Michael L.
High value for you're money
Very harmonic amp, tone controls adjusted since 12 o'clock might not be 100% neutral, i feel i don't miss anything...
THIERRY D.
affichage defectueux
Depuis quelques mois, l'affichage en Db a perdu 2 segments sur le zero et le trois.
bernard g.
Linear Regulated Power Supply Module DC LT1084 4.9V to 24V 5A - reviews - There are 4 reviews.
Daniel C.
Module does not meet the specs!
Purchased the module, for use as regulated power supply at 32V.
But, unfortunately, the module cannot work at 32V, as the trimmer is running very hot when tuned at 32V, and on top, the electrolytic capacitors C3 and C4 are 25V types.
The operating voltage voltage at C4 is simply the output voltage.
When the VR trimmer is set at 32V, the voltage on VR is 27V, and VR is in that position abt 300 ohms : 2,5W dissipation is much too high...
To solve the problem, I adapted the module as follows:
Changed C3 and C4 by 64V types, and replaced R1 (50 Ohm) by 500 Ohm.
The module can now be easily tuned at the desired voltage, without burning the 5k trimmer, and blowing the elco's.
Daniel C. Hamme - Belgium
ALEXANDRE R.
Condensateur occasion ?
Fonctionne parfaitement , mais esthétiquement le condensateur fait peur.
Rayer, bosselé, il doit etre à sa seconde vie.
Fortuné M.
Pour le prix, parfait !!!
Facile à mettre en oeuvre, parfait pour remplacer les prises CPL d'une box
francois R.
excellent module à tout faire
très très bonne surprise: fabrication asiatique donc excellente qualité contrölée par les Taiwanais. Module très compact. Super rapport qualité/prix et surtout plus beaucoup plus rapide que d'arpenter les marchés de Guang Hua à Taipei ou de Huagiang Bei Lu à Shenzhen...
