FURUTECH FI-15 PLUS (R) IEC C15 Connector Rhodium Plated Ø13mm
FURUTECH FI-15 Plus (R) Rhodium plated IEC Connector Ø 13mm
4.0 / 5
Reference : 4609
69,90 €tax incl.
58,25 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
High performance IEC female power plug, ideal for building a high-end Audiophile power cable. In addition to its Rhodium plated phosphor bronze contacts, the FI-15E also benefits from the proprietary Furutech Alpha α anti-magnetism treatment.
Its nylon and fiberglass composite body is extremely resistant to shocks, electric arcs and high temperatures. It also has the particularity of opening completely in 2 to facilitate access to the connectors, and therefore the installation.
The conductors are fixed by means of 3 screws (2 poles + ground) marked by color code whose firmness of maintenance limits any risk of tearing or accidental deterioration of the cable. Compatible with cables of large cross-section and up to 13mm diameter.
Characteristics:
  • Rhodium Plated Phosphor Bronze contacts
  • Furutech Alpha α anti-magnetism treatment
  • Nylon & fiberglass body
  • Mounting type: to screw
  • Max cable diameter: Ø13mm
  • Body length: 51mm
  • Dimensions: 72*32*31mm (L*l*h)
  • Rated voltage / current: 250V/10A - 125V 15A
https://www.audiophonics.fr/images2/4609_FURUTECH-FI-15_1.jpg
https://www.audiophonics.fr/images2/4609_FURUTECH-FI-15_4.jpg
https://www.audiophonics.fr/images2/4609_FURUTECH-FI-15_2.jpg
Max cable diameter (mm)13.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Rated current (A)15.0
Optez pour la version Gold, moins agressive sur les aiguës...
Avec Cable Yarbo 1100, j'ai dû aménager à coup de pince coupante de la place.
Sinon, c'est la connexion qu'il faut pour les TV.
This review has been posted for FURUTECH FI-15 PLUS (R) IEC C15 Connector Rhodium Plated Ø13mm
