SOMMERCABLE MERIDIAN SP240 Speaker Cable OFC Copper 2x4mm Ø9.5mm
SOMMERCABLE MERIDIAN SP240 Câble HP Cuivre OFC 2x4.0mm² Ø9.5mm
4.3 / 5
Reference : 2077
5,20 €tax incl.
4,33 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
https://www.audiophonics.fr/images2/783/MERIDIAN_SP240.jpg
SOMMER CABLE - Meridian SP240
When it is a matter of will or force ...
they are the acousticians in action - and they do not go there with the dead hand, because they often do not have the time to take a lot of precautions. These rugged drivers are specially designed for loudspeakers andall the technical qualifications required. The cores are made of low oxygen copper, for a better tone and a long life.
TAll types of cables are easily rollable. The SP215 and SP225 versions are equipped with very flexible cores composed of 0.15 mm diameter copper strands.
Test AUDIO 1/2005 SUPERIOR CLASS value for money VERY GOOD
Excerpt: "Compared to other hi-fi drivers, it is more precise, accentuates the dryness of the gravel but refrains from any kind of harshness"
"The Meridian by SOMMER Cable is always interesting because of its price. It is easier to install and better suited to amplification. Its electronic characteristics allow very long distances: good and universal! ".
ADVANTAGES:
  • Flexible (PVC versions only) and easily rollable
  • Minimum external diameter, usable with almost all common connectors
  • Very long life due to the special PVC mixture
  • Discrete installation (dark gray sheath)
  • Very good price
USE:
  • Various acoustic installations
  • Fixed installations
  • Wiring for hi-fi systems
Specifications:
Constitution(2LIY4,0mm2) Y
diameter 9.5 mm
AWG12
Number of Conductors2 x 4.0 mm2
Envelope material, insulation PVC
Copper strands per core 56 x 0.30 mm
Conductor insulation, diameter 4.2 mm
Operating temperature min. -30 ° C
Operating temperature max. 70 ° C
Fire resistance per m 0.46 kWh
Weight per m150 g
Color of envelope, PVCdark gray
Packaging unit, packing unit 100/500 m
Electrical Specifications:
Capacitymetric cond./cond. 125 pF
Odometer Resistance, Conductor<4.5 Ohm
Resistance, insulation> 5 MOhm
Diameter (mm)9.5
Length (m)Sold by length
Number of conductors2
Insulation materialPVC
ShieldingNo
Section (mm²)4.00
Ground / ShieldingNo
3 reviews
passable
Câble surprenant, avec des bas médiums brouillons et très en avant, le haut du spectre est plus précis mais trop montant l'ensemble reste déséquilibré. Pourrait peut être convenir à un système trop plat!
This review has been posted for SOMMERCABLE MERIDIAN SP240 Speaker Cable OFC Copper 2x4mm Ø9.5mm
Bon câbles, robustes et souples a la fois, satisfait entièrement mes attentes.
Accompagné d'un gaine nylon ils font sensation! Que dire de plus a part que le rapport qualité prix est excellent!
Pour ma part j' utilise ce cable en bi-cablage.
Pour le grave: le SP240 Diametre 4, brins de 0.30
Pour le medium aigu: le SP225 Diametre 2,5, brins de 0.15
Ainsi pour un prix modique nous avons un cable de trés bonne qualité...
Bien que ce sont des cables trés simples, ils leurs faut une bonne trentaine d'heures de rodage, aprés, que du bonheur..
