LITE LS56 High Voltage power supply for tube circuit 2x15 + 2x200-400V
LITE LS56 Alimentation HT pour circuit a tube 2x15 + 2x200-400V
Reference : 5895
99,00 €tax incl.
82,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
LITE LS56 Regulated Power Supply for Tube Amplifier
This card allows to obtain 4x regulated voltages for the supply of a tube amplifier.
It has 2 separate low-voltage circuits, which accept an AC voltage of 13 to 18VAC, for a controlled output adjustable from 6.3 to 15V
CThis regulation is carried out using a pair of LM 317K.
Two high voltage circuits are also available to obtain a regulated voltage adjustable between 200V-400V DC (TIP50)
It will be necessary to adapt the voltage of the transformer to the voltage and the current that you want to obtain at the output.
For 300VDC at output, we recommande a 330VAC transformer, to get around 100V drop-out.
  • Output voltages:
    • 2x 6.3 to 15V DC (1.5A)
    • 2x 200 to 400V DC (100mA)
  • Dimensions: 230 x 155 x 50mm
  • Board delivered without manual
https://www.audiophonics.fr/images2/5895/5895_LITE_LS56_1.jpg
https://www.audiophonics.fr/images2/5895/5895_LITE_LS56_2.jpg
https://www.audiophonics.fr/images2/5895/5895_LITE_LS56_3.jpg
InputScrew terminals
OutputScrew terminals
Output voltage (V)12.0
Output voltage (V)290.0
Output voltage (V)210.0
Output voltage (V)380.0
Output voltage (V)8.0
Output voltage (V)310.0
Output voltage (V)240.0
Output voltage (V)400.0
Output voltage (V)11.0
Output voltage (V)330.0
Output voltage (V)15.0
Output voltage (V)260.0
Output voltage (V)14.0
Output voltage (V)350.0
Output voltage (V)9.0
Output voltage (V)280.0
Output voltage (V)200.0
Output voltage (V)370.0
Output voltage (V)230.0
Output voltage (V)300.0
Output voltage (V)220.0
Output voltage (V)390.0
Output voltage (V)10.0
Output voltage (V)320.0
Output voltage (V)250.0
Output voltage (V)13.0
Output voltage (V)340.0
Output voltage (V)7.0
Output voltage (V)270.0
Output voltage (V)6.3
Output voltage (V)360.0
Output current (A)0.1
Output current (A)1.5
Input voltage (V)15.0
Input voltage (V)17.0
Input voltage (V)14.0
Input voltage (V)16.0
Input voltage (V)18.0
Input voltage (V)13.0
Power SupplyRegulated Linear Power Supply
Mille merci
Chapeau bas à l'équipe d'audiophonics qui m'ont envoyé cette carte en urgence pour remplacer un autre kit dont les composants n'était pas les bons (ce qui n'est pas de leur faute mais du constructeur). Grace à vous je peux travailler ce week end, merci pour ce geste! La carte est de grande qualité, je la recommande vivement. Bonnes fêtes! Julien
This review has been posted for LITE LS56 High Voltage power supply for tube circuit 2x15 + 2x200-400V
