SOMMERCABLE GOBLIN Male Jack 3.5mm to Female Jack 3.5mm Extension Cable 5m
SOMMERCABLE GOBLIN Rallonge JACK 3,5mm M - JACK 3,5mm F 5m
3.5 / 5
Reference : 4649
26,90 €tax incl.
22,42 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
Jack 3.5mm stereo extension cable built on the Sommercable Goblin cable, which is distinguished by its thinness and flexibility, as well as its sophisticated shielding providing high resistance to crushing and traction.
Black cable, very sober, ideal for a professional use in studio, or within the framework of a private installation which one wishes discrete and powerful. Jack 3.5mm Hicon 3-pole stereo connectors plated with 24k gold with locking system.
https://www.audiophonics.fr/images2/4648-4652_SOMMERCABLE-GOBLIN-JACK3.5M-JACK3.5M_1.jpg
Characteristics:
  • Flexible cable with an external diameter of 4.6mm
  • High tensile strength due to its double shielding and special PVC sheath
  • High linearity of acoustic retransmission due to the composition of the conductor pairs and the special wiring rechnique of the copper cables
  • 100% Shielding (Metallized strip + copper helical coil)
  • 24k Gold Plated Jack 3.5mm Hicon connectors
  • Total length : 5m
Specifications:
Constitution(2LI2Y0,14mm2)(ST)DY
Outer sheath / DiameterPVC / 4,6mm
Section26
Conductors2 x 0,14 mm2
Number of strands per core18 x 0,10 mm
Conductors insulationPE 0,92 mm
ProtectionTinned copper helical coil + metallized strip
Optical covering100 %
Operating temperature rangeMin. -30 °C / Max. 70 °C
Fire resistance / m0,10 kWh
Conductor/Conductor metric capacitance65 pF
Conductor/Screen metric capacitance120 pF
Conductor kilometric resistance< 148 Ohm
Shielding kilometric resistance30 Ohm
Insulation kilometric resistance> 1 GOhm
https://www.audiophonics.fr/images2/4648-4652_SOMMERCABLE-GOBLIN-JACK3.5M-JACK3.5M_2.jpg
Length (m)5.0
ShieldingYes
Section (mm²)0.14
ConnectorJack 3.5mm
2 reviews
câble de bonne facture, les connecteurs sont de bonne qualité, pas de problème de parasite ou autre.
This review has been posted for SOMMERCABLE GOBLIN Male Jack 3.5mm to Female Jack 3.5mm Extension Cable 5m
Câble apparemment de bonne qualité mais les connecteurs eux sont très mauvais; j'ai un mauvais contact dans la prise femelle sur la voie gauche "câble neuf"
Après démontage de la protection plastique j'ai constaté des soudures d'amateurs.
Je conseil pas.
