AUDIOPHONICS PRE-TC10 Preamplifier with Tone Control 2x AOP LM49720NA
The Audiphonics PRE-TC10 is a preamplifier offering of course volume control, but especially a triple tone control.
4.8 / 5
Reference : 12752
59,90 €tax incl.
49,92 € tax excl.
Shipping from France
Billing in France
Technical support in France
Stereo preamplifier with tone control
audiophonics préamplificateur
The Audiphonics PRE-TC10 is a preamplifier offering of course volume control, but especially a triple tone control. Its possibilities are based on a series of components allowing at the same time to propose a powerful device while having a contained price.
Tone control
The main feature of this preamplifier is to offer a triple tone control. This one is able to independently adjust bass, medium and treble as needed. So you can adapt the sound reproduction according to your material and the desired listening, or correct the potential gaps in the sound of your audio system. It is also possible to not use the tone control. For this, simply turn the treble knob fully to the left.
Audiophonics PRE-TC10 préamplificateur contrôle de volume
Audiophonics PRE-TC10 préamplificateur contrôle de tonalité
Careful design
This preamplifier integrates components allowing it to offer very good performances while maintaining a low price. There will be 6 rectifier diodes 1N4007, 2 LM317 controllers and one LM7812 controller, 1 HK19F relay but especially 2 AOP LM49720NA. Mounted on DIP8, they will thus allow the most audiophiles to change them simply to modify the sound of the device.
Tone controlBass
Medium
Treble
OPA on DIP82x TI LM49720NA
Regulators2x LM317
1x LM7812
Relay1x HK19F
Rectifiers6x 1N4007
InputStereo RCA
OutputStereo RCA
Input sensibility2V rms (Max Gain : 13dB)
Output level Max9V rms
Power supplyVia IEC (cable not included)
Dimensions179 x 117 x 48mm
Weight790g
Housing material100% Aluminium
Silver
ColorSilver
ClassN/A
13 reviews
PRE-TC10review
I have used this excellent pre for a diy project where TC-10 drives Nr.2 DSP Tinisyne managing two full 2.1 systems. Perfect for a lot of DIY projects where an high quality preamplifier is needed. Thanks Audiophonics, always a reference.
This review has been posted for AUDIOPHONICS PRE-TC10 Preamplifier with Tone Control 2x AOP LM49720NA
PRE-TC10 review
I have posted a review of this recently bought product at ASR:
https://www.audiosciencereview.com/forum/index.php?threads/audiophonics-pre-tc10-preamp-with-tone-controls-review-and-measurements.44930/
The preamp function is good at affordable price, it is helpful especially in cases we use a record player or cassette recorder. However, there was a QC failure with this product, the negative voltage regulator LM337 did not work and sent -23V to the LME49720 negative supply pin. This, together with +14V positive supply (correct value) made total supply voltage of 37V and this exceeds datasheet absolute maximum value which is 36V. The op amps have survived and I have replaced the faulty LM337 for a new part. However, this should have been tested by the manufacturer.
PETIT EGALISEUR BIEN UTILE
J'ai intégré le TC10 entre un DAC et des enceintes actives et cela m'a permis de conserver mes enceintes qui n'avaient pas de réglage de tonalité
Donc objet précieux et rare pour ceux qui ont besoin comme moi d'augmenter les HF et de modérer les BF pour (bien) entendre...
Merci AUDIOPHONICS ...
Perfect for a Headphone System
I Had this product in the shelve for a long time because i had not found a good use for it, But when I bought an amplifier set for headphones I found the perfect match to integrate this preamp, the tone controls make all the difference.
Petit boitier qui fonctionne correctement
Qualité sonore acceptable. Voyants rouges trop lumineux. Je l'utilise pour seulement une écoute à bas niveau (ambiance,...) sur mon ampli qui n'a aucun correcteur de tonalité ni loudness, quand la source est trop linéaire. Il répond à mes attentes.
