MOGAMI 2901 Câble de modulation Symétrique 2x0.054mm² Ø2.16mm
MOGAMI 2901 Câble de modulation Symétrique Ø 2.16mm
Référence : 9536
1,80 €TTC
1,50 € HT
Le câble MOGAMI 2901 est conçu pour être résistant et souple à la fois.
Ainsi, il est particulièrement adapté à la scène et au studio.
  • Conducteur Cuivre 0.054mm²
  • Isolation Polyester
  • Double blindage : entourage Cuivre en spirale
  • Gaine PVC flexible
  • Diamètre externe : 2.16mm
SPECIFICATIONS
Configurationdiagram cable w2697diagram cable w3031diagram cable w2901
Part No.W2697W3031W2901
No. of Conductor2
ConductorDetails16/0.08 A <T1000D*1>43/0.04 Cu-Sn
Size(mm²)0.08mm² (#28 AWG)0.054mm² (#30 AWG)
InsulationOv. Dia.(mm)0.85Ø (0.033")0.6Ø (0.0236")
MaterialPVCPolyester
ColorsRed / WhiteBlack / Red
Filler Thread-Polypropylene
ShieldServed Shield
Approx. 60/0.08A
Braided Shield
Approx. 16/6/0.08A
Double Served Shield
Approx. 35/0.08A,
Approx. 40/0.08A
JacketOv. Dia.(mm)2.5Ø (0.098")2.8Ø (0.110")2.16Ø (0.085")
MaterialFlexible PVC
ColorsBlackBlack / WhiteBlack
Roll Sizes50m (164 Ft)
100m (328Ft)
200m (656Ft)
200m (656Ft)
(on spool)
305m (1000Ft)
Weight1.8kg / 200m2.5kg / 200m2.7kg / 305m
ELECTRICAL & MECHANICAL CHARACTERISTICS
DC Resistance at 20°CInner Cond.0.23Ω/m(0.070Ω/Ft)0.41Ω/m(0.125Ω/Ft)
Shield0.065Ω/m(0.020Ω/Ft)0.038Ω/m(0.0116Ω/Ft)0.07Ω/m(0.0214Ω/Ft)
Capacitance at 1kHz, 20°C
(Partial C. Value)
See below figure*
K0300pF/m(92pF/Ft)290pF/m(88pF/Ft)176pF/m(54pF/Ft)
K157pF/m(17pF/Ft)70pF/m(21pF/Ft)32pF/m(9.8pF/Ft)
Inductance between conductors at 1kHz. 20°C0.8µH/m(0.24µH/Ft)
Electrostatic Noise**50mV Max.200mV Max.1mV Max.
Electromagnetic Noise**0.15mV Max.
Microphonics at 50KΩ Load**300mV Max.150mV Max.40mV Max.
Voltage BreakdownMust withstand at DC 500V/15sec.
Insulation Resistance100000 MΩ × m Min. at DC 125V, 20°C
Flex Life**49,000 cycles26,000 cycles177,000 cycles
Tensile Strength294N313N176N
EmigrationNon-emigrant to ABS
Applicable Temperature-20°C‾ +70°C(-4°F‾ +158°F)
Diamètre (mm)2.2
Longueur (m)Vendu à la coupe
Nombre de Conducteurs2
Matériaux IsolationAutres
BlindageOui
Section (mm²)0.05
Masse / BlindageOui
