MOGAMI 3104 OFC Copper Speaker Cable 4x4.0mm² Ø 14.5mm
MOGAMI 3104 - Câble HP Cuivre OFC 4x4.0 mm² Ø14.5mm
The Mogami 3104 cable has been designed to provide high audio performance. It integrates 4 OFC Copper conductors with a cross-section of 4mm² (12AWG) and has an efficient PVC insulation.
Reference : 5240
19,90 €tax incl.
16,58 € tax excl.
Available
Shipping date: 13-12-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Mogami 3104
MOGAMI 3104 Câble HP Cuivre OFC 4x4.0mm² Ø 14.5mm
The Mogami 3104 cable has been designed to provide high audio performance. It integrates 4 OFC Copper conductors with a cross-section of 4mm² (12AWG) and has an efficient PVC insulation. It therefore ensures excellent conductivity of the audio signal while considerably limiting interference and therefore parasitic noise. It thus ensures a precise and transparent signal reproduction. The PVC sheath also provides very good flexibility for easy assembly and installation.
The connection of the conductors in diagonal pairs considerably reduces the mutual inductance.
Product typeSpeaker cable
Conductors number4
Conductors materialOFC Copper
Conductors section4mm² (12AWG)
Cable diameter14.5mm
Insulation / sleeve materialPVC
DC Resistance(20°C)0.005 Ohm/m
Inductance (1kHz, 20°C)0.6µH/m
Voltage breakdownMust withstand at 500V DC / 15s
QuantitySold per meter
Diameter (mm)14.5
Number of conductors4
ShieldingNo
Section (mm²)4
Colissimo - TNT - SoColissimo
9 reviews
Formidable rapport qualité-prix
J'ai acheté du Mogami 3104 pour passer en bi-cablage. J'utilise le modèle 2 conducteurs de longue date. Comparé à plusieurs autres câbles de grandes marques je lui trouve un rapport qualité-prix imbattable. Il fait beaucoup mieux que des câbles de prix équivalent ou plus chers. Seuls des câbles beaucoup plus chers apportent une discrète amélioration, mais la différence de plusieurs centaines d'euros vaut-elle le coup?
This review has been posted for MOGAMI 3104 OFC Copper Speaker Cable 4x4.0mm² Ø 14.5mm
Dans ma configuration , tout simplement exceptionnel !
ce câble n est pas meilleur que les autres , mais après 20 ans de mariage de differents modèle de modulation et hp et a tout prix je viens enfin de trouver le Graal avec celui-ci . mais encore une fois c est une question d associations et de chance . curieusement je l ai testé avec le mogami 2549 en modulation , quelle déception !
Alors comme j'en ai plusieurs paires à la maison je les ai tous passer en revue et le meilleur a été et de loin une série professionnelle Monster câbles studio pro 2000 .
L'écoute est devenu somptueuse .
Je ne l'ai pas utilisé en bi cablage mais j'ai simplement doubler les fils pour passé en 2x8 mm , le défi a été de trouver des fiches bananes adapté à cette taille heureusement internet est là .
ce câble ne vous conviendra peu être pas , mais il a fait mon bonheur .
Super cable
BOnjour
Très bon rendu.
bien mieux que mes anciens cables YBA.
J'ai enfin redécouvert mes enceintes....
essai en mono cablage
J'ai essayé ce câble en doublant le conducteur de 4mm,et là ,je doit avoue ,r le résultat est aussi au rendez vous, l'écoute est très intimiste et plus chaleureuse (sur de la musique de chambre) qu'en bi câblage c' est une expérience à tenté pour ceux que cela intéresse
surprenant
L'ayant conseillé pour un ami et pour l'avoir testé sur son système les résultats ont été à la hauteur de toute attente. Fini les duretés sur le médium, une meilleure définition du message, plus de clarté ,une meilleure spatialisation de l'orchestre. Je l'ai donc commandé pour l'essayé et là même conclusion: douceur, qui ne veut pas dire mou ,mais au contraire naturel dans le sens des instruments, il y a chez ce câble le coté spectaculaire sans le coté démonstratif ,expressif sans être agressif ,détaillant le moindre détail sans fatigue auditive. Un seul bémol réside , lors du montage le code couleur est un peu délicat . système : ampli Jadis orchestra/enceinte Spendor S8e/Lecteurs microméga solo et Rega planet/ DAC audiolab.
The Mogami 3104 cable has been designed to provide high audio performance. It integrates 4 OFC Copper conductors with a cross-section of 4mm²...
