MiniDSP miniDC 12V Isolator Ignition Sequencer
MiniDSP miniDC 12 V isolator
Reference : 8445
26,90 €tax incl.
22,42 € tax excl.
Shipping from France
Billing in France
Technical support in France
The miniDC is a small card that allows a perfect integration of the system on / off your DSP system and amplifiers.
Based on a converter and a DC-DC isolated circuit, it allows to have an ignition sequence in the correct order.
This is especially recommended for audio applications to allow complete isolation of alternator noise.
It is compatible with all miniDSP products with the exception of 2x8 and 8x8 units.
Features:
  • Isolation 12V DC / DC compatible with miniDSP (balanced and unbalanced)
  • Input range: 10 - 18V
  • Insulation: 1500V
  • Short circuit protection
  • 12V output: time delayed
Download the MiniDC Insulation PDF Documentation
The diagram below shows the synchronization between Vin, Vout, REM In and REM Out.
When the input (REM) is in high mode (higher 5V), the device immediately isolates le 12V (no delay).
Remote output (REM OUT) is delayed for 3 seconds to allow the DSP to turn on before the amplifier.
When remote input (REM in) is low, the remote output immediately goes low to first turn off the amplifier.
The 12V isolated output is delayed to turn off the DSP last.
https://www.audiophonics.fr/images2/8445/8445_minidsp_minidc-isolator_1.jpg
InputScrew terminals
OutputScrew terminals
Output voltage (V)12.0
Output current (A)NC
Input voltage (V)18.0
Input voltage (V)11.0
Input voltage (V)13.0
Input voltage (V)15.0
Input voltage (V)17.0
Input voltage (V)10.0
Input voltage (V)12.0
Input voltage (V)14.0
Input voltage (V)16.0
Power SupplyNC
