XDUOO XQ-50 PRO Bluetooth 5.0 Receiver aptX HD CSR8675 DAC ES9018K2M
XDUOO XQ-50 PRO Bluetooth 5.0 Receiver aptX CS8406 DAC ES9018K2M
xDuoo offers with its XQ-50 PRO a Bluetooth receiver with integrated DAC very practical, qualitative and affordable. It will allow you to stream your music directly from your smartphone, tablet or any other device with Bluetooth connectivity (transmitter). Its careful design allows it to offer a clean playback of your audio files.
Reference : 14517
75,00 €tax incl.
62,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
This product has been replaced by the new version, the XDUOO XQ-50 PRO2 Bluetooth Receiver 5.1 QCC5125.
xDuoo XQ-50 PRO
Bluetooth Receiver 5.0 aptX-HD CS8406 DAC ES9018K2M
xDuoo XQ-50 Récepteur Bluetooth 5.0 aptX CS8406 DAC ES9018K2M 16bit 44kHz/>xDuoo XQ-50 Récepteur Bluetooth 5.0 aptX CS8406 DAC ES9018K2M 16bit 44kH
XDUOO XQ50 version PRO is a CSR8675 Bluetooth receiver with integrated SABRE ES9018 DAC and CS8406 S/PDIF interface. This solution is ideal for using your purely analog devices (preamplifier / integrated amplifier / active speakers ) with your digital sources. The connection can be wired ( USB ) and wireless (Bluetooth 5.0). It also has a digital output for use with SPDIF devices that lack a wireless connectivity.
The PRO version now has an OLED screen to display the metadata of your digital tracks during playback. It reads in real time the active input, Bluetooth protocol, track number, track name and its bitrate / sampling rate.
Very practical, qualitative and affordable, this reveiver allows you to stream your music directly from your smartphone, tablet or any other device with Bluetooth connectivity (transmitter). Its careful design allows it to offer a clean playback of your audio files.
Bluetooth 5.0 & aptX HD
Le XQ-50 PRO uses a Qualcomm CSR8675 bluetooth chip. This is a major upgrade since the first version since the XQ50 PRO now supports SBC, AAC, apt-X, apt-X Low Latency, apt-X HD and LDAC. Those protocols ensure fast and stable data transmission and guarantees high quality Bluetooth audio playback. A Bluetooth antenna improves the maximum transmission distance.
DAC ES9018K2M
The receiver is also equipped with a DAC ESS SABRE ES9018K2M chip for digital-to-analog conversion. This excellent chip helps to provide the most accurate reproduction possible.
Interface SPDIF CS8406
The output panel has a RCA stereo analog connector, a digitial S/PDIF and a Toslink connector. The digital output stage uses a SPDIF CS8406 interface chip. The device can also function as a USB DAC by connecting it directly via its USB-C port to a computer.
Type Bluetooth Receiver
Bluetooth5.0
Bluetooth protocols supportSBC, AAC, apt-X, apt-X HD, apt-X Low Latency, LDAC
Bluetooth ChipCSR8675
Digital interfaceCS8406
DAC chipES9018K2M
Distance transmission10m
THD+NCoaxial, Optical : 0.00087%
RCA Stéréo : 0.07%
Output levelCoaxial, Optique : 0.5Vp-p
RCA Stéréo : 2.5V
Sampling rateJusqu'à 24bit 44kHz
Power supply5VDC 1A via USB-C (Adaptateur 5V USB-C available)
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipES9018K2M
5 reviews
bonne qualitée
je l'ai depuis peu, je trouve la qualité audio bonne , il se synchronise
bien ,la qualité de fabrication est bonne , l'affichage est un plus agréable , a ce prix c'est une bonne affaire.
This review has been posted for XDUOO XQ-50 PRO Bluetooth 5.0 Receiver aptX HD CSR8675 DAC ES9018K2M
Excellent
Vraiment top , se connecte au Bluetooh de mon Iphone instantannément , je peux envoyer sur l'ampli de ma chaine hifi le son de l'application Deezer qui est sur mon Iphone, distance de réception super suffisante et aucune coupure.
Belle finition de ce petit récepteur et la livraison ultra rapide et bien emballé.
Merci à Audiophonics !
bon produit, supporte les codecs annoncés
Utilisé purement en numérique, je n'ai pas testé le DAC. Fonctionne très bien en LDAC en conjonction avec un DAC externe, affiche le morceau joué comme indiqué.
Excellent
Très bon produit. Aptx hd parfaitement reconnu sous androïd.
Excellent son.
Je recommande.
XDUOO XQ-50 PRO
Très bon recepteur et supporte nativement le meilleur des codec sans fil : LDAC. Piloté depuis un Xiaomi, le son est très bon ! Il est couplé avec un TPA3255.
Un peu cheap de part le poids mais excellent rapport qualité / prix.
xDuoo offers with its XQ-50 PRO a Bluetooth receiver with integrated DAC very practical, qualitative and affordable. It will allow you to stream...
