dans les basses fréquences.
J'apporte une nouvelle fois mon avis sur ce câble mais cette fois-ci sur la version montée par audiophonics.
Dès la première écoute, on retrouve toutes les qualités du câble d'elecaudio, c'est à dire un éclaircissement de tout le spectre, un aigu beaucoup plus précis et plus riche, un médium remarquable et des basses tendues avec de la définition.
Ce câble me plaisant énormément, j'ai décidé d'harmoniser mon système, mon ampli ainsi que l'alim du pré-phono sont alimentés par ce câble secteur. Les câbles de modulation sont des sommercable Epilogue.
Après un petit rodage de quatre cinq après-midi/matinées, je suis assez stupéfait du résultat. C'est même d'ailleurs un peu déroutant. Sur la trompette de Jon Hassel, les montées dans les aigus sont enrichis d'énormément de matières et de détails ! Pareil, sur le disque de la planète sauvage (BO d'Alain Goraguer), j'ai jamais entendu autant de maîtrise et de définition dans les basses fréquences. La basse est d'une propretée et pourtant elle garde tout son côté organique. Bluffant. De même sur le disque d'illustration sonore Guy Pedersen - contrebasse, ce dernier instrument n'a jamais sonné aussi réaliste et vivant.
Ce qu'on peut retenir sur ce câble est qu'il apporte beaucoup de définition et de maîtrise sur tout le spectre audible et cela sans artifices !
Bravo à audiophonics, car pour le prix proposé, ce câble est stupéfiant.
Gorazd K.
XANGSANE XS-6002AU Fiches Bananes Plaqué Or Ø7.5mm (Set x4) Ces fiches banane de la marque Xangsane bénéficient de contacts en alliage de cuivre avec un plaquage or pour une conductivité accrue...
Surprisingly quality bananas. I already have some very well-known audiophile brands, but these are not far behind them... or rather, they seem to me to be of the same quality, double screwing of the wire... in short, there is no point in paying for a well-known brand.
Et je remercie…
...tout d’abord, David et le site Audiophonics, pour le prix, la qualité de leurs produits et celle de leurs services, y compris le SAV, très réactif.
Ensuite les personnes qui ont donné leur avis sur ce câble ! En effet, ce sont eux, les « Audiophiles anonymes », qui m’ont grandement aidé à effectuer enfin LE bon choix.
Je vous expose mon problème d’origine : disposant d’un système audio me convenant PRESQUE (ampli TAGA HT 25, avec lampes chinoises d’origine remplacées par des russes, sur enceintes Focal Aria 906, reliés par du câble Viard HD de base (très bon au demeurant)) et ce après des années de recherche (quelques problèmes d’audition, ce qui fait que je ne supporte pas les aigus scintillants, même légèrement, les voix et médiums pas assez distincts et donc donnant de la « soupe » indigeste à l’écoute , et les basses trop envahissantes ou percutantes) ; or, le son était très bon, mais les aigus restaient encore un peu trop brillants…
(au passage, je m’étonne de ne jamais voir indiqué plus explicitement des mentions dans la présentation ou le test de produits audio du genre ‘déconseillé aux personnes ne supportant pas les aigus brillants’ ou ‘recommandé aux personnes cherchant des basses fermes mais pas des marteaux-piqueurs’ par exemple… ou alors je suis le seul ayant quelques problèmes auditifs ? )
Bref, j’ai beaucoup tâtonné puisque, comme pour le cognac, tout ceci est histoire d’assemblage, et ce entre : les enceintes, le câble, l’ampli, la pièce, le positionnement des enceintes dans la pièce, les caractéristiques auditives de l’auditeur, ses goûts… ce qui fait beaucoup de variables, pour finir par assembler correctement ce qui ressemble plus à un rubik’s cube qu’un puzzle !
Donc, je désespérais et puis en cherchant sur le site le câble qui pourrait enfin peut-être éventuellement à tout hasard me convenir avec un peu de chance, je tombe sur le MOGAMI W3103 2x4 mm2, sa très bonne note et ses 83 avis, et ce pour un prix très abordable.
J’examine la chose de plus près, et là quelques avis, se recoupant, m’interpellent ; il est fait mention de musicalité, neutralité, de scène sonore large, de précision des timbres… et enfin d’un défaut dont j’ignorais le nom : le côté SOMBRE donné au son… Sauf que ce défaut semble, pour moi, LA qualité que je cherchais !
Donc je commande, je reçois, je monte les fiches bananes, je branche et… ô miracle (ou presque!) : dès la première seconde LE son annoncé est là, propre, précis mais pas agressif, agréable, avec une scène sonore très large… et des aigus enfin domptés ! Je peux écouter mon ensemble plus de dix minutes sans avoir mal aux oreilles ! Un seul petit défaut : les basses sont un peu trop discrètes, mais je compte sur le rodage et, comme annoncé par certains, au bout d’une bonne dizaine d’heures elles sont remontées à la surface… pour mon plus grand plaisir : j’ai enfin LE son qui me convient !
Voilà, j’espère tout simplement que mon avis pourra à son tour être utile à d’autres lecteurs-auditeurs d’Audiophonics !
Mikael C.
Relié à mon DAC par câble toslink, fonctionne très bien. A voir la solidité sur la durée, mais c'est un transport cd qui fait très bien son travail. Je n'ai pas essayé la sorti son du lecteur, n'en ayant pas l'usage.
Juri L.
FOSI AUDIO V3 Mono Class D Amplifier TPA3255 240W 4 Ohm. Good!
Pablo P.
AUDALYTIC AH90 DAC AK4499EX XMOS XU316 LAN UPnP Roon 32bit 768kHz DSD512 MQA Noir Le Audalytic AH90 est un DAC proposant d'excellentes performances de décodage et une restitution sonore précise grâce à une conception soignée...
Excellent dac streamer de Gustard
Dac et streaming en un seul appareil.
Qualité de son au rendez-vous.
Nombreuses connexions.
Possibilité d'alimentation externe, un vrai plus.
Télécommande.
Un maillon de la chaine de reproduction audio réussi.
À ce prix il n'ya pas mieux je pense.
Grande communauté des appareils Gustard.
Une valeure sûre dans le monde de l'audio
Geobert Q.
TOPPING DX3 PRO+ DAC ES9038Q2M Amplificateur Casque NFCA Bluetooth 5.0 aptX HD LDAC XMOS XU208 32bit 768kHz DSD512 Argent Topping dévoile son DX3Pro+, évolution directe de l'excellent DX3Pro, excellent DAC compact offrant également les fonctions d'amplification casque et...
Super !
Je l’adore ! On peut sortir sur line out ou casque ou les deux, et chaque mode garde son réglage
Geobert Q.
TOPPING MX5 Amplificateur Merus MA12070 Class D NFCA XMOS Bluetooth aptX HD 2x55W 4Ω 32bit 384kHz DSD256 Argent Le Topping MX5 est un combo amplificateur et amplificateur casque avec DAC ESS ES9018 intégré. Particulièrement polyvalent et performant, il profite d'une...
Juste un défaut
Pour ce prix, un combo DAC, préamp casque et amp, c’est génial. Mais un défaut dont il faut être conscient(e) : en mode casque seul, les enceintes sifflent :-/ Pas forcément gênant, mais faut le savoir.
Damien M.
Musique servie sur un plateau !
Possédant plusieurs cellules phonos et ne disposant pas de réglage de hauteur de bras sur ma platine , je compense en alternant des couvres plateau d'épaisseur différente qu'il m'arrive même de superposer. Une écoute subjective ( bien évidemment ) de l'album "White Hot & Blue" de Johnny Winter (du hard blues qui déménage) avec le Dynavox PM3 semble favoriser l'attaque ferme des lignes de basses et de ce fait met davantage en valeur les solis élastiques et virtuoses du fameux et regretté guitariste albinos dont les notes rebondissent de partout telles des balles de tennis. Les nuances de grain de son obtenu entre les différentes matières (caoutchouc , cuir, liège) sont très subtiles et pas forcément faciles à saisir , mais il est intéressant de faire l'expérience. Ce modèle me semble privilégier légèrement la dynamique et vu son excellent rapport qualité prix , il aurait était dommage de m'en passer.
Alexandre V.
J'ai été agréablement surpris par le look et les finitions de l'appareil. Il présente très bien !
J'utilisais avant un SMSL Q5 Pro branché sur des enceintes Dali Zensor 5. Eh bien, quelle différence !
L'Audiophonics est bien moins fatigant lors d'écoutes prolongées. Les basses sont bien plus présentes... Je vais devoir revoir les réglages de mon sub.
Par contre, j'ai l'impression que la scène sonore est un tout petit peu moins large.
Globalement, je suis très content de mon achat.
Gorazd K.
AUDIOPHONICS AP300-S500NC Amplificateur de Puissance Class D Stéréo Ncore NC502MP 2x500W 4 Ohm Le Audiophonics AP300-S500NC est un amplificateur stéréo basé sur un module d'amplification Hypex Ncore NC502MP. Cette solution est...
This amp exceeded my expectations. It is not too bright in my system as I was afraid for the d class. For the preamplifier I have atoll pr300 signature. It is neutral with excellent and controlled bass and with a huge reserve of power, the workmanship is impeccable, quality connectors... and as always safely packed by audiphoniccs
Mehdi O.
SMSL DL100 DAC 4x CS43131 Amplificateur Casque XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD256 MQA-CD Avec le DL100, SMSL nous propose un DAC haute performance intégrant des composants de qualité tels qu’un combo de 4 puces CS43131 de Cirrus Logic, une...
Un tout en un pour un petit prix (HDMI Arc en bonus)
J'ai mis 5 étoiles non pas pour ses qualités sonores qui sont bonnes sans être extraordinaire, mais pour son côté couteau suisse à un prix vraiment abordable.
Voici ce qu'il inclut :
Sorties XLR (symétriques), RCA, casque 6,35mm et 4,4mm
Entrées : HDMI Arc, optique, coaxial, USB type C (1.0 et 2.0), Bluetooth (Aptx et LDAC)
Tout cela aux alentours de 200€, rien à redire.
Alors certes, pas de DAC ESS ni AKM, mais 4 puces Cirrus Logic CS43131 (2 par canal) qu'on retrouve dans des mini-DAC portables.
Des Op Amp de qualité, mais en quantité moindre, 3 OPA1612a qui permettent une amplification plus que correcte et puissante ( 2x 3W en 16Ω pour la sortie casque 4.4mm). Certes, il y a eu des économies, l'écran LCD a un effet "vintage" (comme nos anciens réveils), mais reste lisible. Certes le son n'est pas le meilleur du marché, mais n'est en aucune façon mauvais, bien au contraire et les mesures plus que correctes en attestent.
Je le conseille principalement à ceux qui désirent écouter au casque sur la TV (grâce au HDMI Arc meilleur que le câble optique (toslink)) et y brancher via les sorties XLR deux enceintes actives en stéréo, puis pourquoi pas un sub sur la sortie RCA.
S'il coûtait le double, il perdrait 2 étoiles, mais c'est justement sur le prix qu'il est imbattable. Une fois de plus, SMSL parvient à sortir un produit au rapport qualité/prix de folie.
PS : Le seul DAC tout en un qui propose les mêmes fonctionnalités dont le HDMI Arc est le FiiO K19 à 1400€, soit quasiment sept fois plus cher. Il y a également le SMS DO200 PRO, mais il n'y a pas de sorties casque.
Yves-G L.
Canare câble coaxial -1m.
Pour un prix vraiment raisonnable, une belle découverte. Niveau de définition supérieure, assise solide, scène sonore plus large. Fermeté et assurance. Merci car rarement distribué sauf erreur. Mon petit combo : Rotel A-14 mk2 et lecteur CD-14mk2 plus "vieilles" Mission M-71i - à changer un jour prochain - a gagné sur beaucoup de plans. Expé. et livraison rapide. Emballage pro.
Merci !
Anders C.
AUDIOPHONICS HPA-T400ET Amplificateur de Puissance Class D 3 Canaux Purifi 1ET400A 3x400W 4 Ohm Nous sommes fiers de vous proposer le AUDIOPHONICS HPA-T400ET, un amplificateur de puissance 3 voies class D basé sur trois modules PURIFI 1ET400A....
Clean power. And a lot of it!
Sounds perfect with my Arendal 1723 speakers.
Mehdi O.
SMSL RAW-MDA1 DAC 2xES9039Q2M Amplificateur Casque Bluetooth 5.1 32bit 768kHz DSD512 MQA Le DAC SMSL RAW-MDA1 est un DAC symétrique qui dispose de deux puces ESS ES9039Q2M et d'une interface USB XMOS XU316. Ces composants de qualité lui permettent de...
Fait aussi bien (voire mieux) que des DAC avec ESS ES9038Pro
Excepté l'absence d'une Entrée HDMI Arc (que j'aurais souhaité, obligé de me rabattre sur le moins qualitatif SMSL DL100 pour le coin TV), le choix de mettre deux puces ESS ES9039Q2M (pour chaque canal) à la place d'une ESS ES9039Pro (le prix serait aisément doublé) et pas de PEQ intégré (une égalisation paramétrique), tout est parfait. Les mesures ne me contredisent pas.
J'avais peur que l'amplification casque (6,3 et 4,4mm) soient en retrait, que nenni, c'est excellent et puissant. Venant d'un Xonar Essence One amélioré avec des Opamp de qualité, j'entends des micro détails jusque là masqués. Un son précis, avec une bonne ouverture, détaillé sur l'ensemble du spectre, dynamique et de bonnes basses percutantes (juste ce qu'il faut). Je n'ai pas essayé de DAC à 1000€ ou plus, mais la différence doit être minime.
En toute honnêteté, ce DAC avec sortie casque vaut largement le SMSL M500 ou autre DAC tout intégré à base d'ESS ES9038Pro.
Un excellent rapport qualité/prix qui sera l'investissement idéal pour les mélomanes/audiophiles/homestudistes modestes et intelligents.
+ Un superbe son (sorties XLR, RCA et casque)
+ Tout est quasiment inclus (Bluetooth, MQA, MQA-CD)
+ Une taille modérée, s'insère partout
- Pas d'HDMI Arc
- Des puces DAC moins chères mais qui sont plus que suffisantes
- Pas de PEQ (égalisation paramétrique incluse) mais des filtres pour colorer le son.
Leonardo B.
DAYTON AUDIO DC200-8 Classic Haut-Parleur de Grave 60W 8 Ohm 87dB 29Hz - 3000Hz Ø20.5cm Le Haut Parleur DC200-8 8 Pouces de chez Dayton Audio propose un rapports qualité/prix très intéressant dans sa gamme. Il est pensé pour offrir de bonnes performances tout en...
Amazing response
Bought as a replacement driver for a 10l reflex subwoofer enclosure. Sound is spectacular, responsive all the way down 40-35hz. Not the cleanest sound but it is what i was looking for!
RAMM AUDIO E72 Câble de Modulation Cuivre OCC Ø8mm Le câble de modulation Ramm Audio E72 offre une excellente qualité de conception, pour une parfaite transmission du signal. Il intègre ainsi deux...
Très musical !
Montage fait avec des connecteurs Ramm vissants. On passe les problemes dus a la rigidité des gaines et la vis minuscule mal adaptée pour serrer 3 minuscules brins de 0,5 mm. Le résultat est tout bonnement stupefiant, précision, ciselé, avec des timbres magnifiques. Il devient mon meilleur câble actuel après en avoir testé beaucoup dans cette gamme de prix et même 3 a 4 fois plus cher.
Jean-Pierre D.
SMSL D1SE DAC ES9038PRO Symétrique CPLD Altera XMOS 32bit 768kHz DSD512 Noir Le D1se de chez SMSL est un DAC extrêmement performant, se basant sur une architecture symétrique utilisant une puce de conversion numérique / analogique...
Petit DAC musical et détaillé
Première Déclinaison du D1, promotion Audiophonics, prux intéressant, délivrant un son très ouvert, belle imagerie, bien, pour quelqu'un qui recherche un appareil musical avec un DAC de pointe ESS non gravé avec un encombrement minimal. Il existe un S2 avec davantage d'OP qui a remplacé celui-ci et le nouveau DAC ESS 9039. Ces modèles ESS ont une belle neutralité, mais ce n'est pas stérile, une alternative intéressante à AKM ou à des R2R d'entrée de gamme.
Lorenzo C.
AUDIOPHONICS HPC4 Câble Haut-Parleur Cuivre OFC 2x4mm² Ce câble Audiophonics HPC4 pour haut-parleur possède deux conducteurs, chacun composé de 511 brins en cuivre OFC, assurant ainsi une conductivité...
Very good!
Got 10 mt. of this nice cable to replace a similar OFC cable, same section (4sq.mm) so no bells and whistles or sound miracles happens here.
Just measured it to find a R value waaaay lower than my previous one, and -this- is actually surprising!
Easy to plug with my full copper Viborg bananas, and very nice to see, this copper cable is worth every cent!
Thanks to Audiophonics Team for a faster than light delivery!
Happy listening!
Jean O.
rodage
Comme déjà signalé, cet ampli nécessite un rodage sérieux (plusieurs dizaines d'heures) avant d'en tirer la quintessence. Ne pas se fier aux premières impressions qui peuvent être un peu décevantes (bien à tort). Magnifique ensuite.
Eric z.
qualité - prix
Trés bon câble, bien construit, simple, rien de magique, avec lui on écoute la musique pas le câble, avec un rapport qualité -prix- résultat qui sort du lôt
eric m.
ELNA LAO Condensateur Électrolytique Hautes Performances 63V 15000µF ELNA propose avec les condensateurs de sa gamme "For Audio" des produits particulièrements adaptés au domaine de l'audio et de la HiFi.
"Bling Bling"
Dans mon projet de mettre à niveau un Amplificateur PIONEER A-447. J’ai fait le choix de ces condensateurs ELNA.
Malheureusement à la réception de ma commande, je suis surpris par l’apparence « Bling Bling » de ces condensateurs ELNA LOA. Ils sont également bien loin de la valeur indiquée sur le composant. Bref…. Il n’y également aucune référence ELNA inscrite sur ces condensateurs. Je n’ai trouvé aucune valeur 15000µf/63V sur le site du fabricant Japonais ELNA.
Dans le doute, je préfère les utiliser pour un autre usage que HI-FI.
