Jean-François D.
Impeccable !
Vasilios K.
Ça Chauffe !
Avis clients - Il y a 19303 avis.
Alessio V.
Well made
Well made noise suppressor, it fits perfectly on the cable. Nice product!!!
Alessio V.
Incredible upgrade for the price!!!
Installed on an HP PC (very easy to install too) used for liquid music. Voice and instruments are more natural and the soundstage is wider than without...simply amazing!!!
Alessio V.
Very nice box!!!
Very very nice box!!! Even the price is something incredible!!! Used for an amplifier external power supply.
Alessio V.
Well made case!!!
Very very nice box!!! Even the price is something incredible!!! Used for a DAC power supply.
Alessio V.
Very very nice entry level mic!!!
High quality, easy to use, precise measurement mic!!!
Alessio V.
Attache Câble Adhésif 20x20mm Blanc Cet attache câble adhésif se fixe simplement sur une paroi afin de vous permettre de regrouper vos câbles. La base de l'attache câble est...
Nice quality
Strong adhesive, they do very well their job!!!
Alessio V.
Nice capacitors
You can't go wrong with Mundorf capacitors!!! Nice quality price ratio.
Alessio V.
Very nice feet
High quality, well made feet at a very interesting cost!!!
Emin B.
perfect one more time
about Khadas Tone Board I think a lot has been said and I can confirm that it is so. Simply the best value for money.
I want to thank the staff who quickly solved the small problem I had with the payment.
All recommendations for the Audiophonics service, shipping was fast, delivery as well. Everything is perfectly packed and without the possibility of damage. Great job, keep it up.
Emin B.
perfect
The NanoDigi is a fantastic device that does everything flawlessly. I got a version with a black box which suits me even better.
Patrick M.
mauvaise pioche
L'appareil que j'ai reçu faisait des pauses pendant l'écoute, environ 1 toutes les minutes.
Je l'avais connecté comme cela: entrée sur RCA coaxial sortie sur RCA.
A noter qu'il n'y a pas de télécommande.
Audiophonics a été correct et me l'a repris.
Christophe O.
Bon produit, tarif raisonnable et finition très correcte ! Fait le travail. Je recommande.
Christophe O.
Bon produit, pas cher et assez bien fini. En revanche, prise en main un peu difficile pour brancher ou débrancher d'un appareil.
merci à Audiophonics pour cette paire de bloc stéréo se hissant au sommet
Acheté en double pour une bi-amp verticale, je me retrouve avec un total de 2400w d'alimentation, les graves de 38cm sont ainsi parfaitement maîtrisés.
Par leur neutralité et transparence, j'entends davantage la signature sonore des autres électroniques en amont.
En été, sans clim, les amplis chauffent un peu.
Les blocs ont toutes les qualités requises : transparence, dynamisme et tenue, naturel, encombrement et consommation réduits.
En réflexion post achat je dirais que les idées d'amplis à tubes ou des classiques transistors sont maintenant écartés.
Bravo pour cette réalisation Française en ce jour du 14 juillet 2020 :-)
Mark P.
Excellent cable
Switched from Van damme concert series cable to this super cable.
Better sound and dynamics from this Canare cable.
Nice thick copper strands with strong and sturdy sleeves.
Also twisted which is the better way to make speaker cables which is why Kimber makes all cables like this.
Thankyou Audiophonics for supplying these excellent cables!
Alvaro S.
JANTZEN AUDIO SUPERIOR Z-CAP Condensateur 800V 2.2µF La gamme Superior Z-Cap de chez Jantzen Audio se compose de condensateurs non polarisés haut de gamme, conçus spécialement pour l'audio afin de permettra...
Timbre natural, realismo sonoro.
Usados como desacoplo en la entrada del ampli, en un equipo que ya sonaba muy bien. Esperaba cierta mejora con respecto a los Cross Cap que había pero el resultado superó lo esperado. La mejora es general, el ataque de las notas y el timbre de las voces e instrumentos es súper natural, hay mucha más información y detalle, llegando a engañar al cerebro que cree que tiene los músicos delante... Yo mismo soy músico, tengo muy claro cómo suenan las cosas en la realidad. De verdad que no esperaba semejante mejora. Un 10/10 a los condensadores. Por parte de Audiophonics todo perfecto, envío rápido y precios razonables pero eso ya lo sabíamos...
Bernard B.
connecteur cable alim source
Par rapport au connecteur FI-E11-N1(G) qu'il remplace, celui ci apporte focalisation et densité des sons sur l'ensemble du spectre et au final un bénéfice certain sur le timbre.
Carsten S.
ALLO NIRVANA Alimentation Audio faible bruit 5V 2.8A Noir Cette alimentation SMPS ultra faible bruit offre un rail d'alimentation possédant une tension de 5V et une intensité max de 2.85A disponible sur connecteur USB A & Jack DC.
Very good quality, perfect linear power supply for high-end USB
I am happy to write a short review of this product. I use this linear power supply for high-end computer audio. It feeds an ifi defender. An ifi ilink USB is attached to it (USB-SPDIF converter). In my opinion, the USB-SPDIF converter benefits from this. The sound is excellent, which is certainly also due to the excellent converter.
The processing of the order and shipping to Germany worked perfectly. Audiophonics works very professionally with very good communication. The power supply arrived very quickly and excellently packaged.
Anytime again. Greetings to France.
Thank you for this great review.
A small correction : Allo Nirvana is a ultra low noise switching mode power supply (not a linear power supply).
Michel h.
delif
Acheté pour alimenter mes amplificateurs Jadis JA 200
Câble Secteur de bonne fabrication, résistant et assez souple pour son diamètre, pas difficile à monter à condition de bien dégager les fils d’alimentation de la garniture en coton et du fil de drain.
Assez mélodieux, pas de dureté, médium aigu un peu descendant, grave ample mais sans excès, spatialisation et dynamique moyenne. Globalement la reproduction est un peu triste, sonne mate et manque, de respiration.
Ce câble peut aller sur des électroniques avec une prédominance du médium, haut-medium, aigu, mais ne convient pas sur mon système.
Michel h.
delifi
Connecteur IEC de médiocre qualité, le serrage des fils n’est pas très efficace et les contacts « à pinces » avec la partie mâle sont de mauvaises qualités, surface des contacts insuffisante, la prise tient très mal.
SCHURTER propose d'ordinaire des connecteurs de qualité, peut-être êtes-vous tombé sur un modèle défectueux ?
Vous pouvez contacter notre SAV afin qu'il procède à un échange.
Rémy V.
Tout simplement Excellent !
Voila une très bonne banane ; Finition de qualité, bien conçue : belle mécanisme de fixation à 2 vis permettant un serrage efficace des câbles (pour une fois les vis ne sont pas trop courtes comme c'est souvent le cas sur de nombreuses bananes même très chères ...). Système de serrage par écartement de la pointe efficace. Pas d 'impact négatif sur la transmission sonore. Je recommande.
Rémy V.
Tout simplement excellent !
Michel h.
delifi
Connecteur secteur de bonne qualité à un prix imbattable, facile à monter, bons contacts. Le principe de serrage du câble est excellent mais rend la prise peu longue.
Lorenzo B.
ALLO DIGIONE PLAYER Lecteur Réseau Raspberry Pi 4 Interface Digitale DigiOne Volumio Pré-Installé Noir Le Allo DigiOne Player est un lecteur numérique avec prise en charge réseau. Il est donc capable de lire vos fichiers audio à partir d'une source distante....
Excellent product
I think this could be the best streamer (and server) for this price point. I came from a GCA and it was good but I need something better and more flexible. I’m totally satisfied.
Câble de grande qualité.
Ce câble est très bien fabriqué. Les prises tiennent parfaitement ce qui assure des contacts impeccables. La souplesse de ce câble est un véritable atout. Cette souplesse permet une installation sans contraintes sur les connecteurs. Par rapport à mon ancien câble Furutech qui coûte près de 2.5 fois plus cher et dont les connecteurs ne sont pas au top il y a pas photo! Pour ce qui est de l'écoute, je constate à nouveau que point n'est besoin de dépenser des fortunes pour obtenir d'excellents résultats. La première vertu a retenir c'est la qualité de fabrication. J'ai fait l'expérience également avec un câble firewire OXAIDE qui coûtait près de 120 € avec des connecteurs absolument indignes par rapport à un câble lambda à 15 €.
Là sans hésitation ce câble a un rapport qualité /prix excellent. N'hésitez pas!!!
Alain A.
Incontournable
Ideal pour fixer le cable de masse d'une platine vinylevsur l'ampli.
Alain A.
FURUTECH FP-900 (G) Embases RCA plaqué Or (La paire) Les embases RCA Furutech ont été développés dans l'optique de satisfaire les consommateurs les plus exigeants. Ces embases sont fabriquées...
Qualite or
La qualite est palpable, montage facile, rca classieuse
Phillip F.
first impression: exceptional value
I bought this on the strength of a very positive review of this module in a DIY application in Archimago's blog.
It took a long time to get it, thanks to the pandemic, but once in stock, delivery was quick and painless.
The unit is self is incredibly small, runs very cool, is dead quiet, and sounds as good as any amplifier I've used. I despise subjective audiophile descriptions, so will merely say that in terms of detail, dynamics and lack of irritation, I can't fault it. It also looks very good (although the "on" light is a bit bright - that is common these days.)
At the price, even including shipping and Canadian tax, it's a phenomenal bargain.
I'm giving it 4 stars because it has to prove its reliability, and also because I would like to measure its performance first.
Bravo Audiophonics!
Alain A.
Super rca
Facile a installer, bien isolees, excellente connectivite.
Mon vieil ampli en bluetooth !
branché pour relier un mac book air à mon vieil ampli sansui et sortir sur des cabasses sloop.
super connectiques, plein de possibilités. le bluetooth fonctionne vraiment bien et est tout de suite reconnu. pas de coupures de sons, c'est top. l'objet a l'air bien construit et solide.
par contre j'ai fait plusieurs comparaisons à partir d'enregistrements différents et grosso modo en mode bluetooth je n'ai pas noté un gain de qualité d'écoute avec le FX MKII par rapport à une simple liaison filaire partant en mini jack de l'ordi à xlr pour l'ampli. Quand l'enregistrement d'origine est bon il reste bon dans les deux cas et inversement lorsqu'il est mauvais.
bon de toute façon je l'ai choisi pour avoir une connection bluetooth lorsque certains jours j'ai la flemme de brancher mes platines ou lorsque j'ai envie d'écouter une musique que je n'ai qu'en dématérialisée et de ce point de vue je suis satisfait.
livraison et infos audiophonics au top ! merci
JANTZEN AUDIO SUPERIOR Z-CAP Condensateur 800V 1µF La gamme Superior Z-Cap de chez Jantzen Audio se compose de condensateurs non polarisés haut de gamme, conçus spécialement pour l'audio afin de permettra...
Parfait l’extrême aiguë
Ce condensateur offre un filtrage très fin et délicat tout simplement musical.
Il exprime l’extrême aiguë sans acidité, agressivité. Je recommande vivement.
Excellent lecteur en sortie analogique
Ce lecteur est tout simplement excellent, ses performances sont évidentes.
Directement connecté à mon ampli de puissance (sans préampli grâce à son potentiomètre intégré) diffuse le meilleur (ou le pire ) de l’enregistrement gravé.
Serge D.
FOUNTEK NEO CD 3.5H Haut-Parleur Tweeter à Ruban 12W 7 Ohm 95dB 1100Hz - 30kHz 9x60mm Fountek innove dans le domaine des hauts-parleurs à ruban en y ajoutant un pavillon. La combinaison de ces deux technologies permet d'obtenir des hautes fréquences d'une extrême...
Sergio
Excellent et conforme à sa description.Beaucoup de précision dans les aiguës au plus fort de sa directivité . Finesse et naturel , peu de distorsions . Une bonne approche bon marché des modèles à ruban professionnels.
Pierre M.
Support casque
L’esthétique et l’ergonomie correspondent à mes attentes. Par contre pour le prix le niveau de finition et le fait que j’ai du le cirer avant de l’utiliser est un peu décevant.
Luc M.
très bon switch. belle qualité, led visible mais pas trop
JOEL C.
ELECTRO-HARMONIX 6H30PI Gold Pin Tube Double Triode (Unité) Le 6H30PI Gold Pin de Electro-Harmonix est un tube double triode. Sa faible résistance de plaque combinée à une excellente linéarité et une...
Remplacement de 2 tubes 6H30 Sovtek
Je viens d'acheter un préampli Audio Research d'occasion équipé de 2 tubes 6H30 Sovtek d'origine. Ces lampes sont sensées durer 10.000 heures. Mon préampli date du début des années 2000 et d'après le précédent et unique propriétaire il l'aurait utilisé moins de 3.000 heures. Mais à l'oreille il ne sonnait pas comme mes autres préamplis Audio Research. C'est la raison pour laquelle j'ai décidé de remplacer les 6H30 d'origine par les EH 6H30PI Gold.
Le résultat est sans appel : mon "nouveau" préampli chante beaucoup beaucoup mieux !
Tout de même un léger bémol : les tubes ne sont pas appairés.
Le tarif Audiophonics est excellent et la livraison très rapide.
Un grand merci !
David G.
Conforme à ce que l'n peut en attendre.
Derek W.
Topping A90
Well-made and compact. Switches have a solid ‘click’ feel. Volume knob is a little shallow in depth and easy to move. Very clean sound with totally silent background.
The power gives my hard to drive headphones (set to ‘Hi’ at 12 O’clock on the dial) a feeling of ease of being driven and more detail. The extra detail was more than I expected.
A90 bought for Bedroom use and initially bought the Topping DX7Pro; good DAC yet I felt struggled with my headphones. Adding the A90 was the answer. DX7Pro as DAC + A90 and amp provides great sound quality and betters my main system which is 8x the price (main system has better DAC yet the combo overall is better). The A90 made the DX7Pro sound better as a DAC I perceived!? (assume a power supply thing!) Also bought the Topping RCA short cables, good value for money and well made. I heard zero differance between RCA and XLR.
4 Stars only as the first unit was supplied ‘dead on arrival’; that said merci beaucoup Audiophonics.fr for the fuss free return and replacement.
Hélas me suis trompé de diamètre. Trop grand
Ces fiches bananes sont nickel
Amélioration sensible du spectre audio.Pus net
Reçu très rapidement
Damon A.
A 'must have'
If you're purchasing the SC-6 cable, the SC-AIR splitter will organize the many individual wire bundles and look really nice. A simple shrink wrap will not look nearly as good. The splitter would otherwise be too big for most other cables.
Damon A.
Hard to beat features.
I purchased four meters of SC-6 for two 2 meter cables. I also got T6s forks, SC-AIR Spliters and Viablue sleeve to complete the set. Ironicaly, Viablue does not sell a 2 meter pair (1.5m, 3m, etc). All were delivered to me in the U.S. without problems.
The features of this cable are as good as anything you'll find, if you like silver-plated OFC copper, air pipes, and litz configurations. Preparing, dressing and terminating the cable will be a long, tedious process because of the cable's complexity. However, it's not difficult at all for the avid DIYer. With that in mind, I think purchasing a 'ready-made' pair would be a better value given the amount of time it takes to prepare it's many individual conductors for termination.
Damon A.
I love these beauties.
Thanks to Audiophonics for fast, trouble-free shipping to the United States.
Two sets of 4 connectors were purchased for use with NeoTech NEI-3004 cable. The connectors were very nicely packaged in a well padded tin, and are of excellent quality. Mounting the cable was trouble free with my ordinary soldering skills. The Audiophonics web site implies the maximum cable size these connectors will take is 10mm. It will actually take much larger which is a huge plus if you like big cables. I would have purchase the 10.5mm NEI-3001 cable if I knew it would fit. It wasn't until I got the connectors that I saw (in the description) it would take up to 13.5mm.
Damon A.
Great Bargain
As always, Audiophonics was excellent with fast, trouble-free shipping. So far all of my orders have been delivered to me in the U.S. with no additional fees or duties.
I purchased four meters of NEI-3004 cable to make two 1 meter balanced pairs. Preparing and mounting the high quality cable was easy using NeoTech NC-06612 XLR connectors. My initial impression is very detailed and neutral sound, as good as any cable I currently have (including recently purchased ViaBlue NF-S6)
Michel p.
Arrivé en bon état, emballage soigné.
Fonctionnement parfait pour l'usage.
Alastair P.
TOPPING D90 DAC Symétrique AK4499 XMOS XU208 I2S 32bit 768kHz DSD512 Bluetooth 5.0 Noir Successeur direct du Topping D70, le D90 profite des mêmes raffinements que son grand frère tout en mettant à jour son DAC vers une version plus...
Compact Gem
This is a very good DAC and significant step-up from my previous DAC. The sound is very clear, detailed and has good dynamics and bass extension, but it will show-up any flaws in your streamer. USB and S/PDIF inputs are both very good. I have not tried I2S and AES inputs or AES output yet.
Catalin I.
Cable Pangea Premier XL 0,5m
Excellent rapport qualité/prix. Je ne suis pas tout a fait convaincu par cette séparation DATA/ ALIMENTATION mais le son est très bon, une très bonne spatialisation et définition.
Hélio R.
Entry level DAC/AMP combo
I've bought this to replace my onboard sound card, on the laptop - it's miles ahead in sound quality. It's good enough to make it possible to hear the difference between low quality MP3 and good ones.
This unit is a excelent entry into this hobby of sound. It's got almost every connection you need at this level: USB, coaxial, optical, and bluethooth 5.0. It also has a RCA output, and that means that it allows you to upgrade in the future, since you could use this unit as a DAC only. And a pretty good one at that too.
The bottom line is, at this price, is not possible to have a better sounding unit. It´s the perfect entry-level unit: it won't ruin the bank even if you don't like the sound of it, and it is a clear upgrade from every pc/laptop onboard sound card.
