IEAST SOUNDSTREAM PRO M30 Media Player UPNP USB DLNA AirPlay Wifi RJ45 Multiroom ES9023
iEast SoundStream Pro Wireless Receiver Multiroom DLNA UPnP AirPlay Sabre ES9023
3.8 / 5
Reference : 11064
139,00 €tax incl.
115,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
This compact WiFi audio streamer / receiver allows you to listen to music on your HiFi system directly from your Smartphone, tablet, computer, or other DLNA / AirPlay / UPnP compatible source.
The iEast receiver has WPS technology, allowing you to connect to the WiFi network in a simple, fast and secure way. The WPS button on the case allows you to access this option. You can also connect it via its RJ45 Ethernet port, free to choose according to your preferences.
With a 3.5mm Stereo Jack and a Toslink Optical Output, you can easily connect it to your HiFi or audio amplifier to listen to music up to 24 bit / 192kHz .
This product also allows playback of audio files via its USB-A input, up to 1TB.
Equipped with audiophile components such as an ESS ES9023 Sabre DAC , it will fit perfectly with your HiFi system.
iEast Récepteur audio sans-fil Multi-room WiFi DLNA UPnP AirPlay
The remote controlc allows you to select the song, manage the volume, and play or pause music when the receiver is in the file player (USB) mode. It also allows you to turn the iEast off and on, as well as select the previously configured quick access list (see operating instructions).
An iEast Play app is available on Android and iOS. It allows you to access music stored on your Smartphone, on your NAS (Synology, QNAP, etc.) ... in short, centralization of your music libraries on a single dedicated application and to easily manage the multiroom.
The iEast Audio / Streamer Receiver has been tested by Qobuz, you can read their test by following this link:
Qobuz IEAST
(Namely that Qobuz is natively supported by the iEast application, and is available in the settings on the iOS application)
You will find in the attached file below, a complete user manual of Streamer iEast.
The Streamer iEast is compatible with all these music services:
Ieast Services
Features:
  • UPNP DLNA server browser (From Ieast Application)
  • Airplay receiver (CD 16bit / 44 Khz)
  • UPNP DLNA receiver (High resolution 24bit / 192 Khz)
  • Playing audio files via USB (Files displayed into Ieast application)
Strong points :
  • Compatibility HighRes
  • Highly reliable Hifi SABRE ES9023 (with Time Domain Jitter Eliminator technologyand Hyperstream)
  • Manage a multi-room audio environment via the dedicated iEast Play application
  • Although it can be controlled via its dedicated application it does not require it to function
  • Firmware update online
  • Web Administration Interface
  • Simplified pairing to the home network with compatible boxes via WPS (Wifi Protected Setup)
  • Playing files up to 1TB on USB port
Specifications:
  • DAC SABRE ESS ES9023
  • Frequency WiFi: 2.4GHz (150Mbps max)
  • WiFi: IEE 802.11 b / g / n
  • Optical Output: Wolfson 8805
  • Sampling rate: Up to 24bit / 192kHz (DLNA / UPNP reception)
  • SPDIF: Toslink Optical Output (16bit / 44khz)
  • Dynamic range: 98dB
  • THD + N: -85dB
  • Signal Noise Ratio: 112dB
Connectors:
  • WiFi antenna included (screwable)
  • AUX input (3.5mm jack)
  • Input Micro-USB (DC 5V)
  • USB-A OTG port
  • Ethernet LAN RJ45 port
  • Optical Output: SPDIF Toslink
  • Line Out 3.5mm Stereo Jack
  • Infrared receiver for remote control
Packaging:
  • Brushed black aluminum housing
  • Housing dimensions: 85x85x25mm
  • Weight Case: 350g
  • Power adapter to Micro USB DC 5V / 1000mA
  • IR Remote Control
  • Cable Jack 3.5mm to Jack 3.5mm
  • 3.5mm Jack to RCA Stereo Cable
  • User Manual (In English)
iEast Stream Récepteur audio sans-fil Multi-room WiFi DLNA UPnP AirPlay
IEast smartphone use HD audio receiver in video:
iEAST Multi-room Wifi
- iEAST VS Bluetooth, and other technologies -
iEAST vs Bluetooth et autres technologies
InputJack 3.5mm
InputWiFi
InputRJ45
OutputJack 3.5mm
OutputOptical Toslink
DAC / ADC ChipES9023
Max sampling rate192kHz
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsWeb radios
17 reviews
Dommage
Celà fait plusieurs mois que j'ai acquis ce petit syteamer. Pour ce qui ai du streaming, pas de soucis, il fait bien le job et son appli smartphone est cool (Qobuz intégré). Par contre une petite faiblesse au niveau du dac et de sa partie sortie analogique. En tout cas sur une chaîne hifi correcte. La restitution est vraiment très moyenne. J'ai dû acheter un petit Dac externe et via les connexions optiques on arrive à qque chose d'acceptable. Mais encore et toujours, à ce prix, faut pas attendre des performances de fou !
This review has been posted for IEAST SOUNDSTREAM PRO M30 Media Player UPNP USB DLNA AirPlay Wifi RJ45 Multiroom ES9023
Lecteur réseau
Petit lecteur réseau particulièrement intéressant sur plusieurs points.
Tout d'abord il bénéficié d'une très bonne finition.
Ensuite, extrêmement simple à mettre en service (rj45 pour moi).
Branché en optique sur mon Dac.
L'application est relativement bien faite et Qobuz fonctionne en Gapless en natif. Par contre j'ai utilisé M connect sur IOS et là, pas de Gapless.
En tous cas un rapport qualité/prix quasi imbattable.
Volume de sortie stéréo trop faible
J'espère qu'il s'agit juste d'un problème de configuration mais j'ai une atténuation de 6dB de la sortie stéréo analogique en comparaison avec mon récepteur Bluetooth SMSL B1. La réponse du SAV de iEAST est que le signal de sortie est de 1V, comme la prise casque d'un iPhone, alors que si je me trompe, le standard de sortie de ligne audio est de 2V. Cela expliquerait les 6dB de différence mesurés sur mon ampli Yamaha. Il faut donc tourner le bouton de volume pour compenser, ce qui n'est vraiment pas très commode, outre la diminution du rapport signal bruit que cela entraîne. Je m'étonne que personne n'ai mentionné ce problème.
Parfait pour utilisation de base
Je l'utilise depuis plus d'un an dans les conditions suivantes:
- connection ethernet (jamais testé en wifi)
- sortie optique (vers DAC RME ADI)
- lecture de musique dématérialisé (Qobuz)
Ce streamer correspond PARFAITEMENT à mon attente (dans le cadre strict de mon utilisation précisée ci-dessus); l'interface Qobuz pourrait être améliorée, mais bon je ne suis pas très difficile pour ça. Par contre je suis intransigeant sur la qualité du son, et je cherchais un appareil le moins cher possible pour récupérer le flux numérique (le son est fait plus loin: DAC, ampli, enceintes); c'est chose faite !!
Quand on juge un streamer sur ces qualités audio, il ne faut jamais oublier qu'on juge en fait sa partie DAC/Preamp...
Complément avis du 14/01
Je précise à le suite de la réponse d'Audiophonics que la connectivité utilisée est un réseau filaire Gigabit.
Alors en effet votre problème est ailleurs.
Mais pas du coté du Streamer en lui même.
C'est un Best seller depuis plusieurs années qui utilise une technologie éprouvée (linkplay) et reprise depuis par des marques mass market. Ce problème est inconnu.
