Tolerance (%)
2 % - 10 %
Capacitor capacitance
Capacitor format
Capacitor type
Rated voltage (V)
Jantzen Capacitors
Michael L.
High value for you're money
Very harmonic amp, tone controls adjusted since 12 o'clock might not be 100% neutral, i feel i don't miss anything...
THIERRY D.
affichage defectueux
Depuis quelques mois, l'affichage en Db a perdu 2 segments sur le zero et le trois.
bernard g.
Jantzen Capacitors
  • Silver Z-Cap Capacitors
  • Superior Z-Cap Capacitors
  • Cross-Cap Capacitors
  • Condensateurs Electrolytic Cap
  • Condensateurs
    Condensateurs
  •  STANDARD Z-CAP Capacitors
    The Standard-Z Series offers affordable, great value-for-money audio capacitors with fast reactivity, detailed sound and a smooth signal compared to its single polypropylene sheet competitors.
  • EleCap Capacitor
    EleCap Capacitor
    Find our range of Jantzen Audio Elecap capacitors, non-polarized aluminum electrolytic capacitors using etched or "raw" foil and offering a tolerance of 5%.
  • Condensateurs MKT Z-Cap
    The MKT Z-Cap capacitors from Jantzen Audio are made of a high-quality metallized polyester film. They offer a longer life and better sound properties than electrolytic capacitors. When it is not possible to use metallized PP-foil capacitors as an alternative to electrolytic capacitors for high value positions on crossovers due to their size, MKT-Z's are an excellent alternative.
  • Compact MKT Capacitors
    Jantzen Audio Compact MKT capacitors use high-quality metallized polyester film. They have been designed to take advantage of a compact format while ensuring excellent performance.
  • Ref : 6594
    In Stock
    Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every detail of the signal, while maintaining unparalleled naturalness and realism.
    18,90 € 15,75 €Ex.
    In Stock
  • Ref : 6595
    In Stock
    21,90 € 18,25 €Ex.
    In Stock
  • Ref : 6596
    In Stock
    22,90 € 19,08 €Ex.
    In Stock
  • Ref : 6597
    In Stock
    27,90 € 23,25 €Ex.
    In Stock
  • Ref : 6598
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 6599
    In Stock
    35,90 € 29,92 €Ex.
    In Stock
