FURUTECH FT-212 (R) Banana Plug Rhodium Ø4.2mm (Set x4)
FURUTECH FT-212 (R) Bananes Rhodium Ø 4.2mm (x4)
By buying this product you get 57 loyalty points
Reference : 8139
199,00 €tax incl.
165,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
The FT-221 banana plugs have a conductor housed in a non-resonant resin body (POM) with a shell made of nylon and fiberglass, as well as piezoelectric (Furutech's damping material).
The pin locks have a new patented mechanism for secure and reliable adhesion..
Specifications :
  • Rhodium-plated pure copper contacts
  • Proprietary anti-magnetic treatment FURUTECH Alpha α
  • Insulation: POM resin
  • Ring: Stainless steel
  • Screw-in plugs
  • Maximum rope diameter: 4.2mm
  • Total Length: 56mm
  • Rod length: 13.8mm (with ring) / 15.5mm (without ring)
  • Sold by 4
https://www.audiophonics.fr/images2/8139/8139_furutech_FT-212R_1.jpg
Max cable diameter (mm)4.0
Mounting typeTo screw
ConnecticMale
ConnectorBanana
Excellent
Très belle qualité de fabrication.
Profonde modification du son. Comparé aux fiches bananes en or que j'ai remplacé : des basses plus précises et fortes, des aigues mieux définis, beaucoup de transparence et de détail. Effet "loudness" typique du Rhodium, faire attention si vos câbles ont de l'argent, ou si votre son est déjà un peu sec.
This review has been posted for FURUTECH FT-212 (R) Banana Plug Rhodium Ø4.2mm (Set x4)
