DYNAVOX PKV-800 Portable Headphone Amplifier 900mW 16 Ohm
If you find that your smartphone or source device does not provide enough power, then the Dynavox PKV-800 is an excellent solution. This small amplifier at affordable price will allow you to get a considerable power boost with its power of 900mW under 16 Ohm. Can be used with the vast majority of headphones, from 8 to 250 Ohm, this amplifier is an ally of choice to accompany you during your travels.
Reference : 12979
39,90 €tax incl.
33,25 € tax excl.
Shipping from France
Billing in France
Technical support in France
Dynavox PKV-800
Portable headphone amplifier 900mW 16 Ohm
Dynavox PKV-800 Amplificateur Casque Mobile
If you find that your smartphone or source device does not provide enough power, then the Dynavox PKV-800 is an excellent solution. This small amplifier at affordable price will allow you to get a considerable power boost with its power of 900mW under 16 Ohm. Can be used with the vast majority of headphones, from 8 to 250 Ohm, this amplifier is an ally of choice to accompany you during your travels. It has a switch on the back to adapt to the impedance of the headphones. In addition, it ensures very good sound quality, ensuring low distortion and low noise level.
With a battery of 1000mAh charging in about 2-3 hours, the amplifier ensures an autonomy of 10h to follow you throughout your day. It also has a status LED around its volume potentiometer. This changes color to indicate the status of the unit:
  • Blue : Operating
  • Red : In charge
  • Green : Complete charge
  • Blinking blue : Low battery
The amplifier is housed in a rugged black aluminium housing that will perfectly protect the internal components on the move on a daily basis.
Qobuzissime
" Very positive result for this Dynavox PKV-800 mobile headset amplifier, equipped with an intelligent electronics allowing to have a rather high power using a standard headset, and offering in addition very good sound performances. "
Qobuz test Dynavox PKV-800
Amplifier typePortable headphone amplifier
Power900mW @ 16Ω
450mW @ 32Ω
65mW @ 250Ω
Max Distortion0.05% (1kHz, 100mW, 16Ω)
Frequency response10Hz - 100kHz
SNR> 100dB
Max input sensitivity2V
ConnectorsInput : 1x Jack 3.5mm
Output : 1x Jack 3.5mm
Charging : Micro USB
Battery1000mAh
Charging timeApprox 2-3 hours
Weight75g
Dimensions80 x 50 x 16mm
InputJack 3.5mm
OutputJack 3.5mm
4 reviews
Très bon
Mini ampli casque nomade ultra compact qui tient dans le creux de la main. Design simple et qui inspire confiance. Associé à un lecteur mp3 Sony NW-A45 Hi-RES et un casque Fostex T-50RP MK3, il tient parfaitement son rôle. Son limpide -rien à redire- et il permet d'étayer le volume avec un casque gourmand. L'autonomie de la batterie est également très, très bonne. Je recommande.
This review has been posted for DYNAVOX PKV-800 Portable Headphone Amplifier 900mW 16 Ohm
excellent
Livraison rapide et correctement emballée !
Amplificateur excellent !
God Headphone Amplifier
Work very well whit my Philips x2,
Fast delivery to Sweden to...
Objet de désir
Magnifique concentré de technologie, je l'ai offert a mon fils, mais je pense que je vais en prendre un pour moi aussi, la différence d'écoute avec et sans est tout simplement bluffante.
If you find that your smartphone or source device does not provide enough power, then the Dynavox PKV-800 is an excellent solution. This small...
