Sur un ampli purement symetrique, cet adaptateur confère une sonorite qui semble souffrir d' aucune perte si ce n'...
Régis C.
C'est la classe (D) cet ampli
Première expérience en classe D et je dois dire que je ne m'attendais pas à ça.
Après un excellent Rotel RB 1582 MKII qui...
bernard g.
cablage xlr
des connecteur de bonne facture pour faire des trés bon cable
monté en gamme pour les connecteurs eizz pour faire un cable...
Avis clients - Il y a 20767 avis.
Sasha V.
A cable for life.
I use 2 of these to feed my dac and preamp. They are very well made and seem durable. The cable is a little stiff but manageable. They also helped to reduce the noise floor a little. I think for the money they are brilliant and I can recommend them wholeheartedley.
Clarice C.
AUDALYTIC AH90 DAC AK4499EX XMOS XU316 LAN UPnP Roon 32bit 768kHz DSD512 MQA Argent Le Audalytic AH90 est un DAC proposant d'excellentes performances de décodage et une restitution sonore précise grâce à une conception soignée...
Updated review - Gustard Audalytic AH90
The AH90 is unique: It is the only device that can act as a DAC, Headphone Amo, and Steamer at this price point and this level of quality. The competition does not offer all 3 in one. Furthermore, after and update the unit is able to output to speakers DSD signals natively rather than converting them. That only works to speakers and for the odd recording that is DSD coded, which are rare in the market.
As a professional musician my sensitivities are not limited to volumes but to being able to hear what people do. This unit has been a joy. Regardless of what type of music and musicians are involved I can hear things. Status Quo was famous for changing guitars to create different sounds durng concerts. This unit will let you hear the difference. As an opera singer, the acoustic of a stage like Munich can make you aware of things you do as a singer that you do. Some houses make a musician reach into their bag of tricks. Think of Queen at Wembley and listen to it on a unit like this and listen to it with this unit: made me smile. No tricks of voicing. My previous SMSL bumped up the bass but never sounded as natural.
If you connect it to your LAN for Upnup or Streaming, you may not need a WiiM unit at all. I still own a WiiM Pro but am sure over my internal system the Gustarender software will sound better.
This is a special machine at this price point. It receives my highest recommendation. It has flexibility the Matrix Mini 4 does not have and is way cheaper than buying several machines to do what this unit does a 3 in !.
David n.
TONEWINNER AD-1PA+ Amplificateur de Puissance Class A Stéréo 2x300W 8 Ohm Argent Puissant amplificateur de puissance stéréo Class A, le Tonewinner AD-1PA+ profite d'une architecture symétrique de grande qualité lui permettant de...
Première écoute déconcertante tellement c’est détaillé sur tout la bande passante avec superbe image stéréo tant en largeur (180° sur certains morceaux) qu’en profondeur (+ étagement des plans).
Je retrouve effectivement tous les attributs cités dans l’article de Remusic.
Les instruments / voix se détachent distinctement (effet 3D) dans l’espace sonore.
Les basses sont amples, profondes, moelleuses et timbrées.
Médiums transparents, avec de la matière.
Aigus naturels, fins et cristallins qui semblent flotter en haut du mur du fond sur certains enregistrements.
Le tout dans une cohésion impeccable.
Ampli réactif au secteur (ligne dédiée symétrisée Gigawatt chez moi + terre indépendante) et donc au câble d’alimentation.
Le meilleur chez moi étant pour l’instant un Tunami V2 Shuko Charlin et IEC C004 pour une belle articulation (particulièrement dans le bas), rapidité et neutralité générales.
Sensible également au support (Finite Element Spider dont un avantage est d’être totalement ouvert pour refroidissement naturel)).
Le résultat me satisfait beaucoup (en classe A pure (bien chaud mais sans surchauffe), mais aussi en mode automatique (tiède)) et me fait oublier mes anciens amplis dont un à + de 13000€.
Difficile à accepter ? L’évidence est là pour moi.
Aucune fatigue à l’écoute, au demeurant très agréable et d’autant plus intéressante qu’on peut y percevoir les particularités des enregistrements.
Venant du monde studio pro, j’aurais pu le prendre en ampli d’écoute principale.
Environ 300 heures d'écoute au moment de cet avis, sur Streamer Antipodes EX (Switch ethernet Uptone) + Ayon Stealth en Dac / pré-ampli, et Harbeth M40.2 en HP avec connectique générale (XLR et RCA) Driade Flow 808 et secteur avec Amadeus (panachage FI-E48 et 50R + Charlin). Pièce d’écoute dédiée de 40m2 légèrement traitée en acoustique.
L’aspect résolvant et neutre de cet ampli révèlera la qualité de votre système en amont.
Et comme toujours, superbe qualité / rapidité de service / envoi d’Audiophonics. Bravo !
P. V.
Raphaël B.
Très bons produit, belle qualité, montage facile, serrage optimum, excellent rapport qualité/prix. Dorénavant, je n'achèterais que ce produit.
Raphaël
Jean-Baptiste D.
Très facile. On branche en USB sur un PC, on installe REW ou équivalent sur son PC.....et on a tout ce qu'il faut pour mesure et corriger/améliorer son système....avec un rapport qualité/prix au top et un micro calibré.
Jean-Baptiste D.
Bon ampli FDA - mais
Globalement il fonctionne très bien. Je l'ai utilisé d'abord avec une paire d'enceinte passive (coas tpx musikit). Impec, à la hauteur d'un marantz pm7200 100 fois plus lourd.
Enceinte, j'en ai pris un second et un dsp minidsp pour piloter une paire d'enceinte active....et là ça a été plus compliqué. Un peu de bruit de fond apparent sur tous les HPs et surtout une tenue en puissance très faible. Je soupçonne une sensibilité aux impédances basses (mais HP était des 4 ohm) vu qu'il n'y avait pas de filtres passif, pas de correction de courbe d'impédance. Je vois que ça.
Donc pour utiliser avec une paire d'enceinte passive adaptée à son champ d'application, c'est parfait. Faut faire attention aux utilisations un peu plus exotiques.
Jean-Baptiste D.
Bon ampli fda
Franchement, un rapport son/prix imbattable. Aucun bruit de fond, belle patate, bon son, franchement bien. Je ne suis pas de ceux qui parlent du son d'un ampli comme d'un grand vin. Je n'attends rien de plus d'un ampli que de faire ce qu'on lui demande. Il le fait parfaitement bien tant qu'on reste dans son terrain de jeu.
Jean-Baptiste D.
HYPEX FUSIONAMP FA251 Module Amplificateur NCore 1x250W DSP ADAU1450 DAC AK4454 L'amplificateur Hypex FusionAMP FA251 pourra vous permettre de concevoir une enceinte active une voie ou un caisson sub actif. Celui-ci est basé sur un module NCore...
Pour piloter un caisson
L'ampli fonctionne très bien. Parfait pour un caisson. Tout est parfait, en revanche, pour initiés. L'interface graphique du logiciel permettant de régler le DSP de l'ampli est très complète et efficace....mais on peut pas vraiment dire que l'ergonomie soit son point fort! Avec quelques connaissances en audio ou de l'aisance à fouiller sur les forums spécialisés, on s'en sort, rien d'infaisable.
Jean-Baptiste D.
DAYTON AUDIO RSS210HO-4 Haut-Parleur Subwoofer Aluminium 300W 4 Ohm 86dB 30Hz - 1500Hz Ø20.3cm Intégré à la gamme  Reference Series  de Dayton Audio, le subwoofer RSS210HO-4 reprend à son compte les critères de qualité...
Utilisé pour faire un caisson clos d'environ 12l avec un ampli hypex ncore 250. Parfait, puissant, malléable, ça transfigure une installation avec un grave profond rapide et sans trainage....en effet, il existe très très peu d'enceinte du marché capable de vraiment bien reproduire le grave. Avec ce genre d'HP, c'est possible avec un peu d'effort. Excellent rapport qualité prix
Jean-Baptiste D.
ARYLIC A50+ Amplificateur FDA STA326 WiFi DLNA UPnP Bluetooth 5.0 2x50W 4Ω Le Arylic A50+ est un amplificateur FDA polyvalent et performant, basé sur une puce STA326 et capable de développer une puissance de 2x50W sous 4Ω. Il profite...
En application hifi, très étonnant !
reçu aujourd'hui et installé. Utilisé avec des dali oberon wall.
Niveau amplification, ça fonctionne en gros comme un fxaudio 802. donc ça fait le job comme un fda. Autrement dit, c'est propre, dynamique, ras. Pour ce type d'enceinte à rendement à peu près standard (85dB) avec une écoute à moins de 3m en appartement, ça suffit large. Je serai plus sceptique avec des très haut rendement (léger bruit de fond, aucun pb avec des enceintes à 85db, pas garanti avec des HD à 105db) ou alors pour remplir une pièce de 60m2 avec une écoute à 5m....on peut pas demander la lune à un ampli de 30W sur 8 ohm.
Donc bilan qualité du son, tant qu"on est sur son terrain de jeu c'est parfait.
......mais c'est sans compter sur son ENORME point fort ! ACPworkbench, pour 20€ de licence supplémentaire, on accède à quasi tous les paramètres de réglage du DSP intégré er là c'est un truc de fou. On peut tout faire et en particulier 4 équalisers paramétriques 10 bandes : 1 général, 1 gauche, 1 droite, 1 sortie subwoofer. On peut faire tous les réglages qu'on veut ou presque. Pour peut qu'on ait un peu de savoir faire, un micro, un logiciel de mesure (genre REW), et on peut régler ça aux micro poil. Pour le prix, c'est juste énorme et ça mache du tonnerre. En 10mn, j'ai corrigé le pic vers 200Hz causé par l'endroit ou sont installées les enceintes, coller un pass haut sur les dali et un pass bas sur le caisson maison (HP 22 dayton et ampli ncore250).
Pour l'appli de controle, simple fiable RAS, le pilotage à partir de deezer fonctionne très bien en airplay (attention aux spec, deezer n'est pas intégré à l'ampli, il passe via airplay ou bluetooth). Lecture du contenu d'un nas freebox via l'appli mconnecte sans pb avec protocole upnp.
Bilan final, à ce prix, avoir un ampli fort convenable, facilement connecté via 2-3 applications sur mobile et un dsp complet totalement paramétrable.....c'est Noël !
Damien C.
SMSL C200 DAC ES9038Q2M Bluetooth 5.0 aptX-HD LDAC 32bit 768kHz DSD512 SMSL propose avec le C200 un DAC aussi compact que performant, profitant d'une conception soignée et d'une connectique capable de répondre à la...
Très bon DAC pour le prix
Satisfait de cet achat.
Son clair et précis, construction qui paraît solide, montage qualitatif.
Branché sur un PC Windows 10, sans pilote, avec câble optique (S/PDIF), le tout relié à un ampli Marantz;
Testé aussi avec USB, fonctionne parfaitement (sans pilote);
Appairage Bluetooth sans difficulté.
Seul bémol, le câble d'alimentation électrique très rigide et surtout très court. Sa longueur ne permet pas d'atteindre une prise au sol depuis une console/meuble de hauteur standard. J'ai dû le remplacer par un câble d'alimentation PC classique et identique mais plus long.
Audiophonics : livraison rapide et emballage de qualité; La notice jointe en français n'était pas celle du C200 (mais celle du DO100). La notice originale en anglais est de toutes façons très succincte.
Christian D.
Cable secteur
J'ai réalisé 3 câbles secteur .
1 pour le distributeur secteur AUDIOPHONICS mpc6 v2
1 pour mon lecteur PIONEER PDP LX800
1 pour mon préamplificateur LECTRON PA 50
L’écoute des disques cd est plus détaillée sur tout le registre sonore du grave aux aigus, tout en étant beaucoup plus agréable.
Les graves sont mieux tenus .
Tous les câbles sont équipés de fiches shuko VIBORG VE 502G et connecteur iec VIBORG VF 502G.
Le résultat est très surprenant.
Étant donné le résultat je pense que la version avec les connecteur en argent pur VIBORG VE504AG doit être exceptionnel .
Si quelqu'un désire fabriquer ce câble avec des fiches VIBORG VIBORG VE504AG en argent pur il vaut mieux acheter la version réalisé par AUDIOPHONICS qui est moins chère de 160€.
Si vous avez une bonne chaine ne pas hésiter
Elom G.
Très bon casque pour un usage domestique
Acheté en remplacement de mes akg studio k240, le son est plus doux et plus équilibré (basses, medium et aigus).
Fonctionne correctement avec la sortie casque de mon smartphone, mais c'est encore mieux avec un petit ampli casque (pour moi, le earstudio de Radson).
Attention : c'est un casque ouvert, donc plutôt pour un usage domestique, dans le métro ou dans la rue, le bruit ambiant rend l'écoute assez décevante voire désagréable.
Elom G.
Bon produit, de bonne qualité et bien fini. Je n'avais pas besoin de l'insert, je l'ai acheté juste pour récupérer les pointes de découplage pour une paire de colonnes Elipson Prestige 3.
J'en suis très satisfait.
Excellente qualité générale, mais...
Bons contacts bien francs, câblage intérieur intéressant, on adore l'absence d'interrupteur, de disjoncteur, de témoin lumineux, qui sont des catastrophes pour le son ou l'image. Mais... Rien pour fixer cette belle barrette, ni pattes, ni trous filetés, dommage. Il faudra donc la coller sur son support (Scotch double face ou pâte ou gel). Sinon, les prises auraient pu être un peu plus écartées entre elles, étant donné qu'elles ne sont pas orientées à 45°. Donc certains blocs secteurs condamneront deux prises, dommage.
Câble impressionnant
Bien réalisé, on dirait presque un EAT, un peu rigide mais sans excès,
la fiche murale est surdimensionnée, ça pèse lourd sur la prise et ses contacts, et cela dépasse beaucoup, il faut de la place... Est-ce techniquement nécessaire, ou est -ce une astuce marketing pour impressionner ? Bien moins cher qu'un EAT et le son est propre, les contacts sont francs.
Patrice H.
Excellent sélecteur d entrées RCA
Très bon sélecteur qui a le bon goût de fonctionner dans les deux sens. Selection d'entrée ou sélection d amplificateur de sortie.
Dommage que la sortie et l'alimentation soient en face avant pour l'intégration. Sinon avec la petite télécommande, les sélections sont très faciles.
Gorazd K.
ELECAUDIO DF-03 Gaine Tressée Extensible Nylon (PET) 06-16mm Gaine tressée élaborée en  PET (Polyéthylène Terephtalate)  monobrins pouvant être utilisée dans une large...
Medium quality. I put it on a 3 m cable without much effort, but you have to be very gentle, because the individual threads like to pull out. Probably the price reflects the quality. Otherwise, as always, excellent in terms of packaging and delivery.
Bruno B.
Ouaouh à peine croyable
En remplacement des contrepointes Elecaudio sd25, les Audio Bastion X-PAD + II ont amené une amélioration sonore considérable pour un simple accessoire. Transparence, aération, dynamique sur l’ensemble des fréquences.
Mon vieux système basé sur l’intègré Vincent SV238 couplé à des BW 804 N a pris un sacré coup de jeune.
Merci Audiophonics pour votre habituelle rigueur dans la qualité de vos envois.
Richard C.
ARYLIC BP50 Préamplificateur DAC ES9023P Bluetooth 5.2 aptX HD aptX Adaptive 24bit 192kHz Le Arylic BP50 est un préamplificateur avec fonction Bluetooth 5.2 extrêmement pratique et capable de fournir une belle qualité sonore. Il intègre...
Connecte sur Chromecast audio pour alimenter mc intosh2205je préfère utiliser le dac du Chromecast plutôt que celui de arilic que je trouve agressif.
Cédric F.
Aop qualitatif
Mis en place dans un modeste Aiyima Dac-A5 max acheté à un prix de 69 euros pendant le black friday, les NRJ Muses l'ont transformé. Plus de dynamique, plus de détails, une scène sonore élargie et une écoute naturelle. Il est au niveau d'un Topping E30II, très très proche et difficile de trouver des différences même avec une écoute au casque. Très satisfait du bon qualitatif pour une somme raisonnable.
Cédric F.
Pour une sonorité chaude
Mais en place dans un modeste Aiyima Dac-A5 max équipe d'une puce sabre, le son est devenu chaud, sonorité Burr-brown en somme. Le bas medium à pris de la consistance, le medium bien à sa place et les aigus doux. L'Aiyima est devenu en terme de son proche de mon audio GD avec ses wolfsons. Pas l'aop le plus détaillé mais agréable à écouter.
ATAUDIO SILVER Câble USB-C Mâle vers USB-B Mâle Argent Pur OCC 0.75m Le câble USB ATAudio Silver offre une qualité de fabrication d'exception pour des performances de transmission optimales. Celui-ci se compose de huit conducteurs en...
Très beau câble
La fabrication du câble est vraiment de belle qualité. Sur le plan audio c'est très équilibré du grave à l'aigu. Le rapport qualité/prix est parfait, il ne tombe pas dans le délire des prix totalement déraisonnables de certains câbles.
Service après-vente
Mon alimentation est arrivée avec un petit défaut cosmétique sans gravité. Après une réclamation, Audiophonics m'a immédiatement répondu en me proposant un échange ou un remboursement. On ne peut que les féliciter pour la qualité de leur service après-vente !
Concernant l'appareil, il n'a pas amélioré de façon spectaculaire le son de mon Minidsp mais celui-ci n'est peut-être pas sensible aux alimentations. Je vais l'essayer sur mon Lümin D2!
Audiophonics est réellement une société en qui l'on peut accorder toute sa confiance. Thierry
Laurent z.
LUDIC ORPHEUS Câble Secteur Schuko Type E/F vers IEC C15 Cuivre OCC 6N Plaqué Or 24k Blindé 1.5m Ludic dévoile avec le Orpheus un câble d'alimentation haut de gamme Schuko Type E/F vers IEC C15, utilisant des matériaux de grande qualité afin...
Rapport qualité prix exceptionnel
On en a réellement pour son argent d’abord pour la qualité de fabrication puis pour l’amélioration sonore. Tout reste équilibré en gagnant en silence. Grande douceur sans perdre en définition. Mention spéciale pour le grave complètement libéré mais sans lourdeur. Seul point négatif, câble très rigide. Ne pas hésiter à prendre une petite longueur supplémentaire. Ça aide. Comment d’habitude servie audiophonics au top
Laurent z.
Avis rectifié…
Après 3mois d’utilisation, je les change pour des MULLARD.
J’ai changé les tubes de puissance EL34 PSVANES PH par des TUNG-SOL KT120. Histoire de goûter au deux monde…
Grosse claque quand même ! Les EL 34 ne sont pas à jeter, non non ! C’est une toute autre approche de la musique c’est tout. Je les garde car un jour ça va me démanger de les remettre en service.
Mon intuition me dit que les tubes de préamplificateur introduisent quelques choses dans l’équilibre obtenu. Donc pas d’autre solution que de les changer pour en avoir le cœur net.
Oui mais prendre quoi ?
Il y a tellement peu de littérature sur le sujet.
Ces PSVANES méritent totalement leurs 5 étoiles.
Ce qui les défini le mieux c’est la générosité.
Dans les timbres, dans les harmoniques, dans la puissance.
Le passage sur les MULLARD m’a fait ressentir une perte de puissance.
Par contre je trouve que le mariage avec les tungsol est pas idéal car il fait déborder d’harmoniques en tout genre les tubes de puissance.
Un superbe tube, à considérer sur des associations de moindre puissance.
Laurent z.
XANGSANE XS-A012 Pieds Aluminium avec Pointe de Découplage Cuivre 44.5x34.5mm Argent (Set x4) Les pieds en aluminium XS-A012 de Xangsane intègrent une pointe de découplage réglable en cuivre pur. Ils permettent une absorption des vibrations et des...
Cadeau à ce tarif
Découplage efficace immédiatement perceptible sur mon ampli à lampes et très pratique à positionner. À ce tarif rien à ajouter
Laurent z.
PANGEA PREMIER XL BALANCED Câble de Modulation Symétrique XLR-XLR Cuivre Cardas 1.5m (La paire) Ce câble de modulation XLR vers XLR Pangea Premier XL Balanced jouit d'une fabrication exceptionnelle. En effet, il est  composé de brins en...
Belle surprise
Ce câble n’est pas donné mais qu’est-ce qu’il est bon…. Équilibré, défini, doux mais pas éteint. Une belle ampleur de la scène sonore et…. quel poids sur les notes. J’adore l’album de Liane Foly « Crooneuse » mais parfois un peu sec voire dur, et la ça passe tout en fluidité. Vraiment très musical. J’adore…… et comme d’habitude service audiophonics au top
Laurent z.
LUDIC AESIR Câble secteur Schuko IEC C15 Cuivre UP-OCC plaqué Or 2m Le Ludic Aesir est un câble d'alimentation de grande qualité. Il intègre en effet des conducteurs en Cuivre UP-OCC Drawn® brevetés, permettant...
Vous pouvez reprendre le commentaire que j’ai posté pour pour le aesir mais encore plus silencieux et un peu plus « nerveux « . Bande passante impressionnant dans le grave.. J’adooooore
Laurent z.
LUDIC AESIR Câble secteur Schuko IEC C15 Cuivre UP-OCC plaqué Or 1m Le Ludic Aesir est un câble d'alimentation de grande qualité. Il intègre en effet des conducteurs en Cuivre UP-OCC Drawn® brevetés, permettant...
Pascal A.
Attention, l'enveloppe extérieure est très souple et tendre. Elle se denude très facilement. Allez y doucement. Sonorité neutre, bonne transparence.
Alex C.
Very good quality but it affects the sound. I prefer the cooper version.
Alex C.
good quality box
good quality box
Marc F.
Parfait même en bi-câblage !
Effectue la jonction, en bi-câblage, entre un ampli AUDIOPHONICS MPA-S125NC et des enceintes B&W 707 S3. Les connexions sont en mode banane VIBORG. Les matériaux composant ce câble sont de grande qualité, souples, agréables au toucher et faciles à travailler. Au final, la qualité sonore est également parfaite en 4 longueurs de 2.5m. Le tout pour un tarif très contenu. Que demander de plus ?!
Marc F.
Parfait même pour enceintes paresseuses (84db) !
J'ai choisi ce 2x75W/8Ohm pour alimenter, en configuration bi-câblage, des Bowers & Wilkins 707 S3 à faible sensibilité (84db). La préamplification est confié à un FX-AUDIO Tube01. J'en ai également profité pour remplacer mes très vieux câbles d'enceintes et passer de 2x2mm2 à 2x2x4mm2 en ELBAC. J'ai souhaité optimiser et écouter différentes sources plusieurs semaines durant avant de poster mes avis sur ces matériels. La différence de rendu est toute à l'honneur de cette nouvelle configuration : l'ensemble du spectre sonore est devenu très intelligible, la dynamique est formidable et mon nouveau système se joue des fortissimo et grosses masses orchestrales ! Cet ampli de puissance joue parfaitement son rôle en restant très transparent et ne faiblissant en aucun cas. Je n'ai détecté pour ma part ni sifflante dans les aigues, ni "ploc" à la mise sous tension, ni quelque autre défaut que ce soit. C'est du tout bon, je recommande !
Marc F.
TB qualité, fait parfaitement le job
Achetée pour alimenter le préampli FX-AUDIO Tube01. Une alim classique qui respire la qualité et "assurera" sans doute durant de longues années !
Marc F.
TB mais pas parfait avec équipement natif
Converti à la préamplification à tubes par un intégré hybride 'Qinpu Q2', je souhaitais pour mon système principal (salon) acquérir un préamplificateur séparé et lui adjoindre un ampli de puissance. J'ai opté pour ce 'petit' FX-AUDIO en me fiant aux commentaires des précédents acquéreurs. Après installation initiale, le tout 1er essai fut peu convaincant car les tubes d'origine étaient manifestement défectueux. Ceci étant, n'ayant pas l'intention de les garder, j'avais pris soin de commander aussi une paire de tubes GE 5654 et le rendu a changé du tout au tout. Depuis, j'ai trouvé des 'Mullard CV4010 UK' qui sonnent encore mieux : plus de clarté et de précision, tout en conservant la rondeur du tube. Il me reste encore à remplacer le potentiomètre d'origine par un Log et tout sera parfait ! J'enlève cependant une étoile à cause des tubes et du potentiomètre d'origine qui obligent à 'mettre les mains dans le cambouis'.
Marc F.
TRIANGLE S01 Pieds d'Enceintes (La paire) Les pieds d'enceintes Triangle S01 ont été pensés pour vous permettre de positionner vos enceintes bibliothèques de manière optimale. Avec une...
TB rapport Q/P
J'ai heureusement trouvé ici ces pieds d'enceintes à un tarif très convenable. En effet, les pieds "propriétaires" assortis spécialement (paraît-il) à mes nouvelles enceintes étaient "proposés" pour une somme six fois supérieure...
Le design est très bon, le montage aisé et la stabilité sur pointes + contre-pointes reste plus que correcte.
Ces contre-pointes reposent sur des plateaux en bois de 25mm d'épaisseur qui isolent du sol et positionnent le plateau supérieur à 66cm sur la verticale, ce qui est idéal pour mon modèle d'enceintes bibliothèque.
Un conseil : enlevez tout objet pouvant se trouver à 60cm (voire plus) autour de ces pieds ; le rendu sonore n'en sera que meilleur !
Bogdan Alexandru Z.
Recommendation
For those who don't believe in a major change in the sound of your system, I suggest you try this splendid cable. I don't want to go into subjective explanations about the values ​​of the cable, I just honestly recommend testing it and I'm sure you won't regret this upgrade. Unfortunately, not it's a cheap cable but totally worth every cent
jevgenijs S.
An excellent quality caps.
Have replaced elecaps on my speakers crossovers and the difference is night and day. Crystal clear mids and highs. All in all very satisfied with my purchase.
jevgenijs S.
JANTZEN AUDIO ELECAP Condensateur Électrolytique 100V 100µF 5% Les condensateurs électrolytiques Jantzen Audio EleCap sont des condensateurs aluminium non-polarisés utilisant une feuille gravée ou "brute". Avec une...
Great elecap
Significantly improved the quality of base in my speakers..
Thomas B.
MISSION ACCOMPLIE !
Postulat de départ, m'équiper pour à peu près1000 € max ce qui est déjà une somme pour sublimer et profiter de la qualité audio de mes abonnements DEEZER et QOBUZ via ROON ce depuis mon PC, ayant la chance d'avoir une connexion internet stable.
Pour le DAC choix porté sur un EVERSOLO Z6 que je trouve génial, ça s'installe en 5 minutes téléchargement du driver inclus, mais dont la sortie casque n'est pas fameuse avouons le...Alors pour améliorer tout ça choix porté sur ce "petit" appareil...Et ça apporte vraiment un plus ! Le mariage entre ces deux appareils fonctionne parfaitement bien. Là encore simplissime d'installation, on branche sur le courant, on branche son câble RCA et roula ma poule. Difficile pour moi qui ne suis en rien spécialiste de décrire une qualité sonore, mais le résultat est bluffant surtout après quelques temps d'écoute, le fameux rodage ! Pour qui veut caresser le monde audiophile sans "trop" se ruiner, allez-y ! Il ne me reste qu'à me rapprocher de l'équipe AUDIOPHONICS pour me conseiller un casque de qualité pour compléter l'ensemble de ma petite installation qui pour moi me convient parfaitement. Bref bravo !
Sebastien C.
EVERSOLO DMP-A8 Lecteur Réseau AK4191EQ AK4499EX XMOS XU316 WiFi DLNA AirPlay Bluetooth aptX HD LDAC 32bit 768kHz DSD512 Eversolo  revient cette fois-ci avec son  DMP-A8 , un  lecteur réseau et DAC  de très haute qualité et d'une incroyable...
Tout d'abord 5etoiles à audiophonics qui m à expédié le dmp-a8 à peine arrivé dans leurs locaux.
Le dmp-a8 remplace efficacement chez moi topping pre90 et dac d90 et ifi stream.je gagne en dynamique les médiums se sont réveillé tout c est équilibré aujourd'hui. En bref chacun son oreille mais sur mon système cet appareil fait des merveilles ! Donc 5etoiles sans esiter au vu du prix
Jean-Pierre B.
J'ai constitué un jeu de câbles XLR droite gauche avec quatre fiches ETI KRYO XLR (deux males et deux femelles en rouge et noir) pour relier en symétrique un ampli audio GD A1 avec un DAC MATRIX X-Sabre Pro MQA. J'écoute principalement des fichiers Qobuz suréchantillonnés en DSD 64.
Le montage n'est pas très compliqué : trouver le schéma de câblage sur internet ne pose pas de problème et la soudure du câble sur les fiches non plus à condition de savoir souder (j'ai fait appel à un pro). J'au utilisé de la soudure MUNDORF SUPREME Étain à Souder Soudure Argent 10% qui me paraît adaptée.
Comme j'ai aussi des fiches bananes ETI KRYO pour le raccordement des enceintes, l'ensemble des prises à l'arrière de l'Audio GD A1 est esthétiquement homogène.
Conclusion : avec ce câble et les fiches ETI KRYO on obtient un très bon et beau câble pour un prix qui est dans la moyenne du marché à ce niveau de qualité.
A noter la qualité de service d'Audiophonics qui est toujours très réactif et expédie immédiatement les produits quand ils sont mentionnés comme étant en stock.
Jean-Pierre B.
ETI KRYO Connecteur XLR Femelle 3 Pôles Cuivre Tellurium Plaqué Argent Ø12mm (La paire) Ces Kryo de ETI sont des connecteurs XLR femelles haut de gamme conçues avec des composants d'exception. On y retrouve des contacts en Cuivre Tellurium avec un plaquage...
Très bons connecteurs XLR
Après avoir changé mon intégré Marantz Amp1 par un couple Audio GD A1 et DAC Matrix X-Sabre PRO MQA, j'avais câblé les enceintes sur des fiches bananes ETI KRYO qui me donnent toute satisfaction. J'ai acheté quatre fiches ETI KRYO XLR (deux noires et deux rouges en male et femelle) , pour relier le DAC et l'ampli.
Les fiches à l'arrière de l'Audio GD sont homogènes et l'ensemble fonctionne bien avec une amélioration du son sensible après rodage.
J'écoute principalement des fichiers audio issus de Qobuz, avec un rééchantillonnage en DSD 64 qui est particulièrement agréable avec Audivarna et le DAC Matrix. Le câble USB est un OYAIDE Continental 5S également pris chez Audiophonics (décidément) et qui est aussi de très haute qualité.
Au niveau montage, j'ai fait câbler ces fiches avec un câble NEOTECH NEI-2001 soudé avec de la soudure MUNDORF SUPREME Étain à Souder Soudure Argent 10%. Rien de spécial à signaler (je travaille avec un artisan qui est un excellent soudeur et qui a fait le travail pour moi). Le schéma de câblage n'est pas fourni mais se trouve facilement sur internet.
A l'écoute : aucun problème à signaler sauf nécessité de quelques dizaines d'heure de rodage.
Laurent C.
Exceptionnel !!!
J'utilisais la version cuivre argent or sur un elecaudio cs-361b, ampli marantz enceintes focal aria926 et je la trouvais pleines de qualités mais elle avait tendance à atténuer la chaleur du marantz et accentuer le défaut des mogami w3103 dans le haut médium. J'ai commencé sur la pointe des pieds à remplacer seulement l'iec en basculant sur le rhodium... immédiatement un effet audible, alors que jusqu'à présent je trouvais que les iec n'avaient pas grande influence. J'ai donc commandé le schuko VE512R et là dès les premières écoutes, plus d'amplitude, de douceur autant de profondeur qu'avec la version or, des basses qui claquent et chaleureuses... Le top ! Pour avoir essayé les 3 versions de viborg, je dirais que le rhodium est un savant mélange des 2 autres modèles. Douceur et chaleur du VE501 pur cuivre et dynamisme et profondeur du VE501G. Vraiment exceptionnel, sachant que les défauts que j'avais ont été gommé.
Thierry W.
ORACLE II 01 AOP Discret Simple DIP8 (Unité) L'AOP simple Oracle II 01 représente une nouvelle génération d'amplificateur opérationnel discret hybride, spécialement conçu pour des...
Utilisé en remplacement d'OPA627 déjà très bon, juste pour voir vu le prix très abordable et là c'est la révélation. Si vous aimez le grave, vous allez être servi ! Ça ajoute un sub ! Le reste est comparable au 627. Donc que du bonheur. A testé dans tous les cas...
Monter dans un lecteur CD Burmester 939
jean paul R.
AUDIOPHONICS Câble d'Alimentation Jack DC 5.5/2.1mm vers GX16 Cuivre OFC pour Alimentations Audiophonics LPSU100 1m Ce câble d'alimentation Audiophonics, assemblé en France dans nos ateliers, se compose d'une part d'un connecteur Jack DC 5.5/2.1mm et d'autre part d'un connecteur...
Excellent Rapport Qulité/Prix
Beau produit, bien protégé et expédié rapidement. Utilisé pour connecter l'alimentation régulée au miniPC
