LITE DAC-AE DAC Converter PCM67U I2S to Analog
LITE DAC-AE Convertisseur DAC I2S vers Analogique
Reference : 5749
39,00 €tax incl.
32,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
This component-based converter BB PCM67Uis intended to replace the original elements in your Audiophiles set-ups.
Particularly intended to replace the original component in a CD deck, it finds its place thanks to its ease of implementation in any type of DIY projects.
Components:
  • BurrBrownPCM67U, better than (PCM1710, PCM1716, CS4390 and SM5871)
  • R-2R circuitfor 18bit PCM conversion
  • YAMADA filter IC: YM3433, including oscillator
  • KSS Japan(VCO, voltage control)Jitter extremely low
  • Oscillator: CXO-043C, jitter within 10ps
  • Opamp: LPF,AD712 -18dB
  • Buffer output: IC:ELANT EL2003
Specifications:
  • THD: 0.003%
  • Dynamic range: 106dB
  • S / N: 116dB
  • Separation:99dB
Easy installation:
Just connect the four pins directly:BCK, LRCK, GND, DATA of yoursource I2S (CD player or other) and everything is played
Power supply: 2x18V + 9V AC(suitable transformer 5085)/ A>
Dimensions: H: 50 mm L: 137 mm L: 78 mm
https://www.audiophonics.fr/images2/5749/5749_LITE_DAC-AE_PCM670U.jpg
DATASHEET ANGLAISE
InputI2S
Channel2 (Stereo)
