Michel V.
Musical et costaud !
Facile
Comme à son habitude, Viborg nous propose des prises RCA haut de gamme et facile à connecter avec vos cables préférés. Mais...
Avis clients - Il y a 19150 avis.
Christopher B.
TOPPING EHA5 Amplificateur Casque Électrostatique Symétrique 700Vrms La plupart des casques électrostatiques offrent un excellent potentiel musical mais leur performance est souvent limitée par l'amplificateur casque associé....
Works Well
I just moved to France and am setting up my sound system. I purchased this and Stax Lambda headphones for my new home audio system, and it works well and looks good. I can not compare it with the other electrostatic headphone amplifiers available for Stax headphones because I have not heard any of those available now, but this is a fraction of the cost and sounds clear and clean to me. I like the visual aesthetic (and the fake tube glow, which amuses me, but...I like it), and I am contented with this product's ability to drive my difficult-to-drive headphones.
Christopher B.
AIYIMA T9 PRO Amplificateur TPA3250 Tubes 2x JAN5725 ES9018K2M Bluetooth aptX HD 2x60W 4 Ohm Le Aiyima T9 Pro est un amplificateur intégré polyvalent et abordable, idéal pour monter un système audio sans se ruiner et sans multiplier le nombre...
A Little Treasure
This little amp is cute and fun. It is very versatile and the Bluetooth works well. I have been using it as my television and CD/DVD/Blueray audio amplifier, and it has really grown on me. Whether the sound improved or I adjusted to it, I cannot say, but I really enjoy it. The power output is more than that of most of the amplifiers I've had in my life and the sound quality is surprisingly good. This little amplifier has an almost cult following in the U.S., and I can understand why. Small, convenient, multiple inputs, fun to look at and use, and it sounds good running my small and also cute speakers (Lii Audio Raindrop-3) and has the power to fill the house with music. Tiny and cute as it is, this is a serious little amplifier and I like it.
Christopher B.
AUDIOPHONICS DAW-S250NC Amplificateur Intégré Class D NCore NC252MP DAC ES9038Q2M WiFi Bluetooth 2x250W 4 Ohm 32bit 768kHz DSD Polyvalent et performant, nous vous proposons avec le DAW-S250NC un amplificateur intégré à entrées numériques auquel il suffira d'ajouter des...
Good Integrated Amp
I find this to be a good amplifier and I greatly appreciate its power, clarity, and versatility. I have no reservations about it and I am pleased to have it in my system.
My only regret is that it does not have RCA inputs. I would like to connect a phono amp directly into it, but that is my problem, not this amplifier's. This is a modern integrated amp that accepts Bluetooth and WiFi streaming, and phono is for dinosaurs--like me. With a DAC built in and COAX, OPT and USB inputs, this really is a versatile and advanced amplifier. It is very responsive to the remote control and the design is aesthetic: simple and pleasing. It is remarkably light for the rated power output and VERY convenient to use. I connected audio from a video projector via Bluetooth and was impressed by the quality of sound and the excellence of the connection. I was streaming videos and films with audiophile sound and quick and easy connection.
I have been able to stream from my computer, my laptop, my phones, and the phones of guests with quick and easy connections that provided stable wireless connection and audiophile-quality sound. I have also been able to connect a Topping electrostatic headphone amp that I also purchased through Audiophonics to it, and the sound is clean and clear.
I am happy with this purchase and will no doubt recommend this amplifier to friends.
I recently moved to France and wanted to buy French-built products for my new home and new life and I am very proud that this amplifier, which is advanced and of good quality is French. French-designed and French-built and in line with legendary French quality.
Christopher B.
Well Built, Well Designed, Works Well
I feel that this is a good-quality item. It is well-designed: the prongs go in to the outlets at right angles; another power strip that I have has them at an angle and some power plugs prevent another from being positioned in the next outlet. The same plugs in this power distributor have no such problem. It feels solid and well-built and heavy enough to not be twisted around by the power cords plugged into it. I feel confident in the quality of this item and I am comfortable plugging in my audio equipment to it.
I would buy this item again if I need another and would recommend it to a friend.
Christopher B.
It Works Well
It works well. I see no problems. I would not hesitate to order this again.
I purchased this cord to connect an "AUDIOPHONICS Aluminium Power distributor 8 Schuko plugs Black" to an outlet (that power strip needs the additional purchases of a cord and bumpons for feet), and it fits perfectly and I see no problems whatsoever.
Rodolphe L.
Petit ampli vivant
Cet ampli marche correctement, il semble vivant et dynamique. Je l'alimente à +-40V.
Rodolphe L.
Bon boitier et pas cher. Mine de rien c'est un boitier radiateur très discret et pratique pour tourner un petit ampli classe B ou bien tout montage qui a besoin de dissipation. Je fais tourner un Ampli LJ L7 dessus et ça va très bien.
Rodolphe L.
Module d'Alimentation à Découpage 700W +/-40V Ce module d'alimentation à découpage LLC dispose d'une sortie principale délivrant une tension de ±40V. Le circuit de résonance utilise une...
Très pratique mais Bruyant
Alimentation qui est bien pensé, pratique avec des sorties 12V ventilateur, +-12V auxiliaire en plus de la tension principale, le tout sur borniers, très appréciable. Il fait le job d'alimenter mais le seul bémol il est bruyant. Je suppose au prix vendu , il ne faut pas s'attendre à mieux.
Laurent C.
Excellent connecteur, musical et précis, monté sur Elecaudio cs-361b vers un ampli Marantz... à renvoyer sur leboncoin des câbles secteur de grande marque.
David G.
Top qualité
Qualité vraiment au top pour ce bloc prise!
Rien que le poids en dit long!
Livré dans un petit coffret.
Gain significatif sur la propreté du signal! Un upgrade indispensable !
Jerome C.
Belle qualité
Je n'avais pas fait attention à la description et c'est une belle surprise, une finition exemplaire, entièrement métallique, la marque non pas imprimée mais emboutie, une peinture sans défaut et un contact doré.
Leur longueur n'est pas excessive et effectivement c'est plus simple pour la soudure du câble.
20/20
Renzo L.
KECES P8 Alimentation Linéaire Régulée Ultra Faible Bruit 19 / 20V 8A + USB 5V 1A La Keces P8 est une alimentation linéaire régulée de grande qualité qui permettra à votre système audio haute-fidélité de...
Stark und edel
Eigentlich habe ich mein Keces Gerät als gebraucht günstiger kaufen können aber seine Ausgangsspannung ist stabiler als bei anderen günstigeren chinesischen Netzteilen. Auf dem Display erscheint auch vieviele Ampére die Last beansprucht, mein HTPC mit Windows10 AsrockVision benötigte nur um die 3A, aber das wusste ich ursprünglich nicht, darum hatte ich diesen starken Netzteil mir gewünscht. Aber nachdem ich Windows stark getweakt habe, vor allem dank MSMGToolkit, habe ich nur noch 1,7 A im Maximalfall. Für mini-PC und Laptop ist absolut notwendig ein Linearnetzteil, ich konnte sofort den Unterschied zum SMPS feststellen, vorher die hohen Töne waren kreischend, überlagert mit SMPS-Schwingungen, jetzt sind sie klarer, ein USB-Isolator allein half nicht genügend.
MONOLITH M1060C Casque Fermé Planar Magnetic 90dB 18 Ohm 10Hz - 50kHz Le casque Monolith M1060C se dote de haut-parleurs planar magnetic repensés, capables de reproduire une scène sonore détaillée et précise au...
agréable
Le casque est volumineux mais son port est confortable ; on à tendance à l'oublier . Le son est détaillé et le rendu spatial séduisant et pas caricatural . Un bon compromis pour moins de 300 euros . Fait aussi bien que certains casques plus chers .
Sans plus ...
Pour les porteurs de lunettes le port de ce casque pince celles-ci et décolle les lunettes du nez . Sans lunettes le port manque clairement de confort . Le son ne pas convaincu mais je souligne que je n'ai pas eu la patience d'attendre le rodage malgré un léger mieux après dix heures d'écoute . ( son de boîte ).
Déçu !
Petit prix mais qualité médiocre.
L'isolant central fond quand on soude.
Avec ma station de soudure réglable, impossible de souder un fil sans que la pin centrale se mette en oblique.
Achetez une fiche rca avec isolant PTFE téflon, c'est impératif.
Uwe K.
Phantastisch
Bestellvorgang und Lieferung ohne Probleme.Lediglich der Umkarton und die Freundlichkeit des DPD Mitarbeiters sind zu bemängeln,was aber nichts mit Audiophonics zu tun hat!Erster Eindruck ist großartig...solide Verarbeitung,problemlose Integration in mein Heimkino und eine Dynamik meiner Frontlautsprecher,die ich so noch nie gehört habe.Wie gesagt...erster Eindruck,aber voll umfänglich zufrieden!!!!
Aristotel Eduard G.
I buyed them for my Ramm Amadeus speaker cable . Good looking and top quality. I recommend these spades.
Aristotel Eduard G.
I buyed them to replace my Dali Zensor 7 factory binding post. By far these are in a different class. Good looking and top quality.
Baptiste R.
MOONDROP LAN Écouteurs Intra-Auriculaires IEM Dynamiques 10mm 120dB 32 Ohm 15Hz-37KHz Moondrop dévoile avec les LAN des écouteurs intra-auriculaires dynamiques ayant la particularité d'une coque compacte en acier inoxydable ainsi qu'un...
Sympa
Une valeur sûr !
Aigus un peu en avant mais pas trop. Semble super solide.
Seul petit point regrettable la boîte est super grande mais y'a que 3 paires d'ambouts.. Plus d'embouts et une boite moins tape à l'oeil ça aurait été pas mal.
Suis fan et ça m'énerve ...
Bien moins cher qu'une paire de de câbles de modulation de haute qualité si vous voulez un résultat immédiatement positif (à condition d'avoir une chaine résultante ou résolvante).
Je ne croyais pas à une amélioration sur des signaux de 1 et 0. Alors je ne me l'explique pas, mais c'est à l'encontre de ce que disent les experts en informatique (manque d'objectivité face au savoir ?).
Je fais confiance à mes zoreilles et j'oublie mes croyances.
Ce truc ... ça fonctionne. Les voix sont plus belles. Entre autre.
De toute façon, si vous n'entendez pas le gap, retournez le Ifi silencer à la boutique.
Comme à chaque fois, c'est en revenant à la situation d'avant que l'on sent si c'était mieux ou pas.
La marche descente est curieusement plus haute que la marche montante. Si le gain ne saute pas aux yeux, pardon, aux oreilles de façon flagrante, retirer le ifi dégrade le son.
Je recommande ce ti-truc miraculeux et anti-logique :
ça fonctionne (si votre chaine est à la hauteur).
Roman J.
Highly recommended AMP
I'm using a miniDSP flex RCA to drive the MPA-S250NC amp. Both devices in combination are superb. There is no noise or hum. Without an input signal, it's simply dead silent. Listening to music is really an enjoyment.
- The built quality and finish of the MPA-S250NC amp is perfect.
- The output signal measurements are well known and can be found on the ASR forum.
- The audio output of the amp is excellent.
Dirk d.
TOPPING G5 Amplificateur Casque NFCA DAC ES9068AS Portable Bluetooth aptX HD LDAC Argent Topping présente avec le G5 un amplificateur casque et DAC portable à la fois compact et performant. Celui-ci intègre notamment un puissant étage...
Audiophile... ?
Après plusieurs semaines d écoute, j ai un avis différent de tout ce que je lit sur les éloges du produit .
Super produit dans l ensemble.
Connection Bluetooth super.
Connection Usb super.
Les détailles , qualité de restitution , souffle, super .
Autonomie ,et sa charge constante , super
par contre....
un manque de vie, de dynamique , le son est clair, mais vide qu' il en devient fatigant .
Je suis quand même content de mon achat, pour les raisons décrit plus haut.
je m en sert juste lorsque je me déplace, car il fait son job .
Par contre a la maison, tranquille dans mon jardin , je passe a autre chose.
Je suis toujours a la recherche d un dac nomade, qui peu me surprendre.
Déçu.
Super !!
Jeu de clés made in Japan qui ne se tordent pas quand on serre.
Un jeu de grande qualité à petit prix, profitez-en.
Philippe S.
Séduisant.
J'ai choisis ce câble pour mon préampli en échange d'un furutech 31, c'est plus présent dans le médium, j'en ai acheté un deuxième pour le dac, la couleur du câble ressort trop, j'ai donc du furutech tc31 et 32 et un oyade.
Le deuxième vondida alimente maintenant la barrette pour le vidéo projecteur, l'image à fait un bon en avant, idem après un essai sur une télé oled panasonic.
Philippe S.
FURUTECH FI-48 NCF (AG) Connecteur IEC C15 Cuivre Plaqué Argent Traitement Alpha NCF Ø20mm Le Furutech FI-48 NCF (AG) fait partie de la gamme de connecteurs de la marque intégrant le matériau NCF et profitant, comme pour l'ensemble des produits Furutech,...
La qualité à un malheureusement un prix
Excellent connecteur, un peu plus de subtilité qu'une fi46, meilleur scène sonore, évidemment ce n'est pas le jour et la nuit mais sur un bon système on voit la différence. Associé à un câble furutech 55, je me régale.
Philippe S.
Un cran au dessus
Comme de nombreux clients, je me suis constitué quelques câbles furutech, j'en ai gardé 2, le 31 et le 32, les 31 pour mon préampli, l'alimentation de mon streamer et mon dac, c'est un câble que je trouve cohérent. Pour l'ampli et la barrette j'ai choisi le 32 un peu plus présent dans le grave mais un peu moins bon dans le haut médium. Le 55 est nettement plus long à rôder, les premières heures sont une catastrophe (c'est bouché, peu d'aigu, on peut vite regretter son achat) il faut l'accepter. Aujourd hui après une cinquantaine d'heures, le câble s'est ouvert, j'y retrouve les qualités du 32 avec un grave encore mieux défini et lhaut du spectre qui ressemble au 31.
P. S : il fonctionne avec une Schuko fi46 et une IEC Fi48 argent.
Jean-Marie L.
Bon rapport Q/P
Bon plan que ces fiches à # 1.50/ pièce, en alu au lieu de plastoc, fabrication esthétique et de bonne qualité. Le système utilisé pour la connexion s'apparente au goupilles élastiques fendues Mécanindus. Le contact est étroit, pas de risque de déconnexion accidentelle, et grand surface de contact sur toute la longueur de la "banane". Du tout bon !
Savvas P.
NEOTECH NEUB-3020 Câble USB-A Male/USB-B Male 2.0 OCC plaqué Or 24k 1.5m Le câble USB AUDIO class 2.0 Neotech NEUB-3020 offre une qualité de restitution numérique redoutable utilisant des technologies innovantes venant bousculer...
Bonne Fabrication
Très bon câble à prix raisonnable.
Savvas P.
Très bonne multiprise
Fabrication de qualité
Frederic B.
Module DAC pour Raspberry Pi PCM5122 I2S 32bit 384khz DSD128 Ce module DAC pour Raspberry se base sur l'utilisation d'une puce de conversion numérique / analogique PCM5122, lui permettant de supporter les flux PCM jusqu'à...
Bien, mais quelques détails à revoir :-(
Bonjour à toutes et à tous,
Après l'achat de cette carte je l'ai montée sur mon Raspberry pi4 qui tourne sous moOde AUdio (la dernière version de Volumio est trop buggée et rAudio, ex Rune Audio, est un projet qui semble désormais en mort cérébrtale avec quelques modifications mineures par-ci par par-là).
L'installation est super simple et, après avoir choisi le bon "driver" I2S pour cette carte comme indiquée, il fonctionne sans souci. Seul truc à savoir il faut appuyer sur le bouton pour sélectionner "I2S In" afin d'avoir du son direct depuis le pi4.
L'écran est vraiment sympa pour savoir si le pi4 joue bien ce qu'on lui demande de jouer dans le bon format. Il affiche manifestement correctement le taux d'achantillonnage (44.1, 48 ou 96khz) mais le mitrate est faux : il affiche 32bits au lieu de 24bit... Alors de là à croire qu'il upsample il n'y a qu'un pas. Or je voudrais avoir la certitude qu'il ne sort pas un message "faussé". Bug d'affichage ou vraie difficulté ?
Par ailleurs, si la sortie casque a l'air d'être suffisamment puissante, il faut l'utiliser avec des casques ULTRA gourmands... Pourquoi ? Parce que le régalge ne s'opère que sur 8 niveaux. Inutile de dire que du coup si le réglage "5" est un peu insuffisant, le réglage suivant "6" est vraiment fort... Un régalge sur une douzaine de niveaux n'aurait pas fait de mal si ?
En conséquence, je ne mets qaue 4 étoiles. Mais 4 étoiles quand même pour la simplicité d'utilisation, pour la qualité du son, pour la puissance de la sortie casque et pour le petit écran, qui reste quand même une petite aide...
Et quand je parle de qualité du son, franchement, je trouve que c'est vraiment vraiment BON. Même comparé à des propositions bien plus "puissantes" et dédiées à l'écoute au casque : c'est franchement pas mal pour mes oreilles. Peut-être que la puce 5122 fait des petites merveilles ou que simplement la différence me fait croire que c'est bon... Quoiqu'il en soit, je pense que le son qui sort de cette petite carte à 65€ peut rivaliser avec un combo DAC et Ampli casque jusqu'à 8 fois plus cher. Alors pourquoi se priver ?
Ballester M.
XDUOO MT-602 Amplificateur Casque à Tubes Class A 2x 6J1 Le xDuoo MT-602 est un amplificateur casque à la fois compact, performant et abordable. Il se base sur une architecture Class A, intégrant des transistors pour son...
UTILISATION PREAMPLI
BON PREAMPLI ENTRE UN DAC SMSL DO100 ET UN AMPLI AIYIMA A07 PRO AVEC AOP MUSES02 ET SPARKOS.
LE GAIN EN SORTIE EST ENORME PAR RAPPORT AU GAIN DU DAC J' AI MIS DU TUBE VOSHKOD DESSUS ET LES DETAIL ET LA DYNAMIQUE SONT AU RENDEZ VOUS.
J'AI FAIT DES TEST AVEC ET SANS CE PREAMPLI ET C'EST LE JOUR ET LA NUIT.
JE RECOMMANDE VIVEMENT CET APPAREIL !
Ferenc M.
KHOZMO ACOUSTIC Atténuateur de Volume à Relais Stéréo 64 Pas Commutation MBB Vishay 10K Khozmo propose avec ce produit un atténuateur de volume ladder à relais très haut de gamme aux performances audio incroyables. Celui-ci est basé sur...
Very good quality
This attenuator is very good! The clicking sound of the relay is smooth and more quiet than the other I have tried. The display is tricky to be applied to the front panel of a chassis but functional, clearly visible, adjustable brightness.
Pavol B.
DYNAVOX ANTIVIBE Pieds Absorbeurs Antivibratoires Ronds Caoutchouc Noir (Set x4) Ces pieds pour enceintes ou systèmes hifi en caoutchouc très simples d'utilisation absorberont efficacement les vibrations générés par votre système pour un son plus clair.
perfect isolation pads
Easy to use, good work, very soft and eat many small vibrations and etc. Recoomend it for any hifi device or speakers.
Pavol B.
Perfect full body cable, with 3D soundstage
I use this cable no for bi wiring, but i made him as single wiring in cross connection of wires. What i have to say - is magical, full body cable, with microdetails and 3D soundstage, no harsh or etc, deep bass, timre close to warm, for this price ...same as Mogami i guess, but cheaper. VERY recommend him. PS: is little bit stronger, but still OK
Pavol B.
good just little bit fat
Good strong fabric, just little bit fat, full. This fabric has deep layering, can keep dust to much, hard to clean, and i think also will dump high notes/microdetails... But for covering is OK.
Pavol B.
perfect splitters
Perfect splitters, even little bit expensive. I bout them for ELECAUDIO HP-25OCC cable. Fit perfect. Very nice....thanks...
VIBORG VB401S Fiches Banane Cuivre Pur Plaqué Argent Ø4mm (Set x4) Viborg propose avec ses VB-401 (S) des fiches bananes d'exception, grâce à une conception utilisant des matériaux particulièrement haut de gamme.
EXCELLENT
Possédant un ampli numérique audiophonics les borniers d'enceintes sont petits et pas pratiques . Ces fiches bananes sont de bonne longueurs et assurent un contact parfait . Associées à un cable viablue cuivre argent le mariage est idéal. Son propre et net avec du relief ; aucune coloration . A éradiqué la coquetterie dans le médium certainement dû à un problème de contact . Gaine thermo pour la finition du meilleur effet .
Marc J.
très bon rapport qualité prix
Oui l'écoute est bonne au vu de l'appareil et de son prix....mais il ne faut pas s'attendre à une qualité d'écoute bluffante non-plus. Les voix sont sombres, il subsiste un voile sur l'ensemble du spectre et les timbres sont très simplifiés. Il est difficile d'être objectif pour juger cet appareil de toute façon totalement hors catégories. Comment se plaindre d'un appareil combinant ampli et dac pour moins de 150 euros ? L'exploit est là, cet appareil fait fonctionner sans problème des enceintes à 88db de rendement avec une dynamique pas ridicule. Et c'est déjà très bien. Mais on est quand même très loin du rendu musical...
Juan C.
Fantastique!
Après plusieurs mois d’utilisation, je suis encore plus impressionné et heureux de posséder ce dac Gustard. Comme déjà mentionné dans d’autres commentaires, il nécessite plusieurs heures de rodage et gagne vraiment en profondeur et précision avec le temps. Les basses fréquences descendent alors vraiment bien. Après ce rodage, le son devient extrêmement précis, profond avec une scène large. Bref, je ne lui trouve aucun manque par rapport à un dac delta sigma, mais un gros avantage par rapport à ceux-ci: le son est NATUREL et sans dureté. Ce dac fait de la musique avant tout. Un véritable plaisir.
Topissime
Ce câble Mogami est une révélation.
Associé à des prises Rca plaquées or basiques il offre une scène musicale exceptionnelle avec une bonne gestion des basses.
Par contre j’ai supprimé la tresse des deux côtés et c’est mieux je trouve.
Je vais le monter avec des prises plus performante pour voire ?
Bref, essayez le, vous serez étonné
La magie des câbles..
Je suis débutant dans le domaine de la hifi, mais j' ai des oreilles qui sont aussi vieilles que moi...
Je viens de changer mon câble furutech fp 314 AG ( bon câble au demeurant) pour celui ci....
Je comptais changer mon ampli Yamaha pour un ampli a tube (je le ferais surement), mais ce t excellent câble m' a apporté ce qui me manquait, a savoir, de l' aération. Une plus grande scène sonore. Des détails insoupçonnés, et une douceur mais aussi de la force !
Je le recommande , bien qu'il doit exister des câbles encore meilleurs.
Edgar P.
Audiophonics HPA-S400ET
I must say that Audiohonics did it right compared to similar Purifi based amplifiers. It was worth the wait and I bought 2 of these! 2 American companies also make these but Audiophonics clearly made a higher quality amplifier. And I checked inside of both and took lots of pix. These also run very, very cool. compared to my tube amps. I will not compare these to my NAD M23 at more than twice the price. The NAD is not a fair comparison, NAD makes their own modules, also. This Audiophonics amp is serious competition to any amplifier if you are wanting an extremely transparent, clean amplifier. Audio Science Review was extremely impressed. They are notoriously tough reviewers/testers. But let your eyes and ears be the judge of course. I have several preamps to pair with these for now. But I suspect a preamp with XLR connections like my ancient Mcintosh MX130 or better may be needed to get the best out of these great amplifiers. Way to go Audiophonics!! Made in France!!!!!!!
Edgar P.
Outstanding music streamer
WOW! The DMP-A6 is a very impressive, flexible and high quality music streamer. It is paired with a Audiophonics HPA-S400ET Purifi amp and Vincent SA-31 preamp. Speakers for testing this setup are Sonus Faber Lumina V for now.
Anh J.
TONEWINNER AD-1PA+ Amplificateur de Puissance Class A Stéréo 2x300W 8 Ohm Argent Puissant amplificateur de puissance stéréo Class A, le Tonewinner AD-1PA+ profite d'une architecture symétrique de grande qualité lui permettant de...
Really a very rare winner; excellent in Class A.
There is a review on Remusic in Italian. Use google translate and you will read the same as i did before i purchased this device. Now i have it and have listened to it for a couple of days i can only say this is a Best Kept Secret Device. Very rare winner. In Class A it is perfect. When used in combination with real hifi devices it does nothing wrong. You sit front row, projection of music is real live experience. All in Class A. Strong and deep Bass. No glare in the high frequencies. Voices are real life voices. Great resolution and wonderfull transparancy. And all this voor 3.400 euro. Remusic compared it with Viola Symphony amplifier. 25.000 euro device beginning this century. I compare it with Coda 16.0, Mcintosh MC 1.25 KW and also a Audreal PA Class A amplifier. This Tonewinner doesn't blush with these competitors. My pre-amplifier is a Accuphase C 3900, AVM PA 8.3 or a Mcintosh C 1100. Loudspeakers BW 801 D4, Chario Academy Serendipity and several others. On all speakers it is doing very well. Really a rare winner. Use a ventilator to cool it down; in Class A it gets very hot. When using in auto configuration it changes very quickly in AB. You miss the Class A experience. Buy it. You will not regret it.
Dr. David M.
Well-designed, easy-to-use + powerful
I purchased one of these to drive a pair of Elac DBR62s fed by a Wiim Pro source connected to the amp via optical cable. The amp is minimalist; produces a clean, transparent sound; and is powerful enough to drive a pair of DBR62s very loud in a small- or medium-sized room without issues and with power to spare. It is well-designed; easy-to-use; rugged; doesn't take up a lot of space; and integrates neatly into my application. This is a high-quality piece of equipment made available at a fair price. It is solid enough that I didn't think twice about purchasing a 2nd unit for use with another application. Recommended.
marco g.
PRE-TC10review
I have used this excellent pre for a diy project where TC-10 drives Nr.2 DSP Tinisyne managing two full 2.1 systems. Perfect for a lot of DIY projects where an high quality preamplifier is needed. Thanks Audiophonics, always a reference.
Nicolas l.
Équilibre et performance
Ce câble est très équilibré et ne zoom pas le haut du spectre « ouf » Aucunes fatigue!
Il à même gommé une très légère acidité sur certains aigus qui était de trop dans la musique de qualité moyenne.
La force de ce câble est le médium qui est chaleureux et bien présent sur les voix.
je ne trouve pas une grande différence sur les graves profond .
Le changement globale de sonorité entre les câble secteur et très discuté mais oui il y a une équilibre différent à l’écoute mais Il faut une électronique derrière et des enceintes qui peuvent vous donner cette chance de le percevoir, est ce n’est pas à 20% de volume qu’il y aura une différence mais plutôt dans les écoutes assez soutenue ou les défauts et qualité sont mis en évidence d’un système.
Je conseil ce câble pour écoute neutre et agréable sans faire de fausse notes.
Philippe s.
Fiches Bananes d'Interconnexion Haut-Parleurs Cuivre Plaqué Or (Set x4) Ces fiches bananes d'interconnexion sont idéales pour permettre une connexion / déconnexion rapide d'une paire d'enceintes ou haut-parleurs ou encore pour...
Bonne idée et bonne qualité mais il ne faudra pas les démonter trop souvent car les vis ne sont pas terribles.
Attention : je pensais que le plastique transparent pouvait être facilement coupé (comme les sucres d’électricien) mais il n’en est rien. Si vous voulez 2 paires séparées il faudra les découper avec une Dremel.
Philippe s.
EVERSOLO DAC-Z6 DAC 2x ES9068AS XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA Le DAC-Z6 de EverSolo est un DAC performant basé sur une structure technique soignée. Il embarque des composants haut de gamme avec notamment deux puces de...
Packaging exceptionnel tant au niveau esthétique que fonctionnel. Appareil de très bonne facture livré avec un bon câble secteur ainsi qu’un câble USB de qualité. La télécommande en plastique dénote un peu mais comme on bénéficie d’une application smartphone bien pratique, on ne l’utilise pas. Le panel de connections est particulièrement complet. La qualité sonore me paraît au rendez-vous avec une scène sonore assez étendue.
