OLFLEX 110CY Power cable shielded 3x1.5mm² Ø9mm
OLFLEX 110CY Câble Secteur Blindé 3x1.50mm² Ø 8.0mm
4.0 / 5
Reference : 4633
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
câble au mètre
Olflex 110CY
Olflex 110CY Câble secteur blindé 3x1.5mm² Ø8mm
Area of application:
Connecting cables of this type are used wherever electrical interference fields can affect signal transmission, e.g. in the presence of electric motors with static frequency converters. This provides electronics engineers with a cable for both low and high currents that allows the transmission of signals with minimal external interference. In high-current applications, these screened cables are used to prevent interference effects from the cable network from spreading to the outside.
Special feature:
The shielding braid made of tinned copper wire combines functionality and aesthetics of the cable (transparent sheath). It is characterized by high performance and low coupling resistance (max. 250 ohms/km at 30 MHz).
Constitution :
Fine-stranded conductors made of bare copper, conductor insulation made of special PVC, layered assembly, color-coded conductors, stuffing box made of special PVC mixture. Shielding braid made of tinned copper wire, transparent protective sheath made of special PVC mixture, flame retardant (IEC 332.1).
Remark:
The special PVC P 8/1 conductor insulation is tested at a voltage of 4 kV to ensure a high level of safety. From 1.5 mm² cross-section, this cable is suitable for a nominal voltage of 450/750 V. This product complies with the 73/23/EEC directive ("low voltage directive")
Type de produitCâble secteur
Section3x1.5mm²
DiamètreØ9mm
ConducteursCuivre
IsolantPVC
BlindageTresse de Cuivre
Plage de température-40°C / +80°C
Tension d'essai4000V
CouleurArgent / Gaine transparente
ConditionnementVendu au mètre
Diameter (mm)9.0
Length (m)Sold by length
Number of conductors3
Insulation materialPVC
ShieldingYes
Section (mm²)1.5
ConnectorN/A
Ground / ShieldingYes
21 reviews
Cablage tv
J'ai utiliser ce câble avec une schuko premier prix et une ferrite pour recabler ma TV. L'imaGe est plus nette et les couleurs plus vives.
This review has been posted for OLFLEX 110CY Power cable shielded 3x1.5mm² Ø9mm
les gaines n ont pas de couleur différentes
Dans mon exemplaire toutes les gaines sont noires. Ce n est pas compliqué de retrouver qui est qui mais ca oblige à une mesure de continuité et un marquage perso...
Rapport Prestations / Prix imbattable
Je l'ai utilisé en 3x 2,5 mm² pour mes amplificateurs est barrettes secteur et j'en suis ravi.
J'utilise la version 3 x 1,5 mm² pour les sources.
Je connecte la tresse de masse du blindage uniquement du coté de la prise Schuco en entrée des câbles. Permet de réaliser à prix très contenu des câbles qui sur mes installations fonctionnent aussi bien que des cordons de marque à 400 €.
Bon rapport Qualité/prix.
Simple et de qualité.
Montage connecteur Schuko Type E/F 250V 16A Ø8mm Noir à 2€.
Avec du câble OLFLEX 110CY 3x1,5mm² et un connecteur IEC C13 à 3€. Pour remplacer les fiches d'origines (en 0,75mm²) de mes deux amplis (Denon DRA800H et Cambridge CXA80) Fonctionne parfaitement.
Première commande depuis la Belgique et pas la dernière.
Un très bon câble
J’ai essayé plusieurs marque de câble secteur Cette marque olflex est un très bon choix mon système c’est trouvé comme vitaminé le son est plus ouvert plus détaillé
C’est le meilleur rapport qualité prix que j’ai trouvé
A recommander les yeux fermés il remplacera avantageusement les cordons d’origine fourni avec vos appareils
