ELECAUDIO CS-361B Power Cable OCC PTFE 3x2.5mm² Triple shielding Ø 17mm
ELECAUDIO CS-361B Power Cable OCC PTFE 3x2.5mm² Ø 17mm
4.8 / 5
Reference : 7527
22,90 €tax incl.
19,08 € tax excl.
Available
Shipping date: 21-06-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
The ELECAUDIO team has devised a mains cable capable of upsetting the established order as it implements materials and technologies usually reserved for products at much higher prices.
TheCS-361B is a mains cable developed according to a famous structure of Audiophile conductors namely the Litz wire, using strands of individually insulated copper wires it allows to control the skin effect of its structure.
Ainif the Phase and Neutral conductors of the CS-361B consist of 3 cores individually insulated with PTFE, these consisting of 6 strands of OFC copper surrounding an OCC core form a 2.5 mm² conductor overall.
These 3 conductors with a highly structured structure are encapsulated individually in PVC sheaths marked with a red / white / green color code. The bundles thus formed are themselves isolated from each other and kept in a distant order by means of a cotton lining which provides both suppleness and firmness to the assembly.
comesthen a first shield made from an aluminum strip, then a second one consisting of a braided copper braid preventing any EMI / RFI interference. Between these two lines of defense also comes a slip OFC copper drain wireant the cable from one end to the other to ensure linear earthing.
A thick silver-colored PVC protective sheath completes this work, and finishes making the CS-361B particularly resistant
Features:/ H2>
  • 3 OFC Copper Conductors / OCC of Each Section 2.5mm²
  • Triple Shielding and Protection: Aluminum Sheath, Copper Braid Sheath, Copper Drain OFC
  • PTFE insulation on main conductors
  • Exterior PVC Sheath of Forte Thickness Resistant to Wear and Shock
  • Cotton Trim
  • High-end Finish Color Silver Pearl
Specifications:
  • Diameter of Conductors + Single PVC Sheath: 5.50 mm
  • Total Cable Diameter: 17 mm
elecaudio cs361 b occ cable secteur
https://www.audiophonics.fr/images2/7527/7527_ELECAUDIO_CS361B_AUDIOPHILE_GRADE_POWER_CABLE_1.jpg
https://www.audiophonics.fr/images2/7527/7527_ELECAUDIO_CS361B_AUDIOPHILE_GRADE_POWER_CABLE_2.jpg
Example of embodiment:/ P>
https://www.audiophonics.fr/images2/7527/7527_ELECAUDIO_CS361B_AUDIOPHILE_GRADE_POWER_CABLE_4.jpg
Details of the structure:
https://www.audiophonics.fr/images2/7527/7527_ELECAUDIO_CS361B_AUDIOPHILE_GRADE_POWER_CABLE_3.jpg
Cable schematics
https://www.audiophonics.fr/images2/SCHEMA_PHASE.jpg
Diameter17.00
Numéro de Conducteur3
Matériaux IsolationPVC
BlindageOui
Section2.5
Colissimo - TNT - SoColissimo
4 reviews
basique, mais pas mal et pas trop cher!
en fait je le connais dejà, sur mon ampli de puissance: correct, un peu pataud en fait, mais une belle energie... Là je l'ai pris pour en recuperer les conducteurs et la tresse... Fabrication a partir de bons materiaux, mais geometrie du cable quand meme tres basique... Je mets quand meme 4 etoiles, car au niveau rapport performances prix, c'est tres bien!
This review has been posted for ELECAUDIO CS-361B Power Cable OCC PTFE 3x2.5mm² Triple shielding Ø 17mm
Bienvenu chez les fous
ça y est, je fais partie des fous qui ont changé leur câble secteur et trouvé que cela changeait beaucoup de choses à leur système.
Je n'y croyais absolument pas. Comment 1m de câble 220V peut changer quoi que ce soit au son de mon système. Après avoir trop lu que cela apportait, j'ai craqué... et force est de constater que c'est bluffant, c'est même déroutant. Les voix ont plus de détail et de corps, plus de présence, les cordes trouvent une texture que je n'avais jamais entendu sur mon système. En bas du spectre, c'est aussi mieux défini, plus nuancé sans perdre à la profondeur des basses.
D'un point de vue pratique, j'ai mesuré en le recevant ce que représentait un câble de 17mm de diamètre. C'est ENORME ! Prévoir un espace important derrière le meuble car ce câble ne pliera pas.
Je recommande l'expérience. J'ai choisi des connecteurs "basiques" pour baisser la note et je ne le regrette pas.
 (3)
Time to wonder what a power cable can do
For my new project "Nord Hypex NC500 monoblock"
www.iqspeakers.co.uk/hypex-amps
I need to build some new power cable, last weekend we was building 4 different type for verification and test. After testing all of them this one shines. All the other one was not close to this one. Reason is.
I get more dynamic sound a lot more "Crezy I think, before I play typical with -20 to -17dB. now I use -30 to -25dB.
More details in the sound image.
The sound is warm with a grate dark room that I newer have heard before.
And the reason is a power cable!
Are I'm Crazy??????
Un excellent câble secteur.
Associé au prise shucko et IEC de la même marque, ce câble secteur a bonifié "mon installation" Hifi sur beaucoup de paramètre tel que la qualité des timbres, l'assise, la précision du message et la scène sonore. Tout est plus clair plus précis plus détouré.. C'est étonnant!
La musique a même perdu cette acidité que certains morceaux faisaient ressortir auparavant.
Je suis absolument satisfait.
Ce n'est pas pour rien qu'Audiophonics intègre ce câble secteur son ensemble secteur haut de gamme MP6.
Je le recommande chaudement pour des installations ou on a l'impression qu'il manque ce petit quelque chose.
Mon installation composée d'Atoll In 200 / Hegel HD11 / Davis Cezanne s'est transfigurée.
 (3)
