OYAIDE C-004 Connector IEC Beryllium + Platinum / Palladium Ø17mm
OYAIDE C004 - Connecteur IEC Beryllium + Platine/Palladium Ø17mm
4.9 / 5
Reference : 5475
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
These 100% Japanese manufacturing connectors have been designed to provide a high quality and reliable standard for your audio connections.
Oyaide selects each material to achieve a homogeneous connector, reducing vibration and improving sound quality.
This series is one of the rare to use beryllium copper contacts, this material having the resistance of brass, with the conductivity of pure copper.
Ensuia rare metal base plating was selected, a first layer of 0.5μ Platinum and then 0.3μ Palladium
Features:/ Strong>
  • Contactscopper Beryllium
  • Platinum Platinum 0.5μ + Palladium 0.3μ (Nickel free)
  • Conductors up to 5.5mm²
  • 30% fiberglass filled body for increased rigidity
  • Stainless steel screws
  • Cable diameter: 6 to 17mm
  • Tension / Courant : 250V 10A CE
Technical Specifications:
  • Total diameter: 38mm
  • Overall Length: 70.75mm
Max cable diameter (mm)17.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Contacts Material (Connector)Beryllium Copper
Contacts Plating (Connector)Platinum
Contacts Plating (Connector)Palladium
Rated current (A)10.0
8 reviews
Excellent
Testé par hasard suite à la lecture d'un test sur un forum, je confirme les avis précédent : le son est plein et bien équilibré.
This review has been posted for OYAIDE C-004 Connector IEC Beryllium + Platinum / Palladium Ø17mm
Best I've heard
This is the highest-resolution IEC connector that I ever tried. Very open, very wide soundstage, fantastic detail retrivel and the quickest transients. If there are any shortcomings, it's that it can be quite unforgiving. If your system has lean and analytical character it's probably best to avoid it. But if your system sounds natural and full, this connector in a right place can give a nice boost of speed and resolution.
Bien pour le son
Rien à redire à propos du son, mais la limitation à des câbles de moins de 17mm me gêne beaucoup, comme Fabian, j'ai monté du Viborg (à mon avis c'est la meilleure conception toutes marques confondues) j'ai ainsi monté du 18mm.
Astuce pour propriétaire de iec ou schuko viborg serie bati en alu
Pour garder le batis alu de mes viborg cu rhodium. Par apport a celui ded oayde moins de place et moins protegé des iem. Garder l iec oyade et fixer la sur le bâti viborg. Cela permet une meilleur integration des gros câbles secteur de la meme marque. Le resultat et sympa. Solide et pratique. Garde toutes les qualités de la fiche.. ????
Sublime le son
Etant alimenté par cable oayde tunami monté cu pl rhodium. Je voulais changer les iec car les prises de mes appareils sont en cuivre pl or. Or et rhodium ne font pas d exelents partenaires. Et bien je suis heureux du resultat. Non seulement le son na pas changé musicalement. Mais a amelioré la dynamique la transparence et aussi la richesse des harmoniques. Le filé la fluidite rythmique sont parfaite. Apres deux semaine d utilisation, la prise sais ameliorée jours après jours. Le grave et puissant ferme et d une rapidité impressionnante. Les attaques du violon du cello et du piano sont fenomenale. Certains album de jazz de classique et meme d electro housse trance rock sont encore plus percutant. Et de l autre côte de la douceur et un naturel magnifique. Les voix sont encore plus incarnées et d une intelligibilité incroyable. Et en sachant que la chuko reste cuivre pl rhodium. J ai une barrette type furutech nfc rhodium le mariage de ses dezx prises et exelentisime. Monté sur mon dac audio gd r2r. Charnel emouvant et aussi percutant et puissant. L ouverturr aussi et exelente. Mes delta signature sont ainsi magnifiée et il en ressort un plaisir a l ecoute jouissive.
