PANGEA XTREME Gold plated Tellurium copper banana plug Ø5mm (Unit)
PANGEA Gold plated Tellurium copper banana plug
This PANGEA Xtreme connector, made entirely from Tellurium copper, is ideal for making high-quality loudspeaker cables. It will be the ideal companion for custom-made Do IT Yourself OCC copper cables.
Key points:
  • 100% Tellurium copper connector body
  • Screw or solder
Reference : 12399
11,90 €tax incl.
9,92 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
PANGEA Xtreme Gold
Screw Gold Tellurium copper plated banana
Give to your speaker cables a new life with this high-quality Pangea Xtreme connector. Xtreme bananas are specially designed to be welded or screwed in the easiest way in the world. These 100% Tellurium copper connectors (98% IACS) ensure superior conductivity, thereby eliminating the linear resistance of competing brass and phosphorous bronze connectors.
The result is immediately obvious with firmer and low distorted bass, a lower-pitched high midrange that is less projected, less screaming and more precise.
Technical caracteristics
Spécification
TypeBanana for loudspeakers wit screws
Matérial100%  Tellurium Copper IACS 98% conductivity
PlatedGold  plated 24K
Dimensions Lenght 45mm x Diameter 9mm
Banana Length17.8mm
Internal capacity cableØ 5mm
ColorsCopper gold
Max cable diameter (mm)5.0
Mounting typeTo weld
Mounting typeTo screw
ConnecticMale
ConnectorBanana
Contacts Material (Connector)Tellurium Copper
13 reviews
Vraiment top ces fiches !
Destinées à un câble Mogami 3103, sans soudure, ces fiches sont d'une très grande qualité.
Je les préfère aux Viborg VB 401 qui offrent moins de contact dans les borniers d'un amplificateur.
Ces fiches ont une prise banane intérieure pleine qui renforce le cylindre quand on l'introduit dans le bornier.
Après l'avoir enfoncé jusqu'au 3/4, j'ai poussé fortement et une résistance se fait sentir jusqu'au fond, tout au fond du bornier.
On est sûr que le contact est maximal et ça ne bouge vraiment plus, le bornier est totalement rempli.
La qualité des vis est excellente, on peut bien serrer avec une clé 6 pans de 2mm (non fournie).
Le matériau est génial, aucune détérioration du signal contrairement à des bananes basiques.
Pour la finition j'ai mis une gaine thermo-rétractable.
La fiche accepte bien un câble jusqu'à 5mm2.
4 fiches livrées en vrac dans un sachet plastique, pour un cadeau prévoir une jolie boite.
Livraison éclair en 2 jours chrono, bravo à Audiophonics.
This review has been posted for PANGEA XTREME Gold plated Tellurium copper banana plug Ø5mm (Unit)
Très bon rapport qualité prix
Après rodage sonne vraiment bien
Par contre sur un système très transparent elles donnent la limite (ETI tellurium par exemple donne son musical transparent et précis )
 (3)
Excellent produit
Associée au cable hp Elecaudio 250 Cc, un son doux, neutre, avec un très beau médium, des aigus soyeux et une belle assise dans le grave. Des heures d écoute sans fatigue grâce à une belle spacialisation des différents plan sonores. à recommander sans hésitation !
Presque parfait !
Excellentes fiches bananes à visser ou à souder ! Pas de souci avec les vis qui mêmes serrées très fortement ne cassent pas… Les pas de vis sont également très résistants ! Si ces fiches bananes étaient livrées avec de la gaine thermo rétractable, cela serait parfait ! De plus, le contact entre fiche banane et embase est parfait et très bien étudié ! À recommander à 100% !
Excellente fiche banane
Ayant acheté ces très bonnes fiches bananes il y a quelque temps que j'utilisais en vissant mon câble hp de faible diamètre elles se sont révélées encore meilleures en soudant le câble ( échancrure prévue) .
Les timbres sont parfaits et beaucoup de raffinement dans les aigus.
A recommander sans aucune hésitation
 (3)
This PANGEA Xtreme connector, made entirely from Tellurium copper, is ideal for making high-quality loudspeaker cables. It will be the ideal...
