Heat-shrink tubing 3: 1 Ø39.0mm Red (1.22m)
Heatshrink tube 3: 1 Ø39.0mm Length 1.22m (Red)
4.5 / 5
Reference : 3712
5,50 €tax incl.
4,58 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
Thermo-retractable sheath with a ratio of 3: 1, internally equipped with an adhesive layer ensuring better support on any type of surface (plastic, rubber, metal ...)
Thickness of intermediate size studied to provide excellent protection to mechanical strength, while maintaining a high degree of flexibility.
Adapts to irregular shapes and provides a high degree of insulation and waterproofing. Product is halogen-free, flame retardant, and RoHS certified.
A ratio of 3: 1 means that the diameter of the sheath once heated will be divided by 3: for example for a 12mm sheath, after being heated its diameter will be 4mm.
Diameter: 39.0mm => about 13mm after retraction
https://www.audiophonics.fr/images2/GAINES-THERMO_1.jpg
Specifications:
  • Retractable Ratio: 3: 1
  • Longitudinal Retracting Ratio: ± 8%
  • Shrink Temperature: 70 - 120 ° C
  • Melting Temperature of Internal Adhesive Layer: 70 - 90 ° C
  • Sheath Thickness Retractable : +/- 0.85mm
  • Sheath Thickness After Shrinkage : +/- 2.40mm
  • Temperature Resistance: -45 to + 125 ° C
  • Rigidity Dielectric: ≥15 Kv / mm (IEC243)
  • Certifications: RoHS
  • Diameter: 39.0mm
  • Length: 1.22m
  • Color Red
ColorRed
MaterialN/A
Length (m)Sold by length
Max cable diameter (mm)39.0
2 reviews
insatisfaction totale
Bonjour je viens d'ouvrir ce matin le colis car absent ! Enorme déception ce n'est absolument pas le bon produit , autre aussi d'ailleurs !
Pour le rouge le diamètre est de 4 mm et pour le noir je dirai 8 cm !
Comment peut on se tromper à ce point ?
Je vous renvoie bien évidemment les 2 produits !
A votre écoute
Cordialement
This review has been posted for Heat-shrink tubing 3: 1 Ø39.0mm Red (1.22m)
moyen !
plus rose que rouge helas , je voulais l'assortir a une elecaudio couleur wine ,mais ça ne correspond pas du tout !! et dans mon cas bcp trop large pour un cable secteur de 16.5 mm de diametre ; une erreur de jugement de ma part ! !
