Soldering tin - Mundorf Silver-Gold 4% (2 meters)
Soudure Mundorf Argent-Or 4% (2 mètres)
4.9 / 5
Reference : 3201
8,50 €tax incl.
7,08 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
Tin soldering silver 10% Mundorf
Silver solder 10% Mundorf - 11.7g
Caution : this is a partial packaging. By ordering this product you will not receive the full coil shown on the picture, but a part (2m / 11.7 of it). You can get the full coil here .
Mundorf's SilverGod Msolder welding wire is composed of 0.7% silver and 0.038% Gold. It is indicated for advanced projects that require superior conductivity (mounting tubes, cable assembly, silver / gold foil). The rare metals content is balanced by a flux ratio of (2.2.3).
Caution, melting point is 217 °C / 422°F, which implies the need of a good soldering iron.
TypeWelding wire
Conditioning11.7g / 2m
Wire Diameter1mm
Flux2.5% 2.2.3
Melting point217°C / 422°F
Composition
S-Sn95.50%
Cu0.70%
Ag9.50%
the0.04%
12 reviews
Bonne qualité
Bon produit.
Il faut juste bien respecter la température de fusion pour
de belles soudures
This review has been posted for Soldering tin - Mundorf Silver-Gold 4% (2 meters)
Un charme
Un réel plaisir que de souder avec ce fil pour autant que votre fer chauffe suffisamment (point de fusion 217°C)
Très bien.
Facile à utiliser qualité Mundorf , je n'ai pas envie d'essayer autre chose.
soudure mundorf argent or
très satisfait de ce fil de soudure, bonne adhérence
utilisé avec fer 60w
Best solder
By far the best solder I've used. Flows very well without the need for additional flux.
