Câble de modulation fin et souple. Très bon rapport qualité/prix
Cet avis a été posté pour MOGAMI W2330 Câble de modulation Asymétrique 0.08mm² Ø3mm Nouveau client ?
Le câble MOGAMI 2330 est conçu pour être résistant et souple à la fois.
Ainsi, il est particulièrement adapté à la scène et au studio.
Configuration | ||||
Part No. | W2330 | W2333 | W2368 | |
No. of Conductor | 1 | |||
Conductor | Details | 16/0.08 A <T1000D*1> | ||
Size(mm²) | 0.08mm² (#28 AWG) | |||
Insulation | Ov. Dia.(mm) | 1.5Ø (0.059") | 1.0Ø (0.039") | |
Material | LNXLPE (Low Noise Cross - Linked polyethylene) | PVC | ||
Colors | Clear | White | ||
Served Shield | Approx. 36/0.12A | Approx. 38/6/0.08A | ||
Jacket | Ov. Dia.(mm) | 3.0Ø (0.118") | 4.0Ø (0.157") | 2.0Ø (0.079") |
Material | Flexible PVC | |||
Color | Black | |||
Roll Sizes | 100m (328Ft) 200m (656Ft) | 200m (656Ft) (standard) | 100m (328Ft) 200m (656Ft) | |
Weight per 200m Roll | 2.5kg | 4.2kg | 1.5kg |
DC Resistance at 20°C | Inner Cond. | 0.23Ω/m(0.070Ω/Ft) | ||
Shield | 0.05Ω/m(0.015Ω/Ft) | 0.10Ω/m(0.031Ω/Ft) | ||
Capacitance at 1kHz, 20°C (Partial C. Value) See below figure* | K0 | 115pF/m(35pF/Ft) | 350pF/m(107pF/Ft) | |
Inductance between conductors at 1kHz. 20°C | 0.3µH/m(0.092µH/Ft) | |||
Electrostatic Noise** | 50mV Max. | |||
Electromagnetic Noise** | 0.05mV Max. | 0.05mV Max. | ||
Microphonics at 50KΩ Load** | 300mV Max. | 1mV Max. | ||
Voltage Breakdown | Must withstand at DC 500V/15sec. | |||
Insulation Resistance | 100000 MΩ × m Min. at DC 125V, 20°C | |||
Flex Life** | 15,500 cycles | 16,500 cycles | 43,000 cycles | |
Tensile Strength | 255N | 284N | 206N | |
Emigration | Non-emigrant to ABS | |||
Applicable Temperature | -20°C‾ +70°C(-4°F‾ +158°F) |
Diamètre (mm) | 3.0 |
Longueur (m) | Vendu à la coupe |
Nombre de Conducteurs | 1 |
Matériaux Isolation | Autres |
Blindage | Oui |
Section (mm²) | 0.08 |
Matériau conducteurs (Câble) | Cuivre |
Plaquage Conducteurs (Câble) | Aucun |
Masse / Blindage | Oui |
Note moyenne 4.9 / 5 7 avis | Pourquoi donner votre avis les produits ? Vous pouvez partager votre expérience tout en informant d'autres clients |
RENAUD C.
POPOVSCHI B.
marco g.
marco g.
