Vincent B.
Bof
Shigeo I.
Couldn't be more satisfied
A flawless power amplifier. The extension of the sound and the precision of left-right imaging are excellent—especially in solo...
Shigeo I.
outstanding cost-performance!
Purchased together with the Audiophonics LPA-S450ET. Since the power amplifier has a balanced architecture, when used with...
Avis clients - Il y a 19131 avis.
Zoltán K.
AUDIOPHONICS MPC5 STEALTH Distributeur Secteur 5 Ports Aluminium Noir Le distributeur secteur Audiophonics MPC5 Stealth met à disposition 5 prises secteurs Schuko. Celui-ci est assemblé à la main, en France, et intègre...
Excellent product
This is a high quality, good looking, well made power distributor that is well priced at around 160 EUR. It does not include an RF filter, which is the main reason why I chose this unit. The input and output connectors are of excellent quality, they provide a connection that is firm, neither loose nor too tight. One does not need to use excessive force to connect or disconnect high quality power cords. The four feet ensure stable positioning. In my Hifi system this unit supplies power only to a NAS, a switch and a media converter. Still, in comparison with an entry level HiFi power distributor equipped with RF noise filtering, to my ears the use of this unit provided a more alive and lively musical performance, through better spatial perception, better resolved details, better transients and dynamics. This unit is clearly well suited for use in HiFi applications.
Julien D.
Matériaux de qualité, Très Satisfaisant !
Ne sachant pas encore qu'il existait des versions améliorées VORTEX HIFI (informées énergétiquement) j'ai commandé ces versions standard d'excellente qualité, la matière est très souple mais ferme, se logeant ainsi de manière optimum dans les prises jack 6.35mm inutilisées de vos appareils et accessoires HIFI. Dans mon cas un lecteur MINIDISC SONY et des rallonges de casque de plusieurs métres faites en câble "GEB" de chez HIFI & Cie avec prises NEUTRIK et FURUTEC achetées ici chez AUDIOPHONICS.
Les prises de casque que je traite aux nettoyants Deoxit (vendus ici également) et à l'huile VORTEX HIFI NANO DIAMANT SIGMA sont ainsi protégées de la poussière et de l'oxydation quant inutilisées. Egalement très satisfaisant pour les maniaques comme moi qui prennent grand soin de leurs appareils ! :)
Julien D.
Nickel pour remplacement sur câble secteur ACTINOTE ARIA
En ayant voulu démonter le connecteur IEC d'origine de mon câble secteur ACTINOTE ARIA ancienne génération (avant le EVO avec prise schuko en bois), j'ai détérioré les visses plastique ; ça ne m'a pas trop dérangé car je comptait faire prisonnier le câble dans un lecteur MINIDISC SONY.
Cependant, après découverte de l'aspect et de la rigidité des conducteurs du câble ACTINOTE, j'ai abandonné et décidé de réhabiliter le câble secteur à ses fonctions premières.
Mon choix s'est donc porté sur cette version ELECAUDIO, identique aux fiches qu'utilisait Actinote avant de passer en 2023 à la marque Oyaide.
Son assemblage est bien conçu, attention tout de même à bien insérer les visses finales dans leur filetage, car une fois je suis passé à coté.
Il a fallu également abandonner une pièce plastique permettant de serrer le câble à l'entrée de la fiche, car une bague caoutchouc, propre à actinote et permettant le serrage de la gaine tissu avant la section, augmentait le diamètre total du câble.
Après quelques tests d'écoute, Le rendu sonore m'est apparu préservé par rapport à la version d'origine, l'aspect du câble parait plus robuste et moderne. On saluera tout de même les très bons conducteurs de l'ancienne fiche IEC Actinote (plaqués argent à l'époque) dans lesquels les conducteurs cuivre (phase/terre/neutre) étaient soudés à l'argent.
Au final, je recommande fortement ce connecteur IEC ELECAUDIO au rapport qualité prix exceptionnel ; pas étonnant qu'Actinote les avait choisis précédemment, avec un cahier des charges spécifique bien entendu (visses non métalliques, stickers et traitement/placage or des connecteurs peut être supérieur).
Leonas J.
XDUOO TA-22 Amplificateur Casque à Tubes 2x 12AU7 DAC 2x ES9038Q2M Bluetooth 5.0 aptX HD LDAC 32bit 384kHz DSD256 MQA xDuoo dévoile avec son TA-22 un beau combo amplificateur casque et DAC à la conception soignée. . Celui-ci embarque des composants de qualité afin de...
perfect xduoo ta-22
neutral sound with very good stock tubes, rolled nos RFT 12au7 from 1960 east germany made. more relaxed sound with more extended highs.
Bernard B.
AIYIMA T9 PRO Amplificateur TPA3250 Tubes 2x JAN5725 ES9018K2M Bluetooth aptX HD 2x60W 4 Ohm Le Aiyima T9 Pro est un amplificateur intégré polyvalent et abordable, idéal pour monter un système audio sans se ruiner et sans multiplier le nombre...
Du plaisir
le velouté des lampes au prix chinois...FDA chef d'orchestre, une discothèque toute numérisée sur PC, avec une baguette libre nommée foobar améliorée par une courbe cible du génial Pétoin drivant de petits large bande en caissons bass reflex triple ( en DIY merci Pétoin !!!!) et me voilà auditeur d'un chaîne HI-FI cheap mais très agréable.....je recommande fortement même si une sortie casque serait la bienvenue...
C b.
parfait pour mon lecteur oppo.
parfait pour mon lecteur oppo maintenant piloté par mon ampli home cinéma.De plus il ne reste plus en veille quand je ne l'utilise pas. Je retire 1 étoile car léger flottement quand il est connecté dans la prise iec 13 de mon lecteur.J' ai corrigé avec quelques tours de ruban adhésif autour de la prise de ce boitier.
C b.
pilote mon lecteur oppo relié à l'ampli home cinéma
parfait pour mon installation.
Mon lecteur oppo est maintenant piloté par mon ampli home cinéma via 1 prise triigger et ne este plus constamment en veille quand je ne l'utilise pas.Néanmoins je retire 1 étoile car l
C b.
pilote parfaitement ma freebox revolution avec une télécommande logitech harmony one
Fais le job parfaitement avec ma télécommande logitech harmony one de plus de 10 ans.
vous mettez la clé usb en façade sur la freebox player-pour la télécommande HARMONY ONE dans le logiciel harmony vous chargez Alice L-H D03A et non pas freebox revolution et c'est parti...
Bruno F.
Eclairage sur un Marantz
Très bon rendu sur un éclairage de Marantz 4300, après essai l'idéal est de les incliner vers l'arrière on obtient un meilleur résultat comme à l'origine, incliner côté vitre le rendu est trop fort style bleu piscine !
Pierre M.
ISOACOUSTICS GAIA III Absorbeurs de Vibrations 32kg Ø43x39mm (Set x4) Les absorbeurs de vibrations IsoAcoustics Gaia III améliorent la clarté et l'ouverture sonore pour les enceintes ou subwoofer pesant 32kg ou moins. Ceux-ci sont...
Incroyable
J'avais des soucis de "creux de basse" dans ma pièce impossible à régler, l'écoute était tres localisée. Selon l'endroit de l'écoute cela sonnait très différemment.
Les pieds ont permis dhomogeiniser la diffusion, l'écoute est agréable en tout point d'écoute. Utilisé sur un svs sb1000pro et enceintes paradigm founder80F
Pierre M.
LUDIC KRATOS Distributeur Secteur Filtré 6 Prises Filtrées + 2 Prises Directes Schuko Noir Le Ludic Kratos est un distributeur secteur avec section filtrée extrêmement performant, capable de soutenir la comparaison avec les produits les plus haut de...
Bel objet
Je ne saurais pas dire si le filtrage est efficace, je n'ai pas l'équipement et les connaissances précises en la matière pour le faire.
Mais la fabrication est de qualité. Et l'écran, et c'est rare pour ce genre d'objet, ne fait pas kitch. C'est sérieux et classe.
Pierre M.
KLEI PURE22 HARMONY Connecteurs RCA Mâles Cuivre Plaqué Argent Ø9.5mm (Set x4) Ces connecteurs RCA KLEI Pure22 Harmony représentent le modèle le plus abouti de la marque. Une modélisation mathématique exclusive est...
Une merveille
Une merveille à souder, les soudures argent se déposent sur les pâtes à merveille. On dirait qu du flux est déjà présent c'est bluffant. Plastique TRES résistant à la chaleur du fer.
Particulièrement adapté pour un cablage en masse flottante avec un câble symétrique (alpha S22 de chez furutech).
Les deux pâtes à souder se présentant de part et d'autre au même endroit.
Sonne merveilleusement bien, il a énormément aéré mon écoute.
Pierre M.
Bel effet
Met très bien en valeur un casque sur un meuble.
Très ergonomique. Mes casques Meze y logent très bien.
Olivier L.
VISHAY DALE Potentiomètre Commuté Stéréo Shunt 23 Positions Axe Cranté Logarithmique Ø6mm 10K Ohm Ce type de potentiomètre à commutation shunt est idéal pour la conception de préamplificateurs portatifs transparents et dynamiques. Cette...
Très bien mais
Au niveau de la qualité au niveau du son, extra .
La différence est époustouflante. Le mais, très très dur a manoeuvrer, peut de chance que dans le temps il ce rode. Mais très content de l'achat.
Renaud D.
SHANLING M6 ULTRA Baladeur Numérique DAP 4x AK4493SEQ Bluetooth 5.0 aptX HD LDAC WiFi 32bit 768kHz DSD512 MQA Noir La nouvelle version tant attendue du baladeur Shanling M6, le M6 Ultra, est enfin là, apportant non seulement une plateforme Android modernisée, mais marquant...
Excellent DAP
Très beau produit fluide et d'une qualité sonore exceptionnelle.
Je sens un gap notable avec mon M6 Pro (21)
Un délice, je redécouvre mes albums.
Merci Audiophonics pour la livraison rapide!
IBAN M.
GUSTARD DAC-R26 DAC R2R Discret I2S Bluetooth LAN AirPlay Roon DLNA 32bit 768kHz DSD512 MQA Argent Gustard dévoile avec son DAC-R26 un convertisseur numérique / analogique absolument exceptionnel. Celui-ci utilise une architecture R2R utilisant des composants...
Superlative!
Superlative sound. Forget about measurements.
Just wonderful sound.
Superb soundstage.
Regardless the price tag, a very-very high quality DAC.
Vivien V.
oulala puissant et polyvalent !
bon choix pour un intégré. 30,8 V sur un des secondaires pour 31v annoncé (parfait). Je valide à 200%. Petit bourdonnement quand il est sous tension mais inaudible des qu on sort la tête de l ampli. :-)
Vivien V.
bon rapport qualité prix
Vivien V.
Vivien V.
IFI AUDIO IPOWER MK2 Adaptateur Secteur / Alimentation Audio Faible Bruit 12V 1.8A L'adaptateur secteur iFi Audio iPower MK2 permet de fournir à vos appareils audio un signal électrique extrêmement propre et stable. Cette nouvelle version...
Efficace comme tous les produits iFi
Depuis longtemps je filtre tous mes appareils avec les divers filtres iFi, et donc c'est sans surprise que je l'ai installé sur mon récent NUC Fanless qui accueille QOBUZ et AUDIRVANA.
La différence est audible de suite...tous est plus propre, aéré, chirurgical.
Comme je dis à mes amis:
Vous mangeriez des spaghetti cuits dans de l'eau boueuse ?
La matière première de tout système audio, c'est le courant électrique....et il arrive à la maison pollué..donc on nettoie !!
AUDIO-GD R-27HE DAC R2R Amplificateur Casque Préamplificateur Symétriques Class A 32bit 384kHz DSD512 Argent Nouvelle création de la part d'Audio-GD, le R-27HE se présente comme un Ladder DAC R2R symétrique, avec amplificateur casque et préamplificateur ACSS...
Excellent !!! Magnifique appareil, et qui sonne vraiment bien.
J'ai acheté le R27HE pour remplacer un Auralic Véga G2.1 que je trouvais un peu trop simpliste dans son rendu. Un certain manque de présence. D'humanité.
Pour avoir déjà eu dans le passé un R28, je savais déjà un peu à quoi m'attendre.
Pour planter le décor, j'utilise un Roon Core directement raccordé en USB au R27HE qui est en mode NOS et sorties fixes XLR (2VRMS) qui alimente un NAGRA Classic INT. Ce dernier se chargeant de la partie Pré/ Ampli.
Alors quand j'ai reçu le colis en UPS express le mardi pour une commande prise en compte le lundi, j'ai été surpris par la taille du carton.
Puis par le deuxième carton, puis par le troisième carton.
Chez Audiophonics, on ne plaisante pas avec la marchandise.
Quand j'ai ouvert le dernier carton et que j'ai vu la bête, la première chose que je me suis dit, c'est "je ne voyais pas ce DAC aussi grand, j'aurais du lire le descriptif avant. Les 48 cm de profondeur ne trouveront pas place dans n'importe quel meuble.
Après quelques manipulation dans les menus qui ne sont pas du plus intuitif, mais bon, ça n'a jamais été le fort d'Audio GD, et franchement, une fois les réglages choisis, plus besoin d'y aller, hors mis pour passer de la Fonction DAC à la fonction ampli casque.
Après une mise en chauffe d'une demi heure le temps de tout bien lire du mode d'emploie (traduction de la page d'AGD) je vous livre enfin mon ressenti.
Je ne regrette pas mon choix d'avoir vendu mon Véga G2.1.
Attaquer directement le DAC en USB avec un Roon Core, ça marche parfaitement et pas besoin d'un Endpoint .
Tout y est. Scène sonore, profondeur, largeur et hauteur.
Une belle matière sur tous les instruments. Ca swing, on tape du pied et avec le sourire SVP.
Tout passe ou presque. Les prises de son pourries restent pourries, mais ça c'est normal.
Pour l'instant, seulement le rodage d'usine effectué chez AGD, mais ci c'est encore meilleur dans 300 heures , alors je n'ai pas finis de taper du pieds et de sourire.
Merci à David Aubert pour ses réponses et sa réactivité.
Sans hésitation, 5 étoiles pour Audiophonics et Audio GD.
Paulus v.
IAN CANADA FIFOPI Q7 Module Reclocker FIFO Synchrone 32bit 768kHz DSD1024 DoP Le FifoPi Q7 de Ian Canada est le nouveau flagship de la gamme de reclocker de la marque. Le module parvient à fournir un ultra faible niveau de jitter et de bruit...
IAN CANADA FIFOPI Q7 upgrade
I came from the ALLO Kali to this gem so a few FIFO generations have past.
Great open 3D soundstage with depth and transparency in a very dark background.
Does need some hours before opening up and start playing as it should!
Very happy user, no problems with setting up and connecting.
Big thumbs up
eric m.
Module Softstart de Commande et Temporisation pour Amplificateur Cette carte permet de commander l'allumage d'un amplificateur. Elle assure la fonction stand-by, soft-start, temporisation et protection thermique. Elle limite aussi...
Parfait pour un ampli de forte puissance
Ce module est parfait, et fonctionne très bien sûr mon amplificateur de puissance équipé de 2 transfos de 500VA.
eric m.
Raccord pour Axe de Potentiomètre flexible Ce raccord pour axe de potentiomètre accepte des axes d'un diamètre de 6mm maximum. Le montage se fait simplement à l'aide de vis hexagonales de 1.5mm.
Très efficace
J'avais dans un premier temps utilisé des accesoires en laiton sans vraiment de succès d'alignement de rotation sur le potentiomètre. Ce modèle ma permis de réaliser un accouplement parfait. Je recommande ce produit de très bonne qualité.
eric m.
ELECTRO HARMONIX 7025EH Tube de Préamplification Faible Bruit 12AX7 / ECC83 (Unité) Electro Harmonix propose avec le 7025EH une version faible bruit et microphonie du tube de préamplification 12AX7. Il s'avérera particulièrement efficace au...
Adorable....
Dans la famille des 12ax7...ces doubles triodes sont parmis les meilleures que j'aurais connu... Très bon équilibre, beaucoup de détails avec mon Préamp. Phono Marantz 7C, et le tout... Sans un bruit.... !!! Je recommande vivement.
eric m.
GENALEX GOLD LION KT77 Tubes Platinum (Paire Appairée) Ces tubes Genalex Gold Lion KT77 permettent une reproduction sonore fidèle. Chaque tube est doté d'un verre épais et de plaques robustes pour une grande...
Déception
C'était mais mes premiers Tubes Gold Lion Genalex de puissance.... Après avoir signalé un problème de bruit des le départ... Je les ai mis depuis de côté, car un des tube à carement lâché... Conclusion, je n'acheterai plus de Genalex de puissance.... Pas fiable du tout... Un peu comme leur KT88 qui ont connu une mauvaise période...
Julien D.
le KIT de nettoyage Hifi I-DE-AL !
Après avoir galéré des années avec des accessoires bricolés et inadaptés,, j'ai enfin trouvé le kit et les produits idéaux pour nettoyer et entretenir les connecteurs de ma chaîne hifi !
Les aérosols sont fournis avec une tige de précision (attention à ne pas trop forcer pour les insérer dans la buse) et en plus, je n'avais jamais vu cela : 3 positions pour régler le débit du jet !
Les goupillons et autres tiges (4 sortes) sont impeccables et s'insèrent dans toutes les prises et fiches avec une facilité déconcertante comme les RCA notamment ; attention cependant aux accrocs sur certaines parties métalliques, les mousses frottent bien mais sont fragiles…
Le DEOXIT rouge nettoie parfaitement les oxydations, quant au Gold c'est la finition pour traiter et optimiser le signal.
Le produit vert "Fader" en tube, est fait pour les contacts à glissement ou rotation (potards, volumes, sélecteurs de source)
A l'heure ou j'écris, je n'ai pas encore écouté le rendu, mais j'avais auparavant de bons résultats avec l'huile Cardas.
En bref : le kit indispensable à tout Audiophile averti ! Je recomande fortement !
Merci qui ?.. Merci Audiophonics !
Hideaki E.
good
I got good tweeters ,fast delivery and in good price. thank you.
I'm trying to find close-over with my speaker now.
Guy L.
Petit DT-25N mais puissant
Et bien que dire sur cet excellent tweeter, très bien fini.
Il file haut, possède une bonne sensibilité, aigus très clairs.
Peut être filtré très haut à 6dB/octave,vers 7KHz.
Peut nécessiter une légère atténuation. Par exemple 2.7uF+3.3 ohms.
Seul petit reproche qui peut être corrigé : dôme non protégé, mettre une grille ou un tissus devant, sinon gare aux idiots qui mettrons immanquablement les doigts sur le dôme.
Kjetil P.
SMSL D1SE2 DAC ES9039MSPRO Symétrique CPLD Altera XMOS XU316 32bit 768kHz DSD512 MQA Le D1se2 de SMSL représente l'évolution directe du performant DAC D1se dans une version mise à jour notamment avec une puce de conversion numérique /...
Excellent!
This is one fantastic dac! Compared to Smsl D300 this D1se2 is more detailed and sound more technical without getting harsh. And this is right out of the box! Its smooth and will probably get better with a little more time! Big soundstage and very good control off the lowest frequency! Was a little worried it would be to bright for me, but thats not an issue. Good layering within soundstage, not flat like Topping d90se.. Its a keeper! Using this with Audiolab 6000a and Wharfedale evo 4.2. This is my first purchase from Audiophonics. No problems, very fast shipping to Norway!!
Vivien V.
Module Amplificateur Stéréo UPC2581 IRFP9240 Class AB 2x 125W 4 Ohm Ce module d'amplification Class AB permet de développer une puissance conséquente de 2x 125W dans un form factor compact. Il se base sur l'utilisation de...
Propre !
C est pas mal généreux en puissance, une précision redoutable dans les basses fréquences c est moins bien sur les médiums aigus mais ça fait le taf. Ça chauffe peu, même à volume fort. Pour le prix c est parfait. Alimenté avec un bon transfo et un pré ampli correct il y a de quoi faire de la musique
Denis B.
Le FDA gagne en naturel
Je possédais jusque-là, en plus de plusieurs amplificateurs à tube et à transistors, trois autres amplificateurs Full Digital (FDA) : un I.AM.D V200, un FX-Audio D802C et un SMSL A18. Je m’en sers sur plusieurs installations, mais en particulier sur des grosses enceintes GKF SVP 505 (haut rendement, aigu/medium à compression et pavillon, grave 38 cm). Je trouvais le D802 un peu agressif, même si spectaculaire pour son prix. Le A18 était plus musical, mais manquait de précision en comparaison. J’étais surtout content du compromis du V200, très « moniteur » sans être trop dur, plus tenu dans les basses que le D802, et un tout petit peu plus transparent dans les aigus (même si c’était très proche). Mais la bonne réputation du D2160 m’a donné envie de voir si je pouvais obtenir encore mieux d’un Full Digital Amplifier sur mon installation.
Avant de parler du D2160, rappelons que la force des FDA, c’est d’être de sortes de DAC de puissance, et donc de coller très précisément au signal numérique d’entrée. Cet avantage est un vrai défaut quand l’enregistrement écouté est médiocre, rien ne le sauve, on entend tout ce qui ne va pas alors qu’avec des amplis plus traditionnels, en particulier à lampe, l’écoute est adoucie par la coloration analogique (le même genre de phénomène qui fait que beaucoup de gens préfèrent aujourd’hui l’ambiance feu de bois des disques vinyle à la rectitude du CD). Bref, le FDA, c’est neutre et transparent et donc intraitable avec les mauvais enregistrements mais incroyablement précis avec les meilleurs. On a en fait même souvent l’impression que c’est trop précis jusqu’à perdre en naturel.
Et bien le D2160 MKII est bien un FDA pour ce qui est de la précision, surtout en mode Hi-fi (touche Direct) associé au mode High Gain (deux secondes sur la touche Direct). Mais, par rapport à mes autres FDA, dès les premières écoutes, le D2160 franchit un vrai cap dans le naturel des timbres. La musique coule toute seule, avec cette musicalité qui fait que j’écoutais certains titres plutôt sur mon vieil ampli à lampe (mais au prix d’une perte de netteté et de précision, malgré un excellent DAC). J’ai retrouvé ce sentiment de naturel avec le D2160 sur tous les enregistrements de musique que j’ai testé aujourd’hui : baroque et classique (voix, orchestre, orgue), jazz, titres très variés de pop et de rock, et même sur de la grosse musique qui tape. Car pour taper, le D2160 tape. Quelle solidité dans les basses ! Les HP 38cm de mes enceintes sont tenus avec une fermeté que je n’avais jamais expérimentée, même en classe A.
Je vais multiplier les écoutes comparatives, mais je suis déjà quasiment sûr que le D2160 va devenir le nouvel amplificateur principal de mon installation. À ce prix, on ne peut que le recommander aux amateurs de transparence et de précision.
PS : Arrivé avec une panne d'écran, l'amplificateur a été remplacé sans frais et rapidement par Audiophonics. Merci !
mathieu s.
BLANKO BS-102 Haut-Parleur Vibreur Exciter 50W 4 Ohm 25Hz - 55Hz Ø13cm Le Blanko BS-102 est un haut-parleur vibreur (exciter) ultra plat avec châssis renforcé et pouvant être intégré dans de nombreuses...
Très puissant et fiable
J'ai eu l'occasion d'en avoir 2 autres qui était moins performants et qui saturait vite, celui avec le même ampli à beaucoup de profondeur il fait même aussi un peu de basse pas uniquement de la vibration ce qui les rends autonomes pour la nuit et vos voisins. Je vous conseille d'acheter un caisson d'ocaz de retirer le sub et le connecter au vibracoustic fixé sous votre canapé vous allez voir vos films différemment !
MARCEL D.
Excellent câble pour enceintes acoustiques ,tres bon équilibre tonal ,pas d'agessivité , écoute agréable . Ce câble peut-être inclus dans toute chaîne HIFI ainsi que le haut de gamme et pour le tarif il serait dommage d'en faire abstraction.
Volodymyr S.
TOPPING HS02 Isolateur Audio USB 32bit 768kHz DSD512 Le Topping HS02 est un isolateur USB haute performance et offrant une compatibilité maximale permettant de profiter d'un signal plus propre sur de nombreux appareils. Son...
Great product. Checked with Topping dm7 and RME Babyface, significant improvement of sq in both cases.
Sopel L.
DAYTON AUDIO SPA100-D Amplificateur Class D pour Subwoofer 100W 20Hz-200Hz L'amplificateur pour subwoofer à haut rendement Dayton Audio SPA100-D regroupe des fonctions normalement disponibles sur de gros amplificateurs dans un châssis...
Super ampli adapté sur mon ancien SUB ESPACE TRIANGLE 2 voies
Efficace, sans souffle, pas de bruit de coupure,
Je recommande ce produit.
Marc M.
Je viens de faire l acquisition d une paire d enceintes colonnes de marque monitor audio que j ai associé à un roksan k3.
J avais auparavant un cable hp qui me convenait parfaitement sur mon ancien système mais qui m a beaucoup moins convaincu avec ma nouvelle paire de colonnes. J ai parcouru les sites spécialisés et les forums de passionnés pour trouver ce que je recherchais avec ce cable Elecaudio. Je le recommande a qui souhaite avoir un son réaliste, neutre, avec bcp d espace entre les instruments et les voix, une multitude de détails qui occupe une scène large et profonde à la fois. La douceur souligne la signature presque transparente de ce cable hp.
Un rapport qualité prix musicalité excellent
Lukas v.
SHANLING EC3 Lecteur CD ES9219C Bluetooth 5.0 LDAC 32bit 384kHz DSD256 Noir Le Shanling EC3 est un lecteur CD qui se distingue au premier coup d'oeil de par son format compact avec des mensurations de seulement 188mm de largeur pour 255mm et de...
Big recommendation
First of all, I would like to thank Audiophonics for the quick delivery.
This Shanling CD player is a real beauty and sounds better than the CD players I have had before.
lars s.
Superb sound
Superb sound quality
Leonas J.
TUNG-SOL 12AU7 / ECC82 Tubes (Unité) Le Tung-Sol 12AU7, fabriqué en Russie, assure un très faible bruit. Il a été conçu pour imiter les performances des tubes américains...
leonasj
very musical tubes,separate instrumens,3D sound ,low noise,nice vocals,linear gain. way far better vs im tried TAD,telefunken,rft tubes. immediatly loved them after change my xduoo ta-22 stock tubes( also very good linear sound,but tungsol goes further)
Clive S.
The whole order/delivery process went perfectly.
My first reaction on listening was something was wrong with my foot, then I realised that I was tapping my foot to the music, something that I hadn't done for a while!
I'm still running the DAC in but so far I'm very surprised and very impressed. More later
Clive
Roland v.
LITTLE DOT MKIII Amplificateur Casque / Préamplificateur à Tubes Le Little Dot MKIII est un très bel amplificateur casque à tubes, offrant d'excellentes performances audio. Il est surmonté de deux tubes GE5654 (United...
Excellent!
I bought this pre amp after reading a lot of positive reviews on the internet. I use it only for headphones (AKG 500, Beyer Dynamic DT 770 Pro and Sennheiser HD600). The amp was delivered as expected en well packed. The look and finish is beautifull, construction very solid and the potmeter feels very good and even on all volume setting. The sound is very good paired with the HD600! A touch of tube warmth and detailled sound with good space. I've orderd som Vosnek tubes to try. I also try it with HD 605 wich I expect soon. The unit is stille burning in (3 days now) but very happy so far. For this price very very good! If you have a HD 600 or Beyer DT 770 pro it is a serious upgrade compared to a standard headphone connection. Highly recommended!
Peter B.
Excellent quality
I had to wait for quite some time to get this modules but they are worth waiting. The modules are (compared to a lot of other TPA3255 modules) of excellent quality. A large milled heat sink with tapped holes to fix the modules in an enclosure, high quality parts, precisely aligned (SMD)components, and larger/heavier components fixed with an elastic adhesive. I haven't tested them yet but I am quite confident that they sound as good as they look.
jean luc L.
MUNDORF MRESIST SUPREME MRES20-2.7 Résistance 20W 2.7 Ohm La gamme de résistance Mundorf MResist SUPREME propose des produits d'une qualité exceptionnelle. Avec un réel impact sur la restitution sonore, des...
MUNDORF MRESIST SUPRÊME
Sa fourmillent de détailles !! super
Jean-Marie B.
Qualité et subtilité du son
J'ai acheté un 2 em pour mettre entre la platine CD et l'ampli HG MARANZ pm8006 ..une seulle critique et un défaut a signaler au fabricant ''les slots dans lesquels rentre les tubes sont de mauvaises factures car les lampes fournient 6k4 pour les rentrer c'est du délire de fou
gilbert d.
Pour une enceinte centrale
gilbert d.
JANTZEN AUDIO ELECAP Condensateur Électrolytique 100V 5.6µF 5% Les condensateurs électrolytiques Jantzen Audio EleCap sont des condensateurs aluminium non-polarisés utilisant une feuille gravée ou "brute". Avec une...
gilbert d.
JANTZEN AUDIO CROSS-CAP Condensateur 400V 10µF Les condensateurs Jantzen Audio Cross Cap MKP 400V sont considérés comme étant le meilleur rapport qualité/prix pour la conception de filtres passifs...
gilbert d.
DAYTON AUDIO RS125-4 Reference Haut-Parleur Bas Médium 30W 4 Ohm 90dB 65Hz - 5400Hz Ø13cm En combinant un moteur sophistiqué doté en interne de 2 raccourcis électriques distincts, et un cône en aluminium ultra rigide, les transducteurs de...
Pour une enceinte centrale diy
