Connecteurs de grande qualité, et en plus très esthétique. Je retire 1 étoile car pour 2 lots et quasi 68€ je ne m'attendais pas à les recevoir dans 1 petit colis et dans 2 pochettes plastiques en vrac.
These interchangeable ATOHM WT-STU connectors are the ideal complement to the ZEF MAX and ZEF SPEAKER cables.
This is a top-of-the-range connection set. The body is attached to the cable (max. 6mm² cross-section, i.e. Ø3mm diameter) by two pressure screws.
The "spade" and "banana" connectors are supplied with the body and are fitted to it by threading.
All conductive parts are made of OCC copper and receive genuine silver plating.
Sold in pairs comprising 2 bodies + 4 terminals (2 bananas + 2 forks).
Product type | Interchangeable conectors BFA banana/Spades |
Max. cable diameter | Ø3mm |
Conductor material | OCC Copper |
Contact plating | Silver |
Mounting type | To screw |
Identification ring |
Dimensions | With spades : 56 x Ø13mm With BFA banana : 58 x Ø13mm |
Package | Sold in pairs with two BFA banana connectors and two spade connectors |
Max cable diameter (mm) | 3.0 |
Connectic | Male |
Connector | Banana / Spade |
Connector | Spade |
Connector | Banana |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Silver |
Average votes 4.0 / 5 6 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
C b.
jean-louis C.
Abdelnasser H.
Alain P.
