LJ L20 V10 Amplifier boards 200W 8 ohm mono (Pair)
LJ L20 Modules Amplificateur 200W 8ohms mono (La paire)
4.7 / 5
Reference : 8703
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 02-05-2024.
Shipping from France
Billing in France
Technical support in France
Amplifier modules LJ L20 V10
This model is the most advanced amplifier in the L20 range. These high precision dual mono amplifier modules support 200 W at 8 ohms. They are sold in pairs to compose oriented high-fidelity monobloc systems as well as in separate devices.
Their modularity, their easy implementation and their impressive performance make them a ideal choice for any stereo amplifier project in double mono or for the realization of multichannel amplifiers.
An aliminum square is already integrated into the circuit. The latter facilitates the installation of the module on a dissipator (essential precaution for the use of this module).
THD +N<0.0015% 50W 8Ω
SNR+99dB
Gainx34
Input sensitivity1.9V (@ output 200W 8Ω)
Power supplyde +/-12V à +/-65V DC
Power / power supplyalim +/-65V DC : 200W 8Ω
alim +/-55V DC : 300W 4Ω
alim +/-60V DC : 350W 4Ω
Output DC Voltage<15mV
Max intensity output15A
Damping factor2000+
Quiescent current10mA
Frequency response20HZ-20K HZ +-0.05 DB
Dimensions110 x 97 x 27mm
Packagingx2 modules
InputScrew terminals
OutputPCB Connector
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipN/A
Power (W)300.0
7 reviews
Bon module
Très bon module. Très transparent, belle bande passante et amplificateur vivant. Ne pas hésiter à mettre une très belle alimentation pour en profiter pleinement.
This review has been posted for LJ L20 V10 Amplifier boards 200W 8 ohm mono (Pair)
restaurations ampli
très satisfait
restaurations ampli
très satisfait du double module simple à mettre en œuvre
Perfect
Ik heb reeds 3 versterkers gekocht. Kwalitatief boven het gemiddelde, mooi ontwerp, gemakkelijk te monteren, specificaties kloppen. Prijs kwaliteit zeker OK.
facile a mettre en place
le module est très simple a mettre en oeuvre, pour moi le projet était de remplacer les amplis sur des enceintes penta bang & olufsen 150W sous 8 ohm. bon ça marche mais un gros manque de profondeur et bass a la sortie, les 200w sous 8 ohm de l'ampli semble être non des percherons mais des poneys. cependant le kit reste sympa et simple et de bonne qualité sur les soudures et les composants.
