RAMM AUDIO ELITE 8 RCA Cables OCC Copper Cryo Gold Plated 0.5m (Pair)
RAMM AUDIO ELITE8 RCA Cables OCC Copper Cryo Gold Plated 0.5m (Pair)
RAMM Audio Elite8 cables offer an exceptional design quality, using only high quality materials for a perfect transmission of the audio signal and a transparent, pure and musical sound reproduction. This cable uses high purity OCC copper conductors.
2.0 / 5
Reference : 15356
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
RAMM Audio Elite8
RAMM Audio Elite8 Câbles RCA Cuivre OCC Cryo Plaqué Or 0.5m (La paire)
RAMM Audio Elite8 cables offer an exceptional design quality, using only high quality materials for a perfect transmission of the audio signal and a transparent, pure and musical sound reproduction. This cable uses high purity OCC copper conductors, cryogenically treated for optimal performance. Its efficient Aluminium-Mylar and polypropylene shielding as well as the independent insulation of the three conductors allow it to efficiently reject interferences that could alter the quality of the signal.
Ramm Audio Elite 8 : Composition diagram
Ramm Audio cables comparison
Elite 8
Elite-XTRA
Elite 72 (E72)
Mozart2
Cable geometry
Air-Inside© geometry with multi-layer shielding for excellent transparency and resolution, with less distortion and noise
Conductors
Single-core OCC copper
Number of conductors
3 individually shielded conductors
2 individually shielded conductors
Conductor composition
3 wires of 0.65mm, 0.60mm and 0.55mm individually wrapped in silk thread
2 x 0.5mm PP-insulated wires
3 x 0.5mm bare wires
1 x 0.6mm bare wire
Drain wire
3 x 0.6mm OFC monocrystalline copper strands
3 x 0.5mm OFC monocrystalline copper strands
1 x 0.65mm OFC monocrystalline copper wire
Dielectric
Cotton filling
PP rods
Cotton filling
PP rods
Cotton filling
PP rods
Cotton filling
Conductors shielded by copper foil
Capacitance (pF/m)
140
203.51
203
155
Resistance (Ω/m)
0.024
0.03274
0.033
0.028
Inductance (µH/m)
1.4
1.31394
1.32
1.25
Characteristics
Natural, pure and transparent sound with smooth musicality and exceptional sound image. Quiet, excellent noise and interference rejection
Clean, natural signal transfer for dynamic performance with better-defined deep bass and smoother highs
Musical, transparent and smooth with excellent sound image
Sound image with highlighted voices. Natural sound with low distortion and noise
Connectors
Balanced connection, usually XLR
Single-ended connectors, usually RCA
Outer diameter
9.2mm
9.2mm
8.2mm
9mm
Product typeRCA Cables
Length0.5m
ConnectorsMales RCA
Conductors materialOCC Copper
Connectors contacts platingGold
DiameterØ9mm
ShieldingAluminium-Mylar
Polypropylene
ColorGold and black
Length (m)0.5
ShieldingYes
Section (mm²)N/A
ConnectorRCA
Heavy sound.
The elite 8 by Ramm audio sounds extremely heavy. If you are looking for a neutral, natural sound, this is not for you. If your system sounds extremely thin and bright this cable might be a miracle. It will add body and weight in all frequencies. The plugs are tricky. I think that yo have to unlock them first.
This review has been posted for RAMM AUDIO ELITE 8 RCA Cables OCC Copper Cryo Gold Plated 0.5m (Pair)
RAMM Audio Elite8 cables offer an exceptional design quality, using only high quality materials for a perfect transmission of the audio signal and...
