UR23 Converter SPDIF Optical to USB
UR23 Converter Optical SPDIF to USB
The UR23 is a converter allowing to recover an optical SPDIF signal (on 3.5mm connector) to convert it and then output it to USB-A. It works in USB Audio Class 1, compatible with sampling rates up to PCM 24bit 96kHz and this without driver installation.
Reference : 15612
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
UR23
UR23 Convertisseur SPDIF Optique vers USB
The UR23 is a converter allowing to recover an optical SPDIF signal (on 3.5mm connector) to convert it and then output it to USB-A. It works in USB Audio Class 1, compatible with sampling rates up to PCM 24bit 96kHz and this without driver installation. It is thus compatible with Windows, Mac and Linux systems. The converter is supplied with a Toslink to 3.5mm optical cable and a Toslink to 3.5mm adapter.
Suitable for transferring DAT tapes, minidiscs or other digital sources to audio files on your computer. Please note that it cannot be connected directly to a USB device such as a DAC, it must be connected to a USB host such as a computer.
Product typeOptical SPDIF to USB converter
InputOptical SPDIF 3.5mm
OutputUSB-A
Supported sampling ratePCM up to 24bit 96kHz
Dimensions5.5 x 3.5 x 1.8cm
Weight30g
Package1x UR23 Converter
1x Optical SPDIF 3.5mm cable
1x Optical Toslink to 3.5mm adapter
InputOptical Mini-Toslink
OutputUSB
Max sampling rate96kHz
Interface chipNC
The UR23 is a converter allowing to recover an optical SPDIF signal (on 3.5mm connector) to convert it and then output it to USB-A. It works in USB...
