SHANLING TEMPO eC1B CD Player and file reader on USB key
Shanling Tempo EC 1 CD Player port USB 16bit 44.1Khz
4.0 / 5
Reference : 11007
219,00 €tax incl.
182,50 € tax excl.
Available
Shipping date: 24-09-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
The CD playerTempo EC1Bwith its decoding chip PCM1796is very musical with its two op amps interchangeable NE5532sureDIP support 8.
It is thus possible to change its sound signature by putting, for example,OPA 2604 BB(not supplied) for a warmer sound on compact disc.
Its mechanics Sanyo HD850 CDensures reliability and impeccable tracking.
Its USB port allows it also to read files dematerialized on USB key.
Specifications:
  • Stereo Line Out Level on RCA: 2V.
  • A USB port for playback Wav, MP3, WMA, AAC files.
  • A coaxial digital output 16bit 44.1khz 75Ohm SPDIF.
  • Frequency response: 20hz to 20khz.
  • Signal-to-Noise Ratio: 108dB.
  • Distortion: 0.001%.
  • Dynamic range: 96dB.
  • Power consumption: 20W.
Exits :
  • RCA stereo (2Vrms).
  • Coaxial RCA 75ohm.
Capacity of USB input from 8K to 48Khz:
Files of type:
  • WAV.
  • AAC: m4a, 3gp, mp4.
  • WMA: asf, wma, 16bit pcm.
  • MP3: mp3, mp2, mp1.
Dimensions:
  • 216 Wx 312 W x H 71mm. (60mm without the feet)
  • Weight 3kg.
  • Weight with packaging: 4.5kg.
Supplied with a remote control, an IEC mains cord of 1m50.
ComponentPCM1796
ColorNoir
Channel2 channels (Stéréo)
Colissimo - TNT - SoColissimo
8 reviews
Cd tempo
Appareil de bonne qualité,
Finition irreprochable, mecanisme du tiroir particulierement doux.
Seul petit reproche: la commande de volume est inoperante lorsque l'on y associe un convertisseur externe
This review has been posted for SHANLING TEMPO eC1B CD Player and file reader on USB key
Critique cd Tempo
Appareil plutot satisfaisant : en terme de qualité. commande d'ouverture de plateau particulierement douce, boitier de telecommande agreable
Seul petit reproche, la commande de volume est inoperante lorsque l'on branche un convertisseur!
Platine CD EC18
Très bonne musicalité. Toute ma musique classique est dématérialisée bien sur....Mais pour moi CD+Lecteur reste une valeur sécurisante.
Merci aux personnes d'Audiophonics pour leur réactivité.
Deux remarques: 1-Pas de traduction du mode d'emploi (pas de difficultés particulières mais ce n'est pas légal)
2-Verifier la compatibilité du cordon d'alimentation.
Bonjour,
Nous allons traduire la notice rapidement.
Celle-ci sera disponible en téléchargement sur la page produit.
Excellent produit
J'ai acheté 2 de ces transports. La première fois (voir le premier avis) il y a eu un problème et le SAV n'a pas réagit de façon cohérente. Le produit a été finalement remplacé et les deux produits en ma possession me donnent toute satisfaction. La qualité de fabrication est de très bonne facture et les résultats d'écoute n'ont rien à envier aux lecteurs nettement plus couteux. Personnellement je dispose d'un Cambridge et d'un Denon mais j'ai eu l'occasion de faire des comparaisons avec un Nad. Inutile d'investir dans des appareils haut de gamme. La seule vraie différence concerne l'interface homme/machine assez simpliste, il y a juste un afficheur qui indique la piste ou le numéro de fichier et le temps écoulé. Il s'agit d'un lecteur "linéaire" et on ne peut pas choisir les pistes ou faire du "Random". Ceci étant, il suffit de créer les fichiers audio dans un ordre établi sur CD ou de se connecter via la prise USB à un ordinateur et choisir le bon répertoire.
Probablement de qualité
Produit probablement de qualité, ne pas oublier l alimentation en prise Asiatique dont les adaptateurs sont difficiles à trouver...
Bonjour,
C'est une erreur de notre part.
Le produit aurait du vous être livré avec un câble Euro.
Contactez le SAV pour l'échange de ce câble.
