FURUTECH CF-7445(R) Jack 4.4mm Connector TRRRS Copper Rodium Plated ⌀6mm (Unit)
This CF-7445 (R) Jack 4.4mm balanced connector from Furutech benefits from a very nice carbon finish, with a rhodium-plated copper conductor, all Alpha treated.
Reference : 12594
75,00 €tax incl.
62,50 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
Furutech CF-7445(R) balanced TRRRS - CARBON
Balanced 4.4mm Jack Copper Rhodium plated ⌀6mm
Furutech CF-7445(R) Connecteur Jack 4.4mm
This Furutech CF-7445 (R) 4.4mm Jack connector from Furutech takes advantage of a very nice carbon finish and uses excellent materials, ideal for creating balanced balanced balanced cables of high quality. It should therefore be noted that the connector is designed from a single piece and benefits from Rhodium-plated copper alloy contacts treated with Alpha (cryogenisation) for perfect conductivity. The connector also benefits from PBT isolation to limit interference and a stainless steel structure.
Technical specifications
Jack format4,4mm / Balanced TRRRS
Contact materialAlpha-treated copper alloy
PlatingRhodium
Max. cable diameter acceptableØ 6mm
Type of connectionWelding
Weight9g
Body size11,2 x 30,8mm
Total length50,3mm
Max cable diameter (mm)6.0
Mounting typeTo weld
ConnecticMale
Contacts number5
This CF-7445 (R) Jack 4.4mm balanced connector from Furutech benefits from a very nice carbon finish, with a rhodium-plated copper conductor, all...
