Attention comme tout les petits forets ça casse facilement (surtout si on est pas bien dans l'axe)
Prévoir du stock
High Speed Steel (HSS) and Cobalt 5% ⌀2mm
This twist metal drill bit is made from a high speed steel alloy (HSS) and 5% Cobalt. This design ensures excellent wear resistance and protection against heat. Taking advantage of a double helix structure, the drill bit can be used longer than a conventional drill by promoting chip evacuation. It is suitable for drilling on alloyed or non-alloy steel, stainless steel, cast steel, cast iron or heat and acid resistant metals.The drill bit has a cylindrical shank of the same diameter and is suitable for screw drills or drill holders.
Drill type | Double twist metal drill |
Material | High Speed Steel (HSS) and Cobalt 5% alloy |
Diameter | 2mm |
Total length | 50.6mm |
Shank type | Cylindrical |
Quantity | 1 (Unit) |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
JULIEN B.
