IEC C20 Inlet 3 Poles
IEC C20 Inlet 3 Poles to Screw
This IEC C20 (male) socket will allow you to mount your power connectors and connect a cable with IEC C19 (female) connector. The base plate has 3 horizontal poles and is often used by high power devices rather than IEC C13/C14.
Reference : 13054
5,50 €tax incl.
4,58 € tax excl.
Shipping date: 09-05-2024.
Shipping from France
Billing in France
Technical support in France
IEC Inlet
IEC C20 3 poles
Embase IEC C20
This IEC C20 (male) socket will allow you to mount your power connectors and connect a cable with IEC C19 (female) connector. The base plate has 3 horizontal poles and is often used by high power devices rather than IEC C13/C14. It supports a voltage and current of 250V AC 16A 50Hz.
Connector typeIEC C20 (male)
Poles number3
IEC Nominal Voltage / Current250V AC 16A 50Hz
UL/CSA Nominal Voltage / Current250V AC 20A 60Hz
Operatig temperature range-25°C à 70°C
Connection typeTo solder
Spacing between fixation holes42mm
Total dimensions53.5 x 30.2 x 32mm
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
ConnectorIEC C20
Rated current (A)16.0
Rated current (A)20.0
Eccellente
Presa fantastica, non l ho ancora montato, ma il materiale è di buona qualità. Il fornitore è eccezionale una supporto efficiente, comprerò molto da voi.
This review has been posted for IEC C20 Inlet 3 Poles
This IEC C20 (male) socket will allow you to mount your power connectors and connect a cable with IEC C19 (female) connector. The base plate has 3...
