AUDIOPHONICS PSU-HC Linear Regulated Power Supply RaspTouch 7V 5A 60VA
AUDIOPHONICS Linear Regulated Power Supply Rasptouch ES9023 7V 4A 60VA
By buying this product you get 26 loyalty points
Reference : 11598
269,00 €tax incl.
224,17 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
Audiophonics PSU-HC
Cette linear regulated 7V 4A power supply with two Jack outputs : 1x 5.5/2.5mm and 1x 5.5/2.1mm, is dedicated for streamer audiophile touch Audiophonics Rasptouch.
It will bring back background noise, a lowering of the ripple harmful for the jitter on digital audio devices such as DAC or high fidelity streamers. the result is an improvement in the readability of the acute medium with a less digital sound, a contribution, a seating of the timbre, and better bass dynamics.
Thes components of this power supply are of first quality:
  • Metal Resistors
  • 10 capacitors filtering 4700µF
  • Voltage Regulator LT1083
  • EMI RFI Filter
Thus, this regulated linear power supply developed by our team comes to compete with more expensive solutions.
Equipped with a 100% Aluminum case, two DC 5.5 / 2.5 & 5.5 / 2.1 jacks, this power supply with an extremely stable 60VA transformer even under heavy load will allow you to get the best out of the connected audio components requesting from 7V up to 5A.
The female DC jack connectors of the PSU-HC require the use of cables with a long male DC jack connector (14.5mm).
Housing100% Brushed Aluminum sandblasted
Colorblack anodized
Input VoltageAC 220V
Voltage / output current7V DC / 5A continus (7,5A max, thermal limited)
Outputs2 outputs DC Jack (5.5 / 2.5mm and 5.5 / 2.1mm)
SocketIEC
Transformer80VA
Voltage RegulatorMIC29752WWT
Dimensions240x170x60mm
Weight2,4kg
InputIEC C14
OutputJack DC 5.5/2.1mm
OutputJack DC 5.5/2.5mm
Output voltage (V)7.0
Output current (A)4.0
Input voltage (V)230.0
Power SupplyLinear
3 reviews
Alimentation bien finie et apport immédiatement perceptible
J’utilise le Rasptouch édition Kali d’Audiophonics depuis janvier 2020 et ce produit fonctionne très très bien.
Je lorgnais sur cette alimentation depuis quelques temps, un peu septique cependant.
J’ai sauté le pas, après réflexion et en interrogeant l’équipe d’Audiophonics. Et là surprise, l’apport de cette alimentation est perceptible immédiatement : meilleure tenue des basses qui sont moins baveuses, et plus de micro détails.
Ce n’est pas la révolution tant le Rasptouch se débrouillait très bien sans, mais maintenant je ne me vois pas me passer de cette alimentation. Le plus apporté est indéniable et j’ai été scotché d’entendre la différence. Effectivement cette alimentation devrait être proposée en option à l’achat.
Encore une fois, Audiophonics propose un produit bien fini, avec des matériaux qui ont l’air solide.
Et les conseils éclairés de l’équipe qui a répondu à mes interrogations sans jamais pousser à la consommation.
Bref, un produit et une équipe 5 étoiles.
This review has been posted for AUDIOPHONICS PSU-HC Linear Regulated Power Supply RaspTouch 7V 5A 60VA
Indispensable
Peu de recul car je rédige cet avis après 2h d'écoute avec cette alimentation.
J'ai utilisé le Rasptouch pendant une dizaine de jours sans alimentation, et l'ajout de celle-ci apporte plus de clarté et de détails.
Je constate moins d'infra-basses, des voix un peu plus présentes et un rendu globalement plus juste.
A voir dans le temps mais je pense que c'est une acquisition indispensable sur la durée.
alim lineaire regulee
Quel dommage que audiophonics ne propose pas en option cette super alim qui fait vraiment merveille avec le Rasptouch.
