VIABLUE SC-2 Speaker Cable Silver / Copper 2x4mm² Ø10mm
VIABLUE SC-2 Câble HP Cuivre/Argent 2x4.0mm² Ø10.0mm
4.6 / 5
Reference : 118
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
Les câbles d'enceinte Viablue de la série SC-2 Silver possèdent 2 conducteurs d'une section de 4mm²
Ces conducteurs en cuivre OFC sont plaqués argent pour une moitié et pour l'autre moitié plaqués Étain pour favoriser les graves.
Les deux conducteurs de 4mm² du SC-2 se composent chacun de sept faisceaux torsadés rassemblant un total de 448 brins indépendants.
Des cordons de remplissage assure une flexibilité et résistance à l'élongation sans faille.
  • Diamètre externe : 10mm
  • Inductance : 0.49µH / M
  • Résistance : 4.5 ohm / km
  • Conducteurs 1 : Cuivre plaqué argent  225x 0.15mm = 4mm²
    Conducteurs 2 : Cuivre étamé             225x 0.15mm = 4mm²
ViaBlue SC-2 Silver Series Lautsprecherkabel
Diameter (mm)10.0
Length (m)Sold by length
Number of conductors2
Insulation materialNC
ShieldingNo
Section (mm²)4.00
Conductors material (Cable)Silver
Ground / ShieldingNo
18 reviews
Disappointed
I bought the viablue sc-2 speaker cable as un upgrade to my 30 years old Monitor Cobra Cable 4mm. After a few days I switched back to my old cables as I was not convinced the ViaBlue sound better. On switching back I found my old cables are are better in revealing details across the spectrum. I tested some more playing audio test tones from Qobuz. The ViaBlue were not able to reproduce the 30 Hz tone but my old cables were rock solid. Some critical music listning also revealed less spatial information with the ViaBlue.
The cable is sturdy yet flexible. No complaints in that region. Sound wise however they are a disappointment.
This review has been posted for VIABLUE SC-2 Speaker Cable Silver / Copper 2x4mm² Ø10mm
Perfecto ratio price quality
For me is the perfect ratio for soeaker cable
Use it with mcintosh amps
Bon rapport qualité prix
J'ai testé ce câble avec des enceintes Harbeth HL5 plus,
avec un autre cable "ZEF mini" qui semple plus clair, avec un bas médium
plus ferme. Son prix est plus élevé que le viablue SC-2 qui est moins couteux.
Parfait
Très bon produit en rapport qualité/prix. Permet de confectionner des alims d'enceintes avec un budget raisonnable. La section de 4 est largement suffisante. Je pense avoir un peu plus de grave...mais celà reste très subjectif. Utilisé avec Ampli tube Magnat RV2+JBL L100 Century.
Excellent cable...souple mais qui reste bien et en forme ( construction d'avec les deux tubes silicones) cuivre plaqué argent et plaqué étain..de l'aigu,de la basse et du médium.. Bon rendu sonore, facile a mettre en œuvre... Je n'en suis pris qu'un mettre pu une enceinte centrale de home cinéma, mais il y a une différence en mieux par rapport au 2,5 mm2 cuivre précédemment installé.. Plus de naturel a l'écoute
