François G.
Samuel A.
What a surprise!!!
Frederic A.
3E AUDIO 260-2-29A PFFB
Fonctionne...
Avis clients - Il y a 19454 avis.
Svilen I.
LINDY CROMO LINE Câble de Modulation RCA-RCA Cuivre Plaqué Or 2m (La paire) Les câbles RCA Lindy Cromo Line profite d'une belle qualité de conception. Ses conducteurs sont fait de Cuivre assurant une très bonne conductivité et...
Excellent build quality
Excellent build quality - perfect interconnect. It is very bendy and thin.
Svilen I.
MINIDSP POCKETADC Convertisseur ADC ES9821Q RCA vers Coaxial / Optique Toslink 24bit 192kHz Le miniDSP Pocket ADC est un convertisseur analogique-numérique (ADC) compact et performant. Il dispose d'une entrée analogique RCA stéréo et de deux...
Excellent box
I have a soundbar that lacks of any analogue inputs. Using this device I can connect my old AM/FM tuner to it. The build and sound quality is excellent
Zacharias L.
TANCHJIM ZERO ULTIMA Écouteurs Intra-Auriculaires Dynamique 30 Ohm 123dB Jack 3.5mm Les écouteurs intra-auriculaires Tanchjim Zero Ultima offrent des performances exceptionnelles à un prix accessible. Chaque écouteur est...
Good vibrant sond
The parcel has been received in around 1 week using slow delivery to Greece with no problems.
Nice box design and a earphones with a simple pouch they are not a IEM model but standard plug in earphones. The remain design ensures a IEM type of cabling and plug.
Tested in the road rthe same day with a old type DAP they delivered a quite trebly sound as with any other tested earphones so far, The original recordings have lots of treble as like Dolby cassettes in which the Dolby option is not used! Using other more linear recordings the sound is heard very close to the original I hear in my stereo. All fidelity is herd from the lowest possible level compared to the other earphones!
Replacing the buds with comply types added a few db of bass making the sound more vibrant!
István R.
excellent silver cable
The cable is a big surprise for me. I was planning to replace the legendary Siltech SQ-110 Classic MK2, which I have been listening to for 20 years. The list price of the SQ-110 1m pair was 2600EUR. This NEMOI-1220 with DIY assembly at 1/6 of the price slightly surpasses the SQ-110 cable in sound already before burn-in.
A terrible negative is the peeling of the 0.1mm thick clear Teflon insulation covering the square silver conductor.
Jean-Pascal H.
EVERSOLO BTR-12 Télécommande IR / Bluetooth pour DMP-A6 / DMP-A6 Master / DMP-A6 Gen 2 / DMP-A6 Master Gen 2 Cette télécommande IR / Bluetooth BTR-12 proposée par Eversolo a pour vocation d'être appairée à tous leurs appareils de la gamme DMP,...
Indispensable pour piloter l'Eversolo pour un prix plus que contenu à mon avis :)
Jean-Pascal H.
EVERSOLO DMP-A6 GEN 2 Lecteur Réseau 2x ES9038Q2M WiFi DLNA Roon Bluetooth 32bit 768kHz DSD512 Le Eversolo DMP-A6 Gen 2 est un lecteur réseau HiFi qui allie de manière transparente une qualité sonore exceptionnelle à une technologie de pointe....
Au Top
Produit au top super qualité de fabrication et surtout audiophile , il doit y avoir des défauts peut être perso je n'en ais pas trouvé et j'ai pris le temps pour donner mon avis, je recommande sans réserve , on ne peut plus dire que les chinois ne savent pas faire merci à Audiophonics également pour leur réponse rapide à tous les questions.
Johan V.
FIIO FT1 Casque Audio Dynamique Fermé Circumaural Ø60mm 32Ω 113dB 10Hz-40kHz Le FT1 de FiiO est un casque dynamique fermé aussi esthétique que performant. Ses haut-parleurs dynamiques de 60mm de diamètre couplés à son...
Exceptionnel
István R.
AECO ARP-1512S Connecteurs RCA Cuivre Tellurium Plaqué Argent Ø11mm (Set x4) Ces connecteurs RCA aeco ARP-1512S de haute qualité, vendus par 4, profitent d'une conception rigoureuse utilisant des matériaux haut de gamme. Les contacts sont...
not easy to assemble
This way, you should not expose the plastic body to too much heat, because it softens slightly with heat.
https://www.youtube.com/watch?v=Cnm197OjIaI
This way, after soldering, the + and - poles will not be exactly in place in the plastic body.
However, if you have to solder the shielding as a third conductor, it will be a big pain.
And there is another strange thing. I have to plug the assembled RCA plugs into Aeco ARJ-4045S sockets, but it only fits so tightly that I am afraid that one of parts will break.
https://www.aeco.tw/products/arj-4045s
Paul M.
DYNAVOX Câbles d'enceintes bananes Cuivre OFC (La paire) 2m Ces câbles enceintes hautes performances d'un excellent rapport qualité/prix intègrent des conducteurs en Cuivre OFC ainsi que des fiches bananes permettant...
Excellent speaker cables
These cables tick all the boxes: solid construction, quality cable and nice to the eye. Cannot distinguish an audible difference with more expensive speaker cables. Nicely executed. All you need for happy listening.
Paul M.
Straightforward excellent pre-amplifier
Initially I bought this pre-amp for use with active speakers. Excellent at that. Shortly after that, I bought the accompanying Audiophonics Hypex nCore power amplifier. The combination has now replaced my integrated A/B class amplifier, costing only a fraction of the integrated amplifier. Wish I would have known earlier.
The pre-amplifier has a solid build, with equally solid RCA, XLR and power connections at the back. It's a simple layout, very well executed. The trigger option makes me happy and lazy at the same time.
The sound is, well, indistinguishable. Like there is no pre-amplifier in the signal chain. I really dig that.
If you're looking for a straightforward pre-amplifier or for the combination with a power amplifier, then do not hesitate. Very reasonably priced and very well executed. Listen to your ears, regardless of the price. Recommended!
SHANLING CR60 Lecteur Ripper CD Sanyo HD850 Argent Avec son CR60, Shanling dévoile un lecteur/ripper CD relativement compact et peu encombrant. Le CR60 est basé sur une tête laser Sanyo HD850 et un...
Belle petite machine
Très bien construit, la qualité est là, silencieux en fonctionnement, bonne mécanique. Un seul point négatif, l'alimentation DC 12V n'est pas fournie avec l'appareil !
EVERSOLO DMP-A10 Lecteur Réseau ES9039PRO WiFi DLNA AirPlay Bluetooth aptX HD LDAC 32bit 768kHz DSD512 Avec le DMP-A10, Eversolo dévoile son nouveau lecteur réseau et DAC ultra-performant. Comparé à son son...
Appareil qualitatif
Appareil très bien construit, design audiophile, dommage ce gros bouton ciselé, pas du meilleur goût. La qualité est là, mais est-ce justifié qu'il coûte deux fois plus cher que le A-8, qui est un très bon appareil, et ayant les mêmes options, et que le A-8 a une connexion I2s, ce qu'a perdu le A-10...
Bref, sincèrement, j'ai du mal à trouver une justification à ces 1500€ de surcoût.
LDOVR TPS7A4700 Module Alimentation Linéaire Régulée Ultra Faible Bruit 1.4V / 20.5V 1A Ce module d'alimentation linéaire régulée LDOVR TPS7A4700 assure un niveau de bruit extrêmement faible mesuré à seulement 4µvrms....
Manque d 'info
Cette carte doit sûrement valoir le coup. Je ne le sais pas car l'opération de montage de la carte de régulation ainsi que le pontage des pins a souder sont délicat a faire pour un neofite en soudure électronique. Prévoir un fer très fin vu le peu d' espace qu'il y a. La mienne n' a pas supporter mon manque d' experience.
Alexandru Ovidiu A.
MUNDORF ACW115BK Fil de Câblage Cuivre / Argent / Or PTFE 1.8mm² Ce fil de câblage haut de gamme Mundorf ACW115BK offre une excellente qualité de fabrication pour une conductivité maximale. Ainsi, ses conducteurs sont fait...
Magic
Robert C.
KHOZMO ACOUSTIC Contrôleur de Volume / Sélecteur de Source 10K + Télécommande Noir À la fois préamplificateur passif et sélecteur de source, cet appareil à la finition Aluminium et bois saura sans nul doute convaincre. Il est...
En alu et complète avec mute et même un display à 4 niveaux d'intensité lumineuse de l'affichage jusqu'à l'extinction si on le souhaite.
Fourni pour utilisation dès réception avec les piles déjà à l'intérieur (chose rare !).
Fonctionne parfaitement à n'importe quel endroit de la pièce d'écoute.
Seulement les 3 entrées sont sélectionnables sur le Pré.
Vraiment je suis très satisfait et de mon avis il s'agit d'un excellent RQP.
MARC S.
AUDIOPHONICS Q6 Récepteur Bluetooth 5.4 QCC3084 DAC ES9018K2M aptX HD LDAC Le Audiophonics Q6 est un petit récepteur Bluetooth combinant une puce Qualcomm QCC3084 ainsi qu'une puce DAC ES9018K2M. Il supporte les codecs aptX HD (24bit 48kHz) et...
Épatant
Branchements simples, reconnaissance immédiate de l'appareil depuis un smartphone Androïd. Utilisé avec Qobuz, relié en RCA à un ampli Marantz sans entrée numérique. Écoute grâce à des enceinte Jersey Cabasse : c'est exactement ce que je souhaitais. Ça marche parfaitement, la qualité est surprenante. Il semble que le bluetooth, que l'on dénigre beaucoup, progresse bien vite. Merci à Audiophonics qui propose du si bon matériel, minuscule , à un prix très raisonnable et d'une belle efficacité. Reçu dans les délai. Emballage parfait.
Marc A.
Câble Symétrique pour Casque Jack 3.5mm vers 2x Jack 3.5mm Cuivre OCC Plaqué Argent 3m Ce câble pour casque audio dispose d'un connecteur jack 3.5mm stéréo symétrique et de deux connecteurs jack 3.5 mm symétriques. Le câble...
Mon lecteur réseau Teac NT 505 X possède une sortie casque 3,5mm à 4 pôles. Hors tous les jacks proposés en 3,5mm sont en 3 pôles.
Seul Audiophonics propose se cable avec ce jack 3,3 4 pôles.
De plus ce cable est de très bonne facture, il est bien souple et il est très beau.
La livraison a été rapide, j'ai pu profiter de mon casque assez vite.
TUNG-SOL 6SN7GTB Tube Double Triode (Unité) Le tube Tung-Sol 6SN7GTB est un tube double triode qui profite d'une belle conception grâce à des matériaux de qualité. Ce modèle...
superbe tube .fonctionnent très bien sur un Cayin cs150
.j aimerais savoir si ils sont disponible en quad appairés. Merci pour vos réponses..
alexandre G.
AUDIOPHONICS AP300-S125NC Amplificateur de Puissance Class D Stéréo Ncore NC122MP 2x125W 4 Ohm Le Audiophonics AP300-S125NC est un amplificateur stéréo basé sur un module d'amplification Hypex Ncore NC122MP. Cette solution est...
couplé a un streamer eversolo sur les liaisons symetriques... tout y est!
puissance , details , profondeur et le tout dans une certaine douceur.
chouette!
VIBORG XM203AG Connecteur XLR Mâle Argent Pur PTFE Ø11mm Rouge (Unité) Le XM203AG de Viborg est un connecteur XLR mâle haut de gamme, utilisant des contacts en argent pur afin de fournir une conductivité maximale. Il intègre...
Fiables et belles.
Rien à redire sauf peut-être l'absence de repères 1, 2 et 3.
Donc il faut être très méthodique et concentré pour ne pas faire d'erreur.
A part ça, très bonnes fiches.
VIBORG XM203AG Connecteur XLR Mâle Argent Pur PTFE Ø11mm Noir (Unité) Le XM203AG de Viborg est un connecteur XLR mâle haut de gamme, utilisant des contacts en argent pur afin de fournir une conductivité maximale. Il intègre...
Fiables et belles.
VIBORG XF203AG Connecteur XLR Femelle Argent Pur PTFE Ø11mm Noir (Unité) Le XM203AG de Viborg est un connecteur XLR femelle haut de gamme, utilisant des contacts en argent pur afin de fournir une conductivité maximale. Il intègre...
Fiables et belles.
VIBORG VR106AG Connecteurs RCA Mâles Argent Pur PTFE Ø11mm (Set x4) Les VR106AG de Viborg sont des connecteurs RCA mâles haut de gamme, utilisant des contacts en argent pur afin de fournir une conductivité maximale. Ils...
Peut mieux faire...
Belles, faciles à mettre en œuvre, mais le diamètre n'est pas précis et le serrage n'est pas efficace.
Sur des WBT-0210CuMs, un coup difficile à faire rentrer, un coup ne serre pas bien.
Je ne les recommande pas.
CABLE EXCEPTIONNEL.
Il faut être patient et méticuleux car sa structure est assez complexe.
Le résultat est excellent tant en XLR qu'en RCA.
Sur mon système, l'apport principal est sur la scène sonore et les timbres qui, tout deux, sont très naturels.
On est au dessus du Sommercâble Epilogue.
Robert C.
Beau au regard et qualité des matériaux ainsi que des connexions.
Ecoute : PC Audirvãna Kobuz Dac Chord 2Qute Khozmo ampli de puissance Nuprime AMG SE (spécial édition) colonne Dynaudio Emit 30.
Plus détaillé, plus ouvert et charpenté, plus profond, plus nuancé ou subtil et plus agréable musicalement ; en comparaison du pré Rega Elex R ou Pro-Ject DS2 analogue.
Pas de rondeur exagérée ou de mollesse, cette fois cela reste à la fois fluide, vivant et expressif avec des aigus délicats et sans acidité.
Certainement pas encore la perfection que nous essayons tous de rapprocher, et cela passera probablement pour mon cas par un new Dac. (ce n'est pas ce qui manque chez Audiophonics).
Remerciements à Mr David Aubert pour sa science des conseils et à toute l'Equipe Audiophonics pour la livraison impeccable et plus tôt que prévue (article pas en stock).
Philippe L.
WONDOM AA-AB41163 BEB1 Module Récepteur Bluetooth 5.3 LDAC Interface USB DAC ES9018K2M 24bit 96kHz Le module récepteur Bluetooth Wondom BEB1 de référence AA-AB41163 est un petit module de réception Bluetooth intégrant une puce de...
Récepteur bluetooth
Distance reception très faible malgré le rajout d'une antenne dédié
Excellente qualité sonore
Jeremy D.
IFI AUDIO iPOWER ELITE Adaptateur Secteur à Annulation de Bruit Active 24V 2.5A L'adaptateur secteur iFi Audio iPower Elite cache, sous son robuste châssis en Aluminium extrudé, une technologie de pointe permettant de fournir à votre...
Parfaite évolution
j'étais relativement septique sur l'amélioration de l'alimentation de mon enceinte connectée JMR AGAPE, je possédais jusque là le filtre secteur ipurifier de la marque, mais le résultat est au dessus avec l ipower elite seule, silence de fonctionnement, tout est plus net plus précis plus agréable, ca fait de la musique, je découvre enfin mon enceinte et le plus bluffant c'est que tous les bugs et coupures de connexion ont disparus, incontournable pour profiter pleinement de son système!
Alexandre C.
TOPPING A30 PRO Amplificateur Casque NFCA Noir Le Topping A30 Pro est un amplificateur casque NFCA de grande qualité qui fera le bonheur des amoureux de l'écoute au casque. Avec ses deux sorties casque à...
Une merveille
Que ce soit sur un dac TDA1541WW Nakamichi DAC101 ou sur un Sabre ESS9018 Breeze modifié, câbles Isoda 08, casque Sony MDR CD3000, cet ampli est non seulement d'une puissance extreme mais aussi d'une transparence et d'un silence sans égal.
Quelles que soient les modifications en amont il les restitue immédiatement avec naturel et richesse de timbre, dynamique sans faille et image sonore ultra précise.
Cyrille S.
SMSL PL100 Lecteur CD CS43131 Noir Le lecteur CD SMSL PL100 est un appareil qui vous permettra de profiter de votre collection de CD. Il repose sur une puce DAC CS43131 ainsi qu'un circuit PLL (Phase-Locked Loop)...
Bon transport
Je cherchais un transport de petite taille avec un son correct pour le placer à coté d'un ampli FDA Sabaj, le résultat est correct, peut-etre moins de corps que mon vieux lecteur Pioneer mais c'est tres défini, je n'ai pas testé le DAC interne, sinon branché sur un DAC SMSL SU-1 et des enceintes de monitoring ça marche bien, c'est cohérent, on est pas sur un vieux lecteur Philips ou Marantz, c'est neutre.
Stian L.
AUDIOPHONICS HPA-S450ET Amplificateur de Puissance Class D Stéréo Purifi 1ET6525SA 2x450W 4 Ohm L'amplificateur de puissance Audiophonics HPA-S450ET se base sur une architecture classe D, utilisant une paire de modules Purifi 1ET6525SA, une alimentation Hypex SMPS1200A400...
A very good and powerful amp
Delivers clean and high gain without any colouration or distortion. It is what I wanted. Only negative is a slight power on pop noise and the screws are of low quality and it looks like they could start to rust just by breathing on them.
Paul C.
TRUTHEAR X CRINACLE ZERO:RED Écouteurs Intra-Auriculaires IEM Dynamique Ø10mm/Ø7.8mm 17.5Ω 117.5dB 20Hz-40500Hz Avec les Zero RED, Truthear s’associe une fois de plus avec Crinacle, réputé pour son expertise en matière d’IEM, pour proposer une nouvelle...
D'une remarquable qualité
Excellents écouteurs, tant par leur qualité de construction que par leur son. Les embouts en mousse fournis avec isolent également bien.
Jean Louis d.
AIYIMA A70 Amplificateur 2.1 canaux TPA3255 2x185W 4 Ohm AIYIMA nous offre avec son A70 un amplificateur class D 2.1 canaux intégrant des composants de qualité. En effet, ce dernier incorpore une puce d'amplification TI...
ALIMENTATION
l'ampli est bon mais l'alimentation est une daube , celle si perturbe beaucoup le rendu , j'ai installer une autre alimentation est la ca marche très bien
A H.
OMG
I got: seat at the mixing desk
I paid: the bass
And I love this
Lennart H.
Eric H.
Gaine Tressée Extensible Nylon 6-12mm Grise Cette gaine tressée grise en nylon habillera efficacement vos câbles et leur conférera une plus grande résistance mécanique. Celle-ci dispose d'un diamètre ajustable de 6mm à 12mm.
Bon rapport qualité prix : fait le job !
Eric H.
NEOTECH NEI-3004G Câble de Modulation Symétrique Cuivre G-UPOCC Graphène Ø8.5mm Le câble de modulation NEI-3004G de Neotech est un câble de modulation symétrique incorporant 2 conducteurs composites G-UPOCC, combinaison de cuivre OCC et...
Très bon câble sur tout le spectre
Amène de la clarté et pleins de détails deviennent plus apparents.
Je recommande son achat
Tanel P.
NEOTECH NES-5002 Câble Haut-Parleur Cuivre UP-OFC 2x2mm² Ø9.5mm La gamme NES-5000 de Neotech est composée de câbles à conducteurs Cuivre Ultra Pur UP-OFC tout en assurant un prix abordable. Le NES-5002 intègre 2...
Nicely flexible
It's thick and green like a garden hose, looks good :) Easy to work with and very flexible indeed.
AIYIMA A80 Amplificateur Intégré Class D Bluetooth 5.1 TPA3255 2x120W 4 Ohm Aiyima dévoile son A80, un amplificateur intégré classe D compact doté de nombreuses fonctions et de composants audiophiles. Il repose principalement...
Complet
Après un mois d'usage, je dirais : "Conforme au descriptif" : formule passe-partout pour confirmer qu'il s'agit d'un produit de qualité " à composants audiophiles", sans point faible significatif, surtout pour le prix, et pilotant efficacement, excusez du peu, des DYNAUDIO emit 50 (raisonnablement, hein, sans chercher à faire trembler les murs non plus ! ) avec l'alimentation d'origine, et ce dans mon salon de 25 m2 ; je n'ai donc pas besoin de prendre l'adaptateur secteur doublant la puissance. Merci Audiophonics pour l'info et surtout pour ne pas pousser inutilement à la consommation...
Cet ampli est aussi efficace en vinyle sur entrée analogique qu'avec le lecteur réseau sur l'entrée optique...
Je recommande donc aussi bien cet ampli Aiyima 80 qu'Audiophonics...
benjamin b.
SUPER
Je viens de m'ennuyer de repartir du compteur électrique, de retirer l'ancien 1,5mm2 standard et de dédier la ligne uniquement à l'audio (il n'y a avait toutefois que quelques luminaires en plus de la hifi sur cette ligne) Avant installation, le câble avait "tourné" quelques dizaine d'heures. Verdict :
C'EST LE JOUR ET LA NUIT :-) :-) :-)
si vous installez plusieurs prises murales : ne coupez pas le fil sans isolant. Celui-ci sert à faire la continuité avec la feuille isolante / de blindage.
Je l'ai soudé et gainé au fil de terre côté compteur électrique
très satisfait !
Giovanni B.
Purchase
Dear Sir, my package will arrive as soon as everything is available, or will you ship what is already in stock first? Let me know, thanks.
Juha K.
This amplifier could be described as very versatile for different music genres. Purifi has never disappointed my own ears. This does everything without adding or removing anything from the sound, however, being a little on the warm side. The treble is not dry as is typical for class D, it has nice details and brightness. The bass is also not a little dry as is typical for class D, it has nice thickness and meat, but still perfectly controlled. Overall, the sound has a nice "loudness". Physically very sturdy and high-quality housing. The adjustable gain is a big plus. The only small minus in my opinion is that the connectors on the back (speaker and RCA) are quite close to each other. If you use spades, there may even be a small risk of short circuit! However, there is no danger if you use balanced XLR connectors. This does not affect the number of stars. One of the best power amplifiers in its price range.
Eric H.
NEOTECH DG-202 Connecteurs RCA Cuivre OFC Plaqué Or Ø9mm (Set x4) Ces connecteurs RCA Neotech DG-202, vendus par 4, profitent d’une conception rigoureuse et de matériaux de grande qualité. En effet, ces derniers sont...
Fiches RCA de qualités
Très bonnes prises RCA de très bonnes qualités.
Le seul bémol c’est la soudure de la masse sur le corps qui n’est pas évidente: ils auraient pu faire une « encoche » comme sur leurs autres prises RCA plus chers .
Eric H.
MUNDORF MLYTIC AG Condensateur 25V 22000µF Ces condensateurs ont été spécialement développés pour les amplificateurs de petite puissance ou les préamplificateurs. Ce nouveau...
Excellents condensateurs
3ème commande, pour mes amplis: super sonorité
Pierre-Jean T.
TUNG-SOL EL34B Tubes Pentode Platinum (Quad Appairé) Ces tubes pentodes Tung-Sol EL34B haute tension profitent d'une belle conception, utilisant des matériaux de grande qualité. Ils disposent d'une impédance...
Tung
Un son plus détaillé et limpide. Content.
André G.
Tweeter Dayton en complément du tweeter en facade
Ce tweeter qui est léger et ne paie pas de mine s avère etre clair non agressif et propre, il s intègre bien dans ma configuration en bi actif et rehausse l aigu en fusionnant avec le médium aigu. Pour 36€ c’est une aubaine
Stéphane K.
ELECAUDIO LI-07GB Connecteur Secteur IEC C7 Plaqué Or 24k 3x5mm² Ø15mm Ce connecteur IEC C7 Elecaudio LI-07GB est idéal pour créer des câbles d'alimentation de qualité. Il utilise en effet des contacts en alliage de...
Piètre qualité.
Un produit vraiment basse qualité. Btr cassée au premier démontage. direction la poubelle
Jean-francois L.
3E AUDIO A7 MONO Amplificateur Class D Mono PBTL 1xTPA3255 1x260W 4 Ohm 3E Audio, acteur reconnu dans le monde du DIY, propose le A7 Mono, un amplificateur classe D mono conçu avec des composants Hi-Fi audiophiles. En effet, l'amplificateur...
A7 mono
Superbe ampli, je les préfères à mes anciens fosi v3 mono. Livraison rapide au Canada. Avec le support de 3e audio j’ai réussi à régler le problème du auto-standby trop sensible. Maintenant c’est parfait.
Jerome C.
RAMM AUDIO SA-15 Câble Haut-Parleur Cuivre OFHC Blindé 2x 1.65mm² Le Ramm Audio SA-15 est un câble haut-parleur offrant une conception de qualité à prix abordable. Il se compose de deux conducteurs en cuivre OFHC d'une...
Utilisé en câble secteur bipolaire
Utilisé en câble secteur bipolaire, deux mètres de longueur avec un connecteur secteur schucko basique (ici Sommercable ) et un connecteur C7 que j'avais en stock.
C'est un réel bonus pour mon Lecteur DVD hdg (sur DAC externe) pour la partie audio à l'écoute de CD , son plus charnel un petit bonus en présence et séparation Stéréo.
Une optimisation "budget" très appréciable.
Le câble se "réalisera" (rodage) en une vingtaine d'heure
David C.
HIDIZS MERMAID MM2 Écouteurs Intra-Auriculaires IEM Doubles Haut-Parleurs Magnétostatiques / Dynamiques PEK Noir Les Hidizs MM2 sont des écouteurs intra-auriculaires offrant de très bonnes performances audio pour une expérience d'écoute de immersive et...
Extra!!
Certes je poste mon avis avec 2 ans de retard! Ces petits écouteurs intra sont d'une qualité exceptionnel par rapport à leur prix de vente. La possibilité de pouvoir changer les filtre en fonction de ses goût et vraiment génial, de plus leur rendu acoustique dépasse mes attentes pour type de casque. Bref une petite pépite qui n'est malheureusement plus proposée à la vente au moment ou je me décide enfin à donner mon avis....
Nicolas P.
AUDIOPHONICS LPA-S450ET Amplificateur de Puissance Stéréo Class D Purifi 1ET6525SA 2x450W 4 Ohm Nous sommes fiers de vous proposer le Audiophonics LPA-S450ET, un amplificateur de puissance stéréo classe D basé sur deux modules Purifi 1ET6525SA....
Ampli purifi
Cela fait seulement 2 jours que j ai reçu mon ampli purifi et donc tjrs en rodage.
La claque, il exploser en tout point mon ancien ampli pourtant 3 fois plus cher...
Je n' ose Imaginer dans quelques heures ce que cela va me donner...
Tout y est, à la bonne place, avec une précision extraordinaire.
Tout est sublimé.
Je suis super content de mon achat et certainement le dernier ampli que j achète.
Merci audiophonics pour donner la possibilité d avoir une amplification aussi bonne, à si peu cher en comparaison.
