AUDIO-GD DAC-19 2016 PCM1704UK & DSP I2S HDMI 24bit 192kHz TCXO
Audio-GD DAC-19 PCM1704UK & DSP I2S 24bit 192kHz 10th Anniversary Edition
This Audio-GD DAC-19 Edition 2016 incorporates a PCM1704UK converter for high-quality sound reproduction, as well as many advanced technologies.
KEY POINTS:
  • DAC PCM1704UK
  • 24bits 192kHz
  • I2S via HDMI
  • TCXO
  • ACSS
By buying this product you get 88 loyalty points
Reference : 10513
889,00 €tax incl.
740,83 € tax excl.
Including 1,00 € for green tax
Shipping from France
Billing in France
Technical support in France
Audio-GD DAC-19
DAC / DSP & I2S / 24bit 192kHz
Audio-GD DAC-19
Performances and rich musicality ...
After the DAC-19 in 2005, DAC-19SE in 2006, DAC-19MK3 in 2008 and DAC-19DSP in 2010, here is the DAC-19 PCM1704UK in its latest version.
Even if Audio-GD had already given it its nobility since 2005, the best technical engineers of the firm offer it here in its most accomplished form, with performances reaching a level that very rarely equaled.
This HiFi analog digital converter with recognized and approved results, received a Qobuzissime from Qobuz , excuse the bit!
Rear Audio-GD DAC-19
A particularly efficient connection
The integrated PCM1704UK converter allows you to manage sources up to 24Bit / 192kHz via the I2S. The DAC-19 has 4 inputs: BNC, RCA, Toslink Optics, and HDMI (I2S), as well as 2 outputs: RCA and ACSS.
Its SPDIF interface is extremelyperformance in data processing for better audio quality.
Arrière Audio-GD DAC-19
Great musicality and exceptional dynamics
24bit / 192kHz / I2S / HDMI / TCXO
Every product of the brand is scrupulously tested in all seams with one of the most powerful systems in the world: the Audio Analyzers 2700 Series from Audio Precision.
The DAC-19 is equipped with an R-Core transformer, WIMA capacitors, and Date resistors. It is designed around the PCM1704UK and the Altera Cyclone DSP that work in parallel, as well as a Class A ACSS discrete circuit without any PDO with separate power supply.
Audio-GD DAC-19
TCXO 100MHz
TCXO - 100MHz
Usually the Audio-GD devices are equipped with the standard 80MHz clock, except this Audio-GD DAC-19 includes the 100MHz TCXO Ultra Low Jitter option.This TCXO (Temperature Compensated X (Crystal) Oscillator) clock is more precise and significantly reduces the jitter.
PCM1704UK
This analog digital converter makes use of the R2R conversion which consists in directly using the bits of the digital signals to reconstruct the analog signals, all this acting on a network constituted solely of resistors having a given value (R) and its double (2R ), without going through an over-sampling phase.
PCM1704UK
SNR <108dB
THD <0.0005%
Frequency Response 20Hz - 20kHz (-0.5dB)
Max Output Level 2mA (ACSS) / 2.5V (RCA)
Input sensitivity 0.5Vp-p (Coaxial, 75Ω) / 19dBm (Optical)
Sampling ratesupported I2S up to 192kHz / Coaxial up to 96kHz / Optics up to 96kHz
BNC / RCA / Toslink optics / I2S via HDMI
ExitsRCA / ACSS
Miscellaneous
Consumption16W
Weight5kg
Housing material100% Anodized aluminum
Dimensions320 x 240 x 80mm
AccessoriesPower cable
This Audio-GD DAC-19 Edition 2016 incorporates a PCM1704UK converter for high-quality sound reproduction, as well as many advanced technologies....
